MCP73213 click
PID: MIKROE-2575
MCP73213 click carries the MCP73213 dual-cell Li-Ion/Li-Polymer battery charge
management controller with input overvoltage protection from Microchip. The click is designed
to run on either 3.3V or 5V power supply. It communicates with the target microcontroller over
SPI.
Note: The click is designed to charge a dual‐cell Li‐Ion/Li‐Polymer battery. The input voltage needs to be
higher that the voltage of a dual‐cell Li‐Ion/Li‐Polymer battery.
MCP73213 controller features
The MCP73213 is a highly integrated Li-Ion battery charge management controller.
The MCP73213 provides specific charge algorithms for dual-cell Li-Ion/Li-Polymer batteries to
achieve optimal capacity and safety in the shortest charging time possible.
The absolute maximum voltage, up to 18V, allows the use of MCP73213 in harsh environments,
such as low-cost wall wart or voltage spikes from plug/unplug.
An internal overvoltage protection (OVP) circuit monitors the input voltage and keeps the
charger in shutdown mode when the input supply rises above the typical 13V OVP threshold.
The OVP hysteresis is approximately 150 mV for the MCP73213 device.
How it works
First you need to connect the input voltage to the input screw terminal. Then to set the input
voltage, because it needs to be larger than voltage of two series connected batteries for regular
charging, (which means it needs to be >8V). We can change the charging current trough SPI
interface.
Now just leave the batteries to charge, and when they are charged it will be signalized on the
status LED.
Key features
MCP73213 controller
o 13V Input Overvoltage Protection
o Resistor Programmable Fast Charge Current: 130 mA‐1100 mA
o Elapse Safety Timer: 4 hr, 6 hr, 8 hr or Disable
Two pairs of screw terminals
Status indication LED
SPI interface
Specification
Product Type Buck
Applications Portable Media players, digital camcorders, handheld devices, etc.
MCU
MCP73213
13V Input Overvoltage Protection, Resistor Programmable Fast Charge
Key Features
Current: 130 mA-1100 mA, Elapse Safety Timer: 4 hr, 6 hr, 8 hr or Disable
Interface
SPI
Power Supply 3.3V or 5V
Compatibility mikroBUS
Click board
S (28.6 x 25.4 mm)
size
Pinout diagram
This table shows how the pinout on MCP73213 click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
mikroBUStm
Not connected
NC
1 AN
PWM 16 NC Not connected
Not connected
NC
2 RST
INT 15 NC Not connected
Chip Select SPI_CS 3
CS
TX 14 NC Not connected
SPI Clock SPI_SCK 4 SCK
RX 13 NC Not connected
Not connected
NC
5 MISO
SCL 12 NC Not connected
SPI Master output svale input SPI_MOSI 6 MOSI
SDA 11 NC Not connected
Power supply
+3.3V
7 3.3V
Ground
GND
8 GND
5V 10 +5V Power supply
GND 9 GND Ground
Maximum ratings
Description
Min Typ Max Unit
Input Voltage Range
4
16
V
Operating Supply Voltage
4.2
13
V
Fast Change Current Regulation 130
1100 A
Programming
Code examples for MCP73213 click, written for MikroElektronika hardware and compilers are
available on Libstock.
Code snippet
The following code snippet shows how to initialize the SPI interface, and then use it to set output
current to 250mA.
01 void main() {
02
03
/*Sets chip select*/
04
GPIO_Digital_Output (&GPIOD_BASE, _GPIO_PINMASK_13);
05
06
GPIO_Alternate_Function_Enable(&_GPIO_MODULE_SPI3_PC10_11_12);
07
/*Initializes SPI interface*/
08
SPI3_Init_Advanced(_SPI_FPCLK_DIV256, _SPI_MASTER | _SPI_16_BIT |
09
_SPI_CLK_IDLE_LOW | _SPI_FIRST_CLK_EDGE_TRANSITION | _SPI_MSB_FIRST
10
_SPI_SS_DISABLE | _SPI_SSM_ENABLE | _SPI_SSI_1,
11
12
13
SPI_Set_Active(SPI3_Read, SPI3_Write);
14
/*Sets chip select to inactive*/
15
GPIOD_ODR.B13 = 1;
16
17
delay_ms(5000);
18
19
//5 kOhm, 250mA
22
GPIOD_ODR.B13 = 0;
23
Spi3_Write(0b00000000);
24
Spi3_Write(0b10000010);
25
GPIOD_ODR.B13 = 1;
26
delay_ms(5000);
27 }
https://shop.mikroe.com/click/power‐management/mcp73213 5‐1‐17
很抱歉,暂时无法提供与“MIKROE-2575”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+184.16871
- 5+180.48221
