415-0033-MM150
415-0033-MM150
    CINCH
    415-0033-MM150
415-0033-MM150 数据手册
RF Cable Assembly Guide cinch.com Electrical Ratings Electrical ratings of a cable assembly are determined by the limiting connector type and cable size. Connector Frequency Impedance (Ohms) GHz Dielectric Withstanding Voltage (Vms) Working Voltage (Vms) RG-178 RG-316 50 Ohms 50 Ohms 6 GHz 6 GHz 500 Vms 500 Vms 170 Vms 170 Vms MCX RG-178 RG-316 RG-316 DS 50 Ohms 50 Ohms 50 Ohms 6 GHz 6 GHz 6 GHz 750 Vms 1000 Vms 1000 Vms 250 Vms 335 Vms 335 Vms MCX 75 Ohm RG-179 BELDEN 735A 75 Ohms 75 Ohms 6 GHz 6 GHz 1000 Vms 1000 Vms 335 Vms 335 Vms SMA RG-178 RG-316 RG-316 DS RG-58 RG-142 Hand Formable .086 Hand Formable .141 50 Ohms 50 Ohms 50 Ohms 50 Ohms 50 Ohms 50 Ohms 50 Ohms 12.4 GHz 12.4 GHz 12.4 GHz 12.4 GHz 12.4 GHz 26.5 GHz 26.5 GHz 500 Vms 750 Vms 750 Vms 1000 Vms 1000 Vms 1000 Vms 1500 Vms 170 Vms 250 Vms 250 Vms 335 Vms 335 Vms 335 Vms 500 Vms SMB RG-178 RG-316 50 Ohms 50 Ohms 4 GHz 4 GHz 750 Vms 1000 Vms 250 Vms 335 Vms SMB Mini 75 Ohm RG-179 RG-179 DS BELDEN 735A 75 Ohms 75 Ohms 75 Ohms 2 GHz 2 GHz 2 GHz 1000 Vms 1000 Vms 1000 Vms 335 Vms 335 Vms 335 Vms BNC RG-58 BELDEN 8218 RG-59 RG-59 PLENUM 50 Ohms 50 Ohms 50 Ohms 50 Ohms 4 GHz 4 GHz 4 GHz 4 GHz 1500 Vms 1500 Vms 1500 Vms 1500 Vms 500 Vms 500 Vms 500 Vms 500 Vms BNC True 75 Ohm BELDEN 8218 RG-59 BELDEN 8281 COMM SCOPE 735 BELDEN 735A BELDEN 734A BELDEN 1694A 75 Ohms 75 Ohms 75 Ohms 75 Ohms 75 Ohms 75 Ohms 75 Ohms 3 GHz 3 GHz 3 GHz 3 GHz 3 GHz 3 GHz 3 GHz 1500 Vms 1500 Vms 1500 Vms 1500 Vms 1500 Vms 1500 Vms 1500 Vms 500 Vms 500 Vms 500 Vms 500 Vms 500 Vms 500 Vms 500 Vms N Type RG-58 RG-142 RG-8 RG-213 50 Ohms 50 Ohms 50 Ohms 50 Ohms 11 GHz 11 GHz 11 GHz 11 GHz 1500 Vms 1500 Vms 1500 Vms 1500 Vms 500 Vms 500 Vms 500 Vms 500 Vms Connector Cable MMCX Cable Length Tolerence 2 Standard Cable Length Cable Tolerence Metric Cable Length Cable Tolerence ≤1 ft +1 in - 0.25 in ≤0.3 m +25 mm - 6 mm >1 ft - 5 ft +2 in - 1 in >0.3 m - 1.5 m +50 mm - 25 mm >5 ft - 10 ft +4 in - 2 in >1.5 m - 3 m +100 mm - 50 mm >10 ft - 25 ft +6 in - 3 in >3 m - 7.5 m +150 mm - 75 mm >25 ft +2 % - 1 % >7.5 m +2 % - 1 % Metric assemblies available, highlighted in blue Custom Solutions Johnson offers more than 500 standard fixed length cable assemblies, with various connector configurations and lengths. Johnson also has more than 400 custom cable assemblies, which were designed to meet customer design specification requirements. If you do not see the cable assembly you require, we can design and manufacture one to meet your unique specifications. • • Available Cable Options: Flexible, Semi-Rigid and Conformable CNC Hardline Bender (Semi-Rigid Cables) • • Available Connector Options: Standard and Custom Voltage/Continuity Tested • • • 0 to 40 GHz 50 and 75 Ohms Prototype available upon request Measurements of Cable Length Johnson’s cable length applies to the end of straight