MA600.A.ABC.007
MA600.A.ABC.007
    TAOGLASLIMITED
    MA600.A.ABC.007
MA600.A.ABC.007 数据手册
SPECIFICATION Part No. : MA600.A.ABC.007 Product Name : MA600 Spartan Screw mount 3in1 Combination Antenna GPS/GLONASS/GALILEO 1575~1602MHz Cellular – GSM/CDMA/HSPA/UMTS Dual band Wi-Fi 2.4GHz / 5.8GHz Feature : High performance outdoor antenna Custom cables and connectors available RoHS ✓ SPE-13-8-003/D/ZL Page 1 of 24 MA600.A301111.B305111.C305151 1. Introduction The Spartan MA.600 antenna is a heavy-duty, fully IP67 waterproof external M2M antenna for use in telematics, transportation and remote monitoring applications. The Spartan is unique in the market because it combines a 3in1 GPS/GLONASS/GALILEO, Cellular (2G and 3G) and Wi-Fi, heavy-duty antenna with high efficiency in a compact format. The antenna screws down permanently onto a roof or metal panel and can be pole or wall-mounted with a metal bracket. For industries such as commercial vehicle telematics, remote monitoring, smart meter systems and construction equipment, the Spartan provides a robust, rugged antenna that is durable, even in extreme environments. All while still maintaining 20dB isolation between antennas. It uses high-shielded PTFE dielectric ultra low-loss cables that maintain low attenuation at all frequency bands, with an average 0.3dB per meter (0.1dB per foot), compared to 0.7dB for RG58 and 1.2dB for RG174. Because of this, the Spartan maximizes chances of passing PTCRB and network approvals first time. The Spartan also has excellent GPS/GLONASS/GALILEO reception without need to attach to an external ground-plane due to coupling to its unique own metal base. Note: for ground-isolation antennas use the MA.605 version with Isolation Gaskets. SPE-13-8-003/D/ZL Page 2 of 24 MA600.A301111.B305111.C305151 2. Specification GPS/GLONASS/GALILEO Centre Frequency 1575.42MHz / 1602MHz Bandwidth 10MHz Radiation Efficiency 50(without cable) Passive Gain @ Zenith 4.0 typ(with ψ=140mm ground) VSWR 2 Impedance 50Ω DC Power Input Range 3 ~ 5V DC input 3.3V 4.0V 5.5V MHz 1575.42 1602 1575.42 1602 1575.42 1602 VSWR 2 2 2 2 2 2 LNA Gain 29.2 29 31 31 32.3 32 Noise Figure 3.1 3.1 3.2 3.2 3.4 3.4 Power Consumption 7.5 7.5 9.4 9.4 15 15 Band Attenuation 1520MHz: -20dB 1520MHz: -20dB 1520MHz: -20dB 1642MHz: -20dB 1642MHz: -20dB 1642MHz: -20dB Cable 3m RG-174 standard, fully customizable Connector SMA(M) standard, fully customizable CELLULAR Frequency (GHz) 824~896 880~960 1710~1880 1850~1990 1710~2170 Peak Gain (dBi) 2.1 -0.2 2.9 3.0 5.1 Average (dBi) -4.7 -7.5 -2.7 -3.1 -3.1 Efficiency 35% 20% 51% 49% 49% Impedance 50Ω Polarization Linear Radiation Pattern Omni Cable 3m CFD200 standard, fully customizable Connector SMA(M) standard, fully customizable SPE-13-8-003/D/ZL Page 3 of 24 MA600.A301111.B305111.C305151 WIFI Frequency (GHz) 2.4~2.5 4.7~5.0 5.0~5.4 5.4~5.9 Peak Gain (dBi) 2.1 2.9 3.8 2.8 Average Gain (dBi) -2.3 -3.6 -3.3 -3.8 Efficiency 60% 44% 46% 42% VSWR
MA600.A.ABC.007 价格&库存
很抱歉,暂时无法提供与“MA600.A.ABC.007”相匹配的价格&库存,您可以联系我们找货
