CC
SMTL6-RGB
Industry Standard PLCC6 Package
3 Chips in One Low Profile Package
High Luminous Intensity
Wide Viewing Angle
High Power Efficiency
Bivar SMTL6-RGB LED is offered in an industry standard PLCC6 package with high luminous intensity and
wide viewing angles. The miniature package is ideal for small scale applications such as illumination, general
indication, and backlighting. Low power consumption and excellent long life reliability are suitable for battery
powered equipment. The flexible three chip design allows for a wide variety of lighting options where the
chips can be individually driven or mixed to create numerous color and intensity combinations. Bivar SMTL6
LED is packaged in standard tape and reels for pick and place assemblies.
Part Number
Material
Emitted Color
Lumen Typ. mcd
AlGaInP
Red
700
InGaN
Green
1500
InGaN
Blue
300
SMTL6-RGB
Lens Color
Viewing Angle
Water Clear
140°
Outline Dimensions
BLUE
GREEN
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision B 10/22
Page 1 of 6
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
100 mW
Continuous Forward Current
30 mA
Peak Forward Current 1
100 mA
Electrostatic Discharge Classification (HBM)
2000 V
Reverse Voltage
5V
Derating Linear from 25°C
0.4 mA/°C
Operating Temperature Range
-30 - +85°C
Storage Temperature Range
-40 - +90°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb )
250°C
2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 4 seconds at temperature extreme.
Electrical / Optical Characteristics
T = 25°C & I = 20 mA unless otherwise noted
A
F
Emitting
Color
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
Reverse
Dominant
Luminous
Current
Wavelength (nm)2 Intensity Iv (mcd)3
(μA)
Viewing
Angle
2Ө½
(deg)
MAX
MIN
TYP
MAX
MIN
TYP
MAX
TYP
Red
1.8
2.4
620
630
650
1200
140
Green
2.8
3.4
520
530
1400
2000
140
Blue
2.8
3.4
465
475
200
600
140
Notes: 1. Tolerance of forward voltage : ±0.05V.
2. Tolerance of dominant wavelength : ±1.0nm.
3. Tolerance of luminous intensity : ±15%
Directivity Radiation
Radiation Diagram
Revision B 10/22
Page 2 of 6
Typical Electrical / Optical Characteristics
Revision B 10/22
Page 3 of 6
Recommended Soldering Conditions
Soldering Iron
1. Temperature at tip of iron: 300 ̊C Max. (25W Max.)
2. Soldering time: 3 sec ± 1.
Revision B 10/22
Page 4 of 6
Storage
1. The storage temperature and R.H. are 5 ̊C ~30 ̊C, R.H. 60% Max.
2. Once the package is opened, the products should be used within 24 hrs. Otherwise, they should be kept in a
dampproof box with a desiccating agent.
3. It is recommended to bake at 70 ̊C ± 3 ̊C for 48 hrs before soldering them after the package is unsealed for 24
hrs.
Tape and Reel Dimensions
Note: 1000 pcs/Reel
BLUE
GREEN
Revision B 10/22
Page 5 of 6
0.35 [9.0mm]
0.47 [12.0mm]
Packaging and Labeling Plan
Note: 1 Reel / Bag
Sealed ESD and Moisture Barrier Bag
Internal Quality Control Label
X.XXX
Humidity Indicator Card
X.XXX
Desiccant
Bivar Standard Packaging Label
Revision B 10/22
Page 6 of 6
很抱歉,暂时无法提供与“SMTL6-RGB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+13.142621000+1.70095
