IQS127D-00000-TSR
IQS127D-00000-TSR
    AZOTEQ
    1 CH. CAPACITIVE TOUCH SENSOR WI
IQS127D-00000-TSR 数据手册
IQS127D Datasheet IQ Switch® - ProxSense® Series Single Channel Capacitive Proximity/Touch Controller The IQS127D ProxSense® IC is a fully integrated capacitive sensor with dual outputs (Touch and Proximity outputs). Features Automatic Tuning Implementation (ATI) - Automatic adjustment for optimal performance. Internal Capacitor Implementation (ICI) – reference capacitor on-chip Supply voltage: 2.95V to 5.5V RoHS2 Minimum external components Compliant Data streaming option Advanced on-chip digital signal processing User selectable (OTP): 4 Power Modes (15uA min) IO sink / source Time-out for stuck key Output mode (Direct / Latch / Toggle) Proximity and Touch Button sensitivity 6 pin TSOT23-6 eq ot7D AIzQS12        Representations only, not actual markings Keys: Touch: Proximity: Dielectric: Material: Thickness: 5mm x 5mm or larger (overlay thickness dependent) Various electrical options (wire / PCB trace / ITO / conductive foil) Various non-metal materials (i.e. glass, plastic, painted surfaces) 6 mm plastic, 10 mm glass Applications       LCD, Plasma & LED TVs GSM cellular telephones – On ear detection / touch keys LED flashlights or headlamps White goods and appliances Office equipment, toys, sanitary ware Flame proof, hazardous environment Human Interface Devices       Proximity detection enables backlighting activation Wake-up from standby applications Replacement for electromechanical switches Find-In-The-Dark (FITD) applications Automotive: Door pocket lighting, electric window control GUI trigger on Proximity detected Available options TA -40°C to 85°C TSOT23-6 IQS127D IQ Switch® ProxSense® Series Contents IQS127D DATASHEET .................................................................................................................................................. 1 1 OVERVIEW ......................................................................................................................................................... 3 2 ANALOGUE FUNCTIONALITY............................................................................................................................... 3 3 PACKAGING AND PIN-OUT ................................................................................................................................. 4 4 USER CONFIGURABLE OPTIONS .......................................................................................................................... 5 5 MEASURING CAPACITANCE USING THE CHARGE TRANSFER METHOD ................................................................ 7 6 DESCRIPTIONS OF USER OPTIONS ...................................................................................................................... 7 7 1-WIRE DATA STREAMING MODE......................................................................................................................11 8 ANTENNA TUNING IMPLEMENTATION (ATI)......................................................................................................13 9 ELECTRICAL SPECIFICATIONS .............................................................................................................................15 10 DATASHEET AND PART-NUMBER INFORMATION ..............................................................................................21 Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 2 of 24 May 2019 IQ Switch® ProxSense® Series 1 Overview The IQS127D is a single channel capacitive proximity and touch device which employs an internal voltage regulator and reference capacitor (Cs). The IQS127D device has a dedicated pin for the connection of a sense antenna (Cx) and output pins for proximity events on POUT and touch events on TOUT. The output pins can be configured for various output methods including a serial data streaming option on TOUT. Device configuration is determined by one time programmable (OTP) options. The devices automatically track slow varying environmental changes via various filters, detect noise and has an automatic Antenna Tuning Implementation (ATI) to tune the device to the sense antenna. 1.1 Applicability All specifications, except where specifically mentioned otherwise, provided by this datasheet are applicable to the following ranges:   Temperature:-40C to +85C Supply voltage (VDDHI): 2.95V to 5V 2 Analogue Functionality The analogue circuitry measures the capacitance of a sense antenna attached to the Cx pin through a charge transfer process (refer to section 5) that is periodically initiated by the digital circuitry. The measuring process is referred to a conversion and consists of the discharging of reference capacitor and Cx, the charging of Cx and then a series of charge transfers from Cx to Cs until a trip voltage is reached. The number of charge transfers required to reach the trip voltage is referred to as the current sample (CS). Copyright © Azoteq (Pty) Ltd 2019 All rights reserved The capacitance measurement circuitry makes use of an internal Cs and voltage reference (VREF). The analogue circuitry further provides functionality for:  Power on reset (POR) detection.  