VAOL-5GDE4
VAOL-5GDE4
    VCC
    径向
    LED GREEN CLEAR 4.8MM ROUND T/H
VAOL-5GDE4 数据手册
SUPERBRIGHT LED LAMP VAOL-5GDE4 Package Dimension Feature § § § Low Power Consumption High Intensity I.C. compatible Applications § § § § Commercial Outdoor Sign Board Front Panel Indicator Dot-Matrix Module LED Bulb Description § § § These High Intensity LEDs are Based on GaP/GaP Material Technology Emitted color:Green Water Transparent Lens *Tolerance:± 0.01 0.25 Unit:± inch mm Absolute Maximum Ratings at Ta=25℃ Symbol Parameter Max. Unit 100 mW PD Power Dissipation VR Reverse Voltage 5 V IAF Average Forward Current 30 mA IPF Peak Forward Current(Duty=0.1,1kHz) 100 mA ― Derating Linear Form 25℃ 0.4 mA∕℃ Topr Operating Temperature Range –40 to + 80 ℃ Tstg Storage Temperature Range –40 to + 100 ℃ Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds. Electrical / Optical Characteristics and Curves at Ta=25℃ Symbol Parameter Test Condition VF Forward Voltage IF= 20 mA IR Reverse Current VR= 5 △θ Half Intensity Angle IF= 20 mA 30 Deg. IV Luminous Intensity IF= 20 mA 380 mcd. λd Dominant Wavelength IF= 20 mA 570 nm Min. Typ. Max. Unit 2.0 2.4 V 100 μA V Electrical Characteristics at Ta=25℃ Symbol Iv VF λD Parameter Luminous Intensity Forward Voltage Dominant Wavelength Condition IF=20mA IF=20mA IF=20mA Unit mcd V nm Grade Range Grade Range Grade Range BIN 13 345~485 C 1.9~2.0 G9 569~571 -- -- D 2.0~2.1 G10 571~573 E 2.1~2.2 G11 573~575 F 2.2~2.3 G 2.3~2.4 Binning Intensity: Tolerance of minimum and maximum = ± 15% Vf: Tolerance of minimum and maximum = ± 0.05v NOTE: 1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery must be properly grounded. 2. Specific binning requirements –please contact our home office Radiation Diagram IF=20 mA 50% Power Angle Angle Y=30∘ GREEN Typical Electro-optical Characteristic Curves (25°C Free Air Temperature Unless Otherwise Specified) λ
VAOL-5GDE4 价格&库存
很抱歉,暂时无法提供与“VAOL-5GDE4”相匹配的价格&库存,您可以联系我们找货
VAOL-5GDE4
  • 1+5.206261+0.67104
  • 10+3.5643710+0.45942
  • 100+2.55950100+0.32990
  • 500+2.10745500+0.27163
  • 1000+1.958691000+0.25246
  • 2000+1.832302000+0.23617
  • 5000+1.693935000+0.21834
  • 10000+1.6075910000+0.20721
  • 25000+1.5133625000+0.19506
库存:795
