CLM-9-35-90-36-AA00-F2-3 数据手册
CLM-9 Product Datasheet
CLM-9 COB Arrays
White LED
Features:
• High lumen output and efficacy typical
Table of Contents
• Over 730 lm, 127 LPW @ 3000K, 25ºC
Technology Overview. . . . . . 2
• Over 800 lm, 139 LPW @ 5000K, 25ºC
Test Specifications . . . . . . . . . 2
• Complete CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K
• 80 or 90 CRI min. up to 95 min. in warm white
Chromaticity Bins. . . . . . . . . . 3
• 3 SDCM color binning accuracy
Product Ordering & Shipping
Part Numbers. . . . . . . . . . . . . . 4
• Excellent optical emission uniformity and color over angle consistency
Product Typical Flux Range. 5
Operating Characteristics. 10
• Exceptional long term color stability
• Superior thermal conductivity for uniform heat spreading
• Environmentally friendly: RoHS and REACH compliant
• UL certified, file # E465703
Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . 11
Spectra. . . . . . . . . . . . . . . . . . . 13
Mechanical Dimensions. . . 14
Packaging Information. . . . 14
Handling Notes. . . . . . . . . . . 16
Applications
• Spotlights/Track Lights
• Hospitality Lighting
• Downlights
• Architectural and Specialty
• Replacement lamps
• Parking Lot and Area Lighting
• Shop Lighting
1
PDS-002436 Rev 06
© 2017 Luminus Devices, Inc. - All Rights Reserved
Technology Overview
Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination
applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can
deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and
designers to develop lighting solutions with maximum efficacy, brightness and overall quality.
Reliability
Designed from the ground up, the Luminus COB LED is one of
the most reliable light sources in the world today. Having
passed a rigorous suite of environmental and mechanical stress
tests, including mechanical shock, vibration, temperature
cycling and humidity. Only then are the devices qualified for
use in a wide range of lighting application including some of the
most demanding commercial applications. Delivered with fully
qualified LM80 test data and TM21 lifetime results that certify
lumen maintenance at 35,000 hours or more, Luminus COB
LEDs are ready for the toughest challenges.
UL Recognized Compliance
Luminus COB arrays are tested in accordance with ANSI/UL 8750
to ensure safe operation for their intended applications.
REACH & RoHS Compliance
All LED products manufactured by Luminus are REACH and
RoHS compliant and free of hazardous materials, including lead
and mercury.
Understanding Luminus COB LED Test Specifications
Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products.
Traceability
Chromaticity Bin Range
Each Luminus COB LED is marked with a 2D bar code that
contains a unique serial number. With this serial number,
Luminus has the ability to provide customers with actual test
data measurements for a specific LED. In addition, the 2D bar
code is linked to manufacturing date codes that enables
traceability of production processes and materials.
Chromaticity binning delivers color consistency for every order.
Standard products are delivered with a 3-step MacAdam ellipse.
This ensures color performance matching in the application.
These tightly controlled, small distribution bins provide
customers predictable, repeatable colors.
Testing Temperature
Luminus COB products are measured at temperatures typical for
the LED operating in the fixture. Each device is tested at 85ºC
junction temperature eliminating the need to scale data sheet
specifications to real world situations.
2
PDS-002436 Rev 06
Chromaticity Bin Structure
Chromaticity Bins: 1931 CIE Curve
0.46
0.46
ANSIC78.377-2008
C78.377-2008
ANSI
2-stepEllipse
Ellipse
3-step
3-stepEllipse
Ellipse
5-step
5-step Ellipse
0.44
0.44
2700K
3000K
3000K
3500K
3500K
0.42
0.42
Black Body
4000K
4000K
0.4
0.4
CIE yy
CIE
5000K
5000K
0.38
0.38
0.36
0.36
6500K
6500K
0.34
0.34
0.32
0.32
0.3
0.3
0.3
0.3
0.32
0.32
0.34
0.34
0.36
0.36
0.38
0.38
0.4
0.4
0.42
0.42
0.44
0.44
0.46
0.46
0.48
0.5
CIE
CIE xx
CLM-9 White Chromaticity Bins
The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for
the ellipses. The ANSI Bin is provided for reference.
