SUPERBRIGHT LED LAMP
VAOL-5GSBY4
Feature
Package Dimension
Low Power Consumption
High Intensity
I.C. compatible
Applications
Commercial Outdoor Sign Board
Front Panel Indicator
Dot-Matrix Module
LED Bulb
Description
These High Intensity LEDs are Based on
InGaN/(ITO)Sapphire Material
Technology
Emitted color:Blue
Water Transparent Lens
*Tolerance:± 0.01
0.25
Unit:±
inch
mm
Absolute Maximum Ratings at Ta=25℃
Symbol
Parameter
Max.
Unit
120
mW
PD
Power Dissipation
VR
Reverse Voltage
5
V
IAF
Average Forward Current
mA
IPF
Peak Forward Current(Duty=0.1,1kHz)
85
mA
Derating Linear Form 25℃
0.4
mA∕℃
Topr
Operating Temperature Range
–40 to + 80
Tstg
Storage Temperature Range
–40 to + 100
Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds.
Electrical / Optical Characteristics and Curves at Ta=25℃
Symbol
Parameter
Test Condition
VF
Forward Voltage
IF= 20 mA
IR
Reverse Current
VR= 5
△θ
Half Intensity Angle
IF= 20 mA
30
Deg.
IV
Luminous Intensity
IF= 20 mA
7000
mcd.
λd
Dominant Wavelength
IF= 20 mA
470
nm
Min.
Typ.
3.5
V
Max. Unit
4.0
V
50
μA
Electrical Characteristics at Ta=25℃
Symbol
Iv
VF
λD
Parameter
Luminous Intensity
Forward Voltage
Dominant Wavelength
Condition
IF=20mA
IF=20mA
IF=20mA
Unit
mcd
V
nm
Grade
Range
Grade
Range
Grade
Range
BIN 21
4900~6900
P1
3.0~3.2
B6
465~470
BIN 22
6900~9700
P2
3.2~3.4
B7
470~475
P3
3.4~3.6
P4
3.6~3.8
P5
3.8~4.0
Binning
Intensity: Tolerance of minimum and maximum = ± 15%
Vf: Tolerance of minimum and maximum = ± 0.05v
NOTE:
1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist
band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery
must be properly grounded.
2. Specific binning requirements –please contact our home office
Radiation Diagram
IF=20 mA 50% Power Angle
Angle =30∘
BLUE
Typical Electro-optical Characteristic Curves
(25°C Free Air Temperature Unless Otherwise Specified)
很抱歉,暂时无法提供与“VAOL-5GSBY4”相匹配的价格&库存,您可以联系我们找货
