CXA1304-0000-000C0HC250G
    WOLFSPEED
    LED_13.4X13.4MM_SM
    LED Lighting COBs, Engines, Modules Chip On Board (COB) XLamp® CXA1304 White, Cool Square
CXA1304-0000-000C0HC250G 数据手册
Cree® XLamp® CXA1304 LED PRODUCT DESCRIPTION The XLamp® CXA1304 LED FEATURES array TABLE OF CONTENTS • Available in 4-step, 3‑step and 2-step Characteristics...............................................2 expands Cree’s family of high‑flux, EasyWhite bins at 2700 K, 3000 K, Operating Limits.............................................3 multi‑die arrays in a smaller, easy‑to‑use 3500 K, 4000 K & 5000 K CCT and Flux Characteristics, EasyWhite® Order platform. With XLamp LED lighting‑class 4-step EasyWhite bins at 5700 K & Codes and Bins - 9 V......................................5 reliability, 6500 K CCT Flux Characteristics, ANSI White Order the CXA1304’s small, uniform emitting surface enables both directional and non‑directional lighting applications including lamp retrofit and ® • Available in ANSI white bins at Flux Characteristics, EasyWhite® Order CCT Codes and Bins - 18 V....................................9 • Available in 70-, 80-, 90- and 3‑step and 4-step color consistency, and 93‑minimum CRI options CXA1304 brings new levels of flux and efficacy to this form factor. The CX Family LED Design Guide provides basic information on the requirements to use the CXA1304 LED successfully in luminaire designs. Codes and Bins - 9 V......................................8 4000 K, 5000 K, 5700 K & 6500 K luminaire designs. Available in 2-step, featuring a 6‑mm optical source, the • Forward voltage options: 9‑V class, 18‑V class & 36‑V class Flux Characteristics, ANSI White Order Codes and Bins - 18 V................................. 12 Flux Characteristics, EasyWhite® Order Codes and Bins - 36 V................................. 13 • 85 °C binning and characterization Flux Characteristics, ANSI White Order • Maximum drive current: 1000 mA Codes and Bins - 36 V................................. 16 (9 V), 500 mA (18 V), 250 mA (36 V) • 115° viewing angle, uniform chromaticity profile Relative Spectral Power Distribution......... 17 Electrical Characteristics............................ 17 Relative Luminous Flux............................... 19 • Top-side solder connections Typical Spatial Distribution......................... 22 • Thermocouple attach point Performance Groups - Brightness............. 22 • NEMA SSL-3 2011 standard flux Performance Groups - Chromaticity.......... 23 bins Cree EasyWhite® Bins Plotted on the • RoHS and REACh compliant 1931 CIE Color Space................................. 26 • UL recognized component Cree ANSI White Bins Plotted on the ® (E349212) CLD-DS73 REV 9B PRODUCT FAMILY DATA SHEET 1931 CIE Color Space................................. 26 WWW.CREE.COM/XLAMP Bin and Order Code Formats...................... 27 Mechanical Dimensions............................. 27 Thermal Design........................................... 28 Notes........................................................... 30 Packaging.................................................... 31 Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 XLAMP ® CXA1304 LED CHARACTERISTICS Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Unit degrees Minimum Typical Maximum 115 V 8000 DC forward current (9 V) mA 1000* DC forward current (18 V) mA 500* DC forward current (36 V) mA 250* Reverse current (9 V, 18V, 36 V) mA Forward voltage (9 V, 400 mA, 85 °C) V Forward voltage (9 V, 400 mA, 25 °C) V Forward voltage (18 V, 200 mA, 85 °C) V Forward voltage (18 V, 200 mA, 25 °C) V Forward voltage (36 V, 100 mA, 85 °C) V Forward voltage (36 V, 100 mA, 25 °C) V * 0.1 9 10.5 18 21 36 42 Refer to the Operating Limits section. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 2 XLAMP ® CXA1304 LED OPERATING LIMITS The maximum current rating of the CXA1304 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section on page 27 for the location of the Tc measurement point. Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree recommends a maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 28 for more information on LES temperature measurement. CXA1304-9V 1200 1000 If (mA) 800 9V 600 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) CXA1304-18V 600 500 If (mA) 400 18 V 300 200 100 0 0 25 50 75 100 125 150 Case Temperature (°C) Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 3 XLAMP ® CXA1304 LED OPERATING LIMITS - CONTINUED CXA1304-36V 300 250 If (mA) 200 36 V 150 100 50 0 0 25 50 75 100 125 150 Case Temperature (°C) Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 4 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000C00C465F B4 410 457 CXA1304-0000000C0HB465F C2 440 490 C4 475 527 CXA1304-0000000C0HC465F C2 440 490 CXA1304-0000000C00C257F C4 475 527 CXA1304-0000000C00C457F B4 410 457 CXA1304-0000000C0HB457F C2 440 490 C4 475 527 C2 440 490 C4 475 527 CXA1304-0000000C00C450H B4 410 457 CXA1304-0000000C0HB450H C2 440 490 C4 475 527 CXA1304-0000000C0HC450H CXA1304-0000000C0HC450G CXA1304-0000000C0HC450F A2 330 366 CXA1304-0000000C0UA250H CXA1304-0000000C0UA250G CXA1304-0000000C0UA250F A4 355 396 B2 380 423 Group Order Code Group Order Code Group CXA1304-0000000C00B465F 65F 6500 K 80 70 --- 80 70 80 65F 75 5700 K --- 57F 75 --- 57F 95 CXA1304-0000000C00C265F CXA1304-0000000C0HC265F CXA1304-0000000C0HC257F CXA1304-0000000C0HC457F 50H 50H 5000 K 90 Order Code 50H CXA1304-0000000C00C250H CXA1304-0000000C0HC250H CXA1304-0000000C0UA450H CXA1304-0000000C0UB250H 50F CXA1304-0000000C00C250F CXA1304-0000000C00C450F CXA1304-0000000C0HB450F 50G 50G CXA1304-0000000C0HC250G CXA1304-0000000C0UA450G CXA1304-0000000C0UB250G 50F 50F CXA1304-0000000C0HC250F CXA1304-0000000C0UA450F CXA1304-0000000C0UB250F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 5 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 3500 K 93 80 95 4-Step Group B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000C00C440H CXA1304-0000000C00C440F B4 410 457 CXA1304-0000000C0HB440H CXA1304-0000000C0HB440F C2 440 490 C4 475 527 CXA1304-0000000C0HC440H CXA1304-0000000C0HC440G CXA1304-0000000C0HC440F 94 290 327 CXA1304-0000000C0U9440H CXA1304-0000000C0U9440G CXA1304-0000000C0U9440F A2 330 366 A4 355 396 CXA1304-0000000C0UA440H B2 380 423 CXA1304-0000000C00B235H B4 410 457 C2 440 490 CXA1304-0000000C00C235H 94 290 327 CXA1304-0000000C0Y9435H A2 330 366 CXA1304-0000000C0YA235H B2 380 423 CXA1304-0000000C00B230H B4 410 457 C2 440 490 CXA1304-0000000C00C230H 92 250 281 CXA1304-0000000C0Y9230H 94 290 327 A2 330 366 Group Order Code Group Order Code Group CXA1304-0000000C00B440H 40H 40H 40H 35H 35H 30H 3000 K 93 3-Step Flux (lm) @ 25 °C* 95 --- 2-Step Flux (lm) @ 85 °C 30H CXA1304-0000000C00B440F CXA1304-0000000C00C240H CXA1304-0000000C0HC240H CXA1304-0000000C0UA240H CXA1304-0000000C00B435H CXA1304-0000000C00B430H CXA1304-0000000C0Y9430H CXA1304-0000000C0YA230H Order Code 40F 40G 40G CXA1304-0000000C0HC240G CXA1304-0000000C0UA240G 40F 40F CXA1304-0000000C0UA440G CXA1304-0000000C00C240F CXA1304-0000000C0HC240F CXA1304-0000000C0UA240F CXA1304-0000000C0UA440F CXA1304-0000000C00B235F 35G CXA1304-0000000C00B435G 35F CXA1304-0000000C00C235G 35G CXA1304-0000000C0YA235G CXA1304-0000000C00B435F CXA1304-0000000C00C235F 35F CXA1304-0000000C0Y9435F CXA1304-0000000C0YA235F CXA1304-0000000C00B230F 30G CXA1304-0000000C00B430G 30F CXA1304-0000000C00C230G CXA1304-0000000C00B430F CXA1304-0000000C00C230F CXA1304-0000000C0Y9230F 30G CXA1304-0000000C0Y9430G CXA1304-0000000C0YA230G 30F CXA1304-0000000C0Y9430F CXA1304-0000000C0YA230F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 6 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* A4 355 396 B2 380 423 B4 410 457 CXA1304-0000000C00B427H 84 220 248 CXA1304-0000000C0Y8427H 92 250 281 94 290 327 Group 95 Group Order Code 4-Step Group CXA1304-0000000C00A427H 27H 2700 K 