CCT
Center Point
Angle
3-step Bin
5-step Bin
CIEx
CIEy
θ (°)
a
b
2700K
0.4578
0.4101
53.7
0.0081
0.0042
3000K
0.4338
0.403
53.2
0.00834
0.00408
3500K
0.4073
0.3917
54
0.00927
0.00414
4000K
0.3818
0.3797
53.7
0.00939
0.00402
5000K
0.3447
0.3553
59.6
0.00822
6500K
0.3123
0.3282
58.57
0.00669
*Note:
Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements.
3
PDS-002436 Rev 06
a
b
0.00354
0.0137
0.0059
0.00285
0.01115
0.00475
Product Ordering and Shipping Part Number Nomenclature
All CLM-9 products are packaged and labeled with part numbers as outlined in the table on pages 5. Luminus may include any smaller
chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single
flux and chromaticity bin. The part number designation is as follows:
CLM
9
NN
Product Family
Light Emitting
Surface Diameter
CLM: Chip on
Board, Luminus,
Multi-die
9 : LES
Diameter (mm)
XX
36
QQPP
FG
W
Color
Temperature
Color Rendering Index (CRI)
Voltage
(typical)
Package
Configurator
Flux Bin
Chromaticity
Bin
Color
See Note 1
below
CRI
Volts
AC00
(Basic package)
Lumens
See page 4 for
bins
Note 1: NN nomenclature corresponds to the following color temperatures:
27 = 2700K
30 = 3000K
35 = 3500K
40 = 4000K
50 = 5000K
65 = 6500K
Color Temperature, CRI and R9 Values
Color Temperatures
XX Value
CRI
R9
3500K, 3500K, 5000K
70
>70
2700K, 3000K, 3500K, 4000K, 5000K, 6500K
80
>80
>0
90
>90
>50
95
>95
2700K, 3000K
4000K
Note:
>85
>75
Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released
and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part
number described above will always be included.
4
PDS-002436 Rev 06
CLM-9-AC00 Part Numbers (36V)
The following tables describe products with typical flux and minimum flux measured at 160mA and specified at Tj = 85ºC. The values at
25ºC are calculated and shown for reference only.
Output Flux (lm)
CCT
Reference
Typ.
Typ. (85ºC)
Min. (85ºC)
(calculated)
(25ºC)
2700K
3000K
3500K
4000K
3-step MacAdam Ellipse
630
600
690
80
CLM-9-27-80-36-AC00-F2-3
490
465
540
90
CLM-9-27-90-36-AC00-F2-3
460
435
510
95
CLM-9-27-95-36-AC00-F2-3
660
625
730
80
CLM-9-30-80-36-AC00-F2-3
560
530
620
90
CLM-9-30-90-36-AC00-F2-3
520
495
570
95
CLM-9-30-95-36-AC00-F2-3
690
645
760
80
CLM-9-35-80-36-AC00-F2-3
590
550
650
90
CLM-9-35-90-36-AC00-F2-3
710
665
780
80
CLM-9-40-80-36-AC00-F2-3
610
570
670
90
CLM-9-40-90-36-AC00-F2-3
560
530
615
95
CLM-9-40-95-36-AC00-F2-3
Output Flux (lm)
CCT
Ordering Part Number
Min. Color
Rendering
Index
Reference
Typ.
Typ. (85ºC)
Min. (85ºC)
(calculated)
(25ºC)
Min. Color
Rendering
Index
5-step MacAdam Ellipse
5000K
720
675
800
80
CLM-9-50-80-36-AC00-F2-3
CLM-9-50-80-36-AC00-F2-5
6500K
720
675
800
80
CLM-9-65-80-36-AC00-F2-3
CLM-9-65-80-36-AC00-F2-5
*Note:
Luminus maintains a +/- 6% tolerance on flux measurements.
Luminus maintains a +/- 2% tolerance on CRI measurements.
5
PDS-002436 Rev 06
CLM-9-AA00 Part Numbers (36V)
Output Flux (lm)
CCT
Reference
Typ.
