CXM-6-30-80-36-AA02-F1-3
    LUMINUS(朗明纳斯)
    LEDCOBCXM6WARMWHITERECT
CXM-6-30-80-36-AA02-F1-3 数据手册
CXM-6 Product Datasheet CXM-6 COB Arrays White LED Features: • High lumen output and efficacy typical Table of Contents • Over 520 lm, 120 LPW @ 3000K, 25ºC Technology Overview. . . . . . 2 • Over 570 lm, 131 LPW @ 5000K, 25ºC Chromaticity Bins. . . . . . . . . . 3 • Complete CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K • 80 or 90 CRI min. up to 95 min. in warm white Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 • 2-step and 3-step MacAdam Ellipse color binning accuracy Product Typical Flux Range. 5 • Exceptional long term color stability Product Flux Bins. . . . . . . . . . . 6 • Superior thermal conductivity for uniform heat spreading Operating Characteristics. 11 • Excellent optical emission uniformity and color over angle consistency • Environmentally friendly: RoHS and REACh compliant • Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . 12 Spectra. . . . . . . . . . . . . . . . . . . 14 Mechanical Dimensions. . . 15 Packaging Information. . . . 15 Handling Notes. . . . . . . . . . . 16 Applications • Spotlights/Track Lights • Shop Lighting • Downlights • Hospitality Lighting • Replacement lamps • Architectural and Specialty 1 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet Technology Overview Luminus XNova™ Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. Reliability Designed from the ground up, the XNova™ COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, XNova™ COB LEDs are ready for the toughest challenges. UL Recognized Compliance XNova COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACh and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding XNova™ COB LED Test Specifications Every XNova™ LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each XNova COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature XNova™ COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 ANSI C78.377-2008 2-step Ellipse 3-step Ellipse 5-step Ellipse 0.44 2700K 3000K 3500K 0.42 Black Body 4000K CIE y 0.4 5000K 0.38 0.36 6500K 0.34 0.32 0.3 0.3 0.32 0.34 0.36 0.38 0.4 0.42 0.44 0.46 0.48 0.5 CIE x CXM-6 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. Center Point 5-step Bin 3-step Bin 2-step Bin Angle b CCT CIEx CIEy θ (°) a b a b a 2700K 0.4578 0.4101 53.7 0.0054 0.0028 0.0081 0.0042 0.0135 0.007 3000K 0.4338 0.403 53.2 0.00556 0.00272 0.00834 0.00408 0.0139 0.0068 3500K 0.4073 0.3917 54 0.00618 0.00276 0.00927 0.00414 0.01545 0.0069 4000K 0.3818 0.3797 53.7 0.00626 0.00268 0.00939 0.00402 0.01565 0.0067 5000K 0.3447 0.3553 59.6 0.00548 0.00236 0.00822 0.00354 0.0137 0.0059 6500K 0.3123 0.3282 58.57 0.00446 0.0019 0.00669 0.00285 0.01115 0.00475 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet Product Ordering and Shipping Part Number Nomenclature All CXM-6 products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. Luminus may include any smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM 6 NN Product Family Light Emitting Surface Diameter Color Temperature CXM: Chip on Board, XNova, Multi-die 6.3 : LES Diameter (mm) Color See Note 1 below CXM-6 XX 36 QQPP FFG W Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin CRI Volts AA00 (Basic package) Lumens See page 4 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Color