SPECIFICATION
Part No.
MA600.A.ABC.006
Product Name
MA600 Spartan Screw-mount
3in1 Combination Antenna
GPS/GLONASS/GALILEO 1575~1602MHz
Cellular – GSM/CDMA/HSPA/UMTS
2.4GHz / 5GHz
Feature
High performance outdoor antenna
Custom cables and connectors available
RoHS ✓
SPE-12-8-048/D/ZL
Page 1 of 23
MA600.A301111.B305111.C305111
1.
Introduction
The Spartan MA.600 antenna is a heavy-duty, fully IP67 waterproof external M2M
antenna for use in telematics, transportation and remote
monitoring applications.
The
Spartan
is
unique
in
the
market
because
it
combines
a
3in1
GPS/GLONASS/GALILEO, Cellular (2G and 3G) and Wi-Fi, heavy-duty antenna
with high efficiency in a compact format. The antenna screws down permanently
onto a roof or metal panel and can be pole or wall-mounted with a metal bracket.
For industries such as commercial vehicle telematics, remote monitoring, smart
meter systems and construction equipment, the Spartan provides a robust,
rugged antenna that is durable, even in extreme environments.
All while still maintaining 20dB isolation between antennas. It uses high-shielded
PTFE dielectric ultra low-loss cables that maintain low attenuation at all frequency
bands, with an average 0.3dB per meter (0.1dB per foot), compared to 0.7dB for
RG58 and 1.2dB for RG174.
Because of this, the Spartan maximizes chances of
passing PTCRB and network approvals first time. The Spartan also has excellent
GPS/GLONASS/GALILEO reception without need to attach to an external
ground-plane due to coupling to its unique own metal base.
Note: for ground-isolation antennas use the MA.605 version with Isolation
Gaskets.
SPE-12-8-048/D/ZL
Page 2 of 23
2.
Specification
GPS-GLONASS-GALILEO
Centre Frequency
1575.42MHz / 1602MHz
Bandwidth
10MHz
Radiation Efficiency
50(without cable)
Passive Gain @
4.0 typ(with ψ=140mm ground)
Zenith
VSWR
2
Impedance
50Ω
DC Power Input
3 ~ 5V
Range
DC input
MHz
3.3V
4.0V
5.5V
1575.42
1602
1575.42
1602
1575.42
1602
2
2
2
2
2
2
29.2
29
31
31
32.3
32
Noise Figure
3.1
3.1
3.2
3.2
3.4
3.4
Power Consumption
7.5
7.5
9.4
9.4
15
15
VSWR
LNA Gain
Band Attenuation
1520MHz: -20dB
1520MHz: -20dB
1520MHz: -20dB
1642MHz: -20dB
1642MHz: -20dB
1642MHz: -20dB
Cable
3m RG-174 standard, fully customizable
Connector
SMA(M) standard, fully customizable
CELLULAR
Frequency (GHz)
824~896
880~960
1710~1880
1850~1990
1710~2170
Peak Gain (dBi)
2.1
-0.2
2.9
3.0
5.1
Average (dBi)
-4.7
-7.5
-2.7
-3.1
-3.1
Efficiency
35%
20%
51%
49%
49%
Impedance
50Ω
Polarization
Linear
Radiation Pattern
Omni
Cable
3m CFD200 standard, fully customizable
Connector
SPE-12-8-048/D/ZL
Page 3 of 23
Wi-Fi
Frequency (GHz)
2.4~2.5
4.7~5.0
5.0~5.4
5.4~5.9
Peak Gain (dBi)
2.1
2.9
3.8
2.8
Average Gain (dBi)
-2.3
-3.6
-3.3
-3.8
Efficiency
60%
44%
46%
42%
VSWR
很抱歉,暂时无法提供与“MA600.A.ABC.006”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1633.213961+212.26857
- 10+1442.7615910+187.51551
- 25+1376.9282225+178.95915