Typ. (85ºC)
Min. (85ºC)
(calculated)
(25ºC)
2700K
3000K
3500K
4000K
630
600
690
80
CLM-9-27-80-36-AA00-F2-3
490
465
540
90
CLM-9-27-90-36-AA00-F2-3
460
435
510
95
CLM-9-27-95-36-AA00-F2-3
660
625
730
80
CLM-9-30-80-36-AA00-F2-3
560
530
620
90
CLM-9-30-90-36-AA00-F2-3
520
495
570
95
CLM-9-30-95-36-AA00-F2-3
690
645
760
80
CLM-9-35-80-36-AA00-F2-3
590
550
650
90
710
665
780
80
CLM-9-40-80-36-AA00-F2-3
610
570
670
90
CLM-9-40-90-36-AA00-F2-3
560
530
615
95
CLM-9-40-95-36-AA00-F2-3
Output Flux (lm)
CCT
Min. Color
Rendering
Index
Reference
Typ.
Typ. (85ºC)
Min. (85ºC)
(calculated)
(25ºC)
Min. Color
Rendering
Index
5000K
720
675
800
80
CLM-9-50-80-36-AA00-F2-3
CLM-9-50-80-36-AA00-F2-5
6500K
720
675
800
80
CLM-9-65-80-36-AA00-F2-3
CLM-9-65-80-36-AA00-F2-5
*Note:
6
PDS-002436 Rev 06
(Part
CLM-9
#) Product
Product
Datasheet
Datasheet
CLM-9 Part Numbers (18V)
The following tables describe products with typical flux and minimum flux measured at 320mA and specified at Tj = 85ºC. The values at
Output Flux (lm)
CCT
Reference
Typ.
Typ. (85ºC)
Min. (85ºC)
(calculated)
(25ºC)
2700K
3000K
3500K
4000K
630
600
690
80
CLM-9-27-80-18-AC00-F2-3
490
465
540
90
CLM-9-27-90-18-AC00-F2-3
460
435
510
95
CLM-9-27-95-18-AC00-F2-3
660
625
730
80
CLM-9-30-80-18-AC00-F2-3
560
530
620
90
CLM-9-30-90-18-AC00-F2-3
520
495
570
95
CLM-9-30-95-18-AC00-F2-3
690
645
760
80
CLM-9-35-80-18-AC00-F2-3
590
550
650
90
CLM-9-35-90-18-AC00-F2-3
710
665
780
80
CLM-9-40-80-18-AC00-F2-3
610
570
670
90
CLM-9-40-90-18-AC00-F2-3
560
530
615
95
CLM-9-40-95-18-AC00-F2-3
Output Flux (lm)
CCT
Min. Color
Rendering
Index
Reference
Typ.
Typ. (85ºC)
Min. (85ºC)
(calculated)
(25ºC)
Min. Color
Rendering
Index
5000K
720
675
800
80
CLM-9-50-80-18-AC00-F2-3
CLM-9-50-80-18-AC00-F2-5
6500K
720
675
800
80
CLM-9-65-80-18-AC00-F2-3
CLM-9-65-80-18-AC00-F2-5
*Note:
7
PDS-002436 Rev 06
(Part
CLM-9
#) Product
Product
Datasheet
Datasheet
CLM-9 Part Numbers (12V)
The following tables describe products with typical flux and minimum flux measured at 480mA and specified at Tj = 85ºC. The values at
Output Flux (lm)
CCT
Reference
Typ.
Typ. (85ºC)
Min.. (85ºC)
(calculated)
(25ºC)
Part Number
Min. Color
Rendering
Index
3500K
725
675
780
70
CLM-9-35-70-12-AC00-F2-3
4000K
740
690
795
70
CLM-9-40-70-12-AC00-F2-3
Output Flux (lm)
CCT
Reference
Typ.
