TEL0066
TEL0066
    DFROBOT
    FREEMATICSOBD-IIUARTADAPTERM
TEL0066 数据手册
  Freematics OBD-II UART Adapter MK2 SKU:TEL0066 INTRODUCTION Freematics OBD-II UART Adapter MK2 is the second generation of our popular OBD-II UART Adapter for Arduino. It works as data bridge between a car’s OBD-II port and Arduino with easy-to-use Arduino library provided. Besides OBD-II data access, it also integrates 6-axis MEMS sensor module and voltmeter for measuring vehicle battery power. The adapter draws power from OBD-II port and convert it to 5V (up to 2A) for powering itself and attached device (Arduino board, shield or other components). The adapter plugs into the OBD port usually located under the steering column or slightly to the left of it. To check if your vehicle is OBD-II certified, open your hood and find the sticker that looks like this: Note: Vehicles using following vehicle protocols are supported: CAN 500Kbps/29bit CAN 250Kbps/29bit KWP2000 Fast KWP2000 5Kbps This version 5V-10W is for cars with both 12V & 24V batteries. FEATURES            Supporting CAN bus & KWP2000 protocols Built-in MPU-6050 MEMS module (accelerometer, gyroscope & temperature) Built-in voltage meter for measuring car battery voltage Serial UART data interface for micro-controllers Micro USB port for computer/tablet OBD-II access and firmware upgrade Compatible and extended ELM327 AT command-set Fast (up to 100Hz) read-out of OBD-II PIDs available with vehicle’s ECU Reading multiple (up to 8) OBD-II PIDs from a single query Reading and clearing vehicle diagnostic trouble code (DTC) Powering attached devices with DC 5V (up to 2A) Arduino library and sketches available SPECIFICATION   Output Power: 5V@2A-10W Weight:94g SHIPPING LIST  Freematics OBD-II UART Adapter MK2 x1 https://www.dfrobot.com/product-1485.html 5-4-17
TEL0066 价格&库存
很抱歉,暂时无法提供与“TEL0066”相匹配的价格&库存,您可以联系我们找货
