SMS1105RC
SMS1105RC
    BIVAR
    PLCC-2
    发光二极管/LED 红色 PLCC-2 626nm 250mcd
SMS1105RC 数据手册
PLCC2 SMD Side View Package LED SMS1105RC, RED SMS1105RC      Industry Standard Footprint Side Viewing, Low Profile Package High Luminous Intensity Wide Viewing Angle High Power Efficiency Bivar SMS1105 LED is offered in a side viewing PLCC2 package exhibiting high luminous intensity and wide viewing angles. The miniature package is ideal for small scale applications such as displays, general indication, and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment where minimal maintenance is required. Wide variety of color and intensity combinations are available to meet any illumination needs. Bivar SMS1105 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Lumen Typ. mcd Lens Color Viewing Angle SMS1105RC InGaN Red 250 Water Clear 120° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 1 of 5 PLCC2 SMD Side View Package LED SMS1105RC, RED Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 100 mW Continuous Forward Current 30 mA Peak Forward Current 1 100 mA Electrostatic Discharge Classification (HBM) 2000 V Reverse Voltage 5V Derating Linear From 25°C 0.4 mA/°C Operating Temperature Range -30 ~ +85°C Storage Temperature Range -40 ~ +100°C Soldering Temperature 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Emitting Color Red Recommend Forward Current (mA) Forward Voltage (V)1 Reverse Viewing Luminous Dominant Current (µA) Angle 2 Wavelength (nm) Intensity (mcd)3 VR=5V 2 Ө ½ (deg) MIN TYP MAX TYP MAX MIN MAX MIN MAX TYP 1.8 2.2 2.6 20 10 620 632 100 400 120 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Dominant Wavelength : ±0.1nm. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Radiation Diagram Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 2 of 5 PLCC2 SMD Side View Package LED SMS1105RC, RED Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 3 of 5 PLCC2 SMD Side View Package LED SMS1105RC, RED Recommended Soldering Conditions Tape and Reel Dimensions Note: 3000 pcs/Reel 2 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 4 of 5 PLCC2 SMD Side View Package LED SMS1105RC, RED Packaging and Labeling Plan Note: 1 Reel / Bag Vacuum and Heat Sealed Clear AntiStatic Poly Bag Internal Quality Control Label X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 5 of 5
SMS1105RC 价格&库存
很抱歉,暂时无法提供与“SMS1105RC”相匹配的价格&库存,您可以联系我们找货
SMS1105RC
    • 1+7.07400
    • 200+2.82960
    • 500+2.73240
    • 1000+2.67840
    SMS1105RC
    • 1+11.615951+1.49939
    SMS1105RC
      SMS1105RC
      • 1+11.620591+1.49999
      • 10+8.1816210+1.05609
      • 100+6.10312100+0.78780
      • 500+5.18280500+0.66900
      • 1000+4.881721000+0.63014
      • 2000+4.626392000+0.59718
      库存:11694
      SMS1105RC