Typ. (85ºC)
Min.. (85ºC)
(calculated)
(25ºC)
5000K
750
700
70
CLM-9-50-70-12-AC00-F2-3
CLM-9-50-70-12-AC00-F2-5
810
*Note:
8
PDS-002436 Rev 06
Part Number
Min. Color
Rendering
Index
CLM-9 Operating Characteristics1
36V Parameter
Symbol
Minimum
Typical
Maximum
Unit
160
360
mA
Forward Current2
If
Forward Voltage
Vf
33.5
35
37.5
V
18V Parameter
Symbol
Minimum
Typical
Maximum
Unit
320
720
mA
3
Forward Current2
If
Forward Voltage
Vf
16.7
17.5
17.8
V
12V Parameter
Symbol
Minimum
Typical
Maximum
Unit
480
1080
mA
3
Forward Current2
If
Forward Voltage
Vf
11.2
11.7
12.5
V
Symbol
Minimum
Typical
Maximum
Unit
5.6
14
W
105
ºC
3
Optical Characteristics
Parameter
Power
Operating Case Temperature
Tc
Light Emitting Surface Diameter
LES
9
mm
Thermal Resistance (junction-to-case)
Qjc
1.9
ºC/W
Junction Temperature
Tj
Viewing Angle
140
120
ºC
Degree
Note 1: Ratings are based on operation at a constant junction temperature Tj = 85ºC.
Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions
Note 3: Forward voltage is rated at typical forward current. For voltage at different forward currents, refer to the voltage versus current performance graphs.
Note 4: CLM-9 COB LEDs are designed for operation to a minimum of 20% of the typical forward current value. Operation at currents lower than this value
will not harm the device but may result in uneven light emission across the LES surface.
Note 5: Luminus may change any specifications without prior notice. Please refer to the company web site for the latest data sheet revision
Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
9
PDS-002436 Rev 06
CLM-9 Optical & Electrical Characteristics (36V)
Relative Output Flux vs. Forward Current @ 85ºC
Forward Current vs. Forward Voltage @ 85ºC
400
250%
350
Forward Current (mA)
Relative Luminous Flux
200%
150%
100%
50%
300
250
200
150
100
50
0%
50
100
150
200
250
300
350
32
33
34
35
Relative Output Flux vs. Junction Temperature
39
38
Forward Voltage (V)
38
40
1
0.8
0.6
0.4
36
34
32
0.2
5
15
25
35
45
55
65
75
85
95
105
30
5
15
25
35
Change CIEx vs. Junction Temperature (3000K, 80CRI)
55
65
75
85
95
105
Change CIEy vs. Junction Temperature (3000K, 80CRI)
0.02
0.01
0.01
Δ CIEy
0.02
-0.02
45
Junction Temperature (ºC)
Δ CIEx
37
Change in Voltage vs. Junction Temperature
1.2
Forward Voltage (V)
5
15
25
35
45
55
65
75
10
PDS-002436 Rev 06
85
95
105
-0.02
5
15
25
35
45
55
65
75
85
95
105
CLM-9 Optical & Electrical Characteristics (18V)
220%
720
620
180%
200%
160%
140%
120%
100%
80%
520
420
320
220
60%
40%
120
120
220
320
420
520
620
720
15.5
16
16.5
17
18
17.5
Forward Voltage (V)
1.2
18.5
Forward Voltage (V)
1
0.8
0.6
0.4
18
17.5
0.2
15
25
35
45
55
65
75
85
95
17
105
25
35
45
55
65
75
85
95
105
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
15
Junction Temperature (℃)
-0.02
5
5
15
25
35
45
55
65
75
11
PDS-002436 Rev 06
85
95
105
-0.02
5
15
25
35
45
55
65
75
85
95
105
CLM-9 Optical & Electrical Characteristics (12V)
1100
250.0%
1000
900
200.0%
150.0%
100.0%
800
700
600
500
400
50.0%
300
0.0%
200
300
400
500
600
700
800
900
1000
200
1100
10.5
11
11.5
12
12.5
13
Forward Voltage (V)
1.2
14
Forward Voltage (V)
1
0.8
0.6
0.4
12
0.2
15
25
35
45
55
65
75
85
95
105
10
5
15
25
35
55
65
75
85
95
105
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
-0.02
45
5
15
25
35
45
55
65
75
12
PDS-002436 Rev 06
85
95
105
-0.02
5
15
25
35
45
55
65
75
85
95
105
Typical Spectrum
120.00%
100.00%
Relative Intensity
80.00%
Warm White
60.00%
Neutral White
Cool White
40.00%
3000K-90CRI
3000K-97CRI
20.00%
0.00%
400
450
-20.00%
500
550
600
650
700
750
800
Wavelength (nm)
Typical Polar Radiation Pattern
Typical Angular Radiation Pattern
120%
100%
Relative Intensity (%)
80%
60%
40%
20%
0%
-80
-60
-40
-20
Anglular Displacement (Degrees)
13
PDS-002436 Rev 06
40
60
80
Mechanical Dimensions (AC00)
Shipping Container (AC00)
400 pcs per box
Each bag is boxed for
easier storage/ stacking
80 pcs per tray