93 Order Code 3-Step 27H CXA1304-0000000C00B227H CXA1304-0000000C0Y9227H CXA1304-0000000C0Y9427H Order Code CXA1304-0000000C00A427F 27G CXA1304-0000000C00B227G 27F CXA1304-0000000C00B427G CXA1304-0000000C00B227F CXA1304-0000000C00B427F CXA1304-0000000C0Y8427F 27G CXA1304-0000000C0Y9227G CXA1304-0000000C0Y9427G 27F CXA1304-0000000C0Y9227F CXA1304-0000000C0Y9427F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 7 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 9 V (IF = 400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000C00C40E1 B4 410 457 CXA1304-0000-000C0HB40E1 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000C0HC40E3 B4 410 457 CXA1304-0000-000C00B40E5 C2 440 490 C4 475 527 CXA1304-0000-000C00B40E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F CXA1304-0000-000C00C20E1 CXA1304-0000-000C0HC20E1 CXA1304-0000-000C0HC40E1 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000C00C20E2 CXA1304-0000-000C00C40E2 CXA1304-0000-000C0HB40E2 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000C0HC20E2 CXA1304-0000-000C0HC40E2 3A0, 3B0, 3C0, 3D0, 50F CXA1304-0000-000C00C20E3 CXA1304-0000-000C00C40E3 CXA1304-0000-000C0HB40E3 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C.0, 5D0, 40F CXA1304-0000-000C0HC20E3 CXA1304-0000-000C00C20E5 CXA1304-0000-000C00C40E5 Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 8 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000F00C465F B4 410 457 CXA1304-0000000F0HB465F C2 440 490 C4 475 527 CXA1304-0000000F0HC465F C2 440 490 CXA1304-0000000F00C257F C4 475 527 CXA1304-0000000F00C457F B4 410 457 CXA1304-0000000F0HB457F C2 440 490 C4 475 527 C2 440 490 C4 475 527 CXA1304-0000000F00C450H B4 410 457 CXA1304-0000000F0HB450H C2 440 490 C4 475 527 CXA1304-0000000F0HC450H CXA1304-0000000F0HC450G CXA1304-0000000F0HC450F A2 330 366 CXA1304-0000000F0UA250H CXA1304-0000000F0UA250G CXA1304-0000000F0UA250F A4 355 396 B2 380 423 Group Order Code Group Order Code Group CXA1304-0000000F00B465F 65F 6500 K 80 70 --- 80 70 80 65F 75 5700 K --- 57F 75 --- 57F 95 CXA1304-0000000F00C265F CXA1304-0000000F0HC265F CXA1304-0000000F0HC257F CXA1304-0000000F0HC457F 50H 50H 5000 K 90 Order Code 50H CXA1304-0000000F00C250H CXA1304-0000000F0HC250H CXA1304-0000000F0UA450H CXA1304-0000000F0UB250H 50F CXA1304-0000000F00C250F CXA1304-0000000F00C450F CXA1304-0000000F0HB450F 50G 50G CXA1304-0000000F0HC250G CXA1304-0000000F0UA450G CXA1304-0000000F0UB250G 50F 50F CXA1304-0000000F0HC250F CXA1304-0000000F0UA450F CXA1304-0000000F0UB250F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 9 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 3500 K 93 80 95 4-Step Group B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000F00C440H CXA1304-0000000F00C440F B4 410 457 CXA1304-0000000F0HB440H CXA1304-0000000F0HB440F C2 440 490 C4 475 527 CXA1304-0000000F0HC440H CXA1304-0000000F0HC440G CXA1304-0000000F0HC440F 94 290 327 CXA1304-0000000F0U9440H CXA1304-0000000F0U9440G CXA1304-0000000F0U9440F A2 330 366 A4 355 396 CXA1304-0000000F0UA440H B2 380 423 CXA1304-0000000F00B235H B4 410 457 C2 440 490 CXA1304-0000000F00C235H 94 290 327 CXA1304-0000000F0Y9435H A2 330 366 CXA1304-0000000F0YA235H B2 380 423 CXA1304-0000000F00B230H B4 410 457 C2 440 490 CXA1304-0000000F00C230H 92 250 281 CXA1304-0000000F0Y9230H 94 290 327 A2 330 366 Group Order Code Group Order Code Group CXA1304-0000000F00B440H 40H 40H 40H 35H 35H 30H 3000 K 93 3-Step Flux (lm) @ 25 °C* 95 --- 2-Step Flux (lm) @ 85 °C 30H CXA1304-0000000F00B440F CXA1304-0000000F00C240H CXA1304-0000000F0HC240H CXA1304-0000000F0UA240H CXA1304-0000000F00B435H CXA1304-0000000F00B430H CXA1304-0000000F0Y9430H CXA1304-0000000F0YA230H Order Code 40F 40G 40G CXA1304-0000000F0HC240G CXA1304-0000000F0UA240G 40F 40F CXA1304-0000000F0UA440G CXA1304-0000000F00C240F CXA1304-0000000F0HC240F CXA1304-0000000F0UA240F CXA1304-0000000F0UA440F CXA1304-0000000F00B235F 35G CXA1304-0000000F00B435G 35F CXA1304-0000000F00C235G 