IQS624-300-DNR
IQS624-300-DNR
    AZOTEQ
    HALL ROTATION, INDUCTIVE AND CAP
IQS624-300-DNR 数据手册
Azoteq IQ Switch® ProxSense® Series IQS624 DATASHEET Combination sensor including: Hall-effect rotation sensing, along with dual-channel capacitive proximity/touch sensing, or single-channel inductive sensing. The IQS624 ProxFusion® IC is a multifunctional capacitive and Hall-effect sensor designed for applications where any or all the technologies may be required. The two Hall-effect sensors calculate the angle of a magnet rotating parallel with the sensor. The sensor is fully I 2C compatible and onchip calculations enable the IC to stream the current angle of the magnet without extra calculations. Features > Hall effect angle sensor: • On-chip Hall plates • 360° Absolute Output • 1° Resolution*, calculated on chip • Relative rotation angle. • Detect movement and the direction of movement. • Raw data: can be used to calculate degrees on external processor. • Wide operational range • No external components required > Partial auto calibration: • Continuous auto-calibration, compensation for wear or small displacements of the sensor or magnet. • Flexible gain control • Automatic Tuning Implementation (ATI) – Performance enhancement (10 bit). > Capacitive sensing • Full auto-tuning with adjustable sensitivity • 2pF to 200pF external capacitive load capability > Inductive sensing • Only external sense coil required (PCB trace) Multiple integrated UI DFN10 WLCSP-9 • Proximity / Touch Representations only, not actual markings • Proximity wake-up • Event mode • Wake Hall sensing on proximity Minimal external components Standard I2C interface Optional RDY indication for event mode operation Low power consumption: • 240uA (100Hz response, Hall), • 55uA (100Hz response, capacitive), • 65uA (20Hz response, Hall) • 15uA (20Hz response, capacitive) • 5uA (5Hz response, capacitive) Supply Voltage: 2.0V to 3.6V** > > > > > > *Optimal conditions **5V solution available on demand. Applications > > > Anemometer Dial or Selector knob Mouse wheel > > > TA -20°C to 85°C Measuring wheel Digital angle gauge Speedometer for bicycle Available Packages DFN(3x3)-10 IQS624-xzyy 1 WLCSP-9 IQS624-32yy 1 All versions Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 1 of 75 May 2022 IQ Switch® ProxSense® Series Azoteq Contents IQS624 DATASHEET ........................................................................................................................................ 1 1 INTRODUCTION ....................................................................................................................................... 5 1.1 1.2 1.3 1.4 1.5 2 CAPACITIVE SENSING ............................................................................................................................ 9 2.1 2.2 2.3 2.4 2.5 3 INTRODUCTION TO HALL-EFFECT SENSING ................................................................................... 14 CHANNEL SPECIFICATIONS .......................................................................................................... 14 HARDWARE CONFIGURATION....................................................................................................... 15 REGISTER CONFIGURATION......................................................................................................... 15 EXAMPLE CODE: ......................................................................................................................... 16 SENSOR DATA OUTPUT AND FLAGS .............................................................................................. 16 IQS624-32 INTERVAL UI ............................................................................................................ 17 IQS624-32 EXAMPLE................................................................................................................. 19 IQS624-32 WHEEL WAKE PRELOAD (0X7C) ............................................................................... 20 IQS624-32 EVENT MODE OPTIONS ............................................................................................ 20 DEVICE CLOCK, POWER MANAGEMENT AND MODE OPERATION ............................................... 22 5.1 5.2 6 INTRODUCTION TO INDUCTIVE SENSING........................................................................................ 12 CHANNEL SPECIFICATIONS .......................................................................................................... 12 HARDWARE CONFIGURATION....................................................................................................... 12 REGISTER CONFIGURATION......................................................................................................... 13 SENSOR DATA OUTPUT AND FLAGS .............................................................................................. 13 HALL-EFFECT SENSING ....................................................................................................................... 14 4.1 4.2 4.3 4.4 4.5 4.6 4.7 4.8 4.9 4.10 5 INTRODUCTION ..............................................................................................................................9 CHANNEL SPECIFICATIONS .............................................................................................................9 HARDWARE CONFIGURATION....................................................................................................... 10 REGISTER CONFIGURATION......................................................................................................... 10 SENSOR DATA OUTPUT AND FLAGS .............................................................................................. 11 INDUCTIVE SENSING ............................................................................................................................ 12 3.1 3.2 3.3 3.4 3.5 4 PROXFUSION® .............................................................................................................................5 PACKAGING AND PIN-OUT .............................................................................................................5 REFERENCE SCHEMATIC ................................................................................................................7 SENSOR CHANNEL COMBINATIONS..................................................................................................7 PROXFUSION® SENSITIVITY ..........................................................................................................8 DEVICE MAIN OSCILLATOR........................................................................................................... 22 DEVICE MODES .......................................................................................................................... 22 REPORT RATES ..................................................................................................................................... 24 6.1 NORMAL POWER MAXIMUM REPORT RATE................................................................................... 24 7 SYSTEM RESET ..................................................................................................................................... 24 8 COMMUNICATION ................................................................................................................................. 25 8.1 8.2 8.3 8.4 8.5 8.6 8.7 8.8 CONTROL BYTE.......................................................................................................................... 25 I2C READ .................................................................................................................................. 25 I2C WRITE................................................................................................................................. 26 END OF COMMUNICATION SESSION / WINDOW ............................................................................. 26 STOP-BIT DISABLE OPTION(IQS624-32) ...................................................................................... 26 DEVICE ADDRESS AND SUB-ADDRESSES ...................................................................................... 