Brown out detection (BOD).  Detection of a watch dog timer (WDT) expiry. IQS127D Datasheet Version 1.15 Page 3 of 24 May 2019 IQ Switch® ProxSense® Series 3 Packaging and Pin-out The IQS127D is available in a TSOT23-6 package. 3.1 Pin-out 1 VSS 2 POUT 3 Figure 3.1 Table 3.1 IQS127D TOUT 6 CX 5 VDDHI 4 VREG Pin-out of IQS127D package Pin-out description IQS127D Pin Name 1 2 3 4 5 6 Type TOUT VSS POUT VREG VDDHI CX Digital Out Ground Digital Out Analogue Output Supply Input Analogue I/O 3.1.2 Schematic Component DC Supply Input Sense Antenna CX Rcx C VDDHI VREG 1uF 470 Ω (typical) 1uF Proximity Output Pin POUT VSS CVREG RCX CVDDHI Value Touch Output Pin TOUT CVDDHI is optional for added IC stability Touch Output GND Reference Proximity Output Internal Regulator Pin Supply Voltage Input Sense Antenna 3.1.3 Typical values IQS127D VDDHI Function Keep track as short as possible CVREG GND A 100 pF capacitor can be placed in parallel with the existing capacitors between VDDHI and GND as well as between VREG and GND for added RF immunity GND Figure 3.2 Typical application schematic of IQS127D. Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 4 of 24 May 2019 IQ Switch® ProxSense® Series 4 User Configurable Options The IQS127D provides One Time Programmable (OTP) user options (each option can be modified only once). The device is fully functional in the default (unconfigured) state. OTP options are intended for specific applications. The configuration of the device can be done on packaged devices or in-circuit. In-circuit configuration may be limited by values of external components chosen. A number of standard device configurations are available (refer to Table 10.1). Azoteq can supply pre-configured devices for large quantities. 4.1 Configuring of Devices Azoteq offers a Configuration Tool (CTxxx) and accompanying software (USBProg.exe) that can be used to program the OTP user options for prototyping purposes. More details regarding the configuration of the device with the USBProg program is explained by application note: “AZD007 – USBProg Overview” which can be found on the Azoteq website. Alternate programming solutions of the IQS127D also exist. For further enquiries regarding this matter please contact Azoteq at ProxSenseSupport@azoteq.com or the local distributor. TTHR1 TTHR0 Table 4-1: User Selectable Configuration Options: Bank 0 PTHR1 PTHR0 FUNC1 FUNC0 LOGIC ~ bit 7 bit 0 Bank 1: bit 0, Bank 0: bit 7-6 TTHR: Touch Thresholds -Section 6.4 000 = 1/16 001 = 1/32 010 = 2/16 011 = 3/16 100 = 4/16 101 = 6/16 110 = 8/16 111 = 10/16 Bank0: bit 5-4 PTHR: Proximity Thresholds 00 = 2 01 = 4 10 = 8 11 = 16 -Section 6.3 Bank0: bit 3-2 FUNC: OUTPUT Pins’ functions 00 = POUT active, TOUT active 01 = POUT latch, TOUT active 10 = POUT active, TOUT toggle 11 = POUT latch, TOUT toggle -Section 6.2 Bank0: bit 1 LOGIC: Output logic select 0 = Active Low 1 = Active High -Section 6.1 Bank0: bit 0 Not Used Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 5 of 24 May 2019 IQ Switch® ProxSense® Series STREAMING Table 4-2: User Selectable Configuration Options: Bank 1 SHORT tHALT1 tHALT0 PMODE1 PMODE0 STREAMING TTHR2 bit 7 bit 0 Bank 1: bit 7 STREAMING: 1-wire streaming mode 0 = disabled 1 = enabled Bank1: bit 6 Not used Bank1: bit 5 SHORT STREAMING: Short word streaming enable (Function enabled if this bit together with STREAMING bit is set) –Section 7 -Section 7 Bank1: bit 4-3 tHALT: Halt time of Long Term Average 00 = 18.6 seconds 01 = 74.5 seconds 10 = Never 11 = Always -Section 6.6 Bank1: bit 2-1 PMODE:Power Modes 00 = Boost Mode 01 = Normal Power Mode 10 = Low Power Mode 1 11 = Low Power Mode 2 -Section 6.5 Bank1: bit 0 TTHR: Touch Thresholds See Table 4-1 -Section 6.4 Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 6 of 24 May 2019 IQ Switch® ProxSense® Series 5 Measuring capacitance using the Charge Transfer method The charge transfer method of capacitive sensing is employed on the IQS127D. (The charge transfer principle is thoroughly described in the application note: “AZD004 Azoteq Capacitive Sensing”.) A charge cycle is used to take a measurement of the capacitance of the sense antenna (connected to Cx) relative to ground. It consists of a series of pulses charging Cx and discharging Cx to the reference capacitor, at the charge transfer frequency (FCX - refer to Section 9). The count of the pulses required to reach a trip voltage on the reference capacitor is referred to as a current sample (CS) which is the instantaneous capacitive measurement. The CS is used to determine if either a physical contact or proximity event occurred (refer to section 6.6.1), based on the change in CS detected. The typical values of CS, without a touch or proximity condition range between 650 and 1150, although higher and lower counts can be used based on the application requirements. With CS larger than +/-1150 the gain of the system may become too high causing unsteady current samples. The IQS127D schedules a charge cycle every tSAMPLE seconds to ensure regular