CMD12-21VYC/TR8
CMD12-21VYC/TR8
    VCC
    SMD2
    LED YELLOW CLEAR 2SMD R/A
CMD12-21VYC/TR8 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMD12-21 Bright★Angle™ Right Angle Surface Mount LED Description and Features 3.00 1.00 0.50 0.50 2.00 Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 2000 per reel. • RoHS Compliant Leading Edge LED Optoelectronic Performance • Consistent high brightness. 1.00 R 2.00 1.00 0.40 0.40 Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. • Refer to “Solder Pad Geometry 3.pdf” C AT HODE ANODE C AT HODE MAS K All dimens ions in mm. 0.88 0.45 R AD. R E AR V IE W Electro-Optical Characteristics P art Number C MD12-21S R C /T R 8 C MD12-21V R C /T R 8 C MD12-21V Y C /T R 8 C MD12-21V G C /T R 8 C MD12-21UG C /T R 8 E mitted C olor R ed H.E . R ed Y ellow G reen G reen Lens C olor C lear C lear C lear C lear C lear Luminous Intensity Min. (mcd) 14.0 3.0 1.5 4.4 9.0 F orward V oltage T yp. (mcd) T yp. (V ) Max. (V ) V iewing Angle (degrees) P eak Wavelength (nm) 24.0 5.0 3.0 8.8 14.9 1.7 2.0 2.0 2.1 2.1 2.4 2.8 2.8 2.8 2.8 120 120 120 120 120 660 640 585 570 570 Absolute Maximum Ratings Green H.E.Red Yellow Red Units Power Dissipation.........................................................100................105...................85..................105...............mW Storage/Operating Temperature............................ -40 to +85.... -40 to +85....... -40 to +85........ -40 to +85...........°C Peak Forward Current (1μs @ 10% duty cycle)...........150................150..................150.................150................mA Reverse Voltage (IR=100μA)........................................4.0.................4.0...................4.0..................4.0...................V Lead Solder Time @ 260°C...........................................5....................5......................5....................5...........Seconds Average Forward Current..............................................30..................30....................30...................30.................mA CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
CMD12-21VYC/TR8 价格&库存
很抱歉,暂时无法提供与“CMD12-21VYC/TR8”相匹配的价格&库存,您可以联系我们找货