27 ADDITIONAL OTP OPTIONS ......................................................................................................... 27 REQUEST COMMUNICATION WINDOW .......................................................................................... 28 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 2 of 75 May 2022 IQ Switch® ProxSense® Series 8.9 8.10 9 Azoteq I2C SPECIFIC COMMANDS ........................................................................................................... 28 RECOMMENDED COMMUNICATION AND RUNTIME FLOW DIAGRAM ................................................... 29 IQS624 MEMORY MAP .......................................................................................................................... 30 9.2 9.3 9.4 9.5 9.6 9.7 9.8 9.9 10 ELECTRICAL CHARACTERISTICS ...................................................................................................... 51 10.1 10.2 10.3 10.4 10.5 10.6 11 DFN10 PACKAGE AND FOOTPRINT SPECIFICATIONS ..................................................................... 56 WLCSP-9 PACKAGE AND FOOTPRINT SPECIFICATIONS ................................................................. 57 DEVICE MARKING AND ORDERING INFORMATION ........................................................................... 58 TAPE AND REEL SPECIFICATION ................................................................................................... 59 MSL LEVEL ............................................................................................................................... 60 DATASHEET REVISIONS ...................................................................................................................... 61 12.1 12.2 13 ABSOLUTE MAXIMUM SPECIFICATIONS ........................................................................................ 51 VOLTAGE REGULATION SPECIFICATIONS ...................................................................................... 51 RESET CONDITIONS ................................................................................................................... 51 DIGITAL INPUT/OUTPUT TRIGGER LEVELS ..................................................................................... 52 CURRENT CONSUMPTIONS .......................................................................................................... 53 START-UP TIMING SPECIFICATIONS .............................................................................................. 55 PACKAGE INFORMATION .................................................................................................................... 56 11.1 11.2 11.3 11.4 11.5 12 DEVICE INFORMATION ................................................................................................................ 32 DEVICE SPECIFIC DATA .............................................................................................................. 33 COUNT DATA ............................................................................................................................. 35 PROXFUSION SENSOR SETTINGS ................................................................................................. 36 TOUCH / PROXIMITY UI SETTINGS................................................................................................ 39 HALL SENSOR SETTINGS ........................................................................................................... 40 HALL WHEEL OUTPUT ................................................................................................................ 44 DEVICE AND POWER MODE SETTINGS ......................................................................................... 47 REVISION HISTORY ..................................................................................................................... 61 ERRATA ..................................................................................................................................... 62 APPENDICES ......................................................................................................................................... 64 13.1 13.2 13.3 APPENDIX A: MAGNET ORIENTATION ........................................................................................... 64 APPENDIX B: MAGNET CALIBRATION ............................................................................................ 67 APPENDIX C: HALL ATI .............................................................................................................. 73 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 3 of 75 May 2022 IQ Switch® ProxSense® Series Azoteq List of abbreviations PXS – ProxSense® ATI – Automatic Tuning Implementation LTA – Long term average Thr – Threshold UI – User interface AC – Alternating current DSP – Digital signal processing RX – Receiving electrode TX – Transmitting electrode CS – Sampling capacitor C – Capacitive NP – Normal power LP – Low power ULP – Ultra low power ACK – I2C Acknowledge condition NACK – I2C Not Acknowledge condition FG – Floating gate Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 4 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 1 1.1 Introduction ProxFusion® The ProxFusion® sensor series provide all the proven ProxSense® engine capabilities with additional sensors types. A combined sensor solution is available within a single platform. 1.2 Packaging and Pin-Out 1.2.1 DFN(3x3)-10 SDA VSS RDY NC VDDHI SCL IQS624 VREG RX1 LTX RX0 Figure 1.1 Pin out of IQS624 DFN (3X3)-10 package. Table 1.1 IQS624 Pin-out IQS624 Pin-out Pin 1 2 3 4 5 6 7 8 9 10 Name SDA RDY VDDHI VREG LTX CRX0 CRX1 SCL NC VSS Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. Type Function Digital Input / Output Digital Output Supply Input Regulator Output Analogue Analogue Analogue Digital Input / Output Not connect Supply Input 2 I C: SDA Output I2C: RDY Output Supply Voltage Input Internal Regulator Pin Transmit Electrode 1 Sense Electrode 0 Sense Electrode 1 I2C: SCL Output Not connect Ground Reference IQS624 Datasheet V2.07 Memory map Page 5 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 1.2.2 WLCSP-9 Pin 1 Marking Figure 1.2 1 2 3 A SCL GPIO3/ LTX GPIO0/ RDY B RX1 RX0 SDA C VSS VREG VDDHI IQS624 pin-out (WLCSP-9 package top view; markings may differ) Table 1.2 WLCSP-9 pin-out description IQS620A in WLCSP-9 Pin Name Type A1 B1 B2 B3 C1 SCL GPIO3 / LTX GPIO0 / RDY RX1 RX0 SDA VSS Digital input / output Digital output / Analogue transmitter electrode Digital output Open drain active low logic Analogue receiving electrode Analogue receiving electrode Digital input / output Supply input C2 VREG Voltage regulator output C3 VDDHI Supply input A2 A3 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. Function SCL (I2C Clock signal) Connect to inductive sensor’s transmitting coil RDY (I2C Ready interrupt signal) Sense Electrode 1 Sense Electrode 0 SDA (I2C Data signal) Common ground reference Regulates the system’s internal voltage Requires external capacitors to ground Supply Voltage Input IQS624 Datasheet V2.07 Memory map Page 6 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 1.3 Reference schematic Figure 1.3 Figure 1.4 1.4 IQS624 reference schematic IQS624 WLCSP-9 reference schematic Sensor channel combinations The table below summarizes the IQS624’s sensor and channel associations. Table 1.3 Sensor - channel allocation Sensor type CH0 CH1 Discreet Self Capacitive o o Hall effect rotary UI Mutual Inductive CH2 CH3 CH4 CH5 • 1 plate Positive • 1 plate Negative • 2 plate Positive • 2 plate Negative st o st nd nd o Key: o Optional implementation • Fixed use for UI Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 7 of 75 May 2022 IQ Switch® ProxSense® Series 1.5 Azoteq ProxFusion® Sensitivity The measurement circuitry uses a temperature stable internal sample capacitor (CS) and internal regulated voltage (VREG). Internal regulation provides for more accurate measurements over temperature variation. The size of the sample capacitor can be decreased to increase sensitivity on the capacitive channels of the IQS624. 