SPECIFICATION
Part No.
TG.10R.A.0113
Product Name
Triton 4G/3G/2G Terminal Antenna for Cellular
Modules with Assisted GPS Hinged SMA(M)
Feature
Dipole Terminal Antenna
Hinged SMA(M) Connector
Length 168mm, Φ13mm
AntD© Shunt 10k Ohm Chip Resistor Inside
RoHS compliant
SPE-13-8-076/C/AS
Page 1 of 16
1. Introduction
The TG.10R Triton Dipole Antenna with AntD© Resistor – is primarily designed for use
with CDMA modules with assisted GPS. It does not require a ground-plane to connect
to. It has a quality robust PUS housing for use with wireless terminals. The antenna
has a SMA(M) connector. It can be used straight or hinged 90 degrees. The antenna
has a wide-band response and can also be used for other cellular and wireless
applications such as GSM, LTE, UMTS, and WI-FI.
AntD© allows connected radio products using the latest cellular modules and
recommended circuits from Telit and uBlox to perform diagnostics on the antenna.
This includes detection that the proper antenna is connected and that the connection
isn’t shorted or broken. Contact Taoglas engineering for examples on how to
implement AntD© antenna diagnostics in your product.
SPE-13-8-076/C/AS
Page 2 of 16
2. Specification
ELECTRICAL
Frequency
700~800
824~960
1575.42
Straight
-0.5
-0.5
-0.5
1.0
2.0
1.5
3.0
Bend
-1.5
-3.0
1.5
2.5
2.5
2.5
4.0
Straight
38%
30%
40%
58%
65%
55%
75%
Bend
35%
25%
60%
69%
75%
70%
85%
(MHz)
1710 ~ 1880 1850 ~ 1990 1710 ~ 2170 2490~2600
Peak Gain (dBi)
Efficiency
Impedance
50 Ω
Integrated AntD© Resistor
Integrated Resistor
Shunt 10K Ohm (+/- 5%) to Ground
Polarization
Linear
Radio Pattern
Omni
Input Power
50 W
MECHANICAL
Dimensions
Length 168mm, Φ13mm
Connector
Hinged SMA Male
Casing
PU
ENVIRONMENTAL
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
SPE-13-8-076/C/AS
Page 3 of 16
LTE BANDS
Band Number
LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746 (LTE only)
18
UL: 815 to 830
DL: 860 to 875 (LET only)
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200 (LTE only)
24
UL:1625.5 to 1660.5
DL: 1525 to 1559 (LTE only)
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869 (LTE only)
28
UL: 703 to 748
DL: 758 to 803 (LTE only)
29
UL: -
DL: 717 to 728 (LTE only)
30
UL: 2305 to 2315
DL: 2350 to 2360 (LTE only)
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5 (LTE only)
32
UL: -
DL: 1452 - 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
Covered
*Covered bands represent an efficiency greater than 20%
SPE-13-8-076/C/AS
Page 4 of 16
3. Antenna Characteristics
3.1. Return Loss
3.2. Antenna Efficiency
SPE-13-8-076/C/AS
Page 5 of 16
3.3. Peak Gain
SPE-13-8-076/C/AS
Page 6 of 16
4. Antenna Radiation Patterns
4.1. Antenna setup
4.1.1. Straight
4.1.2. Bend
SPE-13-8-076/C/AS
Page 7 of 16
4.2. Radiation patterns
4.2.1. Straight (Cellular)
Figure 1. Radiation Pattern at 700 MHz
Figure 2. Radiation Pattern at 824 MHz
Figure 3. Radiation Pattern at 960 MHz
Figure 4. Radiation Pattern at 1700 MHz
Figure 5. Radiation Pattern at 1800 MHz
Figure 6. Radiation Pattern at 1910 MHz
SPE-13-8-076/C/AS
Page 8 of 16
Figure 7. Radiation Pattern at 2170 MHz.
4.2.2. Straight (GPS & Wi-Fi)
SPE-13-8-076/C/AS
Page 9 of 16
Figure 8. Radiation Pattern at 1575 MHz
Figure 9. Radiation Pattern at 2400 MHz
Figure 10. Radiation Pattern at 2460 MHz
Figure 11. Radiation Pattern at 2460 MHz
4.2.3. Bend (Cellular)
SPE-13-8-076/C/AS
Page 10 of 16
Figure 12. Radiation Pattern at 700 MHz
Figure 13. Radiation Pattern at 824 MHz
Figure 14. Radiation Pattern at 960 MHz
Figure 15. Radiation Pattern at 1700 MHz
Figure 16. Radiation Pattern at 1800 MHz
Figure 17. Radiation Pattern at 1900 MHz
SPE-13-8-076/C/AS
Page 11 of 16
Figure 18. Radiation Pattern at 2200 MHz
SPE-13-8-076/C/AS
Page 12 of 16
4.2.4. Bend (GPS & Wi-Fi)
Figure 19. Radiation Pattern at 1575 MHz
Figure 20. Radiation Pattern at 2400 MHz
Figure 21. Radiation Pattern at 2460 MHz
Figure 22. Radiation Pattern at 2500 MHz
SPE-13-8-076/C/AS
Page 13 of 16
5. Drawing
6. Packaging
SPE-13-8-076/C/AS
Page 14 of 16
SPE-13-8-076/C/AS
Page 15 of 16
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-13-8-076/C/AS
Page 16 of 16
很抱歉,暂时无法提供与“TG.10R.A.0113”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+52.83768
- 45+51.88249
- 85+50.84267
- 100+48.92020
- 国内价格
- 1+171.39600
- 200+68.38560
- 500+66.10680
- 1000+64.97280
- 国内价格 香港价格
- 1+114.326271+14.81886
- 10+89.8587210+11.64740
- 50+80.0542150+10.37655
- 100+77.01870100+9.98309
- 250+73.81336250+9.56762
- 500+71.88192500+9.31727
- 1000+70.291881000+9.11117
