CHM-6-30-80-9-AA02-F2-3
    LUMINUS(朗明纳斯)
    LEDCOBSENSUSWARMWHITERECT
CHM-6-30-80-9-AA02-F2-3 数据手册
CHM-6 Product Datasheet CHM-6 COB Arrays White LED Features: • High lumen output and efficacy typical • Over 670 lm, 120 LPW @ 3000K, 25ºC Table of Contents • Over 740 lm, 133 LPW @ 5000K, 25ºC Technology Overview. . . . . . 2 • CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K Chromaticity Bins. . . . . . . . . . 3 • 80 or 90 CRI min.. up to 95 min.. in warm white Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 Product Typical Flux Range. 5 • 2-step and 3-step MacAdam Ellipse color binning accuracy • Excellent optical emission uniformity and color over angle consistency • Exceptional long term color stability • Superior thermal conductivity for uniform heat spreading Operating Characteristics . . 7 • Environmentally friendly: RoHS and REACh compliant Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 8 • Spectra. . . . . . . . . . . . . . . . . . . 10 Mechanical Dimensions. . . 11 Packaging Information. . . . 11 Handling Notes. . . . . . . . . . . 12 Applications • Spotlights/Track Lights • Hospitality Lighting • Downlights • Architectural and Specialty • Replacement lamps • Parking Lot and Area Lighting • Shop Lighting 1 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-6 Product Datasheet Technology Overview Luminus XNova™ Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the XNova™ COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, XNova™ COB LEDs are ready for the toughest challenges. UL Recognized Compliance XNova COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACh and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding XNova™ COB LED Test Specifications Every XNova™ LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each XNova COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature XNova™ COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-6 Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 ANSI C78.377-2008 2-step Ellipse 3-step Ellipse 5-step Ellipse 0.44 2700K 3000K 3500K 0.42 Black Body 4000K CIE y 0.4 5000K 0.38 0.36 6500K 0.34 0.32 0.3 0.3 0.32 0.34 0.36 0.38 0.4 0.42 0.44 0.46 0.48 0.5 CIE x CHM-6 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. Center Point 5-step Bin 3-step Bin 2-step Bin Angle CCT CIEx CIEy θ (°) a b a b a b 2700K 0.4578 0.4101 53.7 0.0054 0.0028 0.0081 0.0042 0.0135 0.007 3000K 0.4338 0.403 53.2 0.00556 0.00272 0.00834 0.00408 0.0139 0.0068 3500K 0.4073 0.3917 54 0.00618 0.00276 0.00927 0.00414 0.01545 0.0069 4000K 0.3818 0.3797 53.7 0.00626 0.00268 0.00939 0.00402 0.01565 0.0067 5000K 0.3447 0.3553 59.6 0.00548 0.00236 0.00822 0.00354 0.0137 0.0059 6500K 0.3123 0.3282 58.57 0.00446 0.0019 0.00669 0.00285 0.01115 0.00475 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-6 Product Datasheet Product Ordering and Shipping Part Number Nomenclature All CHM-6 products are packaged and labeled with part numbers as outlined in the table on pages 5 and 6. Luminus may include any smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CHM 6 NN Product Family Light Emitting Surface Diameter Color Temperature CHM: Chip on Board, XNova, Multi-die 6.3 : LES Diameter (mm) Color See Note 1 below CHM-6 XX 36 QQPP FG W Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin CRI See Table Below Volts AA00 (Basic package) Lumens See page 4 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Color Temperature, CRI and R9 Values Color Temperatures Note: XX Value CRI R9 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K, 5000K 90 >90 >50 2700K, 3000K 95 >95 >90 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-6 Product Datasheet CHM-6 Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at 160mA and specified at T = 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Luminus may choose to ship a smaller chromaticity