samples for processing of results. The duration of the charge cycle is defined as tCHARGE. (refer toFigure 5.1) and varies according to the counts required to reach the trip voltage. Following the charge cycle other activities such as data streaming is completed (if in streaming mode), before the next charge cycle is initiated. Please note: Attaching a probe to the Cx pin will increase the capacitance of the sense plate and therefore CS. This may have an immediate influence on CS (decrease tCHARGE – thus CS) and cause a proximity or touch event. After tHALT seconds the system will adjust to accommodate for this change. If the total load on Cx, with the probe attached is still lower than the maximum Cx load the system will continue to function normally after tHALT seconds with the probe attached. t SAMPLE t CHARGE Cx pin 1 Figure 5.1 6 2 3 4 Charge cycles as can be seen on Cx. Descriptions of User Options This section describes the individual user programmable options of the IQS127D in more detail. User programmable options are programmed to One Time Programmable (OTP) fuse registers. Copyright © Azoteq (Pty) Ltd 2019 All rights reserved Note:    HIGH=Logical ‘1’ and LOW=Logical ‘0’. The following sections are explained with the OUT, POUT and TOUT taken as ‘Active LOW’. The default is always where bits are set to 0. IQS127D Datasheet Version 1.15 Page 7 of 24 May 2019 IQ Switch® ProxSense® Series Refer to section 9.3 for the sourcing and sinking capabilities of OUT, POUT and TOUT. These pins are sourced from VDDHI and will be turned HIGH (when active high) for a minimum time of tHIGH, and LOW for a minimum time of tLOW (when active low). 6.1 Logic select for output(s) The logic used by the device can be selected as active HIGH or active LOW. The output pins POUT, TOUT and OUT will function based on the selection. Configuration: Bank0 bit1 LOGIC: Output logic select Bit Selection 0 Active Low 1 Active High 6.2 Configuration: Bank0 bit2-3 FUNC1:FUNC0 OUTPUT Pins’ functions IQS127D Bit Selection 00 POUT active, TOUT active 01 POUT latch, TOUT active 10 POUT active, TOUT toggle 11 POUT latch, TOUT toggle 6.2.1 Output function: Active With a Proximity or Touch event, the output pin will change to LOW and stay LOW for as long as the event remains (see Figure 6.1). Also refer to the use of tHALT section 6.6.1 that may cause the termination of the event. Output pin function Various options for the function of the output pin(s) are available. These are selected as follow: User Actuation 1 0 Output Pin 1 0 Figure 6.1 Active Mode Output Configuration 6.2.2 Output function: Latch (for tLATCH) With a Proximity or Touch event, the output pin will latch LOW for tLATCH seconds. When the event remains active longer than tLATCH the output pin will remain LOW as long as the event remains active (see Figure 6.2). When the event terminates prior to tLATCH the output pin will remain LOW. User Actuation 1 0 Output Pin tLATCH tLATCH tLATCH + time that User Actuation stays active 1 0 Figure 6.2 Copyright © Azoteq (Pty) Ltd 2019 All rights reserved Latch Mode Output Configuration IQS127D Datasheet Version 1.15 Page 8 of 24 May 2019 IQ Switch® ProxSense® Series 6.2.3 Output function: Toggle The touch output pin will toggle with every Touch event occurring. Thus when an event occurs and the output is LOW the output will become HIGH and when the output is HIGH the output will become LOW (see Figure 6.3). User Actuation 1 0 Output Pin 1 0 Figure 6.3 6.3 Toggle Mode Output Configuration Proximity Threshold The IQS127D has 4 proximity threshold settings. The proximity threshold is selected by the designer to obtain the desired sensitivity and noise immunity. The proximity event is triggered based on the selected proximity threshold; the CS and the LTA (Long Term Average). The threshold is expressed in terms of counts; the same as CS (refer to Section 5). Configuration: Bank0 bit4-5 PTHR1:PTHR0 Proximity Thresholds Bit Selection 00 2 (Most sensitive) 01 4 10 8 11 16 (Least sensitive) A proximity event is identified when for at least 6 consecutive samples the following equation holds: at least 3 consecutive samples the following equation holds: TTH =< LTA-CS With lower average CS (therefore lower LTA) values the touch threshold will be lower and vice versa. Configuration: Bank0 bit6-7 and Bank1 bit0TTHR2:TTHR0: Touch Thresholds TTHR2:TTHR0 Proximity Thresholds Bit Selection 000 1/16 001 1/32 (Most sensitive) 010 2/16 011 3/16 100 4/16 101 6/16 110 8/16 111 10/16 (Least sensitive) PTHR =< LTA-CS Where LTA is the Long Term Average (refer to 6.6.1) 6.4 Touch Threshold The IQS127D has 8 touch threshold settings. The touch threshold is selected by the designer to obtain the desired touch sensitivity. The touch threshold is expressed as a fraction of the LTA as follows: TTHR = Selected Touch Threshold x LTA Where LTA is the Long Term Average (refer to 6.6.1) The touch event is triggered based on TTH, CS and LTA. A touch event is identified when for Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 9 of 24 May 2019 IQ Switch® ProxSense® Series PROXIMITY threshold