ZFS-105000-24RGB
ZFS-105000-24RGB
    JKLCOMPONENTS
    ZFS-105000-24RGB
ZFS-105000-24RGB 数据手册
10mm X 5000mm RGB LIGHT RIBBON FEATURES VOLTAGE: 24V DC CURRENT: 3.0A LED VIEWING ANGLE (2 0 1/2): 100° STANDARD PACKAGING: 5 METER REEL (300 LED'S) OPTIONAL PACKAGING: INDIVIDUAL 500mm SECTIONS (30 LED'S) ORDER AS ZFS-105000-24RGB/SEC Note: Individual Sections ARE NOT supplied with insulated wire connections. 5000mm (196.85") 8.4mm (.33") 100mm (3.94") + 24V B + 24V B + 24V B + 24V R R R R G G G G 16.8mm (.66") B 1.46mm REF. (.06") ADHESIVE TAPE FOR MOUNTING + Electrical/Optical Characteristics at TA = 25ºC Parameter Symbol Color Forward Voltage DC VF Dominant Wavelength λD Luminous Flux φV RGB R G B R G IF(rec) -- Recommend Forward Current Condition IF IF IF IF IF IF IF B = 3.0A = 1.0A = 1.0A = 1.0A = 1.0A = 1.0A = 1.0A -- Min Typ Max Unit -618 515 455 ---- 24 630 524 470 428 1508 143 -------- V -- 2.4 -- DC 24V G R B nm Im Mating Components A ZFS-CH0-RGB10J Flex to Flex No Solder Connector + + Absolute Maximum Rating at TA = 25ºC Parameter Symbol Absolute Maximum Rating Unit IF 3 A Forward Current Power Dissipation 10.0mm (.394") 0.53mm REF. (.02") PD 72 W Electrostatic Discharge ESD 400 V Operating Temperature Topr -20~+50 ºC Storage Temperature Tstg -30~+80 ºC 14.3mm (.56") 16.2mm (.64") ZCH-170-RGB-J Flex Ribbon Joiner Harness 14.4mm (.57") 15.8mm (.61") ATTENTION OBSERVE PRECAUTION FOR HANDLING ELECTROSTATIC DISCHARGE SENSITIVE DEVICES METRIC DIMENSIONS ARE IN mm (INCHES) TOLERANCE UNLESS OTHERWISE SPECIFIED B A REV. NO. CHANGE +24V GRB TO +24V BRG [4 PLCS] CHANGE MATING COMPONENT RELEASED DESCRIPTION/ECO NUMBER THIRD ANGLE PROJECTION 1 PL +/2 PL +/ANGLE +/- REF. REF. 6/5/18 DRAWN BY APPV'D BY DATE 3/29/16 L. WENGSTROM L.R. 6/5/18 3/15/16 APPV'D DATE JKL PART NO.: ZFS-105000-24RGB - CAD DRAWING - MANUAL REVISIONS NOT PERMITTED COMPONENTS CORPORATION TITLE 24 V RGB LED FLEX STRIP SIZE A SCALE FSCM NO. 55335 NONE DRAWING NO. ZFS-105000-24RGB RELEASED DATE 3/15/16 REVISION DATE 6/5/18 REV. NO. B SHEET 1 OF 1
ZFS-105000-24RGB 价格&库存
很抱歉,暂时无法提供与“ZFS-105000-24RGB”相匹配的价格&库存,您可以联系我们找货