𝑆𝑒𝑛𝑠𝑖𝑡𝑖𝑣𝑖𝑡𝑦 ∝ 1 𝐶𝑠 The Automatic Tuning Implementation (ATI) is a sophisticated technology implemented on the ProxFusion® series devices. It allows for optimal performance of the devices for a wide range of sense electrode capacitances, without modification or addition of external components. The ATI functionality ensures that sensor sensitivity is not affected by external influences such as temperate, parasitic capacitance and ground reference changes. The ATI process adjusts three values (Coarse multiplier, Fine multiplier, Compensation) using two parameters (ATI base and ATI target) as inputs. A 10-bit compensation value ensures that an accurate target is reached. The base value influences the overall sensitivity of the channel and establishes a base count from where the ATI algorithm starts adding compensation. A rough estimation of sensitivity can be calculated as: 𝑇𝑎𝑟𝑔𝑒𝑡 𝐵𝑎𝑠𝑒 As seen from this equation, the sensitivity can be increased by either increasing the Target value or decreasing the Base value. A lower base value will typically result in lower multipliers and more compensation would be required. It should, however, be noted that a higher sensitivity will yield a higher noise susceptibility. Refer to Appendix B and Appendix C for more information on Hall ATI. 𝑆𝑒𝑛𝑠𝑖𝑡𝑖𝑣𝑖𝑡𝑦 ∝ Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 8 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 2 Capacitive sensing 2.1 Introduction Building on the previous successes from the ProxSense® range of capacitive sensors, the same fundamental sensor engine has been implemented in the ProxFusion® series. 2.2 Channel specifications The IQS624 provides a maximum of 2 channels available to be configured for capacitive sensing. Each channel can be setup separately using the channel’s associated settings registers. Table 2.1 Capacitive sensing - channel allocation Sensor type CH0 CH1 Discreet Self Capacitive o o CH2 CH3 CH4 CH5 Key: Optional implementation o • Optional implementation Fixed use for UI Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 9 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 2.3 Hardware configuration In the table below are two options of configuring sensing (Rx) electrodes. Table 2.2 Capacitive hardware description Self-capacitive configuration 1 button IQS624 RX1 LTX RX0 2 buttons IQS624 RX1 LTX 2.4 RX0 Register configuration 2.4.1 Registers to configure for the capacitive sensing: Table 2.3 Capacitive sensing settings registers Address Name 0x40, 0x41 Ch0/Ch1 Settings 0 ProxFusion 0x42 Ch0&Ch1 Settings 1 ProxFusion 0x43, 0x44 Ch0/Ch1 Settings 2 ProxFusion 0x45 Ch0&Ch1 Settings 3 ProxFusion 0x50, 0x52 Proximity threshold 0x51, 0x53 Touch threshold Description Recommended setting Sensor mode should be set to Sensor mode and capacitive mode configuration of each An appropriate RX should be channel. chosen and no TX Global settings for the None ProxFusion sensors ATI target should be more ATI settings for than ATI base to achieve an ProxFusion sensors ATI Additional Global settings AC filter should be enabled for ProxFusion sensors Proximity Threshold for Preferably more than touch UI threshold Touch Threshold for UI None 2.4.2 Proximity Thresholds A proximity threshold for both channels can be selected for the application, to obtain the desired proximity trigger level. The proximity threshold is selectable between 1 (most sensitive) and 255 (least sensitive) counts. These threshold values (i.e. 1-255) are specified in Counts (CS) in the Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 10 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series Ch0 Proximity threshold (0x50) and Ch1 Proximity threshold (0x51) registers for the discreet button UI. 2.4.3 Touch Thresholds A touch threshold for each channel can be selected by the designer to obtain the desired touch sensitivity and is selectable between 1/256 (most sensitive) to 255/256 (least sensitive). The touch threshold is calculated as a fraction of the Long-Term Average (LTA) given by, 𝑇𝑇𝐻𝑅 = 𝑥⁄256 × 𝐿𝑇𝐴 With lower target values (therefore lower LTA’s) the touch threshold will be lower and vice versa. Individual touch thresholds can be set for each channel, by writing to the Ch0 Touch threshold (0x51) and Ch1 Touch threshold (0x53) for the discreet button UI. 2.4.4 Example code: Example code for an Arduino Uno can be downloaded at: www.azoteq.com//images/stories/software/IQS62x_Demo.zip 2.5 Sensor data output and flags The following register should be monitored by the master to detect capacitive sensor output. a) The Proximity/Touch UI Flags (0x12) provide more detail regarding the outputs. A proximity and touch output bit for each channel 0 and 1 is provided in the Proximity/Touch UI Flags register. Proximity/Touch UI Flags (0x12) Bit Number 7 6 5 4 Data Access Name Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. 3 2 1 0 Read Chan 1 Chan 0 Touch touch out out IQS624 Datasheet V2.07 Memory map Chan 1 Chan 0 proximity proximity out out Page 11 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 3 Inductive sensing 3.1 Introduction to inductive sensing The IQS624 provides inductive sensing capabilities to detect the presence of metal/metal-type objects. 3.2 Channel specifications The IQS624 requires 3 sensing lines for mutual inductive sensing. A single inductance user interface is available. a) Discreet proximity/touch UI (always enabled) Table 3.1 Mutual inductive sensor – channel allocation Mode CH0 CH1 Mutual inductive o o CH2 CH3 CH4 CH5 Key: o • - Optional implementation - Fixed use for UI 3.3 Hardware configuration Rudimentary hardware configurations (to be completed). Table 3.2 Mutual inductive hardware description Mutual inductive Mutual inductance VSS IQS624 RX1 LTX Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. RX0 IQS624 Datasheet V2.07 Memory map Page 12 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 3.4 Register configuration Table 3.3 Inductive sensing settings registers. Address 0x40, 0x41 0x42 0x43, 0x44 0x45 Name Description Ch0/Ch1 Settings 0 ProxFusion Ch0&Ch1 Settings 1 Ch0/Ch1 Settings 2 ProxFusion Ch0&Ch1 Settings 3 ProxFusion ProxFusion 0x50, 0x52 Proximity threshold 0x51, 0x53 Touch threshold Recommended setting Sensor mode should be set to Inductive mode Sensor mode and Choose one channel and configuration of each deactivate the other channel channel. Enable both RX for the activated channel Global settings for the CS divider should be enabled ProxFusion sensors ATI settings for ATI target should be more than ProxFusion sensors ATI base to achieve an ATI Additional Global settings for ProxFusion None sensors Proximity Threshold for Less than touch threshold UI Touch Threshold for UI None 3.4.2 Example code: Example code for an Arduino Uno can be downloaded at: www.azoteq.com//images/stories/software/IQS62x_Demo.zip 3.5 Sensor data output and flags The following register should be monitored by the master to detect capacitive sensor output. a) The Proximity/Touch UI Flags (0x12) provide more detail regarding the outputs. A proximity and touch output bit for each channel 0 and 1 is provided in the Proximity/Touch UI Flags register. Proximity/Touch UI Flags (0x12) Bit Number 7 6 5 4 Data Access Name Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. 