R50RB2-F-0160
R50RB2-F-0160
    BIVAR
    DIP-4
    R50RB2-F-0160
R50RB2-F-0160 数据手册
4-Pin Super Flux Red/Blue LED Lamp Orca R Series (Flat Face) R50RB2-F-0160 ♦ ♦ ♦ ♦ ♦ ♦ RoHS Compliant Low Profile Dome Lens Automatic Insertion Compatible — Tubular Packaging Automatic Placement Compatible High Intensity Output High Power Efficiency Bivar R50RB2-F-0160 comes with low profile package design incorporating higher forward current to maximize intensity while minimizing the number of LEDs required to achieve uniform and enhanced light distribution. Low power consumption with quick response time means savings in electricity. Bivar R50RB2-F-0160 can be coupled with reflectors or lenses for optimal light distribution needs. Typical applications are automotive exterior lighting, decorative interior or exterior lighting, specialty stage lighting, and electronic signage. Part Number R50RB2-F-0160 Material Emitted Color Intensity Typ. mcd AlGaInP/GaAs Red 600 GaN/SiC Blue 150 Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Lens Color Viewing Angle Water Clear 160° Moisture Sensitivity Levels 1 CAUTION: LOOKING DIRECTLY AT LED WITHOUT SHIELDED EYES MAY CAUSE DAMAGE TO RETINA. Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision D 09/11 Page 1 of 4 4-Pin Super Flux Red/Blue LED Lamp R50RB2-F-0160 Absolute Maximum Ratings TA = 25°C unless otherwise noted R - 150 mW B - 220 mW Power Dissipation Forward Current ( DC ) 80 mA Peak Forward Current 1 R - 160 mA B - 150 mA Electrostatic Discharge ( Class1 ) R - 1000 V B - 1000 V Reverse Voltage 5V Operating Temperature Range -25 ~ +80°C Storage Temperature Range -30 ~ +80°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 50 mA unless otherwise noted Emitting Color Forward Voltage (V)1 MIN TYP MAX Red 2.2 2.6 Blue 3.4 3.8 Recommend Reverse Dominant Forward Current (µA) Wavelength (nm)2 Current (mA) VR=5V Luminous Intensity (mcd)3 Viewing Angle 2 Ө ½ (deg) TYP MAX MIN MAX MIN TYP TYP 3.0 50 10 620 635 400 600 160 4.4 50 10 460 470 100 150 160 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Dominant Wavelength : ±0.1nm. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Relative Luminous Intensity vs. Radiation Angle Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision D 09/11 Page 2 of 4 4-Pin Super Flux Red/Blue LED Lamp R50RB2-F-0160 Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Fig.5 Relative Luminous Intensity vs. Ambient Temperature Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision D 09/11 Page 3 of 4 4-Pin Super Flux Red/Blue LED Lamp R50RB2-F-0160 Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Bivar Orca R series Super Flux LEDs are packaged in tubes, each of which contains 60 LEDs; and each tube contains a rubber stopper at each end. Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision D 09/11 Page 4 of 4
R50RB2-F-0160 价格&库存
很抱歉,暂时无法提供与“R50RB2-F-0160”相匹配的价格&库存,您可以联系我们找货
R50RB2-F-0160
  • 100+15.53641
  • 200+14.75954
  • 400+14.46482
库存:120
R50RB2-F-0160
  • 5+15.53745
  • 25+14.91262
  • 50+14.46691
库存:120
R50RB2-F-0160
  • 1+38.89257
  • 10+32.47236
  • 60+25.98028
  • 120+23.38106
  • 240+22.08743
  • 480+20.13502
  • 960+18.18260
  • 1920+16.88898
R50RB2-F-0160
  • 1+41.817661+5.41270
  • 10+34.9208010+4.52000
  • 60+27.9366460+3.61600
  • 120+25.14298120+3.25440
  • 240+23.74615240+3.07360
  • 480+21.65090480+2.80240
  • 960+19.55565960+2.53120
  • 1920+18.158821920+2.35040
