Industry Standard 0402 Package
RoHS Compliant
Small Package and Footprint
Water Clear Lens
Wide Viewing Angle
Ideal for Status Indication, Display, and Backlighting
Bivar Surface Mount 0402 package LED can be used in nearly any lighting or indication application.
It's ultra-miniature packaging makes it ideal for smaller handheld devices, small back panel displays,
and any other size constraint applications. Low power consumption and excellent long life reliability
makes it excellent for battery powered equipment and applications. Bivar offers water clear LED lens
for maximum luminous intensity. The SM0402 LED is packaged in standard tape and reels for pick and
place assemblers.
Part Number
Material
Emitted Color
Peak
Wavelength
λp (nm) TYP.
Lens
Appearance
Luminous
Intensity
(mcd) TYP.
Viewing Angle
SM0402BWC
InGaN
BLUE
468
Water Clear
100
130°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.006" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision B 06/20
Page 1 of 5
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
100 mW
Continuous Forward Current
25 mA
Peak Forward Current 1
100 mA
Reverse Voltage
5V
Derating Linear From 25°C
0.4 mA/°C
Electrostatic Discharge (HBM)
2000 V
Operating Temperature Range
-30 ~ +80°C
Storage Temperature Range
-40 ~ +85°C
Lead Soldering Temperature
2
260°C
Notes: 1. ≤ 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Forward
Voltage (V)
Part Number
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
SM0402BWC
3.1
4.0
Reverse
Current
(μA)
Viewing
Angle
2Ө½
(deg)
Dominant
Wavelength (nm)
Luminous
Intensity Iv (mcd)
MAX
MIN
TYP
MAX
MIN
TYP
MAX
TYP
10
470
72
100
130
Revision B 06/20
Page 2 of 5
Typical Electrical / Optical Characteristics
Revision B 06/20
Page 3 of 5
Recommended Soldering Conditions
Tape and Reel Dimensions
Note: 5000 pcs / Reel
2. Standard tolerance: ±0.010" unless otherwise noted.
Revision B 06/20
Page 4 of 5
Packaging and Labeling Plan
2. Standard tolerance unless otherwise noted: X.XXX ± 0.010"
X.X ± 0.1”
Note: 1 Reel / Bag
Vacuum and Heat Sealed
ESD/MBB Bag
Internal Quality Control Label
Humidity Indicator Card
Desiccant
Bivar Standard Packaging Label
Revision B 06/20
Page 5 of 5
很抱歉,暂时无法提供与“SM0402BWC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+1.762205000+0.22032
- 10000+1.6746610000+0.20937
- 15000+1.6309415000+0.20391
- 25000+1.5826125000+0.19786
- 35000+1.5544235000+0.19434
- 50000+1.5273550000+0.19096
- 国内价格
- 1250+2.61700
- 2500+2.56077
- 国内价格 香港价格
- 1+6.301681+0.78785
- 10+4.1544010+0.51940
- 25+1.8713525+0.23396