bin in an order for a larger. Output Flux (lm) CCT 2700K 3000K 3500K 4000K 5000K 6500K Color Rendering Index Ordering Part Number Typ. Typ. (85ºC) Min.. (85ºC) (calculated) 580 550 450 CRI (min.) 3-step MacAdam Ellipse 2-step MacAdam Ellipse 645 80 CHM-6-27-80-36-AA00-F2-3 CHM-6-27-80-36-AA00-F2-2 425 500 90 CHM-6-27-90-36-AA00-F2-3 CHM-6-27-90-36-AA00-F2-2 429 405 470 95 CHM-6-27-95-36-AA00-F2-3 CHM-6-27-95-36-AA00-F2-2 615 585 670 80 CHM-6-30-80-36-AA00-F2-3 CHM-6-30-80-36-AA00-F2-2 520 495 580 90 CHM-6-30-90-36-AA00-F2-3 CHM-6-30-90-36-AA00-F2-2 485 460 535 95 CHM-6-30-95-36-AA00-F2-3 CHM-6-30-95-36-AA00-F2-2 635 605 700 80 CHM-6-35-80-36-AA00-F2-3 CHM-6-35-80-36-AA00-F2-2 550 525 610 90 CHM-6-35-90-36-AA00-F2-3 CHM-6-35-90-36-AA00-F2-2 655 620 730 80 CHM-6-40-80-36-AA00-F2-3 CHM-6-40-80-36-AA00F2-2 570 540 635 90 CHM-6-40-90-36-AA00-F2-3 CHM-6-40-90-36-AA00F2-2 Typ. (85ºC) (25ºC) Reference Color Rendering Index Typ. Min. (calculated) (85ºC) (25ºC) CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse Output Flux (lm) CCT Reference Part Number 670 640 745 80 CHM-6-50-80-36-AA00-F2-5 CHM-6-50-80-36-AA00-F2-3 585 555 640 90 CHM-6-50-90-36-AA00-F2-5 CHM-6-50-90-36-AA00-F2-3 670 640 745 80 CHM-6-65-80-36-AA00-F2-5 CHM-6-65-80-36-AA00-F2-3 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-6 Product Datasheet CHM-6 Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at 640mA and specified at T = 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Luminus may choose to ship a smaller chromaticity bin in an order for a larger. Output Flux (lm) CCT 2700K 3000K 3500K 4000K 5000K 6500K Color Rendering Index Min.. (85ºC) (calculated) 580 550 450 CRI (min.) 3-step MacAdam Ellipse 2-step MacAdam Ellipse 645 80 CHM-6-27-80-9-AA00-F2-3 CHM-6-27-80-9-AA00-F2-2 425 500 90 CHM-6-27-90-9-AA00-F2-3 CHM-6-27-90-9-AA00-F2-2 429 405 470 95 CHM-6-27-95-9-AA00-F2-3 CHM-6-27-95-9-AA00-F2-2 615 585 670 80 CHM-6-30-80-9-AA00-F2-3 CHM-6-30-80-9-AA00-F2-2 520 495 580 90 CHM-6-30-90-9-AA00-F2-3 CHM-6-30-90-9-AA00-F2-2 485 460 535 95 CHM-6-30-95-9-AA00-F2-3 CHM-6-30-95-9-AA00-F2-2 635 605 700 80 CHM-6-35-80-9-AA00-F2-3 CHM-6-35-80-9-AA00-F2-2 550 525 610 90 CHM-6-35-90-9-AA00-F2-3 CHM-6-35-90-9-AA00-F2-2 655 620 730 80 CHM-6-40-80-9-AA00-F2-3 CHM-6-40-80-9-AA00F2-2 570 540 635 90 CHM-6-40-90-9-AA00-F2-3 CHM-6-40-90-9-AA00F2-2 Typ. (85ºC) (25ºC) Reference Color Rendering Index Typ. Min. (calculated) (85ºC) (25ºC) CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse Part Number 670 640 745 80 CHM-6-50-80-9-AA00-F2-5 CHM-6-50-80-9-AA00-F2-3 585 555 640 90 CHM-6-50-90-9-AA00-F2-5 CHM-6-50-90-9-AA00-F2-3 670 640 745 80 CHM-6-65-80-9-AA00-F2-5 CHM-6-65-80-9-AA00-F2-3 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 6 PDS-002449-Rev 04 Ordering Part Number Typ. Typ. (85ºC) Output Flux (lm) CCT Reference © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-6 Product Datasheet CHM-6 Operating Characteristics1 Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Symbol Parameter Minimum Typical Maximum Unit 160 320 mA 33.5 35 37.5 V Minimum Typical Maximum Unit 640 1,280 mA 2 Forward Current If Forward Voltage3 Vf 8.38 8.75 9.38 V Symbol Minimum Typical Maximum Unit 5.6 11 W 105 ºC Optical and Electrical Characteristics Parameter Power Operating Case Temperature 4 Tc Light Emitting Surface Diameter LES 6.3 mm Thermal Resistance (junction-to-case) Qjc 1.55 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. Note 4: CHM-6 COB LEDs are designed for operation up to an absolute maximum forward drive current as specified above. Refer to the current vs. case temperature derating curves for further information. Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 7 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-6 Product Datasheet CHM-6, 36V Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 350 200.0% 180.0% 300 Forward Current (mA) Relative Luminous Flux 160.0% 140.0% 120.0% 100.0% 80.0% 60.0% 40.0% 250 200 150 100 20.0% 50 0.0% 50 100 150 200 250 32 300 33 34 35 Relative Output Flux vs. Junction Temperature 37 38 39 40 Change in Voltage vs. Junction Temperature 40 1.2 1 38 Forward Voltage (V) Relative Luminous Flux 36 Forward Voltage (V) Forward Current (mA) 0.8 0.6 0.4 36 34 32 0.2 0 30 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CHM-6, 9V Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200% 1250 180% Forward Current (mA) Relative Luminous Flux 160% 140% 120% 100% 80% 60% 40% 1050 850 650 450 20% 250 0% 250 450 650 850 1050 Forward Current (mA) 8 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved 1250 8 8.2 8.4 8.6 8.8 9 9.2 Forward Voltage (V) 9.4 9.6 9.8 10 CHM-6 Product Datasheet CHM-6 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 1.2 9.5 Forward Voltage (V) Relative Luminous Flux 1 0.8 0.6 0.4 9 0.2 0 8.5 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 Junction Temperature (ºC) Change CIEx vs. Junction Temperature (3000K, 80CRI) 55 65 75 85 95 105 Change CIEy vs. Junction Temperature (3000K, 80CRI) 40 0.02 38 Forward Voltage (V) 0.01 Δ CIEx 45 Junction Temperature (ºC) 0 -0.01 36 34 32 -0.02 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 9 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved 85 95 105 30 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CHM-6 Product Datasheet CHM-6 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 -20.00% 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 10 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CHM-6 Product Datasheet Mechanical Dimensions Shipping Container Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 11 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover CHM-6 Product Datasheet Handling Notes for XNova COBs XNova products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging XNova COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. XNova COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility XNova COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with XNova COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the XNova products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the XNova COB products. Storage: XNova products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling XNova COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 12 PDS-002449-Rev 04 © 2015 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Luminus Devices: CHM-6-27-80-36-AA00-F2-3 CHM-6-27-90-36-AA00-F2-3 CHM-6-35-90-36-AA00-F2-3 CHM-6-35-80-36-AA00-F2-3 CHM-6-35-80-36-AA00-F2-2 CHM-6-27-80-36-AA00-F2-2 CHM-6-35-90-36-AA00-F2-2 CHM-6-35-90-9-AA00-F2-2 CHM-6-27-90-36-AA00-F2-2 CHM-6-27-80-9-AA00-F2-3 CHM-6-30-90-36-AA00-F2-2 CHM-6-27-95-36-AA00-F2-2 CHM-6-30-80-36-AA00-F2-2 CHM-6-40-90-9-AA00-F2-2 CHM-6-27-95-36-AA00-F2-3 CHM-6-30-80-36-AA02-F2-3 CHM-6-30-80-9-AA02-F2-2 CHM-6-27-80-9-AA00-F2-2 CHM-6-30-80-9-AA02-F2-3 CHM-6-30-80-9-AA00-F2-2 CHM6-27-95-9-AA00-F2-2 CHM-6-30-80-9-AA00-F2-3 CHM-6-35-80-9-AA00-F2-3 CHM-6-27-95-9-AA00-F2-3 CHM-6-3080-36-AA00-F2-3 CHM-6-40-90-9-AA00-F2-3 CHM-6-35-80-9-AA00-F2-2 CHM-6-30-90-36-AA00-F2-3 CHM-6-50-809-AA00-F2-3 CHM-6-30-80-36-AA02-F2-2 CHM-6-50-80-9-AA00-F2-5 CHM-6-27-90-9-AA00-F2-2 CHM-6-27-90-9AA00-F2-3 CHM-6-65-80-36-AA00-F2-3 CHM-6-65-80-36-AA00-F2-5 CHM-6-30-95-9-AA00-F2-3 CHM-6-30-95-36AA00-F2-3 CHM-6-30-95-9-AA00-F2-2 CHM-6-30-95-36-AA00-F2-2 CHM-6-40-80-9-AA00-F2-3 CHM-6-40-80-9AA00-F2-2 CHM-6-50-80-36-AA00-F2-3 CHM-6-50-80-36-AA00-F2-5 CHM-6-40-80-36-AA00-F2-2 CHM-6-40-80-36AA00-F2-3 CHM-6-40-90-36-AA00-F2-3 CHM-6-40-90-36-AA00-F2-2 CHM-6-35-90-9-AA00-F2-3 CHM-6-65-80-9AA00-F2-5 CHM-6-30-90-9-AA00-F2-3 CHM-6-65-80-9-AA00-F2-3 CHM-6-30-90-9-AA00-F2-2
CHM-6-30-80-9-AA02-F2-3 价格&库存
很抱歉,暂时无法提供与“CHM-6-30-80-9-AA02-F2-3”相匹配的价格&库存,您可以联系我们找货