3 2 1 0 Read Chan 1 Chan 0 Touch touch out out IQS624 Datasheet V2.07 Memory map Chan 1 Chan 0 proximity proximity out out Page 13 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 4 Hall-effect sensing 4.1 Introduction to Hall-effect sensing The IQS624 has two internal Hall-effect sensing plates (on die). No external sensing hardware is required for Hall-effect sensing. The Hall-effect sensor measures the generated voltage difference across the plate, which can be modelled as a Wheatstone bridge. The voltage difference is converted to a current using an operational amplifier in order to be measured by the same ProxSense® sensor engine. Advanced digital signal processing is performed to provide sensible output data. • • • Calculates absolute position in degrees. Auto calibration attempts to linearize degrees output on the fly Differential Hall-Effect sensing: o Removes common mode disturbances Refer to the Errata for correct setup of the IC. 4.2 Channel specifications Channels 2 to 5 are dedicated to Hall-effect sensing. Channel 2 & 4 performs the positive direction measurements while channel 3 & 5 handle all measurements in the negative direction. Differential data is obtained from these four channels. This differential data is used as input data to calculate the output angle of the Hall-effect rotation UI. Channel 2 & 3 is used for the one plate and channel 4 & 5 for the second plate. Table 4.1 Hall-effect sensor – channel allocation Mode > CH0 Hall rotary UI CH1 > CH2 • 1st plate Positive > CH3 CH4 • • 1st plate 2nd plate Negative > Positive > CH5 • 2nd plate Negative Key: o • - Optional implementation - Fixed use for UI Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 14 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 4.3 Hardware configuration Rudimentary hardware configurations. For more detail and alternative placement options, refer to Appendix A. Diametrically polarized magnet (rotational purposes) S Hall Rotation UI N IQS624 X-Y S 4.4 N Register configuration For more detail on the setup of the IQS624 refer to Appendix B. Table 4.2 Table 4-1 Hall sensing settings registers Address 0x70 0x71 Name Hall Rotation UI Settings Hall sensor settings 0x72,0x73 Hall ATI Settings1 0x78 Hall ratio Settings 0x79 0x7A Sin(phase) constant Cos(phase) constant Description Hall wheel UI settings Auto ATI and charge frequency settings Hall channels ATI settings Invert Direction setting for Hall UI Sin phase calibration value Cos phase calibration value 1 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. Recommended setting Hall UI should be enabled for degree output; enable Auto Calibration Auto ATI should be enabled for temperature drift compensation ATI Target should be more than base None Calculate this value using the GUI or the calculations in the Appendix A Calculate this value using the GUI or the calculations in the Appendix A Refer to the errata and Appendix B IQS624 Datasheet V2.07 Memory map Page 15 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 0x7B1 Wheel Filter Beta Degree filter value Adjust filter value based on the amount of noise on the degree value 0x7C1 Wheel Wake Preload Wheel wakeup settings Use default values 0x7D1 Interval UI Divider Depending on the application (should be equal or greater than 3) 0x7E1 Wheel Offset Divider for filtered degree values Wheel offset from zero position 4.5 Can be used for accurate intervals Example code: Example code for an Arduino Uno can be downloaded at: www.azoteq.com//images/stories/software/IQS62x_Demo.zip For ARM mbed resources refer to: https://os.mbed.com/components/IQS624/ 4.6 Sensor data output and flags a) The Hall UI Flags (0x14) register. Bit7 is dedicated to indicating a movement of the magnet. Bit6 indicates the direction of the movement. Bit 1 is set when the movement counts are negative and bit 0 is set when the relative angle is negative. Bit 6 can be used to determine the magnet direction. Please note that these bits will be set for small movements, therefore jitter may change the direction of movement bit. Hall UI Flags (0x14) Bit Number 7 6 5 4 Data Access Name 3 2 1 0 Read Wheel Movement movement direction b) The Filtered Degree Output (0x17-0x16) read from these registers. (0-359 degrees) 1 A 16-bit value for the filtered degrees can be Filtered Degree Output1 (0x17-0x16) Bit Number 15 14 13 12 11 10 Data Access Name 9 8 7 6 5 4 3 2 1 0 Read Degrees High Byte Degrees Low Byte Bit definitions: • 0-360: Filtered absolute degree position of magnet c) The Interval Number (0x18) 1 An 8-bit value for the current interval number can be read from this register. 1 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. Only Available on IQS624-32 IQS624 Datasheet V2.07 Memory map Page 16 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series Interval Number1 (0x18) Bit Number 7 6 5 4 3 2 Data Access Read/Write Name Current Interval Number • 1 0 Bit 7-0: Current interval number d) The Degree Output (0x81-0x80). A 16-bit value for the degrees can be read from these registers. (0-360 degrees) Degree Output (0x81-0x80) Bit Number 15 14 13 12 11 10 Data Access 9 8 7 6 5 4 3 2 1 0 Read/Write Name Degrees High Byte Degrees Low Byte e) The Relative Rotation Angle (0x8E). The delta in degrees from the previous cycle to the current cycle can be read from this register. (0-180 degrees) Relative Rotation Angle (0x8E) Bit Number 7 6 5 4 3 Data Access Read/Write Name Relative degrees 4.7 2 1 0 IQS624-32 Interval UI The IQS624-32 offers a new on-chip interval UI specifically designed for applications with discreet mechanical intervals or reduced resolution requirements. 4.7.1 Interval UI Features > > > > Adjustable interval size (3°-180°) The wheel can be zeroed at startup Adjustable wheel offset value An event is generated for changes to the Interval Number Register (0x18) Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 17 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 4.7.2 Interval UI Settings Registers Hall Rotation UI Settings (0x70) Bit Number 7 6 5 4 Data Access Name 3 2 1 0 Read/Write Hall Wheel UI disable UI Setting Interval UI disable1 Zero Wheel1 Hall Wheel Event disable1 Interval Event Disable1 Auto calibration - Wheel wakeup 0 0 1 0 1 - 0 0 Bit definitions: • Bit 5: Zero Wheel angle1 o 1: Zero angle, automatically cleared by firmware Bit 3: Interval UI Event disable1 o 0: Event UI is enabled o 1: Event UI is disabled • Interval UI Divider1 (0x7D) Bit Number 7 6 5 4 3 2 Data Access Read/Write Name Interval size in degrees Default 3 1 0 Bit definitions: • Bit 7-0: Interval size in degrees (>= 3° and > The device wakes up from the low-power modes when there is a touch on Ch0. In normal power mode events are only generated when there is a touch on Ch0. Ready events will be continuously generated as long as there is a touch on Ch0. If Touch on Wheel is enabled Interval and Hall Wheel Events are ignored. 4.10.2 Interval Event (Bit3, 0x70) > > The device wakes up from low-power modes when the wheel increment or decrement the interval register. Ready events are generated in normal power mode when the interval changes. If Interval Events and Hall Wheel Events (below) are enabled the IC will respond to Hall Wheel Events. 4.10.3 Hall Wheel Event (Bit4, 0x70) > The device wakes up based on the conditions described in Section 4.7. The wheel will wake up if the counter value reaches the counter threshold value before the timer reaches 0. Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 20 of 75 May 2022 IQ Switch® ProxSense® Series > Azoteq Events are generated on the same condition when the device is in low power mode. If Hall Wheel Events and Interval Events are enabled the IC will respond to Hall Wheel Events. The device can also be set to Stream in Normal Power (Bit5, 0xD9). With this bit set the device will wake up from either of the selected modes above. Events will be generated based on the Normal Power Report Rate during Normal Power mode. The device will stop streaming when low-power mode is entered. Table 4.3 : Hall Rotation UI Settings Touch on Wheel Wakeup Interval Event Hall Wheel Event Hall Rotation UI Settings (0x70) 0x1D 0x14 0x0C If all these modes are disabled, there will be no events generated for wheel movements. Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 21 of 75 May 2022 IQ Switch® ProxSense® Series 5 5.1 Azoteq Device clock, power management and mode operation Device main oscillator The IQS624 has a 16MHz main oscillator (default enabled) to clock all system functionality. An option exists to reduce the main oscillator to 8MHz. This will result in charge transfers to be slower by half of the default implementations. To set this option: > > As a software setting – Set the General System Settings (0xD0): bit4 = 1, via an I2C command. As a permanent setting – Set the OTP option in FG Bank 0: bit2 = 1, using Azoteq USBProg program. The ProxFusion® channels charges at half of the main oscillator frequency. Therefore the frequency multiplier selected in Ch0&1 ProxFusion Settings 1 (0x42; bit 4-5) and Hall sensor settings (0x71; bit 4-5) is multiplied by half of the main oscillator frequency. 