ECHO2/0.1M/UFL/S/S/1
    SIRETTA
    Echo 2天线适用于需要敏感、紧凑嵌入式天线解决方案的应用,支持2G/GPRS、3G、WiFi + Bluetooth,并且独立于地平面,非常适合空间有限的应用。
ECHO2/0.1M/UFL/S/S/1 数据手册
Echo 2 2G/3G/4G/WiFi compact 1/4 wave dipole PCB Antenna Key Features • • • • Compact size Flexible connector and cable options Wide frequency range: 800MHz - 2.4GHz Ground plane independent General Description Additional Considerations The Echo 2 antenna is perfect for applications that require a sensitive compact embedded antenna solution. Already proven in many applications where space is at a premium, this antenna is ideal as it is ground plane independent and compact making it a popular choice where a small size combined with efficient performance is critical. • Easy selection makes antenna suitable for many modules • Operates on worldwide 2G / GPRS networks, 3G plus 4G LTE frequencies, WiFi + Bluetooth and can be used. Many small PCB antennas are a half dipole and where they really need a ground plane to be effective. The Echo 2 PCB antennas are based on an efficiently tuned, full dipole antenna element that can be used very effectively with a wide variety of RF & M2M modules operating on Cellular, 868 and 2.4GHz ISM band frequencies. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.4 Echo 2 2G/3G/4G/WiFi compact 1/4 wave dipole PCB Antenna Electrical Specifications Mechanical Specifications Operating Temperature: -30 - +65°C Dimensions: Storage Temperature: -35 - +75°C Cable: Impedance: Gain: VSWR: 50 Ohm 1.13mm Connector: IPEX/uFL 2dBi
ECHO2/0.1M/UFL/S/S/1 价格&库存
很抱歉,暂时无法提供与“ECHO2/0.1M/UFL/S/S/1”相匹配的价格&库存,您可以联系我们找货
  • 1+112.00082
  • 5+106.40859
库存:100
