CXM-7-50-80-36-AA00-F2-3
    LUMINUS(朗明纳斯)
CXM-7-50-80-36-AA00-F2-3 数据手册
CXM-7 Product Datasheet CXM-7 COB Arrays White LED Features: • High lumen output and efficacy typical Table of Contents • Over 720 lm, 125 LPW @ 3000K, 25ºC Technology Overview. . . . . . 2 • Over 780 lm, 137 LPW @ 5000K, 25ºC Test Specifications . . . . . . . . . 2 • Complete CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K • 80 or 90 CRI min. up to 95 min. in warm white Chromaticity Bins. . . . . . . . . . 3 • 3 SDCM color binning accuracy Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 • Excellent optical emission uniformity and color over angle consistency Product Typical Flux Range. 5 • Superior thermal conductivity for uniform heat spreading Operating Characteristics . . 8 • Exceptional long term color stability • Environmentally friendly: RoHS and REACh compliant • Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 9 Spectra. . . . . . . . . . . . . . . . . . . 12 Mechanical Dimensions. . . 13 Packaging Information. . . . 13 Handling Notes. . . . . . . . . . . 14 Applications • Spotlights/Track Lights • Hospitality Lighting • Downlights • Architectural and Specialty • Replacment lamps • Parking Lot and Area Lighting • Shop Lighting 1 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved CXM-7 Product Datasheet Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACh and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved CXM-7 Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 ANSI C78.377-2008 3-step Ellipse 5-step Ellipse 2700K 0.44 3000K 3500K 0.42 Black Body 4000K CIE y 0.4 5000K 0.38 0.36 6500K 0.34 0.32 0.3 0.3 0.32 0.34 0.36 0.38 0.4 0.42 0.44 0.46 0.48 0.5 CIE x CXM-7 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. Center Point *Note: 5-step Bin 3-step Bin Angle CCT CIEx CIEy θ (°) a b a b 2700K 0.4578 0.4101 53.7 0.0081 0.0042 0.0135 0.007 3000K 0.4338 0.403 53.2 0.00834 0.00408 0.0139 0.0068 3500K 0.4073 0.3917 54 0.00927 0.00414 0.01545 0.0069 4000K 0.3818 0.3797 53.7 0.00939 0.00402 0.01565 0.0067 5000K 0.3447 0.3553 59.6 0.00822 0.00354 0.0137 0.0059 6500K 0.3123 0.3282 58.57 0.00669 0.00285 0.01115 0.00475 Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved CXM-7 Product Datasheet Product Ordering and Shipping Part Number Nomenclature All CXM-7 products are packaged and labeled with part numbers as outlined in the table on pages 5 and 6. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM 7 NN Product Family Light Emitting Surface Diameter Color Temperature CXM: Chip on Board, XNova, Multi-die 7.5 : LES Diameter (mm) Color See Note 1 below CXM-7 XX 36 QQPP FG W Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin CRI Volts AA00 (Basic package) Lumens See page 3 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Color Temperature, CRI and R9 Values Note: Color Temperatures XX Value CRI R9 4000K, 5000K, 6500K 70 >70 - 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K, 5000K 90 >90 >50 2700K, 3000K 95 >95 >85 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved CXM-7 Product Datasheet CXM-7, 36V Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at 160mA and specified at T = 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Reference Color Rendering Index Ordering Part Number Typ. Typ. Min. (calculated) (85ºC) (85ºC) (25ºC) CRI (min.) 3-step MacAdam Ellipse Output Flux (lm) CCT 2700K 3000K 3500K 4000K 620 590 680 80 CXM-7-27-80-36-AA00-F2-3 480 455 530 90 CXM-7-27-90-36-AA00-F2-3 450 425 500 95 CXM-7-27-95-36-AA00-F2-3 650 615 720 80 CXM-7-30-80-36-AA00-F2-3 550 520 610 90 CXM-7-30-90-36-AA00-F2-3 520 495 570 95 CXM-7-30-95-36-AA00-F2-3 680 645 750 80 CXM-7-35-80-36-AA00-F2-3 580 550 640 90 CXM-7-35-90-36-AA00-F2-3 700 665 770 80 CXM-7-40-80-36-AA00-F2-3 600 570 660 90 CXM-7-40-90-36-AA00-F2-3 Reference Color Rendering Index Part Number