5.2 Device modes The IQS624 supports the following modes of operation; > > > > > Normal mode (Fixed report rate) Low Power mode (Reduced report rate, no UI execution) Ultra-Low Power mode (Only channel 0 is sensed for a prox) Halt Mode (Suspended/disabled) Note: Auto modes must be disabled to enter or exit halt mode. The device will automatically switch between the different operating modes by default. However, this Auto mode feature may be disabled by setting the Disable Auto Modes bit (Power Mode Settings 0xD2; bit 5) to confine device operation to a specific power mode. The Power Mode bits (Power Mode Settings 0xD2; bit 3-4) can then be used to specify the desired mode of operation. 5.2.1 Normal mode Normal mode is the fully active sensing mode to function at a fixed report rate specified in the Normal Mode report rate (0xD3) register. This 8-bit value is adjustable from 0ms – 255ms in intervals of 1ms. 5.2.2 Low power mode Low power mode is a reduced sensing mode where all channels are sensed but no UI code are executed. The sample rate can be specified in the Low Power Mode report rate (0xD4) register. The 8-bit value is adjustable from 0ms – 255ms in intervals of 1ms. Reduced report rates also reduce the current consumed by the sensor. 5.2.3 Ultra-low power mode Ultra-low power mode is a reduced sensing mode where only channel 0 is sensed and no other channels or UI code are executed. Set the Enable ULP Mode bit (Power Mode Settings 0xD2; bit 6) to enable use of the ultra-low power mode. The sample rate can be specified in the Low Power Mode report rate (0xD5) register. The 8-bit value is adjustable from 0ms – 4sec in intervals of 16ms. When in Ultra-low power mode the IQS624 can be configured to update all channels at a specific rate defined in Power Mode Settings (0xD2) register. A flag will be set in the System flags (0x10; bit 0) register when a normal power update is performed. Wake up will occur on proximity detection on channel 0. Ultra-low power mode will not function properly if channel 0 is not enabled. Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 22 of 75 May 2022 IQ Switch® ProxSense® Series Azoteq 5.2.4 Halt mode Halt mode will suspend all sensing and will place the device in a dormant or sleep state. The device requires an I2C command from a master to explicitly change the power mode out of the halt state before any sensor functionality can continue. 5.2.5 Mode time The mode time is specified in the Auto Mode Timer (0xD6) register. The 8-bit value is adjustable from 0ms – 2 min in intervals of 500ms. 5.2.6 Streaming and event mode: Streaming mode is the default. Event mode is enabled by setting bit 5 in the General System Settings (0xD0) register. Streaming mode The ready is triggered every cycle and per the report rate. Event mode The ready is triggered only when an event has occurred. The events which trigger the ready can be configured to: > Hall wheel movement (If the hall UI is enabled) > Touch or proximity events on channel 0 or 1 > Interval Event1 Note: Both these events have built in hysteresis which filters out very slow changes. 1 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. Only available on IQS624-32 IQS624 Datasheet V2.07 Memory map Page 23 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 6 Report rates 6.1 Normal Power Maximum Report rate Note: Assuming normal mode report rate set to 0 (maximum speed) and Auto Power Modes turned off. Hall UI State Channels Register Address Bytes On 2 x Prox 4 x Hall 0x02 (PXS Flags) 0x80-0x81 (Degrees) 3 On 4 x Hall 0x80-0x81 (Degrees) 2 Off 2 x Prox 4 x Hall 0x02 (PXS Flags) 0x24-0x2B (Counts) 9 Off 4 x Hall 0x24-0x2B (Counts) 8 Off 1 x Hall 2 x Prox Off 1 x Hall 1 x Prox 0x24 (CH2 Counts) 0x02 (PXS Flags) 3 Off 1 x Hall 0x24 (CH2 Counts) 2 0x24 (CH2 Counts) 0x02 (PXS Flags) 3 Functionality1 On-chip calculation of rotation angle and prox channels. On-chip calculation of rotation angle. Off-chip calculation of rotation angle and on-chip prox channels. Off-chip calculation of rotation angle. Off-chip RPM-calculation and 2 Prox channels onchip Off-chip RPM-calculation and 1 Prox channels onchip Off-chip RPM-calculation Report Rate2 4.87 ms 3.29 ms 3.93 ms 2.94 ms 2.25 ms 1.63 ms 0.82 ms - Report rates are not necessarily an accurate indication of maximum observable rotation rate. On-chip calculations are only accurate at low rotation rates. (1) Contact Azoteq for further information on functionality. (2) These values were calculated by design and not by testing. 7 System reset The IQS624 device monitor’s system resets and events. a) Every device power-on and reset event will set the Show Reset bit in the System Flags (0x10; bit 7) register and the master should explicitly clear this bit by setting the Ack Reset bit in the General System Settings (0xD0; bit 6) register. b) The system events will also be indicated with the Event bit in the System Flags (0x10; bit 1) register if any system event occur such as a reset. This event will continuously trigger until the reset has been acknowledged. Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 24 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 8 Communication The IQS624 device interfaces to a master controller via a 3-wire (SDA, SCL and RDY) serial interface bus that is I2CTM compatible with a maximum communication speed of 400 kHz. The communications interface of the IQS624 supports the following: > > Streaming data as well as event mode. The master may address the device at any time. If the IQS624 is not in a communication window, the device returns an ACK after which clock stretching is induced until a communication window is entered. Additional communication checks are included in the main loop in order to reduce the average clock stretching time. The provided interrupt line (RDY) is push-pull active low on IQS624-3001 and open-drain active low on IQS624-32. The RDY indicates a communication window. > 8.1 Control Byte The Control byte indicates the 7-bit device address (44H default) and the Read/Write indicator bit. The structure of the control byte is shown in Figure 8.1. 7 bit address MSB 1 0 0 0 1 I2C Group Figure 8.1 0 0 R/W LSB Sub- addresses IQS624 Control Byte 2 The I C device has a 7 bit Slave Address (default 0x44H) in the control byte. To confirm the address, the software compares the received address with the device address. Sub-address values can be set by OTP programming options. 8.2 I2C Read To read from the device a current address read can be performed. This assumes that the addresscommand is already setup as desired. Current Address Read Start Control Byte S Data n Data n+1 ACK NACK ACK Figure 8.2 Stop S Current Address Read If the address-command must first be specified, then a random read must be performed. In this case a WRITE is initially performed to setup the address-command, and then a repeated start is used to initiate the READ section. Random Read Start Control Byte S Adr + WRITE Addresscommand ACK ACK Figure 8.3 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. Start Control Byte S Adr + READ Data n ACK Stop NACK S Random Read IQS624 Datasheet V2.07 Memory map Page 25 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 8.3 I2C Write To write settings to the device a Data Write is performed. Here the Address-Command is always required, followed by the relevant data bytes to write to the device. DATA WRITE Start Control Byte S Adr + WRITE AddressCommand ACK Data n ACK Figure 8.4 8.4 Data n+1 ACK Stop ACK S I2C Write End of Communication Session / Window Similar to other Azoteq I2C devices, to end the I2C communication session, a STOP command is given. When sending numerous read and write commands in one communication cycle, a repeated start command must be used to stack them together (since a STOP will jump out of the communication window, which is not desired). The STOP will then end the communication, and the IQS624 will return to process a new set of data. Once this is obtained, the communication window will again become available (RDY set LOW). 