Temperature, CRI and R9 Values Color Temperatures Note: XX Value CRI R9 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K 90 >90 >50 2700K, 3000K 95 >95 >90 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet CXM-6, 36V Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at 120mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Luminus may choose to ship a smaller chromaticity bin in an order for a larger. Output Flux (lm) CCT 2700K 3000K 3500K 4000K Reference Ordering Part Number Typ. Typ. (85ºC) Min. (85ºC) (calculated) 440 420 340 CRI (min.) 3-step MacAdam Ellipse 2-step MacAdam Ellipse 490 80 CXM-6-27-80-36-AA00-F2-3 CXM-6-27-80-36-AA00-F2-2 325 380 90 CXM-6-27-90-36-AA00-F2-3 CXM-6-27-90-36-AA00-F2-2 325 310 360 95 CXM-6-27-95-36-AA00-F2-3 CXM-6-27-95-36-AA00-F2-2 470 445 520 80 CXM-6-30-80-36-AA00-F2-3 CXM-6-30-80-36-AA00-F2-2 395 375 440 90 CXM-6-30-90-36-AA00-F2-3 CXM-6-30-90-36-AA00-F2-2 370 350 410 95 CXM-6-30-95-36-AA00-F2-3 CXM-6-30-95-36-AA00-F2-2 485 460 540 80 CXM-6-35-80-36-AA00-F2-3 CXM-6-35-80-36-AA00-F2-2 420 400 470 90 CXM-6-35-90-36-AA00-F2-3 CXM-6-35-90-36-AA00-F2-2 495 470 550 80 CXM-6-40-80-36-AA00-F2-3 CXM-6-40-80-36-AA00F2-2 430 410 480 90 CXM-6-40-90-36-AA00-F2-3 CXM-6-40-90-36-AA00F2-2 Reference Color Rendering Index Output Flux (lm) (25ºC) Part Number Typ. Typ. (85ºC) Min.. (85ºC) (calculated) 5000K 515 485 6500K 515 485 CCT Color Rendering Index CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 570 80 CXM-6-50-80-36-AA00-F2-5 CXM-6-50-80-36-AA00-F2-3 570 80 CXM-6-65-80-36-AA00-F2-5 CXM-6-65-80-36-AA00-F2-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet CXM-6, 36V Flux Bin Part Numbers The following tables describe the products with a maximum and minimum output flux measured at 120mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Color Rendering Index Ordering Part Number CRI (min.) 3-step MacAdam Ellipse 460 80 CXM-6-27-80-36-AA00-F1-3 310 355 90 CXM-6-27-90-36-AA00-F1-3 310 290 340 95 CXM-6-27-95-36-AA00-F1-3 445 425 490 80 CXM-6-30-80-36-AA00-F1-3 375 355 415 90 CXM-6-30-90-36-AA00-F1-3 350 335 390 95 CXM-6-30-95-36-AA00-F1-3 460 440 505 80 CXM-6-35-80-36-AA00-F1-3 400 380 440 90 CXM-6-35-90-36-AA00-F1-3 470 450 520 80 CXM-6-40-80-36-AA00-F1-3 410 390 450 90 CXM-6-40-90-36-AA00-F1-3 Output Flux (lm) Reference Color Rendering Index Part Number Max. (85ºC) Min.. (85ºC) (calculated) CRI (min.) 5-step MacAdam Ellipse 5000K 485 460 535 80 CXM-6-50-80-36-AA00-F1-5 6500K 485 460 535 80 CXM-6-65-80-36-AA00-F1-5 CCT 2700K 3000K 3500K 4000K CCT Output Flux (lm) Reference Max. (85ºC) Min.. (85ºC) (calculated) 420 400 325 Max. (25ºC) Max. (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 6 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet CXM-6, 18V Flux Bin Part Numbers The following tables describe products with typical flux and minimum flux measured at 240mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Luminus may choose to ship a smaller chromaticity bin in an order for a larger. Color Rendering Index Ordering Part Number CRI (min.) 3-step MacAdam Ellipse 490 80 CXM-6-27-80-18-AA00-F2-3 325 380 90 CXM-6-27-90-18-AA00-F2-3 325 310 360 95 CXM-6-27-95-18-AA00-F2-3 470 445 520 80 CXM-6-30-80-18-AA00-F2-3 395 375 440 90 CXM-6-30-90-18-AA00-F2-3 370 350 410 95 CXM-6-30-95-18-AA00-F2-3 485 460 540 80 