SM0402RC
SM0402RC
    BIVAR
    发光二极管/LED 红色 0402 631nm 90mcd
SM0402RC 数据手册
      Industry Standard 0402 Package RoHS Compliant Small Package and Footprint Water Clear Lens Wide Viewing Angle Ideal for Status Indication, Display, and Backlighting Bivar Surface Mount 0402 package LED can be used in nearly any lighting or indication application. It's ultra-miniature packaging makes it ideal for smaller handheld devices, small back panel displays, and any other size constraint applications. Low power consumption and excellent long life reliability makes it excellent for battery powered equipment and applications. Bivar offers water clear LED lens for maximum luminous intensity. The SM0402 LED is packaged in standard tape and reels for pick and place assemblers. Part Number Material Emitted Color Peak Wavelength λp (nm) TYP. Lens Appearance Luminous Intensity (mcd) TYP. Viewing Angle SM0402RC AlGaInP RED 645 Water Clear 90 130° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.006" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/20 Page 1 of 5 Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 78 mW Continuous Forward Current 30 mA Peak Forward Current 1 100 mA Reverse Voltage 5V Derating Linear From 25°C 0.4 mA/°C Electrostatic Discharge (HBM) 2000 V Operating Temperature Range -30 ~ +80°C Storage Temperature Range -40 ~ +85°C Lead Soldering Temperature 2 260°C Notes: 1. ≤ 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Forward Voltage (V) Part Number Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX SM0402RC / 2.1 2.6 / 20 Reverse Current (μA) Viewing Angle 2Ө½ (deg) Dominant Wavelength (nm) Luminous Intensity Iv (mcd) MAX MIN TYP MAX MIN TYP MAX TYP 10 / 631 / 57 90 / 130 / Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/20 Page 2 of 5 Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/20 Page 3 of 5 Recommended Soldering Conditions Tape and Reel Dimensions Note: 5000 pcs / Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/20 Page 4 of 5 Packaging and Labeling Plan Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance unless otherwise noted: X.XXX ± 0.010" X.X ± 0.1” Note: 1 Reel / Bag Vacuum and Heat Sealed ESD/MBB Bag Internal Quality Control Label Humidity Indicator Card Desiccant Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/20 Page 5 of 5
SM0402RC 价格&库存
很抱歉,暂时无法提供与“SM0402RC”相匹配的价格&库存,您可以联系我们找货
SM0402RC
  • 5000+2.041335000+0.26203
  • 10000+1.9436810000+0.24950
  • 15000+1.8936415000+0.24307
  • 25000+1.8371825000+0.23583
  • 35000+1.8036135000+0.23152
库存:114866
SM0402RC
  • 1+6.003641+0.77064
  • 10+4.1694310+0.53520
  • 100+3.02308100+0.38805
  • 500+2.50961500+0.32214
  • 1000+2.341051000+0.30050
  • 2000+2.197892000+0.28213
库存:114866
SM0402RC
    SM0402RC
      • 25+3.16581
      • 1250+3.09708
      • 2500+3.02939
      库存:3400
      SM0402RC
      • 1250+3.09708
      • 2500+3.02939
      库存:3400
      SM0402RC
        SM0402RC
        • 1+4.33718
        • 10+3.69767
        • 55+2.09070
        • 150+1.97592
        • 2000+1.94312
        • 5000+1.91033
        库存:4197