8.5 Stop-bit disable option(IQS624-32) The IQS624-32 part offer: • an additional I2C settings register (0xD9) specifically added for stop-bit disable functionality, • as well as a RDY timeout period register (0xD8) in order to set the required timeout period for termination of any communication windows (RDY = Low) if no I 2C activity is present on SDA and SCL pins. Customers using an MCU with a binary serial-encoder peripheral which is not fully I2C compatible (but provide some crude serial communication functions) can use this option to configure the IQS624-32 so that any auto generated stop command from the serial peripheral can be ignored by the IQS624-32 I2C hardware. This will restrict the IQS624-32 from immediately exiting a communication window during event mode (reduced communication only for events) until all required communication has been completed and a stop command can correctly be transmitted. Please refer to the figures below for serial data transmission examples. Please note: 1. Stop-bit disable and enable must be performed at the beginning and end of a communication window. The first and last I2C register to be written to ensure no unwanted communication window termination. 2. Leaving the Stop-bit disabled will result in successful reading of registers but will not execute any commands written over I2C in a communication window being terminated after a RDY timeout and with no IQS recognised stop command. 3. The default RDY timeout period for IQS624-32 is purposefully long (10.24ms) for slow responding MCU hardware architectures. Please set this register according to your requirements/preference. 4. These options are only available on IQS624-32 parts and not for IQS624-3001. Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 26 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series Stop-bit Disable Communication window open Start Control byte RDY = ↓LOW S Addr + WRITE AddressCommand ACK 0xD9 Disable stop-bit ACK 0x81 ACK Ignored stop Continue with reads / writes S … I2C Stop-bit Disable Figure 8.5 Stop-bit Enable Reads / Writes Finished Start Control byte … S Addr + WRITE AddressCommand ACK 0xD9 ACK 0x01 ACK Stop Communication window closed S RDY = ↑HIGH I2C Stop-bit Enable Figure 8.6 8.6 Enable stop-bit Device address and sub-addresses The default device address is 0x44 = DEFAULT_ADDR. Alternative sub-address options are definable in the following one-time programmable bits: OTP Bank0 (bit3; 0; bit1; bit0) = SUB_ADDR_0 to SUB_ADDR_7 a) Default address: 0x44 = DEFAULT_ADDR OR SUB_ADDR_0 b) Sub-address: 0x45 = DEFAULT_ADDR OR SUB_ADDR_1 c) Sub-address: 0x46 = DEFAULT_ADDR OR SUB_ADDR_2 d) Sub-address: 0x47 = DEFAULT_ADDR OR SUB_ADDR_3 e) Sub-address: 0x4C = DEFAULT_ADDR OR SUB_ADDR_4 f) Sub-address: 0x4D = DEFAULT_ADDR OR SUB_ADDR_5 g) Sub-address: 0x4E = DEFAULT_ADDR OR SUB_ADDR_6 h) Sub-address: 0x4F = DEFAULT_ADDR OR SUB_ADDR_7 8.7 Additional OTP options All one-time-programmable device options are located in FG bank 0. Floating Gate Bank0 Bit Number 7 6 5 4 3 2 Name - Comms ATI - - Sub address 2 8MHz Default - 0 - 0 0 0 1 0 Sub address 0-1 0 0 Bit definitions: • • Bit 6: Comms mode during ATI o 0: No streaming events are generated during ATI o 1: Comms continue as setup regardless of ATI state. Bit 2: Main Clock frequency selection o 0: Run FOSC at 16MHz o 1: Run FOSC at 8MHz Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 27 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series • Bit 0,1,3: I2C sub-address o I2C address = 0x44 All calibration data are located in FG bank 3 for the latest IQS624-3001 and all IQS624-32 IC’s. Floating Gate Bank3 Bit Number 7 6 5 4 3 2 1 Name - Hall Plate Calibration Data Default - 15-1 0 Bit definitions: • Bit 3-0: Hall Plate Calibration Data o 15-1: The calibration bin of the IC o 0: The IC is not calibrated (Before June 2018) Please refer to Appendix B: Magnet calibration for information regarding hall plate calibration. 8.8 Request Communication Window The master or host MCU has the capability to request a communication window at any time, by writing the device address to the IQS624. The communication window will open directly following the current conversion cycle. 8.9 I2C Specific Commands 8.9.1 Show Reset After start-up, and after every reset event, the “Show Reset” flag will be set in the System Flags register (0x10H; bit 7). The “Show Reset” bit can be read to determine whether a reset has occurred on the device (it is recommended to be continuously monitored). This bit will be set ’1’ after a reset. The “Show Reset” flag will be cleared (set to ’0’) by writing a ’1’ into the “Ack reset” bit in the General system settings register (0xD0; bit 6) . A reset will typically take place if a timeout during communication occurs. 8.9.2 I2C Timeout If no communication is initiated from the master/host MCU within the first t COMMS (tCOMMS = 2.038 ms default) of the RDY line indicating that data is available (i.e. RDY = low), the device will resume with the next cycle of charge transfers and the data from the previous conversions will be lost. The RDY timeout period register (0xD8) can be adjusted on IQS624-32. There is also a timeout (tI2C) that cannot be disabled, for when communication has started but not been completed, for example when the bus is being held by another device (tI2C = 33 ms). Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 28 of 75 May 2022 IQ Switch® ProxSense® Series Azoteq 8.10 Recommended communication and runtime flow diagram The following is a basic master program flow diagram to communicate and handle the device. It addresses possible device events such as output events, ATI and system events (resets). . Figure 8.7 Figure 8-1 Master command structure and runtime event handling flow diagram It is recommended that the master verifies the status of the System Flags (0x10) bits to identify events and resets. Detecting either one of these should prompt the master to the next steps of handling the IQS624. Streaming mode communication is used for detail sensor evaluation during prototyping and/or development phases. Event mode communication is recommended for runtime use of the IQS624. Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 29 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 9 IQS624 Memory map Table 9.1 IQS624 Register map Register Address Group 0x00 0x01 Register Name Product Number Device Information Software Number 0x02 Hardware Number 0x10 System Flags 0x12 Proximity/Touch UI Flags 0x14 0x15 HALL UI Flags Device Specific Data Hall Ratio Flags 0x16 (IQS624-32) Filtered Degree Output (Low byte) 0x17 (IQS624-32) Filtered Degree Output (High byte) 0x18 (IQS624-32) Interval Number Output 0x20 CH0 CS Low 0x21 CH0 CS High 0x22 CH1 CS Low 0x23 CH1 CS High 0x24 CH2 CS Low 0x25 CH2 CS High 0x26 CH3 CS Low 0x27 CH3 CS High Count Data 0x28 CH4 CS Low 0x29 CH4 CS High 0x2A CH5 CS Low 0x2B CH5 CS High 0x30 CH0 LTA Low 0x31 CH0 LTA High 0x32 CH1 LTA Low 0x33 CH1 LTA High 0x40 Ch0 ProxFusion Settings 0 0x41 Ch1 ProxFusion Settings 0 0x42 Ch0&1 ProxFusion Settings 1 0x43 0x44 ProxFusion sensor settings Ch0 ProxFusion Settings 2 Ch1 ProxFusion Settings 2 0x45 Ch0&1 ProxFusion Settings 3 0x46 Ch0 Compensation 0x47 Ch1 Compensation 0x48 0x49 0x50 Ch1 Multipliers Ch0 Proximity threshold 0x51 0x52 Ch0 Multipliers ProxFusion sensor settings Ch0 Touch threshold Touch / Proximity UI settings Ch1 Proximity threshold 0x53 Ch1 Touch threshold 0x54 UI Halt period 0x70 Hall Rotation UI Settings Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 30 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 0x71 Hall Sensor Settings 0x72 Ch2&3 Hall ATI Settings 0x73 Ch4&5 Hall ATI Settings 0x74 Ch2&3 Compensation 0x75 Ch4&5 Compensation 0x76 Ch2&3 Multipliers 0x77 Ch4&5 Multipliers HALL Sensor Settings 0x78 0x79 Hall Ratio Settings Sin Constant 0x7A Cos Constant 0x7B (IQS624-32) Wheel Filter Beta 0x7C (IQS624-32) Wheel Wake Preload 0x7D (IQS624-32) Interval UI Divider 0x7E (IQS624-32) Wheel Offset (Low byte) 0x7F (IQS624-32) Wheel Offset (High byte) 0x80 Degree Output (Low byte) 0x81 Degree Output (High byte) 0x82 Ratio Output (Low byte) 