CLM-9-30-80-36-AC02-F2-3
    LUMINUS(朗明纳斯)
    SMD
CLM-9-30-80-36-AC02-F2-3 数据手册
Sensus™ LED Series Product Datasheet Sensus™ LED Series Pure White Targeted COB Arrays Below the Black Body Locus (BBL) Data Sheet Features: • Matching the human perception of “Pure white” light Table of Contents Technology Overview. . . . . . 2 Test Specifications . . . . . . . . . 2 • Designed to provide the look and feel of ceramic metal halide lights • Wide product range from 300lm to over 7,500lm • 3000K and 3500K, 80 CRI and 90 CRI • 3 SDCM color binning accuracy Chromaticity Bins. . . . . . . . . . 3 • Excellent optical uniformity and color over angle consistency Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 • Exceptional long term color stability Product Typical Flux Range. 5 • Environmentally friendly: RoHS and REACh compliant Operating Characteristics . . 7 • Superior thermal conductivity for uniform heat spreading • UL Recognized, File # E465703 Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . 12 Spectra. . . . . . . . . . . . . . . . . . . 19 Mechanical Dimensions. . . 20 Packaging Information. . . . 20 Handling Notes. . . . . . . . . . . 28 Applications • Retail Shop Lighting • Halogen replacement LED lamps • Spotlights/Track Lights • Hospitality Lighting • CMH replacement LED lamps • Architectural and Specialty 1 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus LED™ Series Product Datasheet Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The Sensus LED series has been specially design for retail shop ligthing where enhanced red coloring is a preferred lighting standard. The selection covers a wide lumen range from less than 300lm to over 3,000lm, and is focused on the major market color and CRI of 3000K and 80 CRI. These innovative breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM-80 test data and TM-21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACh and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve ANSI ANSI C78.377-2008 C78.377-2008 3-SDCM 3-SDCM 2-SDCM 0.45 0.4500 3000K 0.43 0.4300 3500K 0.41 0.4100 CIEy CIEy Black Body Locus 0.39 0.3900 0.37 0.3700 0.35 0.3500 0.33 0.3300 0.37 0.3700 0.38 0.3800 0.39 0.3900 0.4 0.4000 0.41 0.4100 0.42 0.4200 CIEx 0.43 0.4300 0.44 0.4400 0.45 0.4500 0.46 0.4600 0.47 0.4700 Sensus™ LED White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. Center Point *Note: 3-step Bin CCT CIEx CIEy θ (°) a b 3000K 0.4285 0.3933 53.1 0.00834 0.00408 3500K 0.4067 0.3845 54 0.00927 0.00414 Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Product Ordering and Shipping Part Number Nomenclature All Sensus LED products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM XX CT Sensus™ LED Series XX 36 Color Color RenderLight Emitting Surface Diameter1 Temperature2 ing Index (CRI)3 Product Family XX: LES Diameter (mm) Approximate CXM: Chip on Board 30 CRI QQPP FG W Voltage (typical) Package Configurator Flux Bin Chromaticity Bin Volts AA02 (Basic package) Lumens See page 3 for bins Note 1 : XX nomenclature corresponds to the following: 6 = 6.3mm 7 = 7.5mm 9 = 9mm 11 = 10.9mm 14 = 13.5mm 18 = 17.5mm 22 = 22mm Note 2: CT Nomenclature corresponds to the following 30 is 3000K 35 is 3500K Note 3: XX Color Rendering nomenclature corresponds to the following 80 = 80 CRI 90 = 90 CRI Note 4: AA02 is a standard package configurator AC02 is an alternative substrate size Color Temperature, CRI and R9 Values Color Temperatures 3000K, 3500K Note: XX Value CRI R9 80 >80 >0 90 >90 >50 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Sensus™ LED Series Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All products are measured and specified at 85ºC junction temperature. Output Flux (lm) Typ. (85ºC) Ordering Part Number Typ. Min. (85ºC) (calculated) (25ºC) CRI