EXR150BN
EXR150BN
    LAIRD(莱尔德)
    ANT TUF DUCK VHF 150-166MHZ BN
EXR150BN 数据手册
Part Number (P/N): EXR EXR450 EXR806 EXR821 EXR902 + Connector Two-Way Radio Antenna Features: Injection molded flexible right angle antenna ¼ wave antenna in VHF and UHF ½ wave antenna in trunking/cellular High durability, high efficiency Textured finish with adjustable 0-90º elbow Allows for 360º movement Available in various standard connectors An original ‘Tuf Duck’ antenna Specifications: All Centurion products are designed for maximum efficiency and are customizable and scalable to meet your frequency and application requirements. Frequency Range Polarization Nominal Impedance VSWR Power Rating Temperature Range Drop Test VHF UHF Trunking/ Cellular Vertical 50 ohms 1.5:1 max at resonance 50 watts -40°C to +85°C 1M The EXR model antenna is available in the following frequencies and connectors. Order by antenna model, frequency and connector. For example: EXR806TN. Length of each antenna will vary according to the connector chosen. Part Number EXR150 EXR450 EXR806 EXR821 EXR902 Frequency Band 150-160 MHz 450-470 MHz 806-869 MHz 824-896 MHz 902-960 MHz Connectors BN BN & TN BN & TN BN & TN BN & TN Average Length 7" – 8" 6.62" – 6.95" 9.25" – 9.5" 9.16" 8.85" – 9.03" Color Code Yellow Green EXR Specifications subject to change without notice. 3425 N.44th Street, LINCOLN, NE 68504 USA PHONE: 402.467.4491 • FAX: 402.467.4528 TECHNICAL SUPPORT: 888.454.6914 www.centurion.com • sales@centurion.com Copyright  2004 Centurion Wireless Technologies, Inc. All Rights Reserved EXR 4 – 9/5/03
EXR150BN 价格&库存
很抱歉,暂时无法提供与“EXR150BN”相匹配的价格&库存,您可以联系我们找货