CXM-6-35-80-18-AA00-F2-3 420 400 470 90 CXM-6-35-90-18-AA00-F2-3 495 470 550 80 CXM-6-40-80-18-AA00-F2-3 430 410 480 90 CXM-6-40-90-18-AA00-F2-3 Output Flux (lm) Reference Color Rendering Index Part Number Max. (85ºC) Min.. (85ºC) (calculated) CRI (min.) 5-step MacAdam Ellipse 5000K 515 485 570 80 CXM-6-50-80-18-AA00-F2-5 6500K 515 485 570 80 CXM-6-65-80-18-AA00-F2-5 CCT 2700K 3000K 3500K 4000K CCT Output Flux (lm) Reference Max. (85ºC) Min.. (85ºC) (calculated) 440 420 340 Max. (25ºC) Max. (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 7 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet CXM-6, 18V Flux Bin Part Numbers The following tables describe the products with a maximum and minimum output flux measured at 240mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Color Rendering Index Ordering Part Number CRI (min.) 3-step MacAdam Ellipse 460 80 CXM-6-27-80-18-AA00-F1-3 310 355 90 CXM-6-27-90-18-AA00-F1-3 310 290 340 95 CXM-6-27-95-18-AA00-F1-3 445 425 490 80 CXM-6-30-80-18-AA00-F1-3 375 355 415 90 CXM-6-30-90-18-AA00-F1-3 350 335 390 95 CXM-6-30-95-18-AA00-F1-3 460 440 505 80 CXM-6-35-80-18-AA00-F1-3 400 380 440 90 CXM-6-35-90-18-AA00-F1-3 470 450 520 80 CXM-6-40-80-18-AA00-F1-3 410 390 450 90 CXM-6-40-90-18-AA00-F1-3 Output Flux (lm) Reference Color Rendering Index Part Number Max. (85ºC) Min.. (85ºC) (calculated) CRI (min.) 5-step MacAdam Ellipse 5000K 485 460 535 80 CXM-6-50-80-18-AA00-F1-5 6500K 485 460 535 80 CXM-6-65-80-18-AA00-F1-5 CCT 2700K 3000K 3500K 4000K CCT Output Flux (lm) Reference Max. (85ºC) Min.. (85ºC) (calculated) 420 400 325 Max. (25ºC) Max. (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 8 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet CXM-6, 9V Flux Bin Part Numbers The following tables describe products with typical flux and minimum flux measured at 480mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Luminus may choose to ship a smaller chromaticity bin in an order for a larger. Color Rendering Index Ordering Part Number CRI (min.) 3-step MacAdam Ellipse 490 80 CXM-6-27-80-9-AA00-F2-3 325 380 90 CXM-6-27-90-9-AA00-F2-3 325 310 360 95 CXM-6-27-95-9-AA00-F2-3 470 445 520 80 CXM-6-30-80-9-AA00-F2-3 395 375 440 90 CXM-6-30-90-9-AA00-F2-3 370 350 410 95 CXM-6-30-95-9-AA00-F2-3 485 460 540 80 CXM-6-35-80-9-AA00-F2-3 420 400 470 90 CXM-6-35-90-9-AA00-F2-3 495 470 550 80 CXM-6-40-80-9-AA00-F2-3 430 410 480 90 CXM-6-40-90-9-AA00-F2-3 Output Flux (lm) Reference Color Rendering Index Part Number Max. (85ºC) Min.. (85ºC) (calculated) CRI (min.) 5-step MacAdam Ellipse 5000K 515 485 570 80 CXM-6-50-80-9-AA00-F2-5 6500K 515 485 570 80 CXM-6-65-80-9-AA00-F2-5 CCT 2700K 3000K 3500K 4000K CCT Output Flux (lm) Reference Max. (85ºC) Min.. (85ºC) (calculated) 440 420 340 Max. (25ºC) Max. (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 9 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet CXM-6, 9V Flux Bin Part Numbers The following tables describe the products with a maximum and minimum output flux measured at 480mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Color Rendering Index Ordering Part Number CRI (min.) 3-step MacAdam Ellipse 460 80 CXM-6-27-80-9-AA00-F1-3 310 355 90 CXM-6-27-90-9-AA00-F1-3 310 290 340 95 CXM-6-27-95-9-AA00-F1-3 445 425 490 80 CXM-6-30-80-9-AA00-F1-3 375 355 415 90 CXM-6-30-90-9-AA00-F1-3 350 335 