Typ. Min. (calculated) (85ºC) (25ºC) CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse Output Flux (lm) CCT 5000K 6500K Typ. (85ºC) 710 675 780 80 CXM-7-50-80-36-AA00-F2-5 CXM-7-50-80-36-AA00-F2-3 605 575 665 90 CXM-7-50-90-36-AA00-F2-5 CXM-7-50-90-36-AA00-F2-3 710 675 780 80 CXM-7-65-80-36-AA00-F2-5 CXM-7-65-80-36-AA00-F2-3 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved CXM-7 Product Datasheet CXM-7, 18V Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at 320mA and specified at T = 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Reference Color Rendering Index Ordering Part Number Typ. Typ. Min. (calculated) (85ºC) (85ºC) (25ºC) CRI (min.) 3-step MacAdam Ellipse Output Flux (lm) CCT 2700K 3000K 3500K 4000K 620 590 680 80 CXM-7-27-80-18-AA00-F2-3 480 455 530 90 CXM-7-27-90-18-AA00-F2-3 450 425 500 95 CXM-7-27-95-18-AA00-F2-3 650 615 720 80 CXM-7-30-80-18-AA00-F2-3 550 520 610 90 CXM-7-30-90-18-AA00-F2-3 520 495 570 95 CXM-7-30-95-18-AA00-F2-3 680 645 750 80 CXM-7-35-80-18-AA00-F2-3 580 550 640 90 CXM-7-35-90-18-AA00-F2-3 700 665 770 80 CXM-7-40-80-18-AA00-F2-3 600 570 660 90 CXM-7-40-90-18-AA00-F2-3 Reference Color Rendering Index Part Number Typ. Min. (calculated) (85ºC) (25ºC) CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse Output Flux (lm) CCT 5000K 6500K Typ. (85ºC) 710 675 780 80 CXM-7-50-80-18-AA00-F2-5 CXM-7-50-80-18-AA00-F2-3 605 575 665 90 CXM-7-50-90-18-AA00-F2-5 CXM-7-50-90-18-AA00-F2-3 710 675 780 80 CXM-7-65-80-18-AA00-F2-5 CXM-7-65-80-18-AA00-F2-3 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 6 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved CXM-7 Product Datasheet CXM-7, 9V Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at 640mA and specified at T = 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Reference Color Rendering Index Ordering Part Number Typ. Typ. Min. (calculated) (85ºC) (85ºC) (25ºC) CRI (min.) 3-step MacAdam Ellipse Output Flux (lm) CCT 2700K 3000K 3500K 4000K 620 590 680 80 CXM-7-27-80-9-AA00-F2-3 480 455 530 90 CXM-7-27-90-9-AA00-F2-3 450 425 500 95 CXM-7-27-95-9-AA00-F2-3 650 615 720 80 CXM-7-30-80-9-AA00-F2-3 550 520 610 90 CXM-7-30-90-9-AA00-F2-3 520 495 570 95 CXM-7-30-95-9-AA00-F2-3 680 645 750 80 CXM-7-35-80-9-AA00-F2-3 580 550 640 90 CXM-7-35-90-9-AA00-F2-3 700 665 770 80 CXM-7-40-80-9-AA00-F2-3 600 570 660 90 CXM-7-40-90-9-AA00-F2-3 Reference Color Rendering Index Part Number Typ. Min. (calculated) (85ºC) (25ºC) CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse Output Flux (lm) CCT Typ. (85ºC) 5000K 710 675 780 80 CXM-7-50-80-9-AA00-F2-5 CXM-7-50-80-9-AA00-F2-3 6500K 710 675 780 80 CXM-7-65-80-9-AA00-F2-5 CXM-7-65-80-9-AA00-F2-3 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 7 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved CXM-7 Product Datasheet CXM-7 Operating Characteristics1 Electrical Characteristics 36V Parameter Symbol Minimum Typical Maximum Unit 160 320 mA Forward Current2 If Forward Voltage Vf 33.5 35 37.5 V Symbol Minimum Typical Maximum Unit 320 640 mA 3 18V Parameter 2 Forward Current If Forward Voltage3 Vf 16.7 17.5 18.8 V Symbol Minimum Typical Maximum Unit 640 1280 mA 9V Parameter 2 Forward Current If Forward Voltage3 Vf 8.3 8.8 9.4 V Symbol Minimum Typical Maximum Unit 5.8 12 W 105 ºC Optical and Electrical Characteristics Parameter Power Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 7.5 mm Thermal Resistance (junction-to-case) Qjc 1.9 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Forward voltage is rated at typical forward current. For voltage at different forward currents, refer to the voltage versus current performance graphs. Note 4: COB LEDs are designed for operation to a minimum of 20% of the typical forward current value. Operation at currents lower than this value will not harm the device but may result in uneven light emission