connectors. The length is applied to the vertical centroid of right angle connectors. Part Number Index 4 1 5 - Connector Type - Connector Type Standard Cable Length Part Number Example: 415-0037-012 Part Number Description: 12" length cable 4 1 5 - Connector Type - Connector Type 1 5 Connector Type - (less than 1 m) - Connector Type Part Number Example: 415-0037-M1.5 Part Number Description: 1.5 m length cable M Metric Cable Connector Length Part Number Example: 415-0037-MM150 Part Number Description: 150 mm length cable 4 M M . Metric Cable Connector Length (1 m and greater) Metric assemblies available, highlighted in blue 3 MMCX Straight Plug to MMCX Straight Plug Connector by Cable Type: RG-178 (135-3402-001) RG-316 (135-3403-001) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Standard Cable Lengthc Metric Cable Length 415-0066-006 6" 152 mm RG-178 Cable Type 415-0067-006 6" 152 mm 415-0066-012 12" 305 mm RG-316 RG-178 415-0067-012 12" 305 mm RG-316 415-0066-018 18" 415-0066-024 24" 457 mm RG-178 415-0067-018 18" 457 mm RG-316 610 mm RG-178 415-0067-024 24" 610 mm RG-316 Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-316 6" 152 mm RG-316 Part Number MMCX Right Angle Plug to MMCX Right Angle Plug Connector by Cable Type: RG-178 (135-3402-101) RG-316 (135-3403-101) Part Number 415-0068-MM150 415-0068-006 415-0068-MM250 Standard Cable Lengthc Metric Cable Length 5.9" 150 mm RG-178 415-0069-MM150 6" 152 mm RG-178 415-0069-006 Cable Type Part Number 9.84" 250 mm RG-178 415-0069-MM250 9.84" 250 mm RG-316 415-0068-012 12" 305 mm RG-178 415-0069-012 12" 305 mm RG-316 415-0068-018 18" 457 mm RG-178 415-0069-018 18" 457 mm RG-316 19.7" 500 mm RG-178 415-0069-MM500 19.7" 500 mm RG-316 24" 610 mm RG-178 415-0069-024 24" 610 mm RG-316 29.53" 750 mm RG-178 415-0069-MM750 29.53" 750 mm RG-316 Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-316 6" 152 mm RG-316 415-0068-MM500 415-0068-024 415-0068-MM750 MMCX Straight Plug to SMA Straight Bulkhead Jack Connector by Cable Type: RG-178 (135-3402-001, 142-0302-431) RG-316 (135-3403-001, 142-0303-411) Part Number 415-0070-MM150 415-0070-006 415-0070-MM250 Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-178 415-0071-MM150 6" 152 mm RG-178 415-0071-006 Part Number 9.84" 250 mm RG-178 415-0071-MM250 9.84" 250 mm RG-316 415-0070-012 12" 305 mm RG-178 415-0071-012 12" 305 mm RG-316 415-0070-018 18" 457 mm RG-178 415-0071-018 18" 457 mm RG-316 19.7" 500 mm RG-178 415-0071-MM500 19.7" 500 mm RG-316 24" 610 mm RG-178 415-0071-024 24" 610 mm RG-316 415-0070-MM500 415-0070-024 415-0070-MM750 29.53" 750 mm RG-178 415-0071-MM750 29.53" 750mm RG-316 415-0070-036 36" 914 mm RG-178 415-0071-036 36" 914 mm RG-316 415-0070-M1.0 39.4" 1000 mm RG-178 415-0071-M1.0 39.4" 1000 mm RG-316 Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-316 MMCX Right Angle Plug to SMA Straight Bulkhead Jack Connector by Cable Type: RG-178 (135-3402-101, 