Minima
Part No:
FXUB68.07.0180C
Description:
Minima Embedded Flexible 4G LTE Wide Band
Antenna 700-960MHz, 1700-2700MHz
Features:
Flexible Wideband Antenna
Covers worldwide 4G/3G/2G Bands
Isotropic Radiation Pattern
Highest efficiency in smallest size
67.0x58.0x0.2 mm
I-PEX® I1.37 coaxial cable
CE Certified
RoHS Compliant
SPE-16-8-023-C
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
6
4.
Radiation Patterns
9
5.
Mechanical Drawing
19
6.
Packaging
Application Note
21
Changelog
23
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-16-8-023-C
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
The patent pending Minima FXUB68 flexible antenna has been designed to cover 4G bands in the 7002700MHz spectrum, but also optimally covers 3G and 2G. The antenna has a compact, flexible, modern
design, with excellent efficiencies on all target bands.
1.
The Minima comes standard with 180mm IPEX cable and connector for easy installation and can also be
configured for different cable lengths and terminations. The 67x58x0.2mm FXUB68 is made from flexible
polymer material, which is ultra-thin, compact and highly efficient across the 4G and 3G bands. It is installed
by a simple “peel and stick” process, attaching securely to non-metal surfaces via adhesive backing.
1.
1.
Introduction
Introduction
Introduction
The Minima has been designed with excess bandwidth so that performance is not affected by thicker or
thinner plastic surfaces to which it is adhered. It enables designers to use only one antenna that covers all
cellular communication frequencies in the IoT market.
Introduction
The Minima antenna has a unique compact geometric design, which has excellent efficiency for its size and
isotropic pattern at both low and high bands. This antenna if integrated optimally with enough clearance,
can in most cases pass US operator requirements.
The antenna performs well at a reasonable distance, typically 20mm, from a ground and has demonstrated
ease of integration into complex end user equipment.
The FXUB65 Minima antenna has a typical efficiency of more than 50% across the low bands and 64% across
the high bands. The Minima is designed to be mounted directly onto a plastic or glass cover. It is an ideal
choice for any device maker that desires ease of integration and needs to keep manufacturing costs down
over the lifetime of a product.
Cable and connector can be customized, contact your regional Taoglas customer support team for more
information.
SPE-16-8-023-C
www.taoglas.com
3
2.
Specifications
5G/4G Bands
3.
Antenna Characteristics2.
Band Number
Specifications
5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA
Uplink
UL: 1920 to 1980
1
3.
4.
2
3
3.
4.
UL: 1710 to 1755
DL: 2110 to 2155
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
DL: 925Antenna
to 960
Antenna Radiation Patterns3.
UL: 880 to 915
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
Specifications
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746
UL: 815 toCharacteristics2.
830
Antenna
18
Specifications
DL: 860 to 875
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
24
UL:1625.5 to 1660.5
DL: 1525 to 1559
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
Characteristics
UL:2000 to
2020
23Antenna
DL: 2180 to 2200
UL: 807 to 824
DL: 852 to 869
Antenna
Radiation
Patterns3.
Antenna
UL:
703
to
748
DL: 758 to 803
28
27
UL: -
31
UL: 452.5 to 457.5
32
UL: -
DL: 717 to 728
DL: 2350 to 2360
DL: 462.5 to 467.5
DL: 1452 - 1496
1850 to 1910
35
2570 to 2620
1880 to 1920
38
39
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
3600 to 3800 Antenna
43
3550 to 3700
48
UL: 1710-1780
66
Characteristics
71
4.
DL: 1805 to 1880
5
29
4.
DL: 1930 to 1990
4
Characteristics
UL: 2305 to 2315
30
4.
DL: 2110 to 2170
UL: 1850 to 1910
Antenna
Characteristics
UL: 1710 to 1785
Characteristics2.
UL: 699 to 716
12
3.
Downlink
DL: 2110-2200
617 to 698
74/75/76
1427 to 1518
78
3300 to 3800
79
4400 to 5000
698-716
728-746
Antenna Radiation
Patterns3.Antenna
85
Characteristics2.
SPE-16-8-023-C
Specifications
Covered
www.taoglas.com
4
Electrical
LTE 700
Frequency (MHz)
GSM 850
GSM 900
DCS
PCS
UMTS1
Wi-Fi
LTE 2600
1850
~1990
1920
~2170
2400
~2480
2490
~2690
698~ 803
824~ 894
880~ 960
1710
~1880
Max Return Loss (dB)
-9
-8
-7
-9
-17
-13
-13
-12
Max VSWR
2.5
2.5
3
2.5
1.5
1.5
1.5
2
Efficiency (%)
45
45
45
60
65
65
65
55
Peak Gain (dBi)
2
2
2
2
2.5
2.5
3
2
Average Gain (dB)
-3.5
-3.5
-3.5
-2.2
-2
-2
-2
-2.6
Radiation Properties
Omni-directional
Max Input Power (Watts)
5
Polarization
Linear
Impedance (Ohms)
50 Ohms
Mechanical
Dimensions (mm)
67x58x0.2 mm
Material
Flexible Polymer
Connector
IPEX MHFI
Cable
180mm 1.37
Environmental
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 85°C
Relative Humidity
40% to 95%
RoHS Compliant
Yes
SPE-16-8-023-C
www.taoglas.com
5
3.
4.
Antenna Radiation Patterns3.Antenna
3.1
Return Loss
Characteristics
4.
