DELTA14/SMAM/S/RP/11
    SIRETTA
DELTA14/SMAM/S/RP/11 数据手册
Delta 14 2.4GHz Stubby WiFi/WLAN & Bluetooth SMA Male RP Antenna Key Features • • • • Compact design: 56mm long Cable free WiFi antenna solution 2.4 to 2.5GHz operating frequency 2dBi peak gain General Description Additional Considerations The Delta 14 is a direct connect stubby antenna tuned to 2.4GHz - the WiFi / WLAN/Bluetooth/ZigBee frequencies. • Made out of TPS for durability. Typical applications for this cost effective antenna are WiFi enabled terminals and modems. • Omnidirectional radiation for even coverage • Supplied with RP SMA connector for direct connection to a device This 2.4GHz antenna can be used with most modern day WiFi modems such as NetGear and TP-link that operate on the traditional 2.4GHz frequency. The Delta 14 is supplied, as standard, with a reverse polarity (RP) SMA male connector but can be built with an alternative connector for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.6 Delta 14 2.4GHz Stubby WiFi/WLAN & Bluetooth SMA Male RP Antenna Electrical Specifications Mechanical Specifications Operating Temperature: -20 - +60°C Dimensions: Storage Temperature: -30 - +75°C Connector: Impedance: Peak Gain: VSWR: Operating Frequencies: Polarization: Radiation: 50 Ohm 2.0dBi L56 x 7.3mm Ø SMA RP Mounting Method: Direct Connect 2.0 max 2400MHz Vertical Omni Return Loss VSWR @ 2.4MHz 1.58dB Ordering Details: Part number Description DELTA14/X/SMAM/S/RP/11 2.4GHz Stubby WiFi/WLAN & Bluetooth SMA Male RP Antenna Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.6
DELTA14/SMAM/S/RP/11 价格&库存
很抱歉,暂时无法提供与“DELTA14/SMAM/S/RP/11”相匹配的价格&库存,您可以联系我们找货
    • 1+81.24677
    • 10+78.81524
    • 50+77.23414
    库存:306