35G CXA1304-0000000F0YA235G CXA1304-0000000F00B435F CXA1304-0000000F00C235F 35F CXA1304-0000000F0Y9435F CXA1304-0000000F0YA235F CXA1304-0000000F00B230F 30G CXA1304-0000000F00B430G 30F CXA1304-0000000F00C230G CXA1304-0000000F00B430F CXA1304-0000000F00C230F CXA1304-0000000F0Y9230F 30G CXA1304-0000000F0Y9430G CXA1304-0000000F0YA230G 30F CXA1304-0000000F0Y9430F CXA1304-0000000F0YA230F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 10 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* A4 355 396 B2 380 423 B4 410 457 CXA1304-0000000F00B427H 84 220 248 CXA1304-0000000F0Y8427H 92 250 281 94 290 327 Group 95 Group Order Code 4-Step Group CXA1304-0000000F00A427H 27H 2700 K 93 Order Code 3-Step 27H CXA1304-0000000F00B227H CXA1304-0000000F0Y9227H CXA1304-0000000F0Y9427H Order Code CXA1304-0000000F00A427F 27G CXA1304-0000000F00B227G 27F CXA1304-0000000F00B427G CXA1304-0000000F00B227F CXA1304-0000000F00B427F CXA1304-0000000F0Y8427F 27G CXA1304-0000000F0Y9227G CXA1304-0000000F0Y9427G 27F CXA1304-0000000F0Y9227F CXA1304-0000000F0Y9427F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 11 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 18 V (IF = 200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000F00C40E1 B4 410 457 CXA1304-0000-000F0HB40E1 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000F0HC40E3 B4 410 457 CXA1304-0000-000F00B40E5 C2 440 490 C4 475 527 CXA1304-0000-000F00B40E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F CXA1304-0000-000F00C20E1 CXA1304-0000-000F0HC20E1 CXA1304-0000-000F0HC40E1 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000F00C20E2 CXA1304-0000-000F00C40E2 CXA1304-0000-000F0HB40E2 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000F0HC20E2 CXA1304-0000-000F0HC40E2 3A0, 3B0, 3C0, 3D0, 50F CXA1304-0000-000F00C20E3 CXA1304-0000-000F00C40E3 CXA1304-0000-000F0HB40E3 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C.0, 5D0, 40F CXA1304-0000-000F0HC20E3 CXA1304-0000-000F00C20E5 CXA1304-0000-000F00C40E5 Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 12 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 2-Step 3-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000N00C465F B4 410 457 CXA1304-0000000N0HB465F C2 440 490 C4 475 527 CXA1304-0000000N0HC465F C2 440 490 CXA1304-0000000N00C257F C4 475 527 CXA1304-0000000N00C457F B4 410 457 CXA1304-0000000N0HB457F C2 440 490 C4 475 527 C2 440 490 C4 475 527 CXA1304-0000000N00C450H B4 410 457 CXA1304-0000000N0HB450H C2 440 490 C4 475 527 CXA1304-0000000N0HC450H CXA1304-0000000N0HC450G CXA1304-0000000N0HC450F A2 330 366 CXA1304-0000000N0UA250H CXA1304-0000000N0UA250G CXA1304-0000000N0UA250F A4 355 396 B2 380 423 Group Order Code Group Order Code Group CXA1304-0000000N00B465F 65F 6500 K 80 70 --- 80 70 80 65F 75 5700 K --- 57F 75 --- 57F 95 CXA1304-0000000N00C265F CXA1304-0000000N0HC265F CXA1304-0000000N0HC257F CXA1304-0000000N0HC457F 50H 50H 5000 K 90 Order Code 50H CXA1304-0000000N00C250H CXA1304-0000000N0HC250H CXA1304-0000000N0UA450H CXA1304-0000000N0UB250H 50F CXA1304-0000000N00C250F CXA1304-0000000N00C450F CXA1304-0000000N0HB450F 50G 50G CXA1304-0000000N0HC250G CXA1304-0000000N0UA450G CXA1304-0000000N0UB250G 50F 50F CXA1304-0000000N0HC250F CXA1304-0000000N0UA450F CXA1304-0000000N0UB250F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 13 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 80 Minimum Luminous Flux Typ 75 --- 95 --- 3500 K 93 80 95 4-Step Group B4 410 457 C2 440 490 C4 475 527 CXA1304-0000000N00C440H CXA1304-0000000N00C440F B4 410 457 CXA1304-0000000N0HB440H CXA1304-0000000N0HB440F C2 440 490 C4 475 527 CXA1304-0000000N0HC440H CXA1304-0000000N0HC440G CXA1304-0000000N0HC440F 94 290 327 CXA1304-0000000N0U9440H CXA1304-0000000N0U9440G CXA1304-0000000N0U9440F A2 330 366 A4 355 396 CXA1304-0000000N0UA440H B2 380 423 CXA1304-0000000N00B235H B4 410 457 C2 440 490 CXA1304-0000000N00C235H 94 290 327 CXA1304-0000000N0Y9435H A2 330 366 