measured as Current Sample value: Most A B D C Sensitive 2 4 8 Default Proximity threshold = 2 16 1/32 Figure 6.4 6.5 TOUCH threshold measured as Fraction of Current Sample: I F G H K J E The IQS127D IC has four power modes specifically designed to reduce current consumption for battery applications. The power modes are basically implemented around the occurrence of charge cycle every tSAMPLE seconds (refer to Section 5). The fewer charge transfer cycles that need to occur per second the lower the power consumption (but decreased response time). During Boost Power Mode (BP), charge cycles are initiated approximately every 9ms. Additional Power Modes are provided. While in any power mode the device will zoom to BP Charge Cycle Duration = tCHARGE tSAMPLE 10/16 whenever a current sample (CS) indicates a possible proximity or touch event. The device will remain in BP for tZOOM seconds and then return to the selected power mode. The Zoom function allows reliable detection of events with current samples being produced at the BP rate. Table 6-1: Power Mode configuration (Bank1 bit[3:2]) Bit Power Mode timing tSAMPLE (ms) 00 tBP (default) BP (9ms) 01 tNP 50 10 tLP1 100 11 tLP2 200 tSAMPLE LP Modes: Charge cycles Filters used by the IQS127D The IQS127D device employs various signal processing functions that includes the execution of various filters as described below. 6.6.1 Long Term Average (LTA) Capacitive touch devices detect changes in capacitance that are not always related to the intended proximity or touch of a human. This is a result of changes in the environment of the sense plate and other factors. These changes need to be compensated for in various manners in order to reliably detect touch events and especially to detect Copyright © Azoteq (Pty) Ltd 2019 All rights reserved 8/16 Zoom to Boost Mode after proximity detected Figure 6.5 6.6 2/16 3/16 4/16 6/16 Default Touch threshold = 1/16 Least Sensitive Proximity and Touch Thresholds. Power Modes CX 1/16 L proximity events. One mechanism the IQS127D employs is the use of a Long Term Averaging filter (IIR - Infinite Impulse Response - type filter) which tracks slow changes in the environment (expressed as changes in the current sample). The result of this filter is a Long Term Average (LTA) value that forms a dynamic reference used for various functions such as identification of proximity and touch events. The LTA is calculated from the current samples (CS). The filter only executes while no proximity or touch event is detected to ensure compensation only for environmental changes. However there may be instances where sudden changes in the environment or IQS127D Datasheet Version 1.15 Page 10 of 24 May 2019 IQ Switch® ProxSense® Series changes in the environment while a proximity or touch event has been detected cause the CS to drift away from the LTA. To compensate for these situations a Halt Timer (tHALT) has been defined. The Halt Timer is started when a proximity or touch event occurs and when it expires the LTA filter is recalibrated. Recalibration causes LTA < CS, thus the disappearance of proximity or touch events (refer to Section 6.3 and Section 6.4). The designer needs to select a Halt Timer value to best accommodate the required application. Configuration: Bank1 bit4-3 tHALT1:tHATL0: Halt time of Long Term Average Bit Selection 00 18.6 seconds 01 74.5 seconds 10 NEVER 11 ALWAYS Notes:   The “NEVER” option indicates that the execution of the filters will never be halted. With the ‘ALWAYS’ option and the detection of a proximity event the execution of the filter will be halted for only 18.6 seconds and with the detection of a touch event the execution of the filter will be halted as long as the touch condition applies. Refer to Application note “AZD024 - Graphical Representation of the IIR Filter” for detail regarding the execution of the LTA filter. 6.6.2 IIR Raw Data filter The extreme sensitivity of the IQS127D makes it susceptible to external noise sources. This causes a decreased signal to noise (S/N) ratio, which could potentially cause false event detections. Noise can also couple into the device as a result of poor PCB, sense antenna design and other factors influencing capacitive sensing devices. In order to compensate for noise the IQS127D uses an IIR filter on the raw data to minimize Copyright © Azoteq (Pty) Ltd 2019 All rights reserved result of noise in the current sample. This filter cannot be disabled. 7 1-Wire Mode Data Streaming The IQS127D has the capability to stream data to a MCU. This provides the designer with the capability to obtain the parameters within the device in order to aid design into applications. Data streaming may further be used by a MCU to control events or further process results obtained from the IQS127D devices. Data streaming is performed as a 1wire data protocol on one of the output pins (TOUT). The function of this pin is therefore lost when the device is put in streaming mode. Data Streaming can be enabled as indicated below: Configuration: Bank1 bit7 STREAMING: 1-wire data streaming mode Bit Selection 0 Disabled 1 Enabled The IQS127D has a short data streaming mode where a reduced set of data is streamed to the MCU. This option can be used only when data streaming has been activated. Configuration: Bank1 bit5 SHORT STREAMING: Short data streaming Bit Selection 0 Disabled 1 Enabled Data streaming is initiated by the IQS127D. When data streaming is enabled data is sent following each charge cycle (refer to Section 5). Figure 7.1 illustrates the communication protocol for initialising and sending data with the 1 wire communication protocol. 