Front
Back
Viking
PA.700.J
Specification
Part No.
PA.700.J
Product Name
Viking
Hexa-Band Cellular SMD Antenna
Feature
Designed for Japan LTE frequency bands
Covers all in one 2G/3G/4G applications
700~2600MHz
LTE / GSM / CDMA / DCS / PCS / WCDMA / UMTS
/ HSDPA / GPRS / EDGE
High efficiency wide-band antenna
Patent pending
SMT for precision mounting and labor saving
40*6*5mm
RoHS Compliant
SPE-12-8-017/D/EZ |
page 1 of 15
1. Introduction
This revolutionary patent pending PA.700J
is a 2G/3G/4G high efficiency SMD ceramic
antenna operating at 700MHz to 960MHz,
1400MHz to 2600MHz to cover all LTE
frequency bands applied in Japan.
It uses high grade ceramics to deliver
the highest efficiencies on all bands
on the shortest device ground-plane
lengths possible. The exceptional
wide-band response means it covers
all standardly used operation bands
around the globe.
4.
Rectangular shape
Easy to integrate. Other antenna
designs come in irregular shapes and
sizes making them hard to integrate.
9.
5.
SMD (On-Board)
Antenna saves on labor, cable and
connector costs, leads to higher
integration yield rates, and reduces
losses in transmission.
1.1 Key Advantages
1.
2.
3.
Highest efficiency in a small size,
i.e. 40mm*6mm*5mm.
A comparative metal, FR4, FPC,
whip, rod, helix antenna, would have
much more reduced efficiency in this
configuration for the same size due
to their different dielectric constants.
Very high efficiency antennas are
critical to 3G and 4G devices ability to
deliver the stated data-speed rates of
systems such as HSPA and LTE.
More resistant to detuning
compared to other
antenna integrations.
If tuning is required it can be tuned
for the device environment using a
matching circuit or other techniques.
There is no need for new tooling,
thereby saving money if
customization is required.
Highly reliable and robust
Its predecessor the PA.25 antenna
is used by the world’s leading auto
makers in extremely challenging
environments. The antenna meets all
temperature and mechanical specs
required (vibration, drop tests etc)
6.
It mounts directly on edge of
device main-board.
7.
Transmission losses are kept to
absolute minimum
Resulting in much improved over the
air (OTA) TRP (Total Radiated Power)
/ TIS (Total Isotropic Radiation) device
performance compared to similar
efficiency cable and connector
antenna solutions.
8.
Reductions in probability of
radiated spurious emissions
Compared to other antenna
technologies are observed when
using the PA.700J and strictly
following this application note layout
Achieves moderate to high gain in
both vertical and horizontal
polarization planes
This feature is very useful in certain
wireless communications where the
antenna orientation is not fixed and
the reflections or multipath signals
may be present from any plane.
In those cases the important
parameter to be considered is the
total field strength, which is the
vector sum of the signal from the
horizontal and vertical polarization
planes at any instant in time.
LTE Bands
(Japan)
Frequency
1
2100
1920~2170MHz
6
800
830~885MHz
8
900
880~960MHz
9
1700
1749~1880MHz
11
1500
1427~1496MHz
18
800
815~875MHz
19
800
832~889MHz
21
1500
1447~1510MHz
41
2500
2496~2690MHz
SPE-12-8-017/D/EZ |
page 2 of 15
2. Specification
Electrical
Antenna
PA700.J Viking
Standard
2G/3G/4G
Operation Frequency (MHz)
698~800MHz
824~960MHz
1410~1520MHz 1710~2170MHz 2400~2700MHz
Peak Gain
-3.6 dBi
-0.5 dBi
-1.0 dBi
0.5 dBi
2.7 dBi
Average Gain
-5.5 dB
-2.0 dB
-2.5 dB
-2.8 dB
-2.4 dB
Efficiency
30 %
63%
55 %
53%
57%
Return Loss [dB]
-5.0 dB
-14.0 dB
-7.0 dB
-7.0 dB
-7.5 dB
VSWR
很抱歉,暂时无法提供与“PA.700.J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+72.387641+9.27255
- 10+55.9934310+7.17252
- 25+51.9017725+6.64840
- 100+47.39983100+6.07172
- 国内价格 香港价格
- 450+44.14183450+5.65438
- 900+43.04560900+5.51396
- 1350+42.496421350+5.44361