Typ. Current (mA) 3-step MacAdam Ellipse 445 420 495 3000K 80 120 CXM-6-30-80-36-AA02-F2-3 585 555 645 3000K 80 160 CHM-6-30-80-36-AA02-F2-3 615 585 685 3000K 80 160 CXM-7-30-80-36-AA02-F2-3 525 495 580 3000K 90 160 CXM-7-30-90-36-AA02-F2-3 625 590 695 3000K 80 160 930 885 1,025 3000K 910 1,065 3500K 780 750 870 3000K 785 910 3500K 1,310 1,245 1,455 3000K 1,280 1,501 3500K 1,110 1,050 1,230 3000K 1,100 1,285 3500K 1,865 1,770 2,050 3000K 240 1,472 1,745 3000K 360 CHM-9-35-80-36-AC02-F2-3 360 CHM-9-30-90-36-AA02-F2-3 CHM-9-35-90-36-AC02-F2-3 CHM-9-35-90-36-AA02-F2-3 CXM-11-30-80-36-AC02-F2-3 80 90 Luminus maintains a +/- 2% tolerance on CRI measurements. © 2016 Luminus Devices, Inc. - All Rights Reserved CHM-9-30-80-36-AA02-F2-3 CHM-9-30-90-36-AC02-F2-3 Luminus maintains a +/- 6% tolerance on flux measurements. PDS-002349 Rev 10 CXM-9-35-90-36-AC02-F2-3 CHM-9-35-80-36-AA02-F2-3 *Note: 5 CXM-9-30-90-36-AA02-F2-3 CHM-9-30-80-36-AC02-F2-3 480 1,580 CXM-9-35-80-36-AC02-F2-3 CXM-9-35-90-36-AA02-F2-3 90 1,160 CXM-9-30-80-36-AA02-F2-3 CXM-9-30-90-36-AC02-F2-3 80 1,350 240 CXM-9-35-80-36-AA02-F2-3 90 825 CLM-9-30-80-36-AA02-F2-3 CXM-9-30-80-36-AC02-F2-3 80 960 CLM-9-30-80-36-AC02-F2-3 CXM-11-30-80-36-AB02-F2-3 CXM-11-30-90-36-AC02-F2-3 CXM-11-30-90-36-AB02-F2-3 Sensus™ LED Series Product Datasheet Sensus™ LED Series Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Luminus may choose to ship a smaller chromatiticy bin in an order for a larger. Output Flux (lm) Ordering Part Number Typ. Typ. (85ºC) 1,930 Min. (85ºC) (calculated) (25ºC) 1,830 2,135 CCT CRI 1,985 1,885 1,105 3500K 1,635 1,550 1,810 3000K 1,625 1,900 3500K 2,660 2,525 2,925 3000K 2,615 3,030 3500K 2,265 2,150 2,495 3000K 2,580 3,210 3,050 3,565 2,735 2,600 3,030 5,130 4,870 5,700 4,360 4,140 4,800 7,090 6,735 7,800 6,050 5,745 6,650 3000K 3000K 720 CHM-14-30-80-36-AA02-F2-3 CHM-14-35-80-36-AC02-F2-3 CHM-14-30-90-36-AC02-F2-3 720 CHM-14-30-90-36-AA02-F2-3 CHM-14-35-90-36-AC02-F2-3 CHM-14-35-90-36-AA02-F2-3 80 90 80 90 80 90 Luminus maintains a +/- 2% tolerance on CRI measurements. © 2016 Luminus Devices, Inc. - All Rights Reserved CXM-14-35-90-36-AC02-F2-3 CHM-14-35-80-36-AA02-F2-3 Luminus maintains a +/- 6% tolerance on flux measurements. 6 CXM-14-30-90-36-AA02-F2-3 CHM-14-30-80-36-AC02-F2-3 *Note: PDS-002349 Rev 10 480 3500K 3000K CXM-14-35-80-36-AC02-F2-3 CXM-14-35-90-36-AA02-F2-3 90 2,225 CXM-14-30-80-36-AA02-F2-3 CXM-14-30-90-36-AC02-F2-3 80 2,755 480 CXM-14-35-80-36-AA02-F2-3 90 1,710 3-step MacAdam Ellipse CXM-14-30-80-36-AC02-F2-3 3000K 80 2,345 Typ. Current (mA) 800 1,280 1,920 CXM-18-30-80-36-AA02-F2-3 CXM-18-30-90-36-AA02-F2-3 CXM-22-30-80-36-AC02-F2-3 CXM-22-30-90-36-AC02-F2-3 CHM-22-30-80-36-AC02-F2-3 CHM-22-30-90-36-AC02-F2-3 Sensus™ LED Series Product Datasheet CXM-6 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current (36V) If Forward Voltage3 Vf 2 Minimum 33.5 Power Typical Maximum Unit 120 355 mA 35 37.5 V 4.3 13 W 105 ºC Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 6.3 mm Thermal Resisitance (junction-to-case) Qjc 2.33 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CXM-7 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current (36V) If Forward Voltage3 Vf 2 Power Minimum 33.5 Typical Maximum Unit 160 360 mA 35 37.5 V 5.6 13.5 W 105 ºC Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 7.5 mm Thermal Resisitance (junction-to-case) Qjc 1.9 ºC/W Junction Temperature Tj Viewing Angle 120 7 PDS-002349 Rev 10 140 © 2016 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Series Product Datasheet CHM-6 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current (36V) If Forward Voltage3 Vf 2 Minimum 33.5 Power Typical Maximum Unit 160 360 mA 35 37.5 V 5.6 13.5 W 105 ºC Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 6.3 mm