Return Loss [dB]
4.
-10
Antenna
-15
Characteristics
-20
Straight Cable
4.
-25
Antenna
Patterns3.
Antenna
600 Radiation
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
2800
3000
Frequency [MHz]
Characteristics
3.2
4.
Efficiency
100
Antenna
Radiation Patterns
90
80
4.
70
Antenna
Radiation Patterns
60
Efficiency [%]
4.
50
40
30
Antenna
Radiation Patterns
Straight Cable
Half Wrap Cable
10
4.
Antenna
Antenna
600 Radiation
750
900 1050Patterns3.
1200 1350 1500
1650 1800
Characteristics
4.
Full Wrap Cable
SPE-16-8-023-C
1950
2100
2250
2400
2550
2700
Frequency [MHz]
www.taoglas.com
6
3.3
Average Gain
-2
Aver Gain [dB]
-3
-4
-5
-6
-7
Straight Cable
-8
Half Wrap Cable
-9
Full Wrap Cable
-10
600
750
900
1050
1200
1350
1500
1650
1800
1950
2100
2250
2400
2550
2700
Frequency [MHz]
Gain [dBi]
3.4
Peak Gain
6
5
4
3
2
1
-2
-3
-4
-5
-6
-7
-8
-9
-10
-11
-12
Straight Cable
Half Wrap Cable
Full Wrap Cable
600
750
900
1050
1200
1350
1500
1650
1800
1950
2100
2250
2400
2550
2700
Frequency [MHz]
SPE-16-8-023-C
www.taoglas.com
7
3.5
VSWR
10
Straight Cable
9
8
VSWR
7
6
5
4
3
2
1
600
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
2800
3000
Frequency [MHz]
SPE-16-8-023-C
www.taoglas.com
8
Test Setup (Chamber)
4.4.1 Radiation
Patterns
4.
4.1
Test Set-Up
4.
4.
4.
4.
4.
Chamber Set-Up
Antenna
Radiation Patterns
4.
SPE-16-8-023-C
VNA Set-Up
www.taoglas.com
9
4.2
2D And 3D Radiation Patterns
700 MHz
XY Plane
SPE-16-8-023-C
XZ Plane
YZ Plane
www.taoglas.com
10
850 MHz
XY Plane
SPE-16-8-023-C
XZ Plane
YZ Plane
www.taoglas.com
11
950 MHz
XY Plane
SPE-16-8-023-C
XZ Plane
YZ Plane
www.taoglas.com
12
1750 MHz
XY Plane
SPE-16-8-023-C
XZ Plane
YZ Plane
www.taoglas.com
13
1850 MHz
XY Plane
SPE-16-8-023-C
XZ Plane
YZ Plane
www.taoglas.com
14
2000 MHz
XY Plane
SPE-16-8-023-C
XZ Plane
YZ Plane
www.taoglas.com
15
2150 MHz
XY Plane
SPE-16-8-023-C
XZ Plane
YZ Plane
www.taoglas.com
16
2600 MHz
XY Plane
SPE-16-8-023-C
XZ Plane
YZ Plane
www.taoglas.com
17
2750 MHz
XY Plane
SPE-16-8-023-C
XZ Plane
YZ Plane
www.taoglas.com
18
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-16-8-023-C
Mechanical Drawing
www.taoglas.com
19
6.
Packaging
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.SPE-16-8-023-C
www.taoglas.com
Application Note
6.Like allPackaging5.
Mechanical Drawing
flex antennas, the FXUB65 Minima antenna performance is somewhat sensitive to the routing of the
cable during integration. The preferred routing is a “full wrap” or “half wrap”, as shown below where the cable
is routed around the long side of the device. Routing over the lower part of the device as shown will also work
well. An integration where the cable runs straight off will work, but the performance in the 900MHz band may
not be optimal. Avoid running the cable up along the short side or wrapping it around the short side, as these
will not work. If a longer cable is needed to wrap around the long side and still reach the module, this is ok, and
a longer cable can be easily built. Keep the antenna at least 20mm away from conductors in the end user
device.
6.
Packaging
can be integrated
into assemblies
over a small ground
plane such as a PCB. The efficiency in these
7.The FXUB65
Application
Note6.
Packaging5.
Mechanical
cases can sometimes be higher than the antenna alone.
Drawing
Preferred
Mechanical Drawing
6.
Packaging5.
6.
Packaging
7.
Preferred
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-16-8-023-C
Mechanical Drawing
www.taoglas.com
21
Avoid
SPE-16-8-023-C
www.taoglas.com
22
Changelog for the datasheet
SPE-16-8-023 – FXUB68.07.0180C
Revision: C (Current Version)
Date:
Changes:
Changes Made by:
15/02/21
Update to new datasheet template.
Gary West
Previous Revisions
Revision: B
Date:
Changes:
Changes Made by:
30/03/2017
Updated Spec with LTE table
Andy Mahoney
Revision: A (Original First Release)
Date:
Notes:
4/21/2016
Author:
Jack Conroy
SPE-16-8-023-C
www.taoglas.com
23
www.taoglas.com
SPE-16-8-023-C
© Taoglas 24
www.taoglas.com
很抱歉,暂时无法提供与“FXUB68.07.0180C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 7+115.51583
- 35+103.94508
- 国内价格
- 10+49.70611
- 55+42.48779
- 100+34.47145
- 国内价格 香港价格
- 7+124.258437+16.14770
- 35+111.8239035+14.53180
