VAOL-5LDE2
VAOL-5LDE2
    VCC
    插件
    发光二极管/LED 插件
VAOL-5LDE2 数据手册
LED LAMP VAOL-5LDE2 Feature § § Package Dimension Low Power Consumption I.C. compatible Applications § § § § Commercial Outdoor Sign Board Front Panel Indicator Dot-Matrix Module LED Bulb Description § § § These LEDs are Based on GaP/GaP Material Technology Emitted color:Green Green Diffusion Lens *Tolerance:± 0.01 0.25 Unit inch mm Absolute Maximum Ratings at Ta=25℃ Symbol Parameter Max. Unit 100 mW PD Power Dissipation VR Reverse Voltage 5 V IAF Average Forward Current 30 mA IPF Peak Forward Current(Duty=0.1,1kHz) 100 mA ― Derating Linear Form 25℃ 0.4 mA∕℃ Topr Operating Temperature Range –20 to + 80 ℃ Tstg Storage Temperature Range –20 to + 100 ℃ Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds. Electrical / Optical Characteristics and Curves at Ta=25℃ Symbol Parameter VF Forward Voltage IF= 20 mA IR Reverse Current VR= 5 △θ Half Intensity Angle IF= 20 mA 60 Deg. IV Luminous Intensity IF= 20 mA 50 mcd. λd Dominant Wavelength IF= 20 mA 570 nm engineered to light up your design Test Condition Min. Typ. 2.2 V www.vcclite.com Max. Unit 2.8 V 100 μA 1.800.522.5546 02/15 Rev 1 Electrical Characteristics at Ta=25℃ Symbol Iv VF λD Parameter Luminous Intensity Forward Voltage Dominant Wavelength Condition IF=20mA IF=20mA IF=20mA Unit mcd V nm Binning Grade Range Grade Range Grade Range -- 50 C 1.9~2.0 G9 569~571 -- -- D 2.0~2.1 G10 571~573 -- -- E 2.1~2.2 G11 573~575 F 2.2~2.3 G 2.3~2.4 Intensity: Tolerance of minimum and maximum = ± 15% Vf: Tolerance of minimum and maximum = ± 0.05v NOTE: 1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery must be properly grounded. 2. Specific binning requirements –please contact our home office Radiation Diagram IF=20 mA 50% Power Angle engineered to light up your design www.vcclite.com Angle =60∘ 1.800.522.5546 02/15 Rev 1 GREEN Typical Electro-optical Characteristic Curves (25°C Free Air Temperature Unless Otherwise Specified) λ engineered to light up your design www.vcclite.com 1.800.522.5546 02/15 Rev 1
VAOL-5LDE2 价格&库存
很抱歉,暂时无法提供与“VAOL-5LDE2”相匹配的价格&库存,您可以联系我们找货
VAOL-5LDE2
  • 1+5.114921+0.66479
  • 10+3.5069210+0.45580
  • 100+2.52464100+0.32813
  • 500+2.08423500+0.27089
  • 1000+1.939371000+0.25206
  • 2000+1.816212000+0.23606
  • 5000+1.681525000+0.21855
  • 10000+1.5974610000+0.20762
  • 25000+1.5057425000+0.19570
库存:7058
VAOL-5LDE2