CXA1304-0000000N0YA235H B2 380 423 CXA1304-0000000N00B230H B4 410 457 C2 440 490 CXA1304-0000000N00C230H 92 250 281 CXA1304-0000000N0Y9230H 94 290 327 A2 330 366 Group Order Code Group Order Code Group CXA1304-0000000N00B440H 40H 40H 40H 35H 35H 30H 3000 K 93 3-Step Flux (lm) @ 25 °C* 95 --- 2-Step Flux (lm) @ 85 °C 30H CXA1304-0000000N00B440F CXA1304-0000000N00C240H CXA1304-0000000N0HC240H CXA1304-0000000N0UA240H CXA1304-0000000N00B435H CXA1304-0000000N00B430H CXA1304-0000000N0Y9430H CXA1304-0000000N0YA230H Order Code 40F 40G 40G CXA1304-0000000N0HC240G CXA1304-0000000N0UA240G 40F 40F CXA1304-0000000N0UA440G CXA1304-0000000N00C240F CXA1304-0000000N0HC240F CXA1304-0000000N0UA240F CXA1304-0000000N0UA440F CXA1304-0000000N00B235F 35G CXA1304-0000000N00B435G 35F CXA1304-0000000N00C235G 35G CXA1304-0000000N0YA235G CXA1304-0000000N00B435F CXA1304-0000000N00C235F 35F CXA1304-0000000N0Y9435F CXA1304-0000000N0YA235F CXA1304-0000000N00B230F 30G CXA1304-0000000N00B430G 30F CXA1304-0000000N00C230G CXA1304-0000000N00B430F CXA1304-0000000N00C230F CXA1304-0000000N0Y9230F 30G CXA1304-0000000N0Y9430G CXA1304-0000000N0YA230G 30F CXA1304-0000000N0Y9430F CXA1304-0000000N0YA230F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 14 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) - CONTINUED Nominal CCT CRI Min 80 Minimum Luminous Flux Typ --- 2-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* A4 355 396 B2 380 423 B4 410 457 CXA1304-0000000N00B427H 84 220 248 CXA1304-0000000N0Y8427H 92 250 281 94 290 327 Group 95 Group Order Code 4-Step Group CXA1304-0000000N00A427H 27H 2700 K 93 Order Code 3-Step 27H CXA1304-0000000N00B227H CXA1304-0000000N0Y9227H CXA1304-0000000N0Y9427H Order Code CXA1304-0000000N00A427F 27G CXA1304-0000000N00B227G 27F CXA1304-0000000N00B427G CXA1304-0000000N00B227F CXA1304-0000000N00B427F CXA1304-0000000N0Y8427F 27G CXA1304-0000000N0Y9227G CXA1304-0000000N0Y9427G 27F CXA1304-0000000N0Y9227F CXA1304-0000000N0Y9427F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 15 XLAMP ® CXA1304 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - 36 V (IF = 100 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA1304 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 27). Nominal CCT CRI Min 70 Minimum Luminous Flux Typ 75 6500 K 80 70 --- 75 5700 K 80 70 --- 75 5000 K 80 4000 K 70 --- 75 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000N00C40E1 B4 410 457 CXA1304-0000-000N0HB40E1 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 C2 440 490 C4 475 527 B4 410 457 C2 440 490 C4 475 527 CXA1304-0000-000N0HC40E3 B4 410 457 CXA1304-0000-000N00B40E5 C2 440 490 C4 475 527 CXA1304-0000-000N00B40E1 1A0, 1B0, 1C0, 1D0, 65F 1A0, 1B0, 1C0, 1D0, 65F CXA1304-0000-000N00C20E1 CXA1304-0000-000N0HC20E1 CXA1304-0000-000N0HC40E1 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000N00C20E2 CXA1304-0000-000N00C40E2 CXA1304-0000-000N0HB40E2 2A0, 2B0, 2C0, 2D0, 57F CXA1304-0000-000N0HC20E2 CXA1304-0000-000N0HC40E2 3A0, 3B0, 3C0, 3D0, 50F CXA1304-0000-000N00C20E3 CXA1304-0000-000N00C40E3 CXA1304-0000-000N0HB40E3 3A0, 3B0, 3C0, 3D0, 50F 5A0, 5B0, 5C.0, 5D0, 40F CXA1304-0000-000N0HC20E3 CXA1304-0000-000N00C20E5 CXA1304-0000-000N00C40E5 Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 30). • Cree XLamp CXA1304 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 16 XLAMP ® CXA1304 LED Relative Spectral Power Distribution RELATIVE SPECTRAL POWER DISTRIBUTION The following graph is the result of a series of pulsed measurements at 400 mA for the 9-V CXA1304 LED, 200 mA for the 18-V CXA1304 LED and 100 mA for the 36-V CXA1304 LED and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000 K, 70 CRI 50% 4000 K, 70 CRI 40% 3000 K, 80 CRI 30% 3000 K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) ELECTRICAL CHARACTERISTICS The following graphs are the result of a series of steady-state measurements. 