MOPI-STACK
MOPI-STACK
    PIMORONI
    MOPI:MOBILEPOWERFORTHERASPB
MOPI-STACK 数据手册
  MoPi: Mobile Power for the Raspberry Pi Stackable MOPI‐STACK Low Profile MOPI‐LP   MoPi is mobile and 24/7 power for the Pi. On your bike, up a tree, or for your home server: we've got you covered. Update: As of 19th December 2016 the MoPi no longer supports the Raspberry Pi 3 - details can be found here https://pi.gate.ac.uk/posts/2016/12/19/good-news-and-bad/ Features:      multiple inputs — standard batteries, car power sockets, old laptop supplies, solar panels, and  more... all attachable via standard screw terminals  hot‐swap power replacement without stopping work  shutdown the Pi cleanly when batteries discharge  integrated on/off switch  usable as a UPS (uninterruptible power supply) by attaching both batteries and mains              on‐board LED indicators and on screen linux system notifications  configuration of multiple battery chemistries and number of cells from a UI on the Pi  full API in Python, plus a shell‐friendly command‐line interface  stackable headers allowing connections of multiple boards at once (e.g. MoPi + XLoBorg, or  MoPi + AirPi, or etc.).  PCB remoting pads for the power switch  self‐resetting fuse for over‐current protection  two‐way communication via the I2C bus  remote power‐off: tell MoPi to power down the Pi when logged‐in remotely (after a clean  shutdown, of course)  timer‐based wake‐up: tell MoPi what time you want your Pi to wakeup, then power it down and  MoPi will boot the Pi as requested  3.3V supply mod: swap three resistors and supply 3.3V, overpowering the Pi's on‐board  regulator and saving the power that is dissipated there, for weight and battery life critical  applications like ballooning  wide input voltage range: 6.2V to 20V  designed in Sheffield, made in Europe, used all over the world  Choose between stackable and low-profile GPIO headers (if you want to fit your MoPi into tight spaces, you want a low-profile header; if you want to stack MoPi with other Pi add-on boards, then you want a stackable header). For more details surf on over to http://pi.gate.ac.uk/mopi. Note: DO NOT plug MoPi onto your Pi while the Pi is powered up!                                                          https://shop.pimoroni.com/products/mopi‐mobile‐pi‐power 4/17/2017
MOPI-STACK 价格&库存
很抱歉,暂时无法提供与“MOPI-STACK”相匹配的价格&库存,您可以联系我们找货