142-0302-431) RG-316 (135-3403-101, 142-0303-411) Standard Cable Lengthc Metric Cable Length Cable Type 415-0072-006 6" 152 mm RG-178 415-0073-MM150 415-0072-012 12" 305 mm RG-178 415-0073-006 Part Number Part Number 6" 152 mm RG-316 9.84" 250 mm RG-316 415-0072-018 18" 457 mm RG-178 415-0073-MM250 415-0072-024 24" 610 mm RG-178 415-0073-012 12" 305 mm RG-316 RG-178 415-0073-018 18" 457 mm RG-316 19.7" 500 mm RG-316 24" 610 mm RG-316 29.53" 750mm RG-316 415-0072-036 36" 914 mm 415-0073-MM500 415-0073-024 415-0073-MM750 4 Metric assemblies available, highlighted in blue 415-0073-036 36" 914 mm RG-316 415-0073-M1.0 39.4" 1000 mm RG-316 MCX Straight Plug to MCX Straight Plug Connector by Cable Type: RG-178 (133-3402-021) RG-316 (133-3403-001) RG-316 DS (133-3404-001) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0014-006 6” 152 mm RG-178 415-0018-024 24” 610 mm RG-316 415-0014-012 12” 305 mm RG-178 415-0018-030 30” 762 mm RG-316 415-0014-018 18” 457 mm RG-178 415-0018-036 36” 914 mm RG-316 415-0014-024 24” 610 mm RG-178 415-0020-006 6” 152 mm RG-316 DS 415-0014-030 30” 762 mm RG-178 415-0020-012 12” 305 mm RG-316 DS 415-0014-036 36” 914 mm RG-178 415-0020-018 18” 457 mm RG-316 DS 415-0018-006 6” 152 mm RG-316 415-0020-024 24” 610 mm RG-316 DS 415-0018-012 12” 305 mm RG-316 415-0020-030 30” 762 mm RG-316 DS 415-0018-018 18” 457 mm RG-316 415-0020-036 36” 914 mm RG-316 DS Standard Cable Lengthc Metric Cable Length Cable Type 19.7" 500 mm RG-316 MCX Straight Plug to MCX Straight Bulkhead Jack Connector by Cable Type: RG-316 (133-3403-001, 133-3303-401) Part Number 415-0016-MM150 415-0016-006 Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-316 415-0016-MM500 Part Number 6" 152 mm RG-316 415-0016-024 9.84" 250 mm RG-316 415-0016-MM750 415-0016-012 12" 305 mm RG-316 415-0016-018 18" 457 mm RG-316 415-0016-MM250 24" 610 mm RG-316 29.53" 750 mm RG-316 415-0016-030 30" 762 mm RG-316 415-0016-036 36" 914 mm RG-316 415-0016-M1.0 39.4" 1000 mm RG-316 MCX Straight Plug to MCX Right Angle Plug Connector by Cable Type: RG-316 (133-3403-001, 133-3403-101) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0017-006 6” 152 mm RG-316 415-0017-024 24” 610 mm RG-316 415-0017-012 12” 305 mm RG-316 415-0017-030 30” 762 mm RG-316 415-0017-018 18” 457 mm RG-316 415-0017-036 36” 914 mm RG-316 Standard Cable Lengthc Metric Cable Length Cable Type 9.84" 250 mm RG-316 12" 305 mm RG-316 MCX Right Angle Plug to MCX Right Angle Plug Connector by Cable Type: RG-178 (133-3402-101) RG-316 (133-3403-101) RG-316 DS (133-3404-101) Part Number 415-0015-MM150 415-0015-006 415-0015-MM250 Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-178 415-0019-MM250 6" 152 mm RG-178 415-0019-012 Part Number 9.84" 250 mm RG-178 415-0019-024 415-0015-012 12" 305 mm RG-178 415-0019-MM750 415-0015-018 18" 457 mm RG-178 19.7" 500 mm 24" 610 mm 415-0015-MM500 415-0015-024 415-0015-MM750 24" 610 mm RG-316 29.53" 750 mm RG-316 