10.75 9V Voltage (V) 10.25 Tc = 25 °C 9.75 Tc = 55 °C Tc = 85 °C 9.25 Tc = 105 °C 8.75 8.25 200 300 400 500 600 700 800 900 1000 Current (mA) Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 17 XLAMP ® CXA1304 LED ELECTRICAL CHARACTERISTICS - CONTINUED 21.5 18 V Voltage (V) 20.5 Tc = 25 °C 19.5 Tc = 55 °C Tc = 85 °C 18.5 Tc = 105 °C 17.5 16.5 100 150 200 250 300 350 400 450 500 Current (mA) 43 36 V Voltage (V) 41 Tc = 25 °C 39 Tc = 55 °C Tc = 85 °C 37 Tc = 105 °C 35 33 50 75 100 125 150 175 200 225 250 Current (mA) Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 18 XLAMP ® CXA1304 LED RELATIVE LUMINOUS FLUX The relative luminous flux values provided below are the ratio of: • Measurements of CXA1304 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 400 mA at TJ = 85 °C for the 9-V CXA1304 LED. Using the 9-V CXA1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 700 mA, the relative luminous flux ratio is 160% in the chart below. A 9-V CXA1304 LED that measures 380 lm during binning will deliver 608 lm (380 * 1.6) at steady-state operation of Tc = 55 °C, IF = 700 mA. 240% Relative Luminous Flux 200% 9V 160% Tc = 25 °C Tc = 55 °C 120% Tc = 85 °C Tc = 105 °C 80% 40% 0% 200 300 400 500 600 700 800 900 1000 Current (mA) Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 19 XLAMP ® CXA1304 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXA1304 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 200 mA at TJ = 85 °C for the 18-V CXA1304 LED. Using the 18-V CXA1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 350 mA, the relative luminous flux ratio is 160% in the chart below. An 18-V CXA1304 LED that measures 380 lm during binning will deliver 608 lm (380 * 1.6) at steady-state operation of Tc = 55 °C, IF = 350 mA. 240% Relative Luminous Flux 200% 18 V 160% Tc = 25 °C Tc = 55 °C 120% Tc = 85 °C Tc = 105 °C 80% 40% 0% 100 150 200 250 300 350 400 450 500 Current (mA) Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 20 XLAMP ® CXA1304 LED RELATIVE LUMINOUS FLUX - CONTINUED The relative luminous flux values provided below are the ratio of: • Measurements of CXA1304 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 100 mA at TJ = 85 °C for the 36-V CXA1304 LED. Using the 36-V CXA1304 LED as an example, at steady-state operation of Tc = 55 °C, IF = 175 mA, the relative luminous flux ratio is 160% in the chart below. A 36-V CXA1304 LED that measures 380 lm during binning will deliver 608 lm (380 * 1.6) at steady-state operation of Tc = 55 °C, IF = 175 mA. 240% Relative Luminous Flux 200% 36 V 160% Tc = 25 °C Tc = 55 °C 120% Tc = 85 °C Tc = 105 °C 80% 40% 0% 50 75 100 125 150 175 200 225 250 Current (mA) Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 21 XLAMP ® CXA1304 LED TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) PERFORMANCE GROUPS - BRIGHTNESS (9 V, IF = 400 mA; 18 V, IF = 200 mA; 36 V, IF = 100 mA, TJ = 85 °C) XLamp CXA1304 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux 250 84 220 92 250 290 94 290 330 A2 330 355 A4 355 380 B2 380 410 B4 410 440 C2 440 475 510 C4 475 D2 510 550 D4 550 590 Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 22 XLAMP ® CXA1304 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) XLamp CXA1304 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 50H 40H 35H 30H 27H CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3784 0.3741 0.3804 0.3818 0.3867 0.3857 0.3844 0.3778 0.4030 0.3857 0.4061 0.3941 0.4132 0.3976 0.4099 0.3890 0.4291 0.3973 0.4333 0.4062 0.4395 0.4084 0.4351 0.3994 0.4528 0.4046 0.4578 0.4138 0.4638 0.4152 0.4586 0.4060 EasyWhite Color Temperatures – 3-Step Ellipse Major Axis Minor Axis x y a b Rotation Angle (°) 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 Bin Code CCT 50G Center Point Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 23 XLAMP ® CXA1304 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED EasyWhite Color Temperatures – 4-Step Code 65F 57F 50F 40F 35F 30F 27F CCT 6500 K 5700 K 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3097 