CGGBP.25.4.A.02
CGGBP.25.4.A.02
    TAOGLASLIMITED
    CGGBP.25.4.A.02
CGGBP.25.4.A.02 数据手册
CGGBP.25.4.A.02 Part No: CGGBP.25.4.A.02 Description: Embedded 25mm GPS/GLONASS/Galileo/BeiDou Patch Antenna, 1561/1575/1602MHz Features: 25*25*4mm Ceramic patch High Gain (up to 3.5dBi) Excellent stability on the three GNSS systems Optimized radiation patterns Pin Mount RoHS and REACH Compliant SPE-14-8-071-E 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 9 5. Mechanical Drawing 11 6. Footprint 13 7. Packaging 14 Changelog 15 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-14-8-071-E www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction square embedded ceramic GPS/GLONASS/Galileo/BeiDou patch antenna's wide band of operation 1.This 25mm Introduction leads to excellent gain and radiation pattern stability on all four common commercial GNSS systems worldwide. Compared to using a smaller antenna, this will translate into the GNSS system having much higher location accuracy, improved reliability of lock in urban areas, better signal reception, with more satellites acquired and a quicker time to first fix. 1. Introduction The patch is mounted via pin and double-sided adhesive. This patch can be tuned subject to NRE and MOQ, for further information please contact your regional Taoglas customer support team. 1. Introduction 1. Introduction SPE-14-8-071-E www.taoglas.com 3 2. Specifications GNSS Frequency Bands Covered L1 L2 L5 L6 3.GPS/QZSS Antenna Characteristics2. Specifications 1575.42MHz 1227.6MHz 1176.45MHz 1278.75MHz GLONASS 3. □ □ □ L5R 1176.45MHz L3PT 1201.5MHz L2PT 1246MHz L1CR 1575.42MHz L1PT 1602MHz □ ■ ■ E4 1215MHz E3 1256MHz E6 1278.75MHz E2 1561MHz E1 1575.42MHz □ ■ ■ Antenna Characteristics □ □ Galileo 4. ■ E5a 1176.45MHz □ □ □ □ Antenna Radiation Patterns3. Antenna BeiDou B1 1561MHz Characteristics2. ■ Compass 3. SBAS E5b 1201.5MHz E5B(B2)/ E6(B3) 1268.56MHz B2 1207.14MHz B3 1268.52MHz Specifications □ □ E2(B1) 1561MHz □ ■ Antenna Characteristics2. Omnistar 1542.5MHz WAAS/EGN OS 1575.42MHz □ ■ Specifications 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. GNSS Bands and Constellations Antenna Radiation Patterns3.Antenna Characteristics2. SPE-14-8-071-E Specifications www.taoglas.com 4 GNSS Electrical Frequency (MHz) 1561 1575 1602 VSWR (max.) 2.5 2.2 2.1 Efficiency (%) 82.15 85.45 79.76 Peak Gain 4.96 4.99 5.48 Average Gain -0.85 -0.68 -0.38 Centre Frequency Impedance Mechanical Height 4 mm Planner Dimension 25 x 25 mm Casing Ceramic Pin Diameter 0.9 mm Pin Length 2.4 mm Environmental Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-14-8-071-E www.taoglas.com 5 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna 3.1 Return Loss Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 VSWR 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-14-8-071-E www.taoglas.com 6 3.3 Efficiency 3.4 Peak Gain SPE-14-8-071-E www.taoglas.com 7 3.5 Average Gain 3.6 Axial Ratio SPE-14-8-071-E www.taoglas.com 8 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-14-8-071-E Z www.taoglas.com 9 4.2 842MHz 3D and 2D Radiation Patterns XY Plane XZ Plane YZ Plane SPE-14-8-071-E www.taoglas.com 10 5. Mechanical Drawing (Units: mm) Patch Drawings Mechanical Drawing 6.5.1 Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-071-E Mechanical Drawing www.taoglas.com 11 5.2 Adhesive Thickness Red line shows the adhesive without Liner – thickness 0.08~0.1 mm 5.2 Groundplane Mechanical Drawing SPE-14-8-071-E www.taoglas.com 12 6. Footprint Dimensions 4.6.1 Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4.6.2 Antenna Patterns3. Patch onRadiation 70*70mm Ground Plane Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-14-8-071-E www.taoglas.com 13 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-071-E Mechanical Drawing www.taoglas.com 14 Changelog for the datasheet SPE-14-8-071 – CGGBP.25.4.A.02 Revision: E (Current Version) Date: Changes: Changes Made by: 2022-02-18 Updated Datasheet Template Updated Packaging Graphic Paul Doyle Previous Revisions Revision: C Date: Changes: Changes Made by: 2017-03-08 Packaging Details Updated Andy Mahoney Revision: B Date: Changes: Changes Made by: 2017-08-17 Packaging Details Updated Andy Mahoney Revision: A (Original First Release) Date: Notes: Author: SPE-14-8-071-E 2017-08-10 Your Name Here www.taoglas.com 15 www.taoglas.com © Taoglas SPE-14-8-071-E www.taoglas.com 16
CGGBP.25.4.A.02 价格&库存
很抱歉,暂时无法提供与“CGGBP.25.4.A.02”相匹配的价格&库存,您可以联系我们找货
CGGBP.25.4.A.02
    CGGBP.25.4.A.02
