OMB.868.B08F21
OMB.868.B08F21
    TAOGLASLIMITED
    OMB.868.B08F21
OMB.868.B08F21 数据手册
Barracuda - 868MHz 8dBi Omni Directional Outdoor Antenna Part No: OMB.868.B08F21 Features: Omni-Directional Radiation Collinear ISM 868 MHz Band 8dBi Peak gain Robust design for all weather operation IP65 waterproof 1474mm in length, 720 g in weight N type Female connector Wall/Pole mount bracket included RoHS Compliant SPE-15-08-052-E 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 6 5. Mechanical Drawing 8 6. Packaging 9 7. Installation guide 10 Changelog 12 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-15-08-052-E www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The OMB.868.B08F21 is a fiberglass omni-directional outdoor antenna, operating in 868 MHz ISM band. The antenna has an 8dBi high peak gain, providing the largest coverage area for Low Power Radio (UNB Sigfox, LPRN, LoRA) and mesh networks. Typical applications are in IoT, metering, industrial/environmental monitoring and remote asset monitoring. Introduction The OMB.868 operates at 868MHz, one of the most widely used license free ISM bands, with a 8dBi peak gain. The omni-directional antenna collinear dipole design means it radiates uniformly in the azimuth with a high gain, providing coverage over long distances, thus minimizing the amount of cells or nodes needed in a network. Introduction The UV resistant fiberglass housing enables the OMB antenna to be weathered in all kinds of harsh environments, making it more robust and safer than traditional whip antennas. It has been designed to withstand high wind load. The integrated aluminum mounting bracket is perfect for directly mounting the antenna onto a pole or a wall. The connector is industry standard N-type female. Connector can be customized subject to MOQ. Other frequencies and gains are available. Contact Taoglas regional sales office for more details. Introduction SPE-15-08-052-E www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. 3. 4. Specifications Standard ISM 868 Band 860 – 870 MHz Antenna Type Collinear Dipole Array Antenna Peak Gain Characteristics 8 dBi Polarization Vertical Impedance 50 ohms Max Input Power Antenna Radiation Patterns3.Antenna 50 watts VSWR Characteristics2. Radiation 3. Electrical 1.5:1 Specifications Omni-Directional Vertical Beamwidth 13 Deg Horizontal Beamwidth 360 Deg Internal Material Antenna Characteristics2. Copper Specifications Connector N Type Female Mechanical 3. 4. Length 1474 mm(Max) Bracket Dimension 70 x 73mm(Max) Radome Diameter 24mm Antenna Weight 720g Antenna Characteristics Antenna Radiation Patterns3.Antenna Mounting Accessories Weight 70g Application Indoor/Outdoor Radome Material White Fiberglass Bracket Material Aluminum Mount Style Pole Mount/Wall Mount Characteristics 4. 4. Antenna Radiation Patterns Mount Hardware Material Wind Resistance >150mph (>241km/h) Waterproof IP65 Environmental Antenna Radiation Patterns3. Antenna Storage Temperature -40°C to +80°C Characteristics Operating Temperature 4. Stainless Steel -40°C to +60°C Operating Humidity 10%~90% non-condensing Storage Humidity 5%~90% non-condensing Antenna Radiation Patterns3.Antenna Characteristics2. SPE-15-08-052-E Specifications www.taoglas.com 4 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna 0 Characteristics 4. 4. Return Loss [dB] -5 Antenna Radiation Patterns -10 Antenna Radiation Patterns3.Antenna -15 Characteristics -20 800 810 820 830 840 850 860 Antenna Radiation Patterns3. Antenna Frequency [MHz] 4. 870 880 890 900 867 868 869 870 Characteristics 3.2 Peak Gain 10 4. 8 Antenna Radiation Patterns 4. Gain [dBi] 6 Antenna Radiation Patterns 4 2 4. Antenna Radiation Patterns 0 4. -2 860 861Radiation 862 863 864 865 866 Antenna Patterns3. Antenna Frequency [MHz] Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-15-08-052-E www.taoglas.com 5 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-15-08-052-E www.taoglas.com 6 4.2 2D Radiation Patterns 3D and 2D Radiation Patterns Azimuth Elevation 868MHz Azimuth SPE-15-08-052-E Elevation www.taoglas.com 7 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-08-052-E Mechanical Drawing www.taoglas.com 8 8. 6. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-08-052-E Mechanical Drawing www.taoglas.com 9 7. Installation Guide 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing SPE-15-08-052-E www.taoglas.com 10 SPE-15-08-052-E www.taoglas.com 11 Changelog for the datasheet SPE-15-08-052 - OMB.868.B08F21 Revision: E (Current Version) Date: Changes: Changes Made by: 2022-09-20 Full Data sheet update Evan Murphy Previous Revisions Revision: D Date: Changes: Changes Made by: 2018-03-27 Amended Installation Jack Conroy Revision: C Date: Changes: Changes Made by: 2018-08-03 Added Installation Guide Jack Conroy Revision: B Date: Changes: Changes Made by: Unknown Technical Writer Revision: A (Original First Release) Date: Notes: Author: SPE-15-08-052-E 2015-11-27 Technical Writer www.taoglas.com 12 www.taoglas.com © Taoglas SPE-15-08-052-E www.taoglas.com 13
OMB.868.B08F21 价格&库存
很抱歉,暂时无法提供与“OMB.868.B08F21”相匹配的价格&库存,您可以联系我们找货
OMB.868.B08F21
  • 1+1378.145901+179.01416