0.3196 0.3079 0.3297 0.3164 0.3382 0.3176 0.3275 0.3253 0.3325 0.3249 0.3439 0.3331 0.3514 0.3330 0.3393 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 0.3484 0.3521 0.3744 0.3685 0.3782 0.3837 0.3912 0.3917 0.3863 0.3758 0.3981 0.3800 0.4040 0.3966 0.4186 0.4037 0.4116 0.3865 0.4242 0.3919 0.4322 0.4096 0.4449 0.4141 0.4359 0.3960 0.4475 0.3994 0.4573 0.4178 0.4695 0.4207 0.4589 0.4021 Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 24 XLAMP ® CXA1304 LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED ANSI White Bins Code Bin Code CCT 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3130 0.3144 0.3186 0.3068 0.3028 CCT y 0.3207 0.3215 0.3350 0.3290 0.3290 0.3417 0.3290 0.3300 0.3113 0.3222 0.3243 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3215 0.3350 0.3115 0.3391 0.3290 0.3538 0.3205 0.3481 0.3376 0.3616 0.3213 0.3373 0.3371 0.3490 0.3130 0.3290 0.3290 0.3417 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3290 0.3300 2A0 2B0 0E2 5700 K 2C0 2D0 0.3186 ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000 K 3C0 3D0 Bin Code x 0.3144 Code ANSI White Bins x y .3371 .3451 .3440 .3427 .3366 .3369 .3376 .3463 .3451 .3554 .3371 .3490 .3463 .3687 .3551 .3760 .3533 .3620 .3451 .3554 .3451 .3533 .3515 .3487 .3440 .3427 Code CCT Bin Code x y .3490 .3670 .3578 .3554 .3702 .3722 .3825 .3798 .3783 .3646 .3616 .3702 .3722 .3687 .3736 .3874 .3869 .3958 .3825 .3798 .3825 .3798 .3869 .3958 .4006 .4044 .3950 .3875 .3554 .3783 .3646 .3620 .3825 .3798 .3950 .3875 .3898 .3716 5A0 5B0 0E5 4000 K 5C0 5D0 Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 25 XLAMP ® CXA1304 LED CREE EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.44 2700 K ANSI C78.377 Quadrangle 0.43 3000 K EasyWhite 4-Step EasyWhite 3-Step 0.42 EasyWhite 2-Step 3500 K 0.41 4000 K 0.40 4500 K CCy 0.39 5000 K 0.38 0.37 5700 K 0.36 6500 K 0.35 0.34 0.33 0.32 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx CREE ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C) 0.41 4000 K ANSI C78.377 Quadrangle 0.40 4500 K 5C 0.39 5D 0.37 CCy 5B 5000 K 0.38 5700 K 0.36 5A 3C 3B 6500 K 0.35 2B 0.34 1C 1B 0.33 3D 2C 1D 3A 2D 2A 1A 0.32 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.31 CCx Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 26 XLAMP ® CXA1304 LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA13 Series = CXA13 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class C0 = 9-V class F0 = 18-V class N0 = 36-V class SSSSSCC-HHHH-HHHGGRNNNNN Internal code SSSSSCC-WWW-FF-GGR-AAAAA Kit code CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Y = 93 CRI minimum Vf class C0 = 9-V class F0 = 18-V class N0 = 36-V class Flux bin Performance class Performance class MECHANICAL DIMENSIONS Dimensions are in mm. Tolerances unless otherwise specified: ±.13 x° ± 1° Meaning of 1304X 1304F = 18‑V CXA1304 1304N = 36‑V CXA1304 1304X 1304C = 9‑V CXA1304 Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 27 XLAMP ® CXA1304 LED THERMAL DESIGN The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional verification of good thermal design. Please refer to page 2 for the Operating Limit specifications. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to the Thermal Management application note. For CXA soldering recommendations and information on thermal interface materials (TIM), LES temperature measurement, and connection methods, please refer to the Cree XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use Cree XLamp CXA LEDs successfully in luminaire designs. To keep the CXA1304 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following R_j-c R_j-c scale. Tc Tc As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim) R_tim graphs, depending on the operating environment. The y‑axis in each graph is a base 10 logarithmic R_c-a plus the thermal resistance of the heat sink (R_hs). R_hs CXA1304-9V Ta Ta Maximum R_c-a 100.00 