415-0019-036 36" 914 mm RG-316 RG-178 415-0019-M1.0 39.4" 1000 mm RG-316 RG-178 415-0021-006 6” 152 mm RG-316 DS 29.53" 750 mm RG-178 415-0021-012 12” 305 mm RG-316 DS 415-0015-036 36" 914 mm RG-178 415-0021-018 18” 457 mm RG-316 DS 415-0015-M1.0 39.4" 1000 mm RG-178 415-0021-024 24” 610 mm RG-316 DS 415-0019-MM150 5.9" 150 mm RG-316 415-0021-036 36” 914 mm RG-316 DS 6" 152 mm RG-316 415-0019-006 Metric assemblies available, highlighted in blue 5 MCX 75 Ohm Straight Plug to MCX 75 Ohm Straight Plug Connector by Cable Type: RG-179 (133-8433-001) Belden 735A (133-8445-001) Part Number 415-0022-006 Standard Cable Lengthc 6” Metric Cable Length Part Number Standard Cable Lengthc Metric Cable Length Cable Type 152 mm Cable Type RG-179 415-0023-006 6” 152 mm Belden 735A 415-0022-012 12” 415-0022-018 18” 305 mm RG-179 415-0023-012 12” 305 mm Belden 735A 457 mm RG-179 415-0022-024 24” 415-0023-018 18” 457 mm Belden 735A 610 mm RG-179 415-0023-024 24” 610 mm Belden 735A 415-0022-030 30” 415-0022-036 36” 762 mm RG-179 415-0023-030 30” 762 mm Belden 735A 914 mm RG-179 415-0023-036 36” 914 mm Belden 735A MCX 75 Ohm Right Angle Plug to MCX 75 Ohm Right Angle Plug Connector by Cable Type: Belden 735A (133-8445-101) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0024-006 6” 152 mm Belden 735A 415-0024-024 24” 610 mm Belden 735A 415-0024-012 12” 305 mm Belden 735A 415-0024-030 30” 762 mm Belden 735A 415-0024-018 18” 457 mm Belden 735A 415-0024-036 36” 914 mm Belden 735A SMA Straight Plug to SMA Straight Plug Connector by Cable Type: RG-178 (142-0402-011) RG-316 (142-0403-011) RG-316 DS (142-0404-011) RG-58 (142-0407-011) RG-142 (142-0408-011) Part Number 415-0025-MM150 415-0025-006 415-0025-MM250 Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-178 415-0033-012 12” 305 mm RG-316 DS 6” 152 mm RG-178 415-0033-018 18" 457 mm RG-316 DS 19.7" 500 mm RG-316 DS 24" 610 mm RG-316 DS 29.53" 750 mm RG-316 DS 9.84" 250 mm RG-178 415-0033-MM500 415-0025-012 12” 305 mm RG-178 415-0033-024 415-0025-018 18” 457 mm RG-178 415-0033-MM750 19.7" 500 mm RG-178 415-0033-036 36” 914 mm RG-316 DS 24” 610 mm RG-178 415-0033-048 48” 1219 mm RG-316 DS 415-0025-MM500 415-0025-024 415-0025-MM750 29.53" 750 mm RG-178 415-0033-M1.0 39.4" 1000 mm RG-316 DS 415-0025-036 36” 914 mm RG-178 415-0033-M1.5 59.1" 1500 mm RG-316 DS 415-0025-048 48” 1219 mm RG-178 415-0033-M2.0 78.7" 2000 mm RG-316 DS 415-0025-M1.0 39.4" 1000 mm RG-178 415-0038-MM250 9.84" 250 mm RG-58 415-0025-M1.5 59.1" 1500 mm RG-178 415-0038-012 12" 305 mm RG-58 415-0029-MM150 5.9" 150 mm RG-316 415-0038-MM500 19.7 500 mm RG-58 6” 152 mm RG-316 415-0038-024 24" 610 mm RG-58 9.84" 250 mm RG-316 415-0038-036 24” 762 mm RG-58 415-0029-012 12” 305 mm RG-316 415-0038-048 36” 914 mm RG-58 415-0029-018 18” 457 mm RG-316 415-0038-M1.0 39.4" 1000 mm RG-58 19.7" 500 mm RG-316 415-0038-M1.5 59.1" 1500 mm RG-58 24” 610 mm RG-316 415-0038-060 60” 1524 mm RG-58 29.53" 