REV.
B
C
D
E
DESCRIPTION
Engineering Update w/o Changes
Removed Optional Locator Pin, Generated
SLM-XXX-LP
Tolerance adjustment @ "SH"
Removed Material Code
DATE
APPROVED
03/01/04
11/11/04
M. C.
M. C.
12/06/04
05/21/16
M. C.
J. C.
H
0.100 [2.5mm]
0.15 [3.8mm]
SH
Ø.250 [Ø6.4mm]
REF.
Ø.230 [Ø5.8mm]
.025 [0.6mm]
Ø.045 [Ø1.1mm]
TYP.
Ø.290 [Ø7.4mm]
CATHODE I.D.
MARKING
PART NO.
SH ( Ref.)
H
PART NO.
SH ( Ref.)
H
PART NO.
SH ( Ref.)
H
PART NO.
SH ( Ref.)
H
SLM-140
.140 (3.6mm)
.285 (7.1mm)
SLM-280
.280 (7.1mm)
.425 (10.8mm)
SLM-420
.420 (10.7mm)
.565 (14.3mm)
SLM-670
.670 (17.0mm)
.815 (20.7mm)
SLM-150
.150 (3.8mm)
.295 (7.2mm)
SLM-290
.290 (7.4mm)
.435 (11.0mm)
SLM-430
.430 (10.9mm)
.575 (14.6mm)
SLM-690
.690 (17.5mm)
.835 (21.2mm)
SLM-160
.160 (4.1mm)
.305 (7.7mm)
SLM-300
.300 (7.6mm)
.445 (11.3mm)
SLM-440
.440 (11.2mm)
.585 (14.9mm)
SLM-710
.710 (18.0mm)
.855 (21.7mm)
SLM-170
.170 (4.3mm)
.315 (8.0mm)
SLM-310
.310 (7.9mm)
.455 (11.6mm)
SLM-450
.450 (11.4mm)
.595 (15.1mm)
SLM-730
.730 (18.5mm)
.875 (22.2mm)
SLM-180
.180 (4.6mm)
.325 (8.3mm)
SLM-320
.320 (8.1mm)
.465 (11.8mm)
SLM-470
.470 (11.9mm)
.615 (15.6mm)
SLM-750
.750 (19.1mm)
.895 (22.7mm)
SLM-190
.190 (4.8mm)
.335 (8.5mm)
SLM-330
.330 (8.4mm)
.475 (12.1mm)
SLM-490
.490 (12.4mm)
.635 (16.1mm)
SLM-770
.770 (19.6mm)
.915 (23.2mm)
SLM-200
.200 (5.1mm)
.345 (8.8mm)
SLM-340
.340 (8.6mm)
.485 (12.3mm)
SLM-510
.510 (13.0mm)
.655 (16.6mm)
SLM-790
.790 (20.1mm)
.935 (23.7mm)
SLM-210
.210 (5.3mm)
.355 (9.0mm)
SLM-350
.350 (8.9mm)
.495 (12.6mm)
SLM-530
.530 (13.5mm)
.675 (17.1mm)
SLM-810
.810 (20.6mm)
.955 (24.3mm)
SLM-220
.220 (5.6mm)
.365 (9.3mm)
SLM-360
.360 (9.1mm)
.505 (12.8mm)
SLM-550
.550 (13.8mm)
.695 (17.5mm)
SLM-830
.830 (21.1mm)
.975 (24.8mm)
SLM-230
.230 (5.8mm)
.375 (9.5mm)
SLM-370
.370 (9.4mm)
.515 (13.1mm)
SLM-570
.570 (14.5mm)
.715 (18.2mm)
SLM-850
.850 (21.6mm)
.995 (25.3mm)
SLM-240
.240 (6.1mm)
.385 (9.8mm)
SLM-380
.380 (9.7mm)
.525 (13.3mm)
SLM-590
.590 (15.0mm)
.735 (18.6mm)
SLM-870
.870 (22.1mm)
1.015 (25.8mm)
SLM-250
.250 (6.4mm)
.395 (10.0mm)
SLM-390
.390 (9.9mm)
.535 (13.6mm)
SLM-610
.610 (15.5mm)
.755 (19.2mm)
SLM-890
.890 (22.6mm)
1.035 (26.3mm)
SLM-260
.260 (6.6mm)
.405 (10.3mm)
SLM-400
.400 (10.2mm)
.545 (13.8mm)
SLM-630
.630 (16.0mm)
.775 (19.7mm)
SLM-270
.270 (6.9mm)
.415 (10.5mm)
SLM-410
.410 (10.4mm)
.555 (14.1mm)
SLM-650
.650 (16.5mm)
.795 (20.2mm)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 6/6, 94V-0, BLACK.
± .1
± .01
± .005
DESIGNED:
M. Chen
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
MOLDED, SELF-RETAINING LED MOUNT
DATE:
04/23/03
DATE:
04/23/03
PART NO:
REVISION:
SLM-XXX
CAGE CODE : 32559
E
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“SLM-140”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.314651+0.69089
- 10+3.6487610+0.47433
- 100+2.62755100+0.34158
- 500+2.16847500+0.28190
- 1000+2.017601000+0.26228
- 2000+1.889342000+0.24561
- 5000+1.748945000+0.22736
- 10000+1.6613310000+0.21597
- 25000+1.5657725000+0.20355