9V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 300 400 500 600 700 800 900 1000 Current (mA) Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 28 XLAMP ® CXA1304 LED CXA1304-18V THERMAL DESIGN - CONTINUED Maximum R_c-a 100.00 18 V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 100 150 200 250 300 350 400 450 500 Current (mA) CXA1304-36V Maximum R_c-a 100.00 36 V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 50 75 100 125 150 175 200 225 250 Current (mA) Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 29 XLAMP ® CXA1304 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Ecology section of the Cree website. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 30 XLAMP ® CXA1304 LED PACKAGING Cree CXA1304 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. Dimensions are in inches. REV 5.875 4 5 5.875 DESC. 6 NOTICE FIDENTIAL. THIS PLOT AND THE INFORMATION D WITHIN ARE THE PROPRIETARY AND TIAL INFORMATION OF CREE, INC. THIS PLOT NSENT E COPIED, REPRODUCED OR DISCLOSED TO ANY IZED PERSON WITHOUTTHE WRITTEN CONSENT C. REV CHK. DESC. Tolerances: ±.13 x° ±1° DATE BY CHK. 2 R.375 4 1 3 2 1 .562 .562 5.875 BY 3 R.375 5 DATE 5.875 R .375 .875 .875 R.375 5.875 .875 .875 5.875 .875 .38 .38 .58 PATENT LABEL IS LOCATED WITH CREE ON LABEL UNDERSIDE OF CARTON BIN CODE, QTY, LOT# SECTION C-C TH CREE BIN .875LABEL PATENT OF NOT ANTITY, LOTIS# LOCATED ON UNDERSIDEDO SECTION C-C SCALE CARTON DWG. THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION BAG AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED. THIS DOCUMENT AND THE INFORMATION IT CONTAINS DWG.TITLE MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL OF TEK PAK, INCORPORATED. THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION .38 .875ALONG WITH THE PRODUCT OR PRODUCTS AND REMAINS REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED. THIS DOCUMENT AND THE INFORMATION IT CONTAINS DWG.TITLE MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL OF TEK PAK, INCORPORATED. .38 PART DRAWING PART DRAWING BAG UNLESS OTHERWISE NOTED ALL DATE: DR. BY: CHK. BY: 1.000 ARE AS FOLLOWS: DATE: DO NOT 4-3-13 TOLERANCES SIZE SCALE: DR. BY: SCALE DWG. KJS 022490-00 UNLESS OTHERWISE NOTED ALL TOLERANCES ARE AS FOLLOWS: FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm DRAFT ±1° X.XXX" ±.005 X.XXmm ±.10mm B FRACT ±1/64 X.X" DWG. ±.030 NO. X.0mm ±.75mm ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm DRAFT ±1° X.XXX" ±.005 X.XXmm ±.10mm CHK. BY: SHEET 2 OF 2 4-3-13 KJS SIZE B SCALE: 1.000 DWG. NO. 022490-00 SHEET 2 OF 2 L IS LOCATED IDE OF COVER LABEL WITH CREE BIN CODE, QTY, LOT# LABEL WITH CREE BIN CODE, QUANTITY, LOT # LABEL WITH CREE BIN CODE, QUANTITY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS & BEFORE FINISH. TOLERANCE UNLESS SPECIFIED: LABEL WITH CREE BIN CODE, QTY, LOT# .X ± .XX ± .XXX ± X° ± THIRD ANGLE PROJECTION WITH CREE BIN 6 QUANTITY, LOT # 0.1 .05 .005 1° FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX DRAWN ± .010 BY X° ± 2° UNLESS OTHERWISE SPECIFIED 5 4 Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without Inc. UL® and the UR logo are registered trademarks of UL LLC. THIRD ANGLE PROJECTION DIMENSIONS ARE IN 3 MILLIMETERS & BEFORE FINISH. ® notice. Cree , the Cree logo, TOLERANCE UNLESS SPECIFIED: .X ± .XX ± .XXX ± X° ± 0.1 .05 .005 1 ° FOR SHEET METAL PARTS ONLY .X ± .06 DRAWN BY DATE CHECK DATE APPROVED DATE 4600 Silicon Dri Durham, N.C 27 Phone (919) 361 Fax (919) 313-5 TITLE CXA15XX_DATASHEET MATERIAL SIZE FINAL PROTECTIVE FINISH DATE CHECK DATE APPROVED DATE SCALE C DRAWING NO. CXA15XX_DATASHEET_BAG2013 0.500 2 XLamp® and EasyWhite® are registered trademarks of Cree, SHEET Phone (919) 361-4770 Fax (919) 313-5303 TITLE CXA15XX_DATASHEET 31 MATERIAL SIZE FINAL PROTECTIVE FINISH OF 4600 Silicon Drive 1 27703 Durham, N.C DRAWING NO. CXA15XX_DATASHEET_BAG2013
CXA1304-0000-000C0HC250G 价格&库存
很抱歉,暂时无法提供与“CXA1304-0000-000C0HC250G”相匹配的价格&库存,您可以联系我们找货