390 95 CXM-6-30-95-9-AA00-F1-3 460 440 505 80 CXM-6-35-80-9-AA00-F1-3 400 380 440 90 CXM-6-35-90-9-AA00-F1-3 470 450 520 80 CXM-6-40-80-9-AA00-F1-3 410 390 450 90 CXM-6-40-90-9-AA00-F1-3 Output Flux (lm) Reference Color Rendering Index Part Number Max. (85ºC) Min.. (85ºC) (calculated) CRI (min.) 5-step MacAdam Ellipse 5000K 485 460 535 80 CXM-6-50-80-9-AA00-F1-5 6500K 485 460 535 80 CXM-6-65-80-9-AA00-F1-5 CCT 2700K 3000K 3500K 4000K CCT Output Flux (lm) Reference Max. (85ºC) Min.. (85ºC) (calculated) 420 400 325 Max. (25ºC) Max. (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 10 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet CXM-6 Operating Characteristics1 Electrical Characteristics Parameter - 36V Symbol 2 Forward Current If Forward Voltage3 Vf Parameter - 18V Symbol Forward Current2 If Forward Voltage Vf Symbol 3 Parameter - 9V Minimum Typical Maximum Unit 120 240 mA 33.5 35 37.5 V Minimum Typical Maximum Unit 240 480 mA 16.5 17.5 19 V Minimum Typical Maximum Unit 480 960 mA 2 Forward Current If Forward Voltage3 Vf 8.4 8.8 9.4 V Symbol Minimum Typical Maximum Unit 4.3 9 W 105 ºC Optical and Electrical Characteristics Parameter Power Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 6.3 mm Thermal Resistance (junction-to-case) Qjc 2.33 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. Note 4: CXM-6 COB LEDs are designed for operation up to an absolute maximum forward drive current as specified above. Refer to the current vs. case temperature derating curves for further information. Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 11 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-6 Product Datasheet CXM-6, 36V Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 300 200% 180% Forward Current (mA) Relative Luminous Flux 160% 140% 120% 100% 80% 60% 200 100 40% 20% 0 0% 50 75 100 125 150 175 200 225 32 250 32.5 33 33.5 34 34.5 35 35.5 36 36.5 37 Forward Voltage (V) Forward Current (mA) Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 120.0% 38 Forward Voltage (V) Relative Luminous Flux 100.0% 80.0% 60.0% 40.0% 36 34 20.0% 0.0% 32 5 15 25 35 45 55 65 75 85 95 105 5 15 25 Junction Temperature (ºC) 35 45 55 65 75 85 95 105 Junction Temperature (ºC) CXM-6, 18V Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 500 200.0% 180.0% Forward Current (mA) Relative Luminous Flux 160.0% 140.0% 120.0% 100.0% 80.0% 60.0% 40.0% 400 300 200 20.0% 100 0.0% 100 200 300 400 Forward Current (mA) 12 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 500 16 16.5 17 17.5 Forward Voltage (V) 18 18.5 CXM-6 Product Datasheet CXM-6, 18V Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 100.0% 18.5 Forward Voltage (V) 19 Relative Luminous Flux 120.0% 80.0% 60.0% 40.0% 18 17.5 17 16.5 20.0% 16 0.0% 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) CXM-6, 9V Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 200% 1000 180% 900 160% 800 Forward Current (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 140% 120% 100% 80% 60% 700 600 500 400 300 40% 200 20% 100 0% 200 300 400 500 600 700 800 900 8 1000 8.2 8.4 8.6 8.8 9 9.2 9.4 Forward Voltage (V) Forward Current (mA) Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 120% 9.5 Forward Voltage (V) Relative Luminous Flux 100% 80% 60% 40% 9 8.5 20% 0% 8 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 