750 mm RG-316 415-0038-M2.0 78.7" 2000 mm RG-58 415-0029-006 415-0029-MM250 415-0029-MM500 415-0029-024 415-0029-MM750 415-0029-036 36” 914 mm RG-316 415-0043-MM250 9.84" 250 mm RG-142 415-0029-048 48” 1219 mm RG-316 415-0043-012 12” 305 mm RG-142 415-0029-M1.0 39.4" 1000 mm RG-316 415-0043-MM500 19.7 500 mm RG-142 415-0029-M1.5 59.1" 1500 mm RG-316 415-0043-024 24” 610 mm RG-142 415-0029-M2.0 78.7" 2000 mm RG-316 415-0043-036 36” 914 mm RG-142 415-0029-M3.0 118.1" 3000 mm RG-316 415-0043-M1.0 39.4" 1000 mm RG-142 5.9" 150 mm RG-316 DS 415-0043-048 48” 1219 mm RG-142 6” 152 mm RG-316 DS 415-0043-M1.5 59.1" 1500 mm RG-142 9.84" 250 mm RG-316 DS 415-0043-060 60” 1524 mm RG-142 415-0033-MM150 415-0033-006 415-0033-MM250 6 Standard Cable Lengthc Metric assemblies available, highlighted in blue SMA Straight Hand Formable Plug to SMA Straight Hand Formable Plug Connector by Cable Type: 0.086 Conformable (142-0693-001) Part Number 415-0081-MM75 415-0081-003 415-0081-MM100 415-0081-004 415-0081-MM125 415-0081-005 415-0081-MM150 415-0081-006 415-0081-MM175 Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 2.95" 75 mm .086 415-0081-007 7” 178 mm .086 3” 76 mm .086 415-0081-MM200 7.87" 200 mm .086 3.93" 100 mm .086 415-0081-008 4” 102 mm .086 415-0081-MM250 4.9" 125 mm .086 415-0081-012 5” 127 mm .086 415-0081-018 5.9" 150 mm .086 415-0081-MM500 6” 152 mm .086 415-0081-024 6.89" 175 mm .086 415-0081-MM750 8” 203 mm .086 9.84" 250 mm .086 12” 305 mm .086 18” 457 mm .086 19.7" 500 mm .086 24” 610 mm .086 29.53" 750 mm .086 SMA Straight Hand Formable Plug to SMA Straight Hand Formable Plug Connector by Cable Type: 0.141 Conformable (142-0694-001) Part Number 415-0082-MM75 415-0082-003 415-0082-MM100 415-0082-004 415-0082-MM125 415-0082-005 415-0082-MM150 415-0082-006 415-0082-MM175 Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 2.95" 75 mm .141 415-0082-007 7” 178 mm .141 7.87" 200 mm .141 8” 203 mm .141 3” 76 mm .141 415-0082-MM200 3.93" 100 mm .141 415-0082-008 4” 102 mm .141 415-0082-MM250 9.84" 250 mm .141 4.9" 125 mm .141 415-0082-012 12” 305 mm .141 5” 127 mm .141 415-0082-018 18” 457 mm .141 5.9" 150 mm .141 415-0082-MM500 19.7" 500 mm .141 6” 152 mm .141 415-0082-024 24” 610 mm .141 6.89" 175 mm .141 415-0082-MM750 29.53" 750 mm .141 Cable Type SMA Straight Plug to SMA Straight Bulkhead Jack Connector by Cable Type: RG-316 (142-0403-011, 142-0303-411) RG-316 DS (142-0404-011, 142-0304-411) RG-58 (142-0407-011, 142-0307-411) RG-142 (142-0408-011, 142-0308-411) Part Number 415-0031-MM150 415-0031-006 415-0031-MM250 415-0031-012 415-0031-018 415-0031-MM500 415-0031-024 415-0031-MM750 415-0031-036 Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length 5.9" 150 mm RG-316 415-0035-018 18” 457 mm RG-316 DS 6" 152 mm RG-316 415-0035-024 24” 610 mm RG-316 DS 9.84" 250 mm RG-316 415-0035-036 36” 914mm RG-316 DS 12" 305 mm RG-316 415-0035-048 48” 1219mm RG-316 DS 12” 305 mm RG-58 