Thermal Resisitance (junction-to-case) Qjc 1.55 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CLM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Power Minimum 33.5 Typical Maximum Unit 160 360 mA 35 37.5 V 5.6 13.5 W 105 ºC Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 9.0 mm Thermal Resisitance (junction-to-case) Qjc 1.55 ºC/W Junction Temperature Tj Viewing Angle 120 8 PDS-002349 Rev 10 140 © 2016 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Series Product Datasheet CXM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum Typical Maximum Unit 240 550 mA 35 37.5 V 8.6 21 W 100 ºC 33.5 Power Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 9 mm Thermal Resisitance (junction-to-case) Qjc 1.51 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CHM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum Typical Maximum Unit 360 550 mA 35 37.5 V 12.6 21 W 105 ºC 32 Power Operating Case Temperature Tc Light Emitting Surface Diameter LES 9 mm Thermal Resisitance (junction-to-case) Qjc 0.85 ºC/W Junction Temperature Tj 4 140 Viewing Angle 120 ºC Degree CXM-11 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Power Operating Case Temperature4 Minimum 33.5 Typical Maximum Unit 480 960 mA 35 37.5 V 16.8 34 W 105 ºC Tc Light Emitting Surface Diameter LES 11 mm Thermal Resisitance (junction-to-case) Qjc N/A ºC/W Junction Temperature Tj Viewing Angle 120 9 PDS-002349 Rev 10 140 © 2016 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum Maximum Unit 480 1,090 mA 35 37.5 V 17.3 41 W 105 ºC 33.5 Power Operating Case Temperature Typical Tc Light Emitting Surface Diameter LES 13.5 mm Thermal Resisitance (junction-to-case) Qjc 0.87 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CHM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If 3 Forward Voltage Vf Minimum Maximum Unit 720 1,090 mA 35 37.5 V 25.2 41 W 105 ºC 32 Power Operating Case Temperature Typical Tc Light Emitting Surface Diameter LES 13.5 mm Thermal Resisitance (junction-to-case) Qjc 0.46 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CXM-18 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Power Operating Case Temperature Minimum 33.5 Typical Maximum Unit 800 1,800 mA 35 37.5 V 29 67.5 W 105 ºC Tc Light Emitting Surface Diameter LES 17.5 mm Thermal Resisitance (junction-to-case) Qjc 0.56 ºC/W Junction Temperature Tj Viewing Angle 120 10 PDS-002349 Rev 10 140 © 2016 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Series Product Datasheet CXM-22 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Minimum 33.5 Power Operating Case Temperature Typical Maximum Unit 1,280 2,900 mA 35 37.5 V 45 109 W 105 ºC Tc 4 Light Emitting Surface Diameter LES 22 mm Thermal Resisitance (junction-to-case) Qjc 0.37 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CHM-22 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If 3 Forward Voltage Vf Minimum 32 Power Operating Case Temperature Typical Maximum Unit 1,920 2,900 mA 35 37.5 V 67 109 W 105 ºC Tc 4 Light Emitting Surface Diameter LES 22 mm Thermal Resisitance (junction-to-case) Qjc 0.2 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Operating Characteristics Notes Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: To prevent damage refer to operating conditions for maximum operating conditions Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. Note 4: Sensus COB minimum operating current is suggested to be no less than 20% of the typical value. While lower levels will not harm the device, they may result in uneven lighting across the LES area. Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. Note 6: Data sheets are subject to changes without prior notice. Please refer to the Luminus web site for the latest data sheet revisions. 