5 trays are stacked together
with separate cover
Trays are sealed in
an anti-static bag
Label
Luminus Label Model:
(Manufacturer Part Number & Bin Kits)
XXX-XX-XX-XX-XX-XXXX-XX-X
XXXXXXXXXXXXXX
Bar code
14
PDS-002436 Rev 06
Rev XX
Bar code
Bar code
(Box ID)
(Customer Part Number)
Qty: XX
Bar code
RoHS Compliant
Luminus Devices Inc
XXXXXX-XX-XX
Mechanical Dimensions (AA00)
Shipping Container (AA00)
300 pcs per box
60 pcs per tray
with separate cover
Trays are sealed in
an anti-static bag
Label
XXXXXX-XX-XX
XXXXXXXXXXXXXX
Bar code
15
PDS-002436 Rev 06
Rev XX
Bar code
Bar code
(Box ID)
Qty: XX
Bar code
RoHS Compliant
Luminus Devices Inc
Handling Notes for Luminus COBs
Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and
assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines.
The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More
detailed information is available on the Luminus web site at www.luminus.com.
General Handling
Electrical Contact
Devices are made to be lifted or carried with tweezers on two
adjacent corners opposite the contact pads. At no time should
the devices be handled by or should anything come in contact
with the light emitting surface (LES) area. This area includes the
yellow colored circular area and the ring surrounding it. There
are electrical connections under the LES which if damaged will
cause the device to fail.
Luminus COBs are designed with contact pads on their top
surface. These pads are clearly marked with + and – polarity.
Wires can be soldered to the contact pads for electrical
connections or other solderless connector products are
available.
In addition, the ring frame itself should not be used for moving,
lifting or carrying the device. Also do not attach any optics or
mechanical holders to the ring as it is not capable to handle the
mechanical stress.
If wires are being soldered to the COB product, we recommend
attaching these wires prior to mounting the devices to a heat
sink. Please contact Luminus for specific recommendations on
how to solder wires if not familiar with the standard practice.
Luminus can also offer design recommendations for jigs to
allow easily soldering multiple products in rapid succession.
Static Electricity
Chemical Compatibility
Luminus COBs are electronic devices which can be damaged by
electrostatic discharge (ESD). Please use appropriate measures
to assure the devices do not experience ESD during their
handling and or storage. ESD protection guidelines should be
used at all times when working with Luminus COBs.
The resin material used to form the LES can getter hydrocarbons
from the surrounding environment. As a results, certain
chemical compounds are not recommended for use with the
Luminus products. Use of these compounds can cause damage
to the light output of the device and may permanently damage
the device. Please refer to www.luminus.com for a list of the
compounds not recommended for use with the Luminus COB
products.
Storage: Luminus products are delivered in ESD shielded bags
and should be stored in these bags until used.
Assembly: Individuals handling Luminus COBs during assembly
should be trained in ESD protection practices. Assemblers
should maintain constant conductive contact with a path to
ground by means of a wrist strap, ankle straps, mat or other ESD
protection system.
Transporting: When transporting the devices from one
assembly area to another, ESD shielded carts and carriers should
be used.
16
PDS-002436 Rev 06
Thermal Interface Material (TIM)
Proper thermal management is critical for successful operation
of any LED system. Excess operating temperature can reduce
the light output of the device. And excessive heating can cause
permanent damage to the device. Proper TIM material is a
crucial component for effective heat transfer away from the LED
during normal operation. Please refer to www.luminus.com for
specific recommendations for TIM solutions.
