4930
4930
    INSPIREDLED
    LEDPROSERIES21CW3PNLPK
4930 数据手册
Pro Series LED Panels Inspired LED’s Pro Series LED Panels are an ideal lowvoltage LED lighting solution for any application, from under cabinet task lights in the kitchen, to accent lighting on shelves or display cases. These rigid, low-profile panels are easily combined with Inspired LED accessories to create the perfect system for any home or business! Product Features:  Low cost modular design  Simple plug & play installation  Low energy consumption  Rated to last up to 100,000 hrs  UV and IR free  Dimmable with compatible systems Specifications:  CSA listed (C22.2 No. 250.0-08)  Input: 12V DC Class 2 Power (3.5 x 1.3mm jack) 265216  Power: 1.5W per 21 LED panel (3W per 42 LED panel)  Dimensions: 8.75”x 0.5” x 0.25” or 16.5” x 0.5” x 0.25”  Color Temp: Warm≈ 3000K, Pure≈ 4300K, or Cool≈ 6000K  Lumen/ft: Warm≈ 145 lm, Pure≈ 155 lm, Cool≈ 160 lm  CRI: 90 42 LED Panel 21 LED Panel In Line Switch and/or Dimmer Interconnect Cables Power Supply Instructions: 1. To install, secure Pro Series panels onto flat surface using adhesive backing, or screw mounts on each end 2. Make connections between panels using Inspired LED interconnect cables, plugged in from end to end 3. Connect cable from first panel in series to in line switch and/or dimmer, then connect to plug-in power supply or 4. Connect cable from first panel in series to hardwire transformer, then connect transformer to dimmable wall switch (see hardwire transformer specs for more detail) inspiredled.com orders@inspiredled.com (480) 941-4286
很抱歉,暂时无法提供与“4930”相匹配的价格&库存,您可以联系我们找货