1. Communication is initiated by a START bit. Bit defined as a low condition for tSTART. 2. Following the START bit, is a synchronisation byte (TINIT = 0xAA). IQS127D Datasheet Version 1.15 Page 11 of 24 May 2019 IQ Switch® ProxSense® Series 4. Each byte sent will be preceded by a START bit and a STOP bit will follow every byte. 5. STOP bit indicated by taking pin 1 high. The STOP bit does not have a defined period. This byte is used by the MCU for clock synchronisation. 3. Following TINIT the data bytes will be sent. With short data streaming mode enabled, 5 bytes of data will be sent, otherwise 8 bytes will be sent after each charge cycle. TOUT /OUT D7 tINIT tDATA D6 D5 D4 D3 D2 D1 D0 tSTOP Stop – Start Start Stop – Start Figure 7.1 1-wire data streaming mode The following tables define the data streamed from the IQS127D devices during Short Data Streaming and Normal Data Streaming modes. Table 7.1 Byte Definitions for Short Data Streaming Mode Byte 0 1 2 3 4 Bit 7:0 15:8 23:16 31:24 39 35:32 Value Current sample High byte Current sample Low byte LTA High byte LTA Low byte Proximity event detected Touch event detected Not used (always 0) Zoom active Non-user data Table 7.2 Byte Definitions for Normal Data Streaming Mode Byte 0 1 2 3 4 5 6 7 Bit 7:0 15:8 23:16 31:24 39 38 37 36 35 34 33 32 47 46 45 44 43 42 41 40 55:48 63:56 Value CS High byte CS Low byte LTA High byte LTA Low byte ATI busy Compensation (P5) PTH0 – Proximity threshold PTH1 – Proximity threshold Not used (always 0) Zoom active Touch event detected Proximity event detected ATI Multiplier (I) ATI Multiplier (S) ATI Multiplier (S) Compensation (P4) Compensation (P3) Compensation (P2) Compensation (P1) Compensation (P0) Non-user data Counter Azoteq provides an application tool (GUI) that can be utilised to capture and visualise the data streamed from the IQS127D. Refer to the Azoteq website for more details. Normal 1-wire data streaming mode is used when all data is required from IC. Short 1-wire data streaming mode is used when only Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 12 of 24 May 2019 IQ Switch® ProxSense® Series instantaneous measurement and Prox/Touch events are needed. Sample code available: “AZD017 - IQS127D 1-Wire Protocol SAMPLE CODE” 8 Antenna Tuning Implementation (ATI) ATI is a sophisticated technology implemented in the latest generation ProxSense® devices that optimises the performance of the sensor in a wide range of applications and environmental conditions (refer to application note AZD0027 - Antenna Tuning Implementation). ATI makes adjustments through external reference capacitors (as required by most other solutions) to obtain optimum performance. ATI adjusts internal circuitry according to two parameters, the ATI multiplier and the ATI compensation. The ATI multiplier can be viewed as a course adjustment and the ATI compensation as a fine adjustment. The adjustment of the ATI parameters will result in variations in the current sample and sensitivity. Sensitivity can be observed as the change in current sample as the result of a fixed change in sensed capacitance. The ATI parameters have been chosen to provide significant overlap. It may therefore be possible to select various combinations of ATI multiplier and ATI compensation settings to obtain the same current sample. The sensitivity of the various options may however be different for the same current sample. While the automatic ATI algorithm is in progress this condition will be indicated in the streaming data, and proximity and touch events cannot be detected. The device will only briefly remain in this condition and it will be entered only when relatively large shifts in the current sample has been detected. The automatic ATI function aims to maintain a constant current sample, regardless of the capacitance of the sense antenna (within the maximum range of the device). The effects of auto-ATI on the application are the following:       8.1 Automatic ATI The IQS127D implements an automatic ATI algorithm. This algorithm automatically adjusts the ATI parameters to optimise the sensing antenna’s connection to the device. The device will execute the ATI algorithm whenever the device starts-up and when the current samples are not within a predetermined range. Copyright © Azoteq (Pty) Ltd 2019 All rights reserved Automatic adjustment of the device configuration and processing parameters for a wide range of PCB and application designs to maintain an optimal configuration for proximity and touch detection. Automatic tuning of the sense antenna at start-up to optimise