11 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-6 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 160.0% Forward Current vs. Forward Voltage at 85C 350 140.0% Relative Luminous Flux 300 Forward Current (mA) 120.0% 100.0% 80.0% 60.0% 250 200 150 100 50 40.0% 0 100 150 200 250 300 350 32 33 34 Forward Current (mA) 35 36 37 38 39 Forward Voltage (V) Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 40 120.0% 115.0% 38 Forward Voltage (V) Relative Luminous Flux 110.0% 105.0% 100.0% 95.0% 90.0% 36 34 32 85.0% 80.0% 30 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CHM-6 , CXM-7, CLM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 220% 350 200% 300 160% Forward Current (mA) Relative Luminous Flux 180% 140% 120% 100% 80% 60% 40% 250 200 150 100 20% 0% 50 50 100 150 200 250 Forward Current (mA) 12 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 300 350 32 33 34 35 36 Forward Voltage (V) 37 38 39 Sensus™ LED Series Product Datasheet CHM-6, CXM-7, CLM-9 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 1.2 40 38 Forward Voltage (V) Relative Luminous Flux 1 0.8 0.6 0.4 36 34 32 0.2 30 0 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) CXM-9 Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 160.0% 550 140.0% 500 450 120.0% Forward Current (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 100.0% 80.0% 60.0% 40.0% 400 350 300 250 200 20.0% 150 0.0% 100 100 150 200 250 300 350 400 450 500 550 33 34 35 Forward Current (mA) Relative Output Flux vs. Junction Temperature 37 38 39 40 Change in Voltage vs. Junction Temperature 1.2 40 1 38 Forward Voltage (V) Relative Luminous Flux 36 Forward Voltage (V) 0.8 0.6 0.4 36 34 32 0.2 30 0 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 13 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Series Product Datasheet CHM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 550 160% 500 450 120% Forward Current (mA) Relative Luminous Flux 140% 100% 80% 60% 400 350 300 250 200 40% 150 20% 100 150 200 250 300 350 400 450 500 100 550 32 33 34 Relative Output Flux vs. Junction Temperature 36 37 38 Change in Voltage vs. Junction Temperature 120.0% 40 100.0% 38 Forward Voltage (V) Relative Luminous Flux 35 Forward Voltage (V) Forward Current (mA) 80.0% 60.0% 40.0% 36 34 32 20.0% 0.0% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CXM-11 & CXM-14 Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 200% 1100 180% 1000 160% 900 Forward Current (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 140% 120% 100% 80% 60% 800 700 600 500 400 40% 300 20% 200 0% 100 250 350 450 550 650 750 850 Forward Current (mA) 14 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 950 1050 33 34 35 36 37 Forward Voltage (V) 38 39 40 Sensus™ LED Series Product Datasheet CXM-11 & CXM-14 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 120% 40 38 Forward Voltage (V) Relative Luminous Flux 100% 80% 60% 40% 36 34 32 20% 0% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CHM-14 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 160% 1100 1000 120% Forward Current (mA) Relative Luminous Flux 140% 100% 80% 60% 800 700 600 40% 20% 900 500 200 300 400 500 600 700 800 900 1000 34 1100 34.5 35 Forward Current (mA) Relative Output Flux vs. Junction Temperature 36 36.5 37 37.5 Change in Voltage vs. Junction Temperature 120% 40 100% 38 80% Forward Voltage (V) Relative Luminous Flux 35.5 Forward Voltage (V) 60% 40% 36 34 32 20% 0% 30 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 15 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-18 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 180% 1800 1700 1600 1500 140% Forward Current (mA) Relative Luminous Flux 160% 120% 100% 80% 60% 1400 1300 1200 1100 1000 900 800 700 40% 600 20% 500 600 800 1000 1200 1400 1600 1800 33 34 35 