0x83 Ratio Output (High byte) 0x84 Numerator of Ratio (Low byte) 0x85 Numerator of Ratio (High byte) HALL Wheel Output 0x86 Denominator of Ratio (Low byte) 0x87 Denominator of Ratio (High byte) 0x88 Rotation Correction factor (Low byte) 0x89 Rotation Correction factor (High byte) 0x8A Max Numerator of Ratio (Low byte) 0x8B Max Numerator of Ratio (High byte) 0x8C Max Denominator of Ratio (Low byte) 0x8D Max Denominator of Ratio (High byte) HALL Wheel Output 0x8E Relative Rotation Angle 0x8F Movement counter/timer 0xD0 General System Settings 0xD1 Active Channels 0xD2 Power Mode Settings 0xD3 Normal mode report rate 0xD4 0xD5 Device and Power mode Settings Low power mode report rate Ultra-low power mode report rate 0xD6 Auto Mode time 0xD8 (IQS624-32) RDY Timeout Period 0xD9 (IQS624-32) I2C Settings Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 31 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 9.2 Device Information 9.2.1 Product Number Bit Number Data Access Name 7 6 Product Number (0x00) 5 4 3 Read Device Product Number 2 1 0 2 1 0 Bit definitions: • Bit 7-0: Device Product Number = D’67’ 9.2.2 Software Number Bit Number Data Access Name 7 6 Software Number (0x01) 5 4 3 Read Device Software Number Bit definitions: • • • Bit 7-0: IQS624-3yy1 - Device Software Number = D’02’ Bit 7-0: IQS624-3yy2 - Device Software Number = D’14’ (Backwards compatible) Bit 7-0: IQS624-5yy1 - Device Software Number = D’02’ 9.2.3 Hardware Number Bit Number Data Access Name 7 6 Hardware Number (0x02) 5 4 3 2 Read Device Hardware Number 1 0 Bit definitions: • • • • Bit 7-0: IQS624-3yy1 - Device Hardware Number = D’130’ Bit 7-0: IQS624-3yy2 - Device Hardware Number = D’130’ Bit 7-0: IQS624-3yy2 - Device Hardware Number = D’146’ Bit 7-0: IQS624-5yy1 - Device Hardware Number = D’162’ Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 32 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 9.3 Device Specific Data 9.3.1 System Flags Bit Number Data Access Name 7 6 Show Reset System flags (0x10) 5 4 3 Read Current power mode 2 1 0 ATI Busy Event NP Segment Active Bit definitions: • • • • • Bit 7: Reset Indicator: o 0: No reset event o 1: A device reset has occurred and needs to be acknowledged Bit 4-3: Current power mode indicator: o 00: Normal power mode o 01: Low power mode o 10: Ultra-Low power mode o 11: Halt power mode Bit 2: ATI Busy Indicator: o 0: No channels are in ATI o 1: One or more channels are in ATI Bit 1: Global Event Indicator: o 0: No new event to service o 1: An event has occurred and should be handled Bit 0: Normal Power segment indicator: o 0: Not performing a normal power update o 1: Busy performing a normal power update 9.3.2 Proximity/Touch UI Flags Bit Number Data Access 7 Name 6 Proximity/Touch UI Flags (0x12) 5 4 3 2 Read Chan 1 Chan 0 Touch touch out out 1 0 Chan 1 Chan 0 proximity proximity out out Bit definitions: • • • • Bit 5: Channel 1 touch indicator: o 0: Channel 1 delta below touch threshold o 1: Channel 1 delta above touch threshold Bit 4: Channel 0 touch indicator: o 0: Channel 0 delta below touch threshold o 1: Channel 0 delta above touch threshold Bit 1: Channel 1 Proximity indicator: o 0: Channel 1 delta below proximity threshold o 1: Channel 1 delta above proximity threshold Bit 0: Channel 0 Proximity indicator: o 0: Channel 0 delta below proximity threshold o 1: Channel 0 delta above proximity threshold Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 33 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 9.3.3 Hall UI Flags Bit Number Data Access Name 7 Hall UI Flags (0x14) 5 4 3 Read 6 2 1 0 Wheel Movement movement direction Bit definitions: • > Bit 7: Wheel movement indicator: o 0: No wheel movement detected o 1: Wheel movement detected • Bit 6: Movement direction indicator: o 0: If movement is detected it is in positive direction o 1: If movement is detected it is in negative direction Please note that these bits will be set for small movements, therefore jitter may change the direction of movement bit. 9.3.4 Hall Ratio Flags Bit Number Data Access 7 Hall Ratio Flags (0x15) 5 4 3 2 1 0 Read Move Max Max counter Denominator Numerator full set set 6 Name Bit definitions: • • • Bit 2: Move counter full indicator: o 0: Movement counter is not full o 1: Movement counter is full Bit 1: Max Denominator set indicator: o 0: Max denominator has not changed o 1: Max denominator has changed (used for auto calibration) Bit 0: Max Numerator set indicator: o 0: Max Numerator has not changed o 1: Max Numerator has changed (used for auto calibration) 9.3.5 Filtered Degree Output1 Bit Number Data Access Name 15 14 Filtered Degree Output1 (0x17-0x16) 13 12 11 10 9 8 7 6 5 4 3 2 Read Degrees High Byte Degrees Low Byte 1 0 Bit definitions: • 0-360: Filtered absolute degree position of magnet 1 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. Only available on IQS624-32 IQS624 Datasheet V2.07 Memory map Page 34 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 9.3.6 Interval Number1 Bit Number Data Access Name • 9.4 7 6 Interval Number1 (0x18) 5 4 3 Read/Write Current Interval Number 2 1 0 Bit 7-0: Current interval number Count Data 9.4.1 Count CS Values Bit Number Data Access Name 15 14 Count CS values (0x20/0x21-0x2A/0x2B) 13 12 11 10 9 8 7 6 5 4 3 2 Read Count High Byte Count Low Byte 1 0 1 0 Bit definitions: • Bit 15-0: Counts o AC filter or raw value 9.4.2 LTA Values Bit Number Data Access Name 15 14 LTA values (0x30/0x31-0x32/0x33) 12 11 10 9 8 7 6 5 4 3 2 Read LTA High Byte LTA Low Byte 13 Bit definitions: • Bit 15-0: LTA Values o LTA filter value Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 35 of 75 May 2022 IQ Switch® ProxSense® Series 9.5 Azoteq ProxFusion sensor settings 9.5.1 Ch0/1 ProxFusion Settings 0 9.5.1.1 Capacitive Sensing Bit Number Data Access Name Default 7 0 Ch0/1 ProxFusion Settings 0 (0x40/0x41) 6 5 4 3 2 Read/Write Sensor mode TX select 0 0 0 0 0 1 0 RX select Bit definitions: • • • Bit 7-4: Sensor mode select: o 0000: Self capacitive mode Bit 3-2: TX-select: o 00: TX 0 and TX 1 is disabled Bit 1-0: RX select: o 00: RX 0 and RX 1 is disabled o 01: RX 0 is enabled o 10: RX 1 is enabled o 11: RX 0 and RX 1 is enabled 9.5.1.2 Inductive Sensing Bit Number Data Access Name Default 7 1 Ch0/1 ProxFusion Settings 0 (0x40/0x41) 6 5 4 3 2 Read/Write Sensor mode TX select 0 0 1 0 0 1 0 RX select 1 1 Bit definitions: • • • Bit 7-4: Sensor mode select: o 1001: Mutual Inductive mode Bit 3-2: TX-select: o 00: TX 0 and TX 1 is disabled Bit 1-0: RX select: o 11: RX 0 and RX 1 is enabled 9.5.2 Ch0&1 ProxFusion Settings 1 Bit Number Data Access 7 Name - Default Ch0&1 ProxFusion Settings 1 (0x42) 6 5 4 3 2 Read/Write CS Charge Freq Proj bias pxs PXS 0x5B 1 0 Auto ATI Mode Bit definitions: • Bit 6: ProxFusion Sensing Capacitor size select: o 0: ProxFusion Sensing capacitor size is 15 pF o 1: ProxFusion Sensing capacitor size is 60 pF Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 36 of 75 May 2022 IQ Switch® ProxSense® Series • • • Azoteq Bit 5-4: Charge Frequency select: o 00: 1/2 o 01: 1/4 o 10: 1/8 o 11: 1/16 Bit 3-2: Projected bias: o 00: 2.5µA / 88kΩ o 01: 5µA / 66kΩ o 10: 10µA / 44kΩ o 11: 20µA / 22kΩ Bit 1-0: Auto ATI Mode select: o 00: ATI Disabled o 01: Partial ATI (Multipliers are fixed) o 10: Semi Partial ATI (Coarse multipliers are fixed) o 11: Full ATI 9.5.3 Ch0 ProxFusion Settings 2 Bit Number Data Access Name Default Ch0 ProxFusion Settings 2 (0x43) 7 6 5 4 3 2 Read/Write ATI Base ATI Target 0x50 1 0 1 0 Bit definitions: • • Bit 7-6: ATI Base value select: o 00: 75 o 01: 100 o 10: 150 o 11: 200 Bit 5-0: ATI Target: o ATI Target is 6-bit value x 32 9.5.4 Ch1 ProxFusion Settings 2 Bit Number Data Access Name Default Ch1 ProxFusion Settings 2 (0x44) 7 6 5 4 3 2 Read/Write ATI Base ATI Target 0x50 Bit definitions: • • Bit 7-6: ATI Base value select: o 00: 75 o 01: 100 o 10: 150 o 11: 200 Bit 5-0: ATI Target: o ATI Target is 6-bit value x 32 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 37 of 75 May 2022 IQ Switch® ProxSense® Series Azoteq 9.5.5 Ch0&1 ProxFusion Settings 3 Bit Number Data Access 7 Name - Default Ch0&1 ProxFusion Settings 3 (0x45) 6 5 4 3 2 Read/Write