the sensitivity of the application. Automatic re-tuning when the device detects changes in the sensing antenna’s capacitance to accommodate a large range of changes in the environment of the application that influences the sensing antenna. Re-tuning only occurs during device operation when a relatively large sensitivity reduction is detected. This is to ensure smooth operation of the device during operation. Re-tuning may temporarily influence the normal functioning of the device, but in most instances the effect will be hardly noticeable. Shortly after the completion of the re-tuning process the sensitivity of a proximity detection may be reduced slightly for a few seconds as internal filters stabilise. Automatic ATI can be implemented effectively due to:    Excellent system signal to noise ratio (SNR). Effective digital signal processing to remove AC and other noise. The very stable core of the devices. IQS127D Datasheet Version 1.15 Page 13 of 24 May 2019 IQ Switch® ProxSense® Series  The built in capability to accommodate a large range of sensing antenna capacitances. 8.2 Noise Immunity The IQS127D has advanced immunity to RF noise sources such as GSM cellular telephones, DECT, Bluetooth and WIFI devices. Design guidelines should however be followed to ensure the best noise immunity. The design of capacitive sensing applications can encompass a large range of situations but as a summary the following should be noted to improve a design:          A ground plane should be placed under the IC, except under the Cx line. All the tracks on the PCB must be kept as short as possible. The capacitor between VDDHI and VSS as well as between VREG and VSS, must be placed as close as possible to the IC. A 100 pF capacitor can be placed in parallel with the 1uF capacitor between VDDHI and VSS. Another 100 pF capacitor can be placed in parallel with the 1uF capacitor between VREG and VSS. When the device is too sensitive for a specific application a parasitic capacitor (max 5pF) can be added between the Cx line and ground. Proper sense antenna and button design principles must be followed. Unintentional coupling of sense antenna to ground and other circuitry must be limited by increasing the distance to these sources or making use of the driven shield. In some instances a ground plane some distance from the device and sense antenna may provide significant shielding from undesired interference. When the capacitance between the sense antenna and ground becomes too large the sensitivity of the device may be influenced. Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 14 of 24 May 2019 IQ Switch® ProxSense® Series 9 Electrical Specifications 9.1 Absolute Maximum Specifications Exceeding these maximum specifications may cause damage to the device. Operating temperature Supply Voltage (VDDHI – VSS) Maximum pin voltage (OUT, TOUT, POUT) Pin voltage (Cx) Minimum pin voltage (VDDHI, VREG, OUT, TOUT, POUT, Cx) Minimum power-on slope HBM ESD protection1 (VDDHI, VREG, VSS, TOUT/OUT, POUT/SHLD, Cx) 9.2 General Characteristics (Measured at 25°C) Table 9.1 IQS127D General Operating Conditions DESCRIPTION Supply voltage Internal regulator output Boost operating current Normal operating current Low power operating current Low power operating current Table 9.2 Conditions 2.95 ≤ VDDHI ≤ 5.0 2.95 ≤ VDDHI ≤ 5.0 2.95 ≤ VDDHI ≤ 5.0 2.95 ≤ VDDHI ≤ 5.0 2.95 ≤ VDDHI ≤ 5.0 PARAMETER VDDHI VREG IIQS127D BP IIQS127D NP IIQS127D LP1 IIQS127D LP2 MIN 2.95 2.35 TYP 2.50 60 23 17 13 MAX 5.50 2.65 77 29 22 17 UNIT V V μA μA μA μA Start-up and shut-down slope Characteristics DESCRIPTION POR BOD VDDHI safe reset 1 -40°C to 85°C 5.5V VDDHI + 0.5V 2.5V VSS - 0.5V 100V/s 2kV Conditions PARAMETER VDDHI Slope ≥ 100V/s POR VDDHI Slope ≥ 100V/s BOD DC-level (not transient RESET ensure slope dependent) MIN 1.45 1.30 0.6 MAX 1.70 1.40 UNIT V V V See Section 9.4.1 for further details Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 15 of 24 May 2019 IQ Switch® ProxSense® Series 9.3 Output Characteristics (Measured at 25°C) Table 9.3 TOUT Characteristics Symbol Description VOH Output High voltage Symbol Description VOL Output voltage Table 9.4 Low ISOURCE (mA) 1 1 1 ISINK (mA) 1 1 1 Conditions VDDHI = 5V VDDHI = 3.3V VDDHI = 2.5V Conditions VDDHI = 5V VDDHI = 3.3V VDDHI = 2.5V MIN MIN 0.30 0.20 0.20 TYP 4.5 2.97 2.25 TYP 0.50 0.33 0.25 MAX TYP 4.5 2.97 2.25 TYP 0.5 0.33 0.25 MAX UNIT V MAX UNIT V POUT Characteristics Symbol Description VOH Output High voltage Symbol Description VOL Output voltage Low Copyright © Azoteq (Pty) Ltd 2019 All rights reserved ISOURCE (mA) 5.0 2.5 2.5 ISINK (mA) 3.0 2.5 2.5 Conditions VDDHI = 5V VDDHI = 3.3V VDDHI = 2.5V Conditions VDDHI = 5V VDDHI = 3.3V VDDHI = 2.5V MIN MIN 0.1 0.1 0.1 IQS127D Datasheet Version 1.15 UNIT V MAX UNIT V Page 16 of 24 May 2019 IQ Switch® ProxSense® Series 9.4 Electromagnetic Compatibility 9.4.1 Electrostatic discharge (ESD) Table 9.5 ESD Characteristics Symbol Ratings Conditions VESD(HBM) Electrostatic discharge voltage (Human body model) VESD(CDM) Electrostatic discharge voltage (Charge device model) VESD(Product) Electrostatic