VAOL-5LAE2
VAOL-5LAE2
    VCC
    插件
    发光二极管/LED 插件
VAOL-5LAE2 数据手册
LED LAMP VAOL-5LAE2 Feature § § § Package Dimension Low Power Consumption I.C. compatible LED Bulb Description § § § These LEDs are Based on AlGaAs/GaAsMaterial Technology Emitted color:Red Red Diffusion Lens *Tolerance:± 0.01 0.25 Unit:± inch mm Absolute Maximum Ratings at Ta=25℃ Symbol Parameter Max. Unit 100 mW PD Power Dissipation VR Reverse Voltage 5 V IAF Average Forward Current 30 mA IPF Peak Forward Current(Duty=0.1,1kHz) 100 mA ― Derating Linear Form 25℃ 0.2 mA∕℃ Topr Operating Temperature Range –20 to + 80 ℃ Tstg Storage Temperature Range –20 to + 100 ℃ Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds. Electrical / Optical Characteristics and Curves at Ta=25℃ Symbol Parameter Test Condition VF Forward Voltage IF= 20 mA IR Reverse Current VR= 5 △θ Half Intensity Angle IF= 20 mA 60 Deg. IV Luminous Intensity IF= 20 mA 80 mcd. λd Dominant Wavelength IF= 20 mA 640 nm Min. Typ. 1.8 2.2 V Max. Unit 2.8 V 100 μA Electrical Characteristics at Ta=25℃ Symbol Iv VF λD Parameter Luminous Intensity Forward Voltage Dominant Wavelength Condition IF=20mA IF=20mA IF=20mA Unit mcd V nm Binning Grade Range Grade Range Grade Range -- 80 C 1.9~2.0 R1 635~640 -- -- D 2.0~2.1 R2 640~646 -- -- E 2.1~2.2 F 2.2~2.3 G 2.3~2.4 Intensity: Tolerance of minimum and maximum = ± 15% Vf: Tolerance of minimum and maximum = ± 0.025v NOTE: 1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery must be properly grounded. 2. Specific binning requirements –please contact our home office Radiation Diagram IF=20 mA 50% Power Angle Angle Y=60∘ RED Typical Electro-optical Characteristic Curves (25°C Free Air Temperature Unless Otherwise Specified) Fig 2. Relative Intensity vs. Forw ard Current Fig 1. Forward Current vs. Forward Voltage 3.0 Relative Intensity Normalize @ 20 mA Forward Current (mA) 1000 100 10 1 0.1 0.5 2.5 2.0 1.5 1.0 0.5 0.0 1.0 2.0 3.0 4.0 1 10 Forward V oltage(V) 1.1 1.0 0.9 0 20 40 60 80 100 Relative Intensity @ 20 mA Fig 5. Relative Intensity vs. Wavelength 1.0 0.5 610 660 W avelength(nm) 3.0 2.5 2.0 1.5 1.0 0.5 0.0 - 40 - 20 0 20 40 60 Ambient Tem perature( C) Ambient Temperature( C) 0.0 560 Relative Intensity @ 20 mA Normalize @ 25 C Forward Voltage @ 20 mA Normalize @ 25 C 1.2 - 20 1000 Fig 4. Relative Intensity vs. Temperature Fig 3. Forward Voltage vs. Temperature 0.8 - 40 100 Forward Current(mA) 710 80 100
VAOL-5LAE2
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,常用于遥控器等设备。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V至1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817的主要功能是发射红外光,用于无线通信。
6. 应用信息:广泛应用于遥控器、红外通信等领域。
7. 封装信息:EL817采用黑色塑料封装,尺寸为3.5mm x 1.6mm。
VAOL-5LAE2 价格&库存
很抱歉,暂时无法提供与“VAOL-5LAE2”相匹配的价格&库存,您可以联系我们找货
