7010X11
7010X11
    VCC
    1206(3016公制)
    LED RED CLEAR 1206 SMD
7010X11 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 7010X Series SMT LEDs 1206 Package Size Description and Features C AT HODE MAR K 3.00 1 2 LE NS 2.00 1.50 Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 2500 per reel. • RoHS Compliant Leading Edge LED Optoelectronic Performance • Consistent high brightness. LE D C HIP 1.80 0.90 0.60 Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. • Refer to “Solder Pad Geometry 3.pdf” 1.60 2 1 1.50 All dimensions in mm. Electro-Optical Characteristics and Ratings 7010X7 7010X11 P AR T NUMB E R R ed Y ellow Output C olor Non-Diffused Non-Diffused Diffusion C lear C lear P ackage C olor 20 20 T est C urrent (mA) 1.7 2.1 F orward Voltage Typ. (V) 2.0 2.5 F orward V oltage Max. (V ) 6.0 6.0 Luminous Intensity Min. (mcd) 12.0 17.0 Luminous Intensity T yp. (mcd) Luminous Intensity Max. (mcd) P eak Wavelength (nm) 660 570 70 70 Viewing Angle 20 1/2 (degrees) P ower Dissipation (mW) 60 75 Operating Temperature (°C ) -30 to +85 -30 to +85 -40 to +100 -40 to +100 S torage T emperature (°C ) P eak Forward C urrent Max. (1µs @ 10% duty cycle) (mA) 70 70 R everse V oltage (IR =100µA) (V ) 4 4 Lead S older T ime @ 260°C 5 5 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
7010X11 价格&库存
很抱歉,暂时无法提供与“7010X11”相匹配的价格&库存,您可以联系我们找货
