MIKROE-2389
MIKROE-2389
    MIKRO
    CCRF3CLICK
MIKROE-2389 数据手册
  ccRF 3 click PID: MIKROE-2389 Weight: 25 g   Description ccRF 3 click carries the CC1120 high-performance RF transceiver for narrowband systems from Texas Instruments. The clicks will enable you to add a low-power consumption radio transceiver at 433 MHz frequency. ccRF 3 click is designed to run on a 3.3V power supply. It communicates with the target microcontroller over SPI interface, with additional functionality provided by the following pins on the mikroBUS™ line: AN, RST, CS, PWM, INT. Note: the click requires an external N.FL. antenna CC1120 RF transceiver features The CC1120 device is a fully integrated single‐chip radio transceiver designed for high performance  at very low‐power and low‐voltage operation.     The device is mainly intended for Industrial, Scientific, and Medical (ISM) applications and Short  Range Device (SRD).  The CC1120 device provides extensive hardware support for packet handling, data buffering, burst transmissions, clear channel assessment, link quality indication, and wake-on-radio. The main operating parameters of the CC1120 device can be controlled through an SPI interface. Wake-On-Radio Wake-On-Radio or eWOR y enables CC1120 to periodically wake up from SLEEP and listen for incoming packets without MCU interaction. When the CC1120 device enters RX mode, it listens and then returns to sleep if a valid RF packet is not received. The sleep interval and duty cycle can be configured to make a trade-off between network latency and power consumption. Incoming messages are time-stamped to simplify timer resynchronization. The eWOR timer runs off an ultra-low-power 32-kHz RC oscillator. Power consumption In IDLE mode the CC1120 uses 1.3mA, while in power down with retention mode the consumption goes to 0.12µA. SmartRF™ Studio software CC1120 can be configured using the SmartRF™ Studio software. SmartRF™ Studio is highly recommended for obtaining optimum register settings, and for evaluating performance and functionality. After chip reset, all registers have default values and these might differ from the optimum register setting. It is therefore necessary to configure/reconfigure the radio through the SPI interface after the chip has been reset. SmartRF Studio provides a code export function making it easy to implement this in firmware. Key features    CC1120 RF transceiver   o 433 MHz frequency  o Low‐power and low‐voltage operation  o 1.3mA in IDLE mode  o Wake‐On‐Radio  SPI interface  3.3V power supply  Specification  Product Type RF Sub 1GHz Narrowband ultra-low-power wireless systems with channel spacing down to Applications 12.5 kHz, wireless metering and wireless smart grid, home and building automation, wireless alarm and security sytems, etc. MCU CC1120 high-performance RF transceiver for narrowband systems Key Features Power consumption of 1.3mA in IDLE mode, 433 MHz frequency band Interface SPI Power Supply 3.3V Compatibility mikroBUS Click board S (28.6 x 25.4 mm) size Pinout diagram This table shows how the pinout on ccRF 3 click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes    Pin  Pin Notes  mikroBUStm  GPIO0 GP0 1 AN  PWM 16 GP2 GPIO2  Reset RST 2 RST INT  15 GP3 GPIO3  SPI Chip Select CS  3 CS  TX  14 NC Not connected  SPI Clock Pin SCK 4 SCK RX  13 NC Not connected  SPI master in slave out pin for the MCU MISO 5 MISO SCL 12 NC Not connected  SPI master out slave in pin for the MCU MOSI 6 MOSI SDA 11 NC Not connected  Power supply +3.3V 7 3.3V 5V  10 NC Not connected  Ground GND 8 GND GND 9 GND Ground  Programming Code examples for ccRF 3 click, written for MikroElektronika hardware and compilers are available on Libstock. Code snippet This code snippet initializes the system, the display, and waits for button toggling in an endless loop, for executing actions like initializing the ccRF module, sending and receiving packets via RF. Example for STM32 arhitecture 01 void main( void ) 02 { 03 system_init(); 04 display_init(); 05 TFT_Set_Font( &HandelGothic_BT21x22_Regular, CL_GREEN, FO_HORIZONTAL ); 06 TFT_Write_Text("Please initialize the module.", 15, 80); 07 08 while (1) 09 { 10 check_buttons(); 11 is_initialized(); 12 is_sending_mode(); 13 is_receiving_mode(); 14 if ( reading_f ) 15 { 16 ccRF_RunRX(); 17 } 18 } 19 }                                             https://shop.mikroe.com/click/wireless‐connectivity/ccrf‐3_2 5‐1‐17
MIKROE-2389 价格&库存
很抱歉,暂时无法提供与“MIKROE-2389”相匹配的价格&库存,您可以联系我们找货
