Gravity: Analog Infrared CO2 Sensor For Arduino
SKU: SEN0219
Introduction
DFRobot released its latest high-precision analog infrared CO2 sensor. The effectively measuring
range is from 0 to 5000ppm. This sensor is based on non-dispersive infrared (NDIR) technology and
has good selectivity and oxygen-free dependency. Besides, its service life could up to 5 years! It
integrates temperature compensation and support DAC output. Most importantly, the product is easy
to use; it is compatible with all types of microcontrollers with ADC function.
In addition, this product is a high-performance sensor that combines technology of mature infrared
absorption gas detection with precision optical circuit design as well as sophisticated circuit design. It
has characteristics such as high sensitivity, high resolution, low power consumption, fast response,
anti-water vapor interference, no poisoning, high stability and long life.
This sensor is able to directly compatible with the DFRobot Arduino IO expansion board thanks to its
external DFRobot Gravity interface. This character simplify the use of the sensor as it is plug and
play and no need additional wiring.
This product could be widely used in HVAC, indoor air quality monitoring, industrial process and
security protection monitoring, agriculture and animal husbandry production process monitoring.
Feature
Waterproof and anti-corrosion
High sensitivity
Low power consumption
Excellent stability
Temperature compensation
Excellent linear output
High cycle life
Anti-water vapor interference
No poisoning
Specification
Gas Detection: Carbon Dioxide (CO2)
Operating Voltage: 4.5 ~ 5.5V DC
Average Current: 5 years
Size: 37mm * 69mm
Board Overview
SEN0219 CO2 Sensor
Num
Label
Description
1
Signal
Analog Output (0.4~2V)
2
VCC
VCC (4.5~5.5V)
3
GND
GND
Tutorial
In this tutorial, we'll show you how to use DFRobot Infrared Sensor within 5 minutes.
Requirements
Hardware
DFRduino UNO x 1
DFRobot Gravity: Infrared CO2 Sensor
Gravity: IO Expansion Shield for Arduino V7.1
Software
Arduino IDE Click to Download Arduino IDE from Arduino®
https://www.arduino.cc/en/Main/Software%7C
Connection Diagram
SEN0219_Connection
Data Analysis
When the IR CO2 sensor get 5V power supply, it will output 0.4~2V analog value, corresponding to
0~5000 ppm; And when the sensor finds faults during the self-checking process, it will output 0V.
Sample Code
* Infrared CO2 Sensor0-5000ppm
* This example The sensors detect CO2
* @author lg.gang(lg.gang@qq.com)
* @version
* @date
V1.0
2016-7-6
* GNU Lesser General Public License.
* See for details.
* All above must be included in any redistribution
int sensorIn = A0;
void setup(){
Serial.begin(9600);
// Set the default voltage of the reference voltage
analogReference(DEFAULT);
void loop(){
//Read voltage
int sensorValue = analogRead(sensorIn);
// The analog signal is converted to a voltage
float voltage = sensorValue*(5000/1024.0);
if(voltage == 0)
Serial.println("Fault");
else if(voltage < 400)
Serial.println("preheating");
else
int voltage_diference=voltage-400;
float concentration=voltage_diference*50.0/16.0;
// Print Voltage
Serial.print("voltage:");
Serial.print(voltage);
Serial.println("mv");
//Print CO2 concentration
Serial.print(concentration);
Serial.println("ppm");
delay(100);
Expected Results
Open your IDE serial monitor and wait for 3 minutes (preheat process), then you'll see the finial data.
(Indoor Temperature: 30 )
https://www.dfrobot.com/wiki/index.php/Gravity:_Analog_Infrared_CO2_Sensor_For_Arduino_SKU:_SEN0219 5-3-17
很抱歉,暂时无法提供与“SEN0219”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+565.274841+73.48390
