YETDA INDUSTRY LTD.
Technical Data Sheet
MODEL NO:5060BRG4
5060 Package 5.0*5.5mm Chip LEDs
Features:
● Compatible with automatic placement equipment
● Compatible with reflow solder process
● Using patent blue chip
Applications:
●Indicators
●Automotive:backlighting in dashboard and switch
●Backlight for LCD
Dice material
Emitted color
AlGaInP
Red
InGaN
Green
InGaN
Blue
Lens Color
Water Clear
Electrical/Optical Characteristics(Ta=25℃)
Parameter
Wavelength at peak emission
Spectral half bandwidth
Dominant wavelength
Forward voltage
Luminous intensity
Viewing angle at 50% Iv
Reverse current
Test
Condition
If=20mA
λpeak
If=20mA
△λ
If=20mA
λdom
If=20mA
Vf
If=20mA
Value
Symbol
Iv
Unit
Min
Typ
Max
R
640
G
525
B
470
R
G
40
B
25
R
625
630
635
G
520
525
530
B
460
465
470
R
2.0
2.5
G
3.1
3.8
B
3.1
3.8
R
250
G
880
B
180
nm
nm
nm
V
mcd
If=10mA
2θ1/2
120
Deg
Vr=5V
Ir
10
µA
1
YETDA INDUSTRY LTD.
Absolute Maximum Ratings(Ta=25℃)
Parameter
Symbol
Value
R
G
B
75
75
108
Unit
Power dissipation
Pd
Forward current
If
30
mA
Reverse voltage
Vr
5
V
Operating temperature range
Top
-40 ~+80
Storage temperature range
Tstg
-40 ~+85
Ifp
125
mA
Peak pulsing current (1/8 duty f=1kHz)
PACKAGING DIMENSIONS
2
mW
YETDA INDUSTRY LTD.
3
YETDA INDUSTRY LTD.
PACKAGING SPECIFICATIONS
z Dimensions of Reel (Unit: mm)
z Feeding Direction
z Dimensions of Tape (Unit: mm)
A
A
z Arrangement of Tape
NOTES
1. Empty component pockets are sealed with top cover tape;
2. The maximum number of missing lamps is two;
3. The polarity mark is oriented towards the tape sprocket hole ;
4. 3,000pcs/Reel.
4
SEC A-A
YETDA INDUSTRY LTD.
Packaging specifications
Drier
z
Drier
NOTES:
Reeled products (numbers of products are 3,000pcs) packed in a seal off moisture-proof bag
along with a desiccant one by one, Seven moisture-proof bag of maximums (total maximum number of
products are 21,000pcs) packed in an inside box (size: about 283mm x about 194mm x about 102mm)
and four inside boxes of maximums are put in the outside box (size: about 410mm x about 254mm x
about 229mm) Together with buffer material, and it is packed. (Part No., Lot No., quantity should
appear on the label on the moisture-proof bag, part No. And quantity should appear on the label on
the cardboard box.) The number of the loading steps of outside box (cardboard box) has it to three
steps.
5
YETDA INDUSTRY LTD.
● Descriptions:
z
z
The Chip-LED Taping is much smaller than lead frame type components, thus enable smaller
board size, higher packing density, reduced storage space and finally smaller equipment to be
obtained.
Besides, lightweight makes them ideal for miniature application, etc.
● Soldering heat reliability(DIP):
Please refer to the following figure:
Soldering heat 260 ℃ Max.
245 ±5 ℃ within 5 sec
Preheat
● Precautions For Use:
z
Over–current–proof
Customer must apply resistors for protection, otherwise slight voltage shift will cause big current
change (Burn out will happen)
z
1.
Storage
The operation of temperature and R.H. are:5℃∼30℃, 60%R.H. Max..
2.
Once the package is opened, the products should be used within a week. Otherwise, they should
be kept in a dampproof box with desiccating regent. Considering the tape life, we suggest our
customers to use our products within 1.5 year(from production date).
3.
It’s recommended to bake before soldering when the package is unsealed after 72 hrs. The
condition is : 60℃±5℃ for 15hrs.
6
YETDA INDUSTRY LTD.
● Test Circuit
R
LED
● Reflow Temp./Time:
Temp.
240℃ Max.
10sec Max.
5 ℃ /sec Max.
60~120sec
4℃ /sec Max.
Time
● Reliability Test Items And Conditions
The reliability of products shal be satisfied with items listed below.
No.
Items
Test Condition
Test
Hours/Cycles
Sample
Size
1
Solder Heat
TEMP:260℃±5℃
5 sec
48 pcs
2
Temperature Cycle
300Cycles
48 Pcs
3
Thermal Shick
100Cycles
48 Pcs
4
Operation Life
1000 Hrs
48 Pcs
5
High Temperature Storage
If=20mA
Temp:90℃
1000Hrs
48 Pcs
6
Low Temperature Storage
Temp:-30℃
1000Hrs
48 Pcs
7
High Temperature/High Humidity
80℃ / R.H80%
1000Hrs
48 Pcs
90℃~ 25℃~ -30℃ ~ 25℃
30m
5m 30m
100℃~ -55℃
10m
7
10m
5m
很抱歉,暂时无法提供与“COM-12022”相匹配的价格&库存,您可以联系我们找货
