IR601/2
IR601/2
    SGXSENSORTECH
    IR SENSOR HEAD FOR 0-5%CO2 - 1/2
IR601/2 数据手册
SGX Europe Sp. z o.o. Building 11 Ligocka St. 103, 40-568 Katowice, Poland T: +48 (0) 32 438 4778 E: sales.is@sgxsensortech.com www.sgxsensortech.com IR600 Datasheet Infrared Gas Sensor for Hazardous Areas (Fixed Systems) The IR600 Series gas sensors are designed to detect and monitor the presence of CO2, hydrocarbons and acetylene using the same non-dispersive infrared (NDIR) principle as used in the SGX Sensortech range of miniature infrared gas sensors. Dual detector channels are used with a reference for background compensation. A temperature sensor is mounted for temperature compensation. IR600 sensors are designed to be integrated with fixed gas detection systems. Their construction is a stainless steel flameproof enclosure with an integral stainless steel sinter for the safe entry of the gases being tested. Three types of mounting thread are available to allow easy fixing to the junction box of the fixed system. On the front face there is an external M46 thread for attaching optional accessories for use in different applications. The IR600 Series incorporates an inbuilt and sealed preamplifier/buffer and require connection to suitable transmitter systems for their power supply, operation and signal processing. The IR600 lead in/out terminates in an 8-pin connector. FEATURES • • • • • • • • • • • • • • • • • For detection of the following gases: o Carbon Dioxide (IR601), o Hydrocarbons (IR602, IR603) o Acetylene (IR604) Diffused gas sampling via sinter Low power Reference channel for self-compensation Special gold plated optical/gas cavity for stable signal levels Operational in varying temperature, pressure and humidity Fast response Rugged stainless steel construction No moving parts Resistance to corrosion Immunity from ‘poisoning’ Reliable fail-safe operation Low maintenance Sealed preamplifier/buffer electronics Accessories available for field applications ATEX certified CSA certified (Canada and US) OPERATING PRINCIPLE SGX Sensortech manufactures a range of Infrared (IR) Gas Sensors for a variety of gases and vapours in different applications. These are compact and robust gas diffusion type sensors based on an SGX Sensortech patented optical design. They run on low power and use well proven NonDispersive Infrared (NDIR) detection methods. The sensor operates using the natural ability of the target gases to absorb radiation in the infrared portion of the electromagnetic spectrum. Using an infrared source, detector and selective optical filters the SGX infrared sensors can be used to detect a range of target gases. More information on the NDIR sensors can be found in the SGX Sensortech Application Notes. TECHNICAL SPECIFICATION Mechanical Dimensions Body material Weight See Outline on Page 5 Stainless Steel 435g Environmental Ambient temperature range for operation (ATEX): for operation (CSA): storage: Operational pressure range Humidity range for operation and storage Gases Detected -20°C to +60°C -20°C to +65°C -20°C to +60°C 700kPa to 1300kPa 0 to 95% RH (Non-condensing) Carbon Dioxide, hydrocarbons Electrical DC supply to detectors Typical power Lamp Supply See Outline on Page 5 180mW / 5V +5V, 60mA (Recommended) (Square Wave at 4Hz, 50% duty cycle) ___________________________________________________________________________________________ Whilst SGX has taken care to ensure the accuracy of the information contained herein it accepts no responsibility for the consequences of any use thereof and also reserves the right to change the specification of goods without notice. SGX accepts no liability beyond the set out in its standard conditions of sale in respect of infringement of third party patents arising from the use of SGX products in accordance with information contained herein. In case of modification of the product, SGX disclaims all liability. SGX Europe sp .z o.o. Poland REGON: 362332227 DS-0239, Issue 1, 13-May-2016, Page 1 SGX Europe Sp. Z o.o. Building 11 Ligocka St. 103, 40-568 Katowice, Poland T: +48 (0) 32 438 4778 E: sales.is@sgxsensortech.com www.sgxsensortech.com PERFORMANCE For test purposes, all data taken using the following conditions: - SGX linearisation and temperature compensation algorithms; see Infrared Sensor Application Notes. - Lamp modulation 0.4 - 5.0 V, square wave, at 4 Hz and 50% duty cycle. - Ambient temperature (20°C) and pressure (103 kPa). - All gases diluted in dry nitrogen. Sensor type IR601 Gas IR602 Carbon Dioxide Sensing range IR603 Hydrocarbons IR604 Acetylene 0 - 100% LEL and 0 - 100% vol. 0 - 5.0%vol. (same sensor is suitable for both ranges) Maximum response time (T90)
IR601/2
物料型号:IR600系列,具体型号根据检测气体不同分为IR601(二氧化碳)、IR602(窄带烃类)、IR603(宽带烃类)、IR604(乙炔)。
器件简介:IR600系列气体传感器用于危险区域(固定系统)的气体检测和监测,采用非色散红外(NDIR)原理,具备双探测器通道和参考通道以进行背景补偿,还集成了温度传感器以进行温度补偿。
引脚分配:8针连接器,包括温度输出、活性探测器输出、0V参考、5V电源、2.5V参考、参考探测器输出、灯丝电源等。
参数特性:包括尺寸、重量、操作环境(温度、压力、湿度)、电气特性(电源、典型功率、灯丝供电)等。
功能详解:传感器利用目标气体在红外波段的自然吸收特性进行检测,通过红外光源、探测器和选择性光学滤波器来检测目标气体。SGX Sensortech的专利光学设计提供了紧凑且坚固的气体扩散型传感器。
应用信息:适用于固定气体检测系统中,可检测二氧化碳、烃类和乙炔。具有快速响应、坚固的不锈钢结构、无移动部件、抗腐蚀、免维护、ATEX和CSA认证等特点。
封装信息:传感器采用不锈钢防爆外壳,有三种安装螺纹可选,前面板有M46外螺纹用于安装可选配件。传感器内置密封的前置放大器/缓冲电子设备,需要连接到合适的发射器系统进行供电、操作和信号处理。
认证信息:ATEX和CSA认证,具体标准和产品标记详细列出。
安装说明:提供了针对危险区域安装的具体指导,包括设备分类、使用限制、接地要求、内部结构不可自行打开等。
配件信息:提供了流量帽、天气帽和快速校准罩等配件,以适应不同的应用需求。
IR601/2 价格&库存
很抱歉,暂时无法提供与“IR601/2”相匹配的价格&库存,您可以联系我们找货
