PIM221
PIM221
    PIMORONI
    AUTOMATIONPHAT
PIM221 数据手册
    Automation pHAT PIM221   Automation HAT's little bro'. The most compact way to take control of and monitor your world! We've pulled together a great set of features into this home monitoring and automation controller. With a relay, analog channels, powered outputs, and buffered inputs (all 24V tolerant) you can now hook up a plethora of goodies to your Raspberry Pi all at once. Ideal for smart home and automation projects, giving your greenhouse intelligent sprinklers, or scheduling your fish feeding! Features          1 x 24V @ 2A relay (NC and NO terminals)  3 x 12‐bit ADC @ 0‐24V (ADS1015)  3 x 24V tolerant buffered inputs  3 x 24V tolerant sinking outputs  3.5mm screw terminals  SPI pins broken out  Compatible with Raspberry Pi 3, 2, B+, A+, Zero, and Zero W  Python library  Female header and broken out pins require soldering    Software As ever, we've made a super-simple to use Python library to take advantage of Automation pHAT's multitudinous functions, with examples to get you started. In fact, Automation pHAT uses the same library as Automation HAT, and it uses the presence (or absence) of the SN3218 LED driver chip to autodetct which board (HAT or pHAT) is being used. Nifty! Our input, output and relay examples show you how to read the analog and digital inputs, switch the outputs on and off, and control the relay. Notes   Loads for the buffered outputs should be switched on the ground side, i.e. 12/24V (from supply)  ‐> load ‐> output terminal ‐> ground (from supply)  The relay can tolerate up to 2A each and should be switched on the high side        https://shop.pimoroni.com/products/automation‐phat 4/19/2017
PIM221 价格&库存
很抱歉,暂时无法提供与“PIM221”相匹配的价格&库存,您可以联系我们找货