Two ACF CS Div sided LTA Beta Disable PXS 0x00 1 0 ACF Beta Bit definitions: • • • • • Bit 6: CS divider o 0: Sampling capacitor divider disabled o 1: Sampling capacitor divider enabled Bit 5: Two sided ProxFusion Sensing o 0: Bidirectional detection disabled o 1: Bidirectional detection enabled Bit 4: ACF Disable o 0: AC Filter Enabled o 1: AC Filter Disabled Bit 3-2: LTA Beta 0 o 00: 7 o 01: 8 o 10: 9 o 11: 10 Bit 1-0: ACF Beta 1 o 00: 1 o 01: 2 o 10: 3 o 11: 4 9.5.6 Ch0/Ch1 Compensation Bit Number Data Access Name 7 6 Ch0/Ch1 Compensation (0x46,0x47) 5 4 3 2 Read/Write Compensation (7-0) 1 0 Bit definitions: • Bit 7-0: 0-255: Lower 8 bits of the Compensation Value Register addresses: • • 0x46: Channel 0 Lower 8 bits of the Compensation Value 0x47: Channel 1 Lower 8 bits of the Compensation Value Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 38 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 9.5.7 Ch0/Ch1 Multipliers values Ch0/1 Multipliers values(0x48/0x49) Bit Number 7 6 5 4 3 2 1 Data Access Read/Write Name Compensation (9-8) Coarse multiplier Fine multiplier 0 Bit definitions: • • • Bit 7-6: Compensation upper two bits o 0-3: Upper 2-bits of the Compensation value. Bit 5-4: Coarse multiplier Selection: o 0-3: Coarse multiplier selection Bit 3-0: Fine Multiplier Selection: o 0-15: Fine Multiplier selection Register addresses: • • 9.6 0x48: Channel 0 Multipliers Value 0x49: Channel 1 Multipliers Value Touch / Proximity UI settings 9.6.1 Ch0/1 Proximity/touch threshold Bit Number Data Access Name 7 Proximity/touch threshold Ch0/1(0x50-0x53) 6 5 4 3 2 Read/Write Threshold 1 0 Bit definitions: • Bit 7-0: Proximity and touch thresholds: If a difference between the LTA and counts value would exceed this threshold the appropriate event would be flagged (either Touch or Proximity Event). Register addresses: • • • • 0x50 Channel 0 Proximity Threshold Value 0x51 Channel 0 Touch Threshold Value 0x52 Channel 1 Proximity Threshold Value 0x53 Channel 1 Touch Threshold Value 9.6.2 UI Halt period Bit Number Data Access Name Default 7 6 UI Halt period (0x54) 5 4 3 Read/Write UI Halt period 0x28 = 20 sec 2 1 0 Bit definitions: • Bit 7-0: Halt time in 500 ms ticks Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 39 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 9.7 HALL Sensor Settings 9.7.1 Hall Rotation UI Settings Bit Number Data Access Name Default Hall Rotation UI Settings (0x70) 6 5 4 3 7 2 1 0 Auto calibration - Wheel wakeup 1 - 0 Read/Write Hall Wheel UI disable 0 Interval UI disable1 0 Zero Wheel1 0 Hall Wheel Event disable1 0 Interval Event Disable1 1 Bit definitions: • • • • • • • Bit 7: Hall Wheel UI disable o 0: Hall wheel UI is enabled o 1: Hall wheel UI is disabled Bit 6: Interval UI disable1 o 0: Interval UI is enabled o 1: Interval UI is disabled Bit 5: Zero Wheel angle1 o 1: Zero angle, automatically cleared by firmware Bit 4: Hall Wheel UI Event disable1 o 0: Event UI is enabled o 1: Event UI is disabled Bit 3: Interval UI Event disable1 o 0: Event UI is enabled o 1: Event UI is disabled Bit 2: Auto calibration o 0: Auto calibration disabled o 1: Auto calibration enabled Bit 0: Wheel wakeup select o 0: Wheel wakeup mode disabled o 1: Wheel wakeup mode enabled (wakes up on Ch0 touch). 9.7.2 Hall Sensor Settings Hall Sensor Settings (0x71) 6 5 4 3 Read/Write 2 - - 0 0 Bit Number Data Access 7 Name ACF Enable1 - Default 0 0 Charge Freq 0 0 1 0 Auto ATI mode Hall 1 1 Bit definitions: • Bit 7: ACF Enable: Enable filter on the individual Hall channels1 o 0: Filter disabled o 1: Filter Enabled 1 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. Only available on IQS624-32 IQS624 Datasheet V2.07 Memory map Page 40 of 75 May 2022 IQ Switch® ProxSense® Series • • Azoteq Bit 5-4: Charge Frequency: The rate at which our measurement circuit samples o 00: 1/2 o 01: 1/4 o 10: 1/8 o 11: 1/16 Bit 1-0: Auto ATI Mode1 o 00: ATI disabled: ATI is completely disabled o 01: Partial ATI: Only adjusts compensation o 10: Semi-Partial ATI: Only adjusts compensation and the fine multiplier. o 11: Full-ATI: Compensation and both coarse and fine multipliers is adjusted 9.7.3 Ch2/3, Ch4/5 Hall ATI Settings2 Ch2/3, Ch4/5 Hall ATI Settings (0x72/0x73) 7 6 5 4 3 2 Read/Write ATI Base ATI Target 0x73 Bit Number Data Access Name Default 1 0 1 0 Register addresses: • 0x72: Channel 2 & 3 ATI settings • 0x73: Channel 4 & 5 ATI settings Bit definitions: • • Bit 7-6: ATI Base value select: o 00: 75 o 01: 100 o 10: 150 o 11: 200 Bit 5-0: ATI Target: o ATI Target is 6-bit value x 32 9.7.4 Ch2/3, Ch4/5 Hall Compensation Bit Number Data Access Name 7 Ch2/3, Ch4/5 Hall Compensation (0x74,0x75) 6 5 4 3 2 Read/Write Compensation (7-0) Bit definitions: • Bit 7-0: 0-255: Lower 8 bits of the compensation value 1 2 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. Refer to the Errata See Appendix B for more information IQS624 Datasheet V2.07 Memory map Page 41 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 9.7.5 Ch2/3, Ch4/5 Hall Multipliers Ch2/3, Ch4/5 Hall Multipliers (0x76-0x77) Bit Number 7 6 5 4 3 2 1 Data Access Read/Write Name Compensation 9-8 Coarse Multiplier Fine Multiplier 0 Bit definitions: • • • Bit 7-6: Compensation 9-8: o 0-3: Upper 2-bits of the compensation value Bit 5-4: Coarse multiplier selection o 0-3: Coarse multiplier selection Bit 3-0: Fine multiplier selection o 0-15: Fine multiplier selection 9.7.6 Hall Ratio Settings Bit Number Data Access 7 Name - Hall ratio settings (0x78) 6 5 4 3 2 1 0 Read Read/Write Read Direction Octant Y Ratio Denominator Numerator invert / Cos flag negative Negative negative negative negative Bit definitions: • • • • • Bit 6-5: Quadrature output for octant changes (per 45 degrees) o 0-3: Quadrature output Bit 3: Invert direction of degrees o 0 – Invert not active o 1 – Invert active Bit 2: Ratio negative (Used for on-chip angle calculation) o 0 – Ratio is positive o 1 – Ratio is negative Bit 1: Denominator negative (Used for on-chip angle calculation) o 0 – Denominator is positive o 1 – Denominator is negative Bit 0: Numerator negative (Used for on-chip angle calculation) o 0 – Numerator is positive o 1 – Numerator is negative 9.7.7 Sin Constant Bit Number Data Access Name 7 6 Sin constant (0x79) 5 4 3 Read/Write Sin constant 2 1 0 Bit definitions: • Bit 7-0: Sin (phase difference) x 255 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. IQS624 Datasheet V2.07 Memory map Page 42 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 9.7.8 Cos Constant Bit Number Data Access Name 7 Cos constant (0x7A) 5 4 3 Read/Write Cos constant 6 2 1 0 Bit definitions: • Bit 7-0: Cos (phase difference) x 255 Phase difference: Phase difference measured between the signals obtained from the two Hall sensor plates. This can be calculated with a simple calibration, see Appendix B. 9.7.9 Wheel Filter Beta1 Bit Number Data Access Name Default 7 Wheel Filter Beta1 (0x7B) 5 4 3 Read/Write Wheel Filter Beta 0x08 6 2 1 0 Bit definitions: • Bit 7-0: Initial value used during calculation of wheel filter beta. 9.7.10 Wheel Wake Preload1 Bit Number Data Access Name Default Wheel Wake Preload1 (0x7C) 7 6 5 4 3 2 1 Read/Write Counter Threshold Timer Preload 7 31 0 Bit definitions: • • Bit 7-5: Wheel Wake Counter Threshold o 0-7: The wheel will wake up if the counter value reaches the counter threshold value before the timer reaches 0. Bit 4-0: Wheel Wake Timer Preload o 0: Stop timer when wheel is in sleep. Load 31 when wheel is awake. o 1-31: Preload Value loaded into Movement Timer (0x8F). The wheel will wake up if the Movement Counter value (0x8F) reaches the Counter Threshold value before the timer reaches 0. 1 Copyright © Azoteq (Pty) Ltd 2022. All Rights Reserved. Only available on IQS624-32 IQS624 Datasheet V2.07 Memory map Page 43 of 75 May 2022 Azoteq IQ Switch® ProxSense® Series 9.7.11 Interval UI Divider1 Bit Number Data Access Name Default 7 Interval UI Divider1 (0x7D) 5 4 3 Read/Write Interval size in degrees 0x03 6 2 1 0 Bit definitions: • Bit 7-0: Interval size in degrees (>= 3° and
IQS624-300-DNR 价格&库存
很抱歉,暂时无法提供与“IQS624-300-DNR”相匹配的价格&库存,您可以联系我们找货
IQS624-300-DNR
  • 3000+4.872723000+0.63036