13 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CXM-6 Product Datasheet CXM-6 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 550 -20.00% 600 650 750 800 Wavelength (nm) Change in CIEx vs. Junction Temp. (3000K, 80CRI) Change in CIEy vs. Junction Temp. (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 700 0 0 -0.01 -0.01 -0.02 -0.02 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 14 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CXM-6 Product Datasheet Mechanical Dimensions Shipping Container Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 15 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover CXM-6 Product Datasheet Datasheet (Part #) Product Handling Notes for XNova COBs XNova products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging XNova COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. XNova COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility XNova COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with XNova COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the XNova products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the XNova COB products. Storage: XNova products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling XNova COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 16 PDS-002214 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Luminus Devices: CXM-6-27-80-36-AA00-F2-2 CXM-6-40-90-36-AA00-F2-2 CXM-6-35-90-36-AA00-F2-2 CXM-6-35-80-36-AA00-F1-3 CXM-6-30-90-36-AA00-F1-3 CXM-6-30-80-36-AA00-F1-3 CXM-6-27-80-36-AA00-F1-3 CXM-6-27-90-36-AA00-F2-2 CXM-6-30-80-36-AA00-F2-2 CXM-6-27-95-36-AA00-F2-2 CXM-6-50-80-36-AA00-F1-5 CXM-6-35-90-36-AA00-F1-3 CXM-6-40-90-36-AA00-F1-3 CXM-6-30-95-36-AA00-F2-2 CXM-6-27-95-36-AA00-F1-3 CXM-6-30-90-36-AA00-F2-2 CXM-6-40-80-36-AA00-F1-3 CXM-6-40-80-36-AA00-F2-2 CXM-6-35-80-36-AA00-F2-2 CXM-6-27-90-36-AA00-F1-3 CXM-6-30-95-36-AA00-F1-3 CXM-6-50-80-9-AA00-F2-3 CXM-6-35-80-9-AA00-F2-2 CXM-6-30-80-9-AA00-F2-2 CXM-6-65-80-9-AA00-F2-3 CXM-6-40-80-18-AA00-F1-3 CXM-6-30-95-18-AA00-F1-3 CXM-6-40-90-18-AA00-F1-3 CXM-6-27-80-9-AA00-F2-2 CXM-6-65-80-18-AA00-F2-3 CXM-6-50-80-18-AA00-F1-5 CXM-6-40-80-9-AA00-F2-2 CXM-6-30-95-9-AA00-F1-3 CXM-6-30-90-18-AA00-F2-2 CXM-6-30-80-18-AA00-F2-2 CXM-6-35-90-9-AA00-F1-3 CXM-6-30-90-9-AA00-F1-3 CXM-6-40-90-9-AA00-F1-3 CXM-6-27-95-9-AA00-F1-3 CXM-6-35-80-18-AA00-F2-2 CXM-6-27-80-18-AA00-F2-2 CXM-6-35-90-18-AA00-F2-2 CXM-6-27-90-18-AA00-F2-2 CXM-6-27-90-9-AA00-F1-3 CXM-6-65-80-18-AA00-F1-5 CXM-6-50-90-36-AA00-F2-5 CXM-6-50-90-36-AA00-F2-3 CXM-6-27-95-18-AA00-F1-3 CXM-6-30-95-18-AA00-F2-2 CXM-6-50-80-18-AA00-F2-3 CXM-6-65-80-9-AA00-F1-5 CXM-6-40-80-18-AA00-F2-2 CXM-6-40-90-18-AA00-F2-2 CXM-6-27-95-9-AA00-F2-2 CXM-6-35-80-18-AA00-F1-3 CXM-6-27-90-18-AA00-F1-3 CXM-6-27-80-18-AA00-F1-3 CXM-6-40-90-9-AA00-F2-2 CXM-6-35-90-18-AA00-F1-3 CXM-6-27-80-9-AA00-F1-3 CXM-6-65-80-36-AA00-F1-5 CXM-6-27-90-9-AA00-F2-2 CXM-6-40-80-9-AA00-F1-3 CXM-6-27-95-18-AA00-F2-2 CXM-6-35-90-9-AA00-F2-2 CXM-6-50-80-9-AA00-F1-5 CXM-6-30-90-9-AA00-F2-2 CXM-6-50-90-36-AA00-F1-5 CXM-6-30-95-9-AA00-F2-2 CXM-6-30-90-18-AA00-F1-3 CXM-6-30-80-9-AA00-F1-3 CXM-6-30-80-18-AA00-F1-3 CXM-6-35-80-9-AA00-F1-3 CXM-6-40-95-36-AA00-F1-3 CXM-6-50-90-18-AA00-F1-5 CXM-6-50-90-18-AA00-F2-3
CXM-6-30-80-36-AA02-F1-3 价格&库存
很抱歉,暂时无法提供与“CXM-6-30-80-36-AA02-F1-3”相匹配的价格&库存,您可以联系我们找货