Forward Current (mA) Relative Output Flux vs. Junction Temperature 37 38 39 Change in Voltage vs. Junction Temperature 120% 40 100% 38 Forward Voltage (V) Relative Luminous Flux 36 Forward Voltage (V) 80% 60% 40% 36 34 32 20% 0% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CXM-22 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 250% 2800 Forward Current (mA) Relative Luminous Flux 2500 200% 150% 100% 50% 2200 1900 1600 1300 1000 700 400 0% 300 500 700 900 1100 1300 1500 1700 1900 2100 2300 Forward Current (mA) 16 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 2500 2700 2900 100 32 33 34 35 36 Forward Voltage (V) 37 38 39 40 (Part #) Product Sensus™ LED Series Product Datasheet CXM-22 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 120.0% 40 38 Forward Voltage (V) Relative Luminous Flux 100.0% 80.0% 60.0% 40.0% 36 34 32 20.0% 30 0.0% 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) CHM-22 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 2900 160% 2500 120% Forward Current (mA) Relative Luminous Flux 140% 100% 80% 60% 1700 1300 900 40% 20% 2100 800 1100 1400 1700 2000 2300 2600 500 2900 33 33.5 34 34.5 Forward Current (mA) Relative Output Flux vs. Junction Temperature 35.5 36 36.5 37 Change in Voltage vs. Junction Temperature 120.0% 40 100.0% 38 Forward Voltage (V) Relative Luminous Flux 35 Forward Voltage (V) 80.0% 60.0% 40.0% 36 34 32 20.0% 30 0.0% 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 17 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Series Product Datasheet Chromaticity Shift Characteristics Change CIEx vs. Junction Temperature (3000K, 80CRI) Change CIEy vs. Junction Temperature (3000K, 80CRI) 0.02 40 38 Forward Voltage (V) Δ CIEx 0.01 0 -0.01 36 34 32 -0.02 5 15 25 35 45 55 65 75 85 95 30 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) Optical Characteristics Typical Spectrum 120.00% Relative Intensity 100.00% 80.00% 60.00% 40.00% 20.00% 0.00% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 18 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 40 60 80 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Mechanical Dimensions, CXM/CHM-6 Shipping Container, CXM-6 Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 19 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Series Product Datasheet Mechanical Dimensions, CXM-7 Shipping Container, CXM-7 Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 20 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Series Product Datasheet Mechanical Dimensions, CLM/CXM/CHM-9 (AA00) Shipping Container, CLM/CXM/CHM-9 (AA00) Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 21 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Mechanical Dimensions, CLM/CXM/CHM-9 (AC00) Shipping Container, CLM/CXM/CHM-9 (AC00) Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 22 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Series Product Datasheet Mechanical Dimensions, CXM/CHM-14 (AA00) Mechanical Dimensions CXM/CHM-14(AC00) 23 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Mechanical Dimensions CXM-11 (AC00) Shipping Container, CXM-11 & CXM/CHM-14 (AA00 and AC00) Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 24 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Mechanical Dimensions, CXM-18 Shipping Container, CXM-18 Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 25 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Series Product Datasheet Mechanical Dimensions, CXM/CHM-22 Shipping Container, CXM/CHM-22 Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 26 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 27 PDS-002349 Rev 10 © 2016 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
CLM-9-30-80-36-AC02-F2-3 价格&库存
很抱歉,暂时无法提供与“CLM-9-30-80-36-AC02-F2-3”相匹配的价格&库存,您可以联系我们找货
