SM1204PGC
SM1204PGC
    BIVAR
    发光二极管/LED 翠绿色 1204 505nm 360mcd
SM1204PGC 数据手册
SURFACE MOUNT LED PURE GREEN, 1204 PACKAGE SM1204PGC ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 1204 Package RoHS Compliant Right Angle Mounting Water Clear Lens Wide Viewing Angle Ideal for Status Indication and Display Bivar Surface Mount 1204 package LED may be used in nearly any lighting or indication application. The right angle package is ideal for small scale applications such as edge lighting or general indication. Low power consumption and excellent long life reliability are ideal for battery powered equipment. Wide variety of wavelength and intensity combinations are available to meet any illumination need. Bivar offers water clear LED lens for maximum luminous intensity. The SM1204 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Peak Wavelength λp(nm) TYP. Lens Appearance Luminous Intensity (mcd) TYP. Viewing Angle SM1204PGC InGaN GREEN 500 Water Clear 360 110° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Level 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 01/10 Page 1 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 1204 PACKAGE Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 100 mW Forward Current ( DC ) 30 mA Peak Forward Current 1 100 mA Reverse Voltage 5V Operating Temperature Range -30 ~ +80°C Storage Temperature Range -40 ~ +85°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX SM1204PGC / 3.3 3.5 / 20 Notes: 1. Tolerance of forward voltage : ±0.05V. / Reverse Dominant Current Wavelength (nm)2 (μA) Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MAX MIN TYP MAX MIN TYP MAX TYP 10 / 505 / 285 360 / 110 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 01/10 Page 2 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 1204 PACKAGE Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 01/10 Page 3 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 1204 PACKAGE Recommended Soldering Conditions Tape and Reel Dimensions Note: 3000 PCS/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 01/10 Page 4 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 1204 PACKAGE Packaging and Labeling Plan Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance unless otherwise noted: X.XXX ± 0.010" X.X ± 0.1” Note: 1 Reel / Bag Vacuum and Heat Sealed Clear AntiStatic Poly Bag Internal Quality Control X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 01/10 Page Page 4 5 of of 4 5
SM1204PGC 价格&库存
很抱歉,暂时无法提供与“SM1204PGC”相匹配的价格&库存,您可以联系我们找货
SM1204PGC
  • 1+10.304071+1.33488
  • 10+7.2096610+0.93400
  • 100+5.34971100+0.69305
  • 500+4.52517500+0.58623
  • 1000+4.255191000+0.55126
库存:20999
SM1204PGC
  • 3000+3.908663000+0.50636
  • 6000+3.732516000+0.48354
  • 9000+3.642309000+0.47186
  • 15000+3.5405215000+0.45867
  • 21000+3.4800221000+0.45083
库存:20999