610 mm RG-58 18" 457 mm RG-316 415-0040-012 19.7" 500 mm RG-316 415-0040-024 24” 24" 610 mm RG-316 415-0040-036 36” 914 mm RG-58 29.53" 750 mm RG-316 415-0040-048 48” 1219 mm RG-58 36" 914 mm RG-316 415-0040-060 60” 1524 mm RG-58 12” 305 mm RG-142 610 mm RG-142 415-0031-M1.0 39.4" 1000 mm RG-316 415-0045-012 415-0031-048 48" 1219 mm RG-316 415-0045-024 24” 415-0031-M1.5 59.1 1500 mm RG-316 415-0045-036 36” 914mm RG-142 415-0035-006 6” 152 mm RG-316 DS 415-0045-048 48” 1219 mm RG-142 415-0035-012 12” 305 mm RG-316 DS 415-0045-060 60” 1524 mm RG-142 Metric assemblies available, highlighted in blue 7 SMA Straight Plug to SMA Right Angle Plug Connector by Cable Type: RG-178 (142-0402-011, 142-0402-101) RG-316 (142-0403-011, 142-0403-101) RG-316 DS (142-0404-011, 142-0404-101) RG-142 (142-0408-011, 142-0408-101) Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0026-006 6” 152 mm RG-178 415-0034-MM150 415-0026-012 12” 305 mm RG-178 415-0034-006 415-0026-018 18” 457 mm RG-178 415-0034-MM250 415-0026-024 24” 610 mm RG-178 415-0034-012 415-0026-036 36” 914mm RG-178 415-0034-018 415-0026-048 48” 152 mm RG-178 415-0034-MM500 415-0030-MM150 5.9" 150 mm RG-316 415-0034-024 415-0030-006 Part Number Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-316 DS 6" 152 mm RG-316 DS 9.84" 250 mm RG-316 DS 12" 305 mm RG-316 DS 18" 457 mm RG-316 DS 19.7" 500 mm RG-316 DS 24" 610 mm RG-316 DS 6" 152 mm RG-316 415-0034-MM750 29.53" 750 mm RG-316 DS 9.84" 250 mm RG-316 415-0034-036 36" 914 mm RG-316 DS 415-0030-012 12" 305 mm RG-316 415-0034-M1.0 39.4" 1000 mm RG-316 DS 415-0030-018 18" 457 mm RG-316 415-0034-048 48" 1219 mm RG-316 DS 19.7" 500 mm RG-316 415-0034-M1.5 59.1" 1500 mm RG-316 DS 24" 610 mm RG-316 415-0044-012 12” 305 mm RG-142 29.53" 750 mm RG-316 415-0044-024 24” 610 mm RG-142 415-0030-MM250 415-0030-MM500 415-0030-024 415-0030-MM750 415-0030-036 36" 914 mm RG-316 415-0044-036 36” 914mm RG-142 415-0030-M1.0 39.4" 1000 mm RG-316 415-0044-048 48” 1219 mm RG-142 415-0030-048 48" 1219 mm RG-316 415-0004-060 60” 1524 mm RG-142 415-0030-M1.5 59.1" 1500 mm RG-316 SMA Right Angle Plug to SMA Right Angle Plug Connector by Cable Type: RG-178 (142-0402-101) RG-316 (142-0403-101) RG-316 DS (142-0404-101) RG-58 (142-0407-101) RG-142 (142-0408-101) Part Number 415-0027-MM150 415-0027-006 415-0027-MM250 Metric Cable Length Cable Type Standard Cable Lengthc Metric Cable Length 5.9" 150 mm RG-178 Cable Type 415-0032-M1.0 39.4" 1000 mm 6" 152 mm RG-316 RG-178 415-0032-048 48" 1219 mm RG-316 Part Number 9.84" 250 mm RG-178 415-0032-M1.5 59.1" 1500 mm RG-316 415-0027-012 12" 305 mm RG-178 415-0036-006 6" 152 mm RG-316 DS 415-0027-024 24" 610 mm RG-178 415-0036-012 12" 305 mm RG-316 DS 415-0027-MM750 29.53" 750 mm RG-178 415-0036-018 18" 457 mm RG-316 DS 415-0027-036 36" 914 mm RG-178 415-0036-024 24" 610 mm RG-316 DS 415-0027-M1.0 39.4" 1000 mm RG-178 415-0036-036 36" 914 mm RG-316 DS 415-0027-048 48" 1219 