5600F3
5600F3
    VCC
    LED T1 AMBER 603NM RA ASSY
5600F3 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5600 Series T-1 Right Angle LED Assembly Description and Features 3. 00/2. 30 4. 10 5. 30 HOUS IN G : B L A C K T H E R MO P L A S T IC UL 94-V 0 0. 50 S T A N D - O F F 6. 40 3. 00 + 4. 80/4. 10 C A T H O DE ( - ) 0. 50 1. 30 LE D T-1 S IZ E S E E S P E C . T AB L E 2. 50 All dimens ions in mm. Features • Small T-1 size lamp preassembled into Nylon plastic block. • Height and spacing alignment, saves assembly cost. • Super Brite and High Brite LEDs. • High light output - diffused lens. • High contrast ratio. • Low current - only 2 mA. • Built -in resistor chip operates off 5 volt supply without external resistor. • Standoffs prevent flux entrapment. • RoHS Compliant Housing: Black Nylon,UL94V-O Note: Alternate LEDs are also available in this package as a standard variation. Electro-Optical Characteristics and Ratings Part Number Color Typ. Intensity (mcd) Rated Current (mA) 5600F1 Red 10 10 5600F3 Amber 7 10 Continuous Reverse Forward Forward Forward Break-down Current Max. Voltage Typ. Voltag e Max. Voltag e Min. (V) (V) (mA) (V) 30 2.0 5 3.0 30 2.2 5 3.0 Peak Wave length (nm) 650 603 5600F5 Green 16 10 30 2.2 3.0 5 562 5600F7 Yellow 6.3 10 30 2.1 3.0 5 585 5600F1LC Red 2.5 2.0 7 1.8 2.2 5 635 5600F5LC Green 2.1 2.0 7 1.8 2.2 5 565 5600F7LC Yellow 1.8 2.0 7 1.9 2.7 5 583 5602F1-5V Red 8.0 10 20 5 7.5 5 655 5602F3-5V Amber 8.0 10 15 5 7.5 5 583 5602F5-5V Green 8.0 10 15 5 7.5 5 565 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5600F3 价格&库存
很抱歉,暂时无法提供与“5600F3”相匹配的价格&库存,您可以联系我们找货