discharge voltage (Product specification)1 VESD(Product) Electrostatic discharge voltage (Product specification)1 TA = +25°C, conforming to JESD22-A114 TA = +25°C, conforming to JESD22-C101-D TA = +25°C, conforming to IEC61000-4-2, Airdischarge on all pins TA = +25°C, conforming to IEC61000-4-2, Contact-discharge on all pins Level/ Class Maximum Value UNIT 2 2000 V IV 1000 V 4 ±8 kv 3 ±6 kv 9.4.2 Static Latch-Up (LU) Table 9.6 Static Latch-Up (LU) Class Symbol A LU Parameter Static latch-up class Conditions TA = +25°C, conforming to EIA/JESD 78 IC latch-up standard For further details on test results please request from Azoteq. Product specification is dependent on PCB layout. Test performed on standard AZP112A05 product PCB plugged into the AZP113A03 touchpad PCB, powered with a single 3.0V coin-cell. 1 Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 17 of 24 May 2019 IQ Switch® ProxSense® Series 9.5 Timing Characteristics Table 9.7 SYMBOL FOSC Table 9.8 SYMBOL tHIGH tLOW FCX tLATCH tCHARGE tSAMPLE tBP tBP tSTART tINIT tDATA tNP tLP1 tLP2 tZOOM 1 Main Oscillator NP mode1 DESCRIPTION IQS127D Main oscillator Conditions 2.95 ≤ VDDHI ≤ 5.0 MIN 0.9 TYP 1 MAX 1.1 UNIT MHz MAX UNIT General Timing Characteristics for 2.95V ≤ VDDHI ≤ 5.0V DESCRIPTION Output high minimum time Output low minimum time Charge transfer frequency OUT high time in latch mode (active high) Charge cycle duration Refer to section 5 Sampling period in BP Sampling period in BP Refer to section 7 Refer to section 7 Refer to section 7 Sampling period in NP Sampling period in LP1 Sampling period in LP2 Period in BP after possible event Conditions MIN TYP 9 ms 9 ms 125 kHz 4.6 sec CS = 900 7.2 tCHARGE - 2 ≤ tSAMPLE tCHARGE ≥ tSAMPLE 9 ms ms ms ms us us us ms ms ms 14.4 tCHARGE+2 17 136 136 50 100 200 4.6 18.8 s All timings are derived from the main oscillator. Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 18 of 24 May 2019 IQ Switch® ProxSense® Series Table 9.9 IQS127D Response Times Proximity Min Max 54 63 95 145 145 245 245 445 Touch Typical 250 120 Power Mode Boost Power Normal Power Low Power 1 Low Power 2 Power Mode All All 9.6 IC Batch # Unit ms ms ms ms Unit ms ms All All All All IC Batch # Up to 127DBD From 127DBx Packaging Information 9.6.1 TSOT23-6 C A B D E F J G I H Figure 9.1 Table 9.10 TSOT23-6 Packaging1 TSOT23-6 Dimensions A B C D E F G H I J Dimension Typical 2.80 mm 1.60 mm 2.90 mm 0.40 mm 0.95 mm 1.00mm 0.05 mm 0.40 mm 4 0.127 mm Tolerance Basic Basic Basic ±0.10mm Basic Max ±0.05mm ±0.10mm ±4° +0.07/-0.007 9.6.2 TSOT23-6 Tape Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 19 of 24 May 2019 IQ Switch® ProxSense® Series Figure 9.2 IQS127D Tape Specification 9.7 Package MSL Moisture Sensitivity Level (MSL) relates to the packaging and handling precautions for some semiconductors. The MSL is an electronic standard for the time period in which a moisture sensitive device can be exposed to ambient room conditions (approximately 30°C/60%RH). Increasingly, semiconductors have been manufactured in smaller sizes. Components such as thin fine-pitch devices and ball grid arrays could be damaged during SMT reflow when moisture trapped inside the component expands. The expansion of trapped moisture can result in internal separation (delamination) of the plastic from the die or lead-frame, wire bond damage, die damage, and internal cracks. Most of this damage is not visible on the component surface. In extreme cases, cracks will extend to the component surface. In the most severe cases, the component will bulge and pop. Table 9-1: MSL Package TSOT23-6 1 Level (duration) MSL 1 ( Unlimited at ≤30 °C/85% RH) Drawing not on Scale Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 20 of 24 May 2019 IQ Switch® ProxSense® Series 10 Datasheet and Part-number Information 10.1 Ordering Information Only full reels can be ordered and orders will be subject to a MOQ (Minimum Order Quantity) of a full reel. Contact the official distributor for sample quantities. A list of the distributors can be found under the “Distributors” section of www.azoteq.com. For large orders, Azoteq can provide pre-configured devices. The Part-number can be generated by using USBProg.exe or the Interactive Part Number generator on the website. IQS127y zzzzz pp b BULK PACAKAGING IC NAME CONFIGURATION PACKAGE TYPE IC NAME IQS127D = IQS127 with Dual outputs CONFIGURATION zzzzz = IC Configuration (hexadecimal) PACKAGE TYPE TS = TSOT23-6 BULK PACKAGING R = Reel (3000pcs/reel) – MOQ = 3000pcs 10.2 Standard Devices The default (unconfigured) device will be suitable for most applications. Some popular configurations are kept in stock and do not require further programming. (Ordering codes given for Device IDs: 03 0D / 03 0E or later (the Device ID will be read in USBProg)) Standard Devices1 IQS127D-00000TSR IQS127D-00002TSR IQS127D-00200TSR IQS127D-00008TSR 1 Function Default Active HIGH outputs Normal Power Mode Touch Output ac Toggle All configurations ‘default’ except those mentioned under Function Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 21 of 24 May 2019 IQ Switch® ProxSense® Series Table 10.1 Standard Devices Available 10.3 Device Packaging Convention 10.3.1 Top 127y xx IC NAME IC Name BATCH BATCH 127D XX 10.3.2 Bottom Some batches IQS127D will not have any bottom markings. These devices are configured after marking, and may have variations in configuration – please refer to the reel label. Other batches will display the configuration set on the chip on the bottom marking. zzzzz Configuration Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 22 of 24 May 2019 IQ Switch® ProxSense® Series 10.4 Datasheet Revision History Version 1.0 First official release Version 1.1 Add BOD and POR Correct formatting errors Correct minor errors Version 1.2 Edited version (Final Production release) Version 1.3 Updated current consumption Version 1.4 Corrected version number Fixed Section 10.3 Version 1.4 Fixed bookmarks and added patents on last page Version 1.6 Updated power mode descriptions and Section 4 Removed EMI test results Version 1.7 Updated Short and Long 1-Wire protocol data string (removed LTN) Removed the word ‘debug’ when describing the 1-wire data mode Added MSL data Version 1.8 Corrected Section 4.1 Version 1.9 Updated Package dimensions Updated ESD testing information Version 1.10 Fix broken references Version 1.11 Fixed Package Dimensions Added Tape Specification Version 1.12 Update package marking Update Contact Information Version 1.13 Remove IQS127S (IQS127S is EOL) Low voltage version no longer available – use IQS227AS instead. Version 1.14 Update Contact and Patent Information Version 1.15 Update VDDHI reset voltage condition Copyright © Azoteq (Pty) Ltd 2019 All rights reserved IQS127D Datasheet Version 1.15 Page 23 of 24 May 2019 IQ Switch® ProxSense® Series Azoteq USA Asia South Africa Physical Address 11940 Jollyville Suite 120-S Austin TX 78750 USA Room 501A, Block A, T-Share International Centre, Taoyuan Road, Nanshan District, Shenzhen, Guangdong, PRC 1 Bergsig Avenue Paarl 7646 South Africa Postal Address 11940 Jollyville Suite 120-S Austin TX 78750 USA Room 501A, Block A, T-Share International Centre, Taoyuan Road, Nanshan District, Shenzhen, Guangdong, PRC PO Box 3534 Paarl 7620 South Africa Tel +1 512 538 1995 +86 755 8303 5294 ext 808 +27 21 863 0033 Email info@azoteq.com info@azoteq.com info@azoteq.com Visit www.azoteq.com for a list of distributors and worldwide representation. Patents as listed on www.azoteq.com/patents-trademarks/ may relate to the device or usage of the device. Azoteq®, Crystal Driver , IQ Switch®, ProxSense®, ProxFusion®, LightSense™, SwipeSwitch™, and the logo are trademarks of Azoteq. The information in this Datasheet is believed to be accurate at the time of publication. Azoteq uses reasonable effort to maintain the information up-to-date and accurate, but does not warrant the accuracy, completeness or reliability of the information contained herein. All content and information are provided on an “as is” basis only, without any representations or warranties, express or implied, of any kind, including representations about the suitability of these products or informat ion for any purpose. Azoteq disclaims all warranties and conditions with regard to these products and information, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property rights. Azoteq assumes no liability for any damages or injury arising from any use of the information or the product o r caused by, without limitation, failure of performance, error, omission, interruption, defect, delay in operation or transmiss ion, even if Azoteq has been advised of the possibility of such damages. The applications mentioned herein are used solely for the purpose of illustration and Azoteq makes no warranty or representation that such applications will be suitable without further modification, nor recommends the use of its products for application that may present a risk to human life due to malfunction o r otherwise. Azoteq products are not authorized for use as critical components in life support devices or systems. No licenses to patents are granted, implicitly, express or implied, by estoppel or otherwise, under any intellectual property rights. In the event that any of the abovementioned limitations or exclusions does not apply , it is agreed that Azoteq’s total liability for all losses, damages and causes of action (in contract, tort (including without limitation, negligence) or otherwise) will not exceed the amount already paid by the customer for the products. Azoteq reserves the right to alter its products, to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and information, its products, programs and services at any time or to move or discontinue any contents, products, programs or services without pr ior notification. For the most up-to-date information and binding Terms and Conditions please refer to www.azoteq.com. Copyright © Azoteq (Pty) Ltd 2019. All Rights Reserved. info@azoteq.com IQS5xx-B000 Datasheet Revision 2.1 Page 1 of 1 March 2021
IQS127D-00000-TSR 价格&库存
很抱歉,暂时无法提供与“IQS127D-00000-TSR”相匹配的价格&库存,您可以联系我们找货
IQS127D-00000-TSR
  • 3000+2.305973000+0.29832