across the LES surface. Note 5: Luminus may change any specifications without prior notice. Please refer to the company web site for the latest data sheet revision Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 8 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved CXM-7 Product Datasheet CXM-7, 36V Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 350 220% 200% 300 160% Forward Current (mA) Relative Luminous Flux 180% 140% 120% 100% 80% 60% 40% 250 200 150 100 20% 50 0% 50 100 150 200 250 300 32 350 33 34 35 Relative Output Flux vs. Junction Temperature 37 38 39 40 Change in Voltage vs. Junction Temperature 40 1.2 1 38 Forward Voltage (V) Relative Luminous Flux 36 Forward Voltage (V) Forward Current (mA) 0.8 0.6 0.4 36 34 32 0.2 0 30 5 15 25 35 45 55 65 75 85 95 5 105 15 25 Junction Temperature (ºC) 35 45 55 65 75 85 95 105 Junction Temperature (ºC) CXM-7, 18V Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 220% 600 200% 160% Forward Current (mA) Relative Luminous Flux 180% 140% 120% 100% 80% 60% 500 400 300 200 40% 20% 100 0% 100 200 300 400 500 Forward Current (mA) 9 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved 600 16 16.5 17 17.5 Forward Voltage (V) 18 18.5 19 CXM-7 Product Datasheet CXM-7, 18V Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 220% 600 200% 160% Forward Current (mA) Relative Luminous Flux 180% 140% 120% 100% 80% 60% 500 400 300 200 40% 20% 100 0% 100 200 300 400 500 16 600 16.5 17 17.5 18 18.5 19 Forward Voltage (V) Forward Current (mA) Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 19 1.2 Forward Voltage (V) Relative Luminous Flux 1 0.8 0.6 0.4 18 17 0.2 0 16 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CXM-7, 9V Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 220% 1200 200% 160% Forward Current (mA) Relative Luminous Flux 180% 140% 120% 100% 80% 60% 1000 800 600 400 40% 20% 200 0% 200 400 600 800 1000 Forward Current (mA) 10 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved 1200 8 8.2 8.4 8.6 8.8 Forward Voltage (V) 9 9.2 9.4 CXM-7 Product Datasheet CXM-7, 9V Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 1.2 10 9.5 Forward Voltage (V) Relative Luminous Flux 1 0.8 0.6 0.4 9 8.5 0.2 0 8 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CXM-7 Optical & Electrical Characteristics Change in CIEy vs. Junction Temp. (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx Change in CIEx vs. Junction Temp. (3000K, 80CRI) 0 -0.01 0 -0.01 -0.02 -0.02 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 11 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CXM-7 Product Datasheet CXM-7 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 -20.00% 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 12 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CXM-7 Product Datasheet Mechanical Dimensions Shipping Container Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 13 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover CXM-7 Product Datasheet Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 14 PDS-002215 Rev 09 © 2016 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
物料型号:CXM-7 COB Arrays White LED
器件简介:Luminus的CXM-7 COB LED系列提供了一个完整的照明解决方案,适用于高性能照明应用。该系列产品覆盖了从不到400流明到超过10,000流明的广泛流明范围,所有主要色温和超过97的显色指数。
引脚分配:文档中没有提供具体的引脚分配图,但提到了COB LED设计有接触垫在其顶面上,并标有正负极性。
参数特性: - 高流明输出和效率典型值 - 在3000K和25ºC时超过720流明,125 LPW - 在5000K和25ºC时超过780流明,137 LPW - 完整的色温范围2700K, 3000K, 3500K, 4000K, 5000K和6500K - 最小CRI 80或90,暖白色可达95 - 3 SDCM色度分选精度 - 出色的光发射均匀性和颜色角度一致性 - 卓越的长期色彩稳定性 - 优越的热传导性,用于均匀散热 - 环保:符合RoHS和REACh标准
功能详解:Luminus COB LED从设计上就非常可靠,通过了包括机械冲击、振动、温度循环和湿度等一系列严格的环境和机械应力测试。
应用信息: - 聚光灯/轨道灯 - 酒店照明 - 筒灯 - 建筑和特殊照明 - 替代灯具 - 停车场和区域照明 - 商场照明
封装信息:文档提供了机械尺寸图和包装信息,包括每个袋子被装箱,托盘被密封在防静电袋中,每五个托盘堆叠在一起。
CXM-7-50-80-36-AA00-F2-3 价格&库存
很抱歉,暂时无法提供与“CXM-7-50-80-36-AA00-F2-3”相匹配的价格&库存,您可以联系我们找货
  • 2400+10.178392400+1.32316
