SMS1105GC
SMS1105GC
    BIVAR
    2-SMD,J形引线
    LED GREEN CLEAR 2SMD R/A
SMS1105GC 数据手册
PLCC2 SMD Side View Package LED SMS1105GC, GREEN SMS1105GC      Industry Standard Footprint Side Viewing, Low Profile Package High Luminous Intensity Wide Viewing Angle High Power Efficiency Bivar SMS1105 LED is offered in a side viewing PLCC2 package exhibiting high luminous intensity and wide viewing angles. The miniature package is ideal for small scale applications such as displays, general indication, and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment where minimal maintenance is required. Wide variety of color and intensity combinations are available to meet any illumination needs. Bivar SMS1105 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Lumen Typ. mcd Lens Color Viewing Angle SMS1105GC AlGaInP Green 120 Water Clear 120° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 1 of 5 PLCC2 SMD Side View Package LED SMS1105GC, GREEN Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 100 mW Continuous Forward Current 30 mA Peak Forward Current 1 100 mA Electrostatic Discharge Classification (HBM) 2000 V Reverse Voltage 5V Derating Linear From 25°C 0.4 mA/°C Operating Temperature Range -30 ~ +85°C Storage Temperature Range -40 ~ +100°C Soldering Temperature 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Emitting Color Green Recommend Forward Current (mA) Forward Voltage (V)1 Reverse Viewing Luminous Dominant Current (µA) Angle 2 Wavelength (nm) Intensity (mcd)3 VR=5V 2 Ө ½ (deg) MIN TYP MAX TYP MAX MIN MAX MIN MAX TYP 1.8 2.2 2.6 20 10 566 575 40 200 120 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Dominant Wavelength : ±0.1nm. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Radiation Diagram Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 2 of 5 PLCC2 SMD Side View Package LED SMS1105GC, GREEN Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 3 of 5 PLCC2 SMD Side View Package LED SMS1105GC, GREEN Recommended Soldering Conditions Tape and Reel Dimensions Note: 3000 pcs/Reel 2 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 4 of 5 PLCC2 SMD Side View Package LED SMS1105GC, GREEN Packaging and Labeling Plan Note: 1 Reel / Bag Vacuum and Heat Sealed Clear AntiStatic Poly Bag Internal Quality Control Label X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 5 of 5
SMS1105GC 价格&库存
很抱歉,暂时无法提供与“SMS1105GC”相匹配的价格&库存,您可以联系我们找货
SMS1105GC
  • 3000+3.509183000+0.41933
  • 6000+3.348546000+0.40013
  • 9000+3.268309000+0.39054
  • 15000+3.1796115000+0.37995
  • 21000+3.1278721000+0.37376
库存:34003
SMS1105GC
  • 1+11.950591+1.42802
  • 10+7.4839710+0.89429
  • 100+5.18845100+0.61999
  • 500+4.28659500+0.51222
  • 1000+4.009731000+0.47914
库存:34003
