SM0805UGC
SM0805UGC
    BIVAR
    发光二极管/LED 翠绿色 0805
SM0805UGC 数据手册
CC SM0805UGC  Industry Standard 0805 Package  RoHS Compliant Small Package and Footprint  Water Clear Lens  Wide Viewing Angle  Ideal for Status Indication, Display, and Backlighting Bivar Surface Mount 0805 package LED may be used in nearly any lighting or indication application. The miniature package is ideal for small scale applications such as general indication and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. Bivar offers water clear LED lens for maximum luminous intensity. Wide variety of wavelength and intensity combinations are available to meet any illumination need. The SM0805 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Peak Wavelength λp(nm) TYP. Lens Appearance SM0805UGC GaP GREEN 568 Water Clear Luminous Intensity (mcd) Viewing Angle TYP. 2.2 130° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 08/22 Page 1 of 5 Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 78 mW Forward Current (DC) Peak Forward Current 30 mA 100 mA 1 Reverse Voltage 5V Operating Temperature Range -40 - +85°C Storage Temperature Range -40 - +85°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & IF = 5 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX SM0805UGC 1.8 2.0 2.3 Notes: 1. Tolerance of forward voltage : ±0.1V. / 5 / Reverse Dominant Luminous Current Wavelength (nm)2 Intensity Iv (mcd)3 (μA) Viewing Angle 2Ө½ (deg) MAX MIN TYP MAX MIN TYP MAX TYP 10 / 572 / 1.2 2.2 5.1 130 2. Tolerance of dominant wavelength : ±1.0nm. 3. Tolerance of luminous intensity : ±10% Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 08/22 Page 2 of 5 Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 08/22 Page 3 of 5 Recommended Soldering Conditions Temp. (°C) a 25 b 150 c 200 d 220 e 245 f Max. 260 Belt Speed Time (Sec) T0~T1 T1~T2 T2~T4 T3~T6 Max. 3°C/sec 90~130 sec Max. 3°C/sec Max. 50sec Max. 10sec T5~T7 Max. -3°C/sec 70~90 cm/min Soldering Iron 1. Temperature at tip of iron: 300°C Max. (25W Max.) 2. Soldering time: 5 ± 1sec. Tape and Reel Dimensions Note: 3000 pcs/Reel 0.053 [1.35mm] Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 08/22 Page 4 of 5 2.8 [70mm] Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance unless otherwise noted: X.XXX ± 0.010" X.X ± 0.1” Packaging and Labeling Plan Note: 1 Reel / Bag Vacuum and Heat Sealed Clear AntiStatic Poly Bag X.XXX Humidity Indicator Card Desiccant X.XXX Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 08/22 Page 5 of 5
SM0805UGC 价格&库存
很抱歉,暂时无法提供与“SM0805UGC”相匹配的价格&库存,您可以联系我们找货
SM0805UGC
  • 25+2.83569
  • 125+2.33479
库存:150
SM0805UGC
  • 125+2.33479
库存:2150
SM0805UGC
  • 3000+2.357743000+0.30434
  • 6000+2.238036000+0.28889
  • 9000+2.176679000+0.28097
  • 15000+2.1074015000+0.27203
  • 21000+2.0662121000+0.26671
  • 30000+2.0260430000+0.26153
库存:7569
SM0805UGC
  • 1+6.566761+0.84764
  • 10+4.5784910+0.59100
  • 100+3.33371100+0.43032
  • 500+2.77596500+0.35833
  • 1000+2.592911000+0.33470
库存:7569
