Industry Standard 1206 Package
RoHS Compliant
Diffused Inner Lens
High Luminous Intensity
Narrow Viewing Angle
Ideal for Status Indication, Display, and Backlighting
Bivar Surface Mount 1206 Inner Lens package LED may be used in nearly any indication application.
The diffused inner lens provides a narrow viewing angle and high luminous intensity making it suitable
for small scale applications such as display, backlighting, and general indication. Low power consumption and excellent long life reliability are ideal for battery powered equipment. Wide variety of
wavelength and intensity combinations are available to meet any illumination need. The SM1206 -IL
LED is packaged in standard tape and reels for pick and place assemblies.
Part Number
Material
Emitted Color
Chromaticity
Coordinates
(±.05)
Lens
Appearance
Luminous
Intensity
(mcd) TYP.
Viewing Angle
SM1206NUWC-IL
InGaN
WHITE
X=.30, Y=.29
Diffused
750
30°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision D 03/18
Page 1 of 5
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
100 mW
Forward Current ( DC )
25 mA
Peak Forward Current 1
100 mA
Reverse Voltage
5V
Operating Temperature Range
-30 ~ +80°C
Storage Temperature Range
-40 ~ +85°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
SM1206NUWC-IL
3.1
4.2
Notes: 1. Tolerance of forward voltage : ±0.05V.
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MAX
MIN
TYP
MAX
MIN
TYP
MAX
TYP
10
450
750
30
2. Tolerance of dominant wavelength : ±5.0nm.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision D 03/18
Page 2 of 5
Typical Electrical / Optical Characteristics
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision D 03/18
Page 3 of 5
Recommended Soldering Conditions
Tape and Reel Dimensions
Note: 3000 pcs/Reel
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision D 03/18
Page 4 of 5
Packaging and Labeling Plan
2. Standard tolerance unless otherwise noted: X.XXX ± 0.010"
X.X ± 0.1”
Note: 1 Reel / Bag
Vacuum and Heat Sealed
ESD/MBB Bag
Internal Quality Control
X.XXX
Humidity Indicator
Card
X.XXX
Desiccants
Bivar Standard Packaging Label
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
E-mail:
bivar@bivar.com Web: www.bivar.com
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 Web:
www.bivar.com
Rev. A D
01/16/08
Revision
03/18
Page
Page 4
5 of
of 4
5
很抱歉,暂时无法提供与“SM1206NUWC-IL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.398611+1.47539
- 10+8.0132110+1.03720
- 100+5.97557100+0.77346
- 500+5.07158500+0.65645
- 1000+4.775901000+0.61818
- 国内价格 香港价格
- 3000+4.396603000+0.56908
- 6000+4.203816000+0.54413
- 9000+4.105099000+0.53135
- 15000+3.9937115000+0.51693
- 21000+3.9275121000+0.50836
- 国内价格
- 1+6.59880
- 10+5.37840
- 30+4.76280
- 100+4.15800
- 500+3.80160
- 1000+3.60720
- 国内价格 香港价格
- 3000+5.491303000+0.71077
- 国内价格
- 10+5.63493
- 750+5.50892
- 1500+5.39437
