SparkFun OpenPIR
SEN‐13968 Open Source Hardware
Description: The SparkFun OpenPIR is a highly customizable Passive Infrared (PIR) sensor based
around the NCS36000 PIR controller. Passive infrared (PIR) sensors are able to detect motion in a
small/local area –– they’re the sensor of choice in security systems, home automation and proximitysensing applications. The OpenPIR allows you to set the sensitivity, trigger time and pulse mode of
the motion sensor so you can tailor-fit it to your application!
The OpenPIR has a multitude of characteristics unique to itself, including two trimpots to adjust
sensitivity (view distance) and the oscillator to control the length of time the output remains HIGH, as
well as a trigger that supports two motion-detection modes: single-pulse and dual-pulse. Additionally,
each OpenPIR is equipped with a reverse-entry green LED, which duplicates the status of the OUT
pin. When motion is detected, the LED will illuminate; otherwise it will remain off.
The SparkFun OpenPIR supports a power supply range of 3VDC to 5.75VDC at 80µA standby (3mA
when detecting motion) and is able to be connected via a standard 0.1" header or a 4-pin JST PH
connector.
Features:
Voltage Supply Range: 3VDC to 5.75VDC
Standby Average Current: 80µA
Motion-Detected Average Current: 3mA (LED enabled)
Integrated 2−Stage Amplifier
Internal LDO to Drive Sensor
Internal Oscillator with External RC
Single or Dual Pulse Detection
https://www.sparkfun.com/products/13968 5‐1‐17
很抱歉,暂时无法提供与“SEN-13968”相匹配的价格&库存,您可以联系我们找货