mm RG-178 415-0036-048 48" 1219 mm RG-316 DS 415-0027-M1.5 59.1" 1500 mm RG-178 415-0041-012 12” 305 mm RG-58 415-0032-MM150 5.9" 150 mm RG-316 415-0041-024 24” 610 mm RG-58 6" 152 mm RG-316 415-0041-036 36” 914mm RG-58 9.84" 250 mm RG-316 415-0041-048 48” 1219 mm RG-58 12" 305 mm RG-316 415-0041-060 60” 1524 mm RG-58 19.7" 500 mm RG-316 415-0046-012 12” 305 mm RG-142 415-0032-018 18" 457 mm RG-316 415-0046-024 24” 610 mm RG-142 415-0032-024 24" 610 mm RG-316 415-0046-036 36” 914mm RG-142 29.53" 750 mm RG-316 415-0046-048 48” 1219 mm RG-142 36" 914 mm RG-316 415-0046-060 60” 1524 mm RG-142 415-0032-006 415-0032-MM250 415-0032-012 415-0032-MM500 415-0032-MM750 415-0032-036 8 Standard Cable Lengthc Metric assemblies available, highlighted in blue SMA Right Angle Plug to SMA Straight Bulkhead Jack Connector by Cable Type: RG-316 (142-0403-101, 142-0303-411) RG-316 DS (142-0404-101, 142-0304-411) RG-142 (142-0408-101, 142-0308-411) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0074-006 6” 152 mm RG-316 415-0064-036 36” 914 mm RG-316 DS 415-0074-012 12” 305 mm RG-316 415-0064-048 48” 1219 mm RG-316 DS 415-0074-024 24” 610 mm RG-316 415-0075-006 6” 152 mm RG-142 415-0074-036 36” 914 mm RG-316 415-0075-012 12” 305 mm RG-142 415-0074-048 48” 1219 mm RG-316 415-0075-024 24” 610 mm RG-142 415-0064-006 6” 152 mm RG-316 DS 415-0075-036 36” 914 mm RG-142 415-0064-012 12” 305 mm RG-316 DS 415-0075-048 48” 1219 mm RG-142 415-0064-024 24” 610 mm RG-316 DS SMA Quick-Connect Straight Plug to SMA Quick-Connect Straight Plug Connector by Cable Type: RG-316 (142-1403-001) RG-316 DS (142-1404-001) RG-142 (142-1408-001) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0065-006 6” 152 mm RG-316 415-0076-012 12” 305 mm RG-316 DS 415-0065-012 12” 305 mm RG-316 415-0076-024 24” 610 mm RG-316 DS 415-0065-018 18” 457 mm RG-316 415-0076-036 36” 914 mm RG-316 DS 415-0065-024 24” 610 mm RG-316 415-0077-012 12” 305 mm RG-142 415-0065-036 36” 914 mm RG-316 415-0077-024 24” 610 mm RG-142 415-0065-048 48” 1219 mm RG-316 415-0077-036 36” 914 mm RG-142 SMA Quick-Connect Straight Plug to SMA Straight Plug Connector by Cable Type: RG-316 DS (142-1404-001, 142-0404-011) RG-142 (142-1408-001, 142-0408-011) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0078-012 12” 305 mm RG-316 DS 415-0079-012 12” 305 mm RG-142 415-0078-024 24” 610 mm RG-316 DS 415-0079-024 24” 610 mm RG-142 415-0078-036 36” 914 mm RG-316 DS 415-0079-036 36” 914 mm RG-142 SMA Straight Bulkhead Jack to Right Angle MCX Plug Connector by Cable Type: RG-316 DS (142-0304-411, 133-3404-101) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0181-006 6” 152 mm RG-316 DS 415-0181-036 36” 914 mm RG-316 DS 415-0181-012 12” 305 mm RG-316 DS 415-0181-048 48” 1219 mm RG-316 DS 415-0181-024 24” 610 mm RG-316 DS 415-0181-060 60” 1524 mm RG-316 DS Metric assemblies available, highlighted in blue 9 SMB Straight Plug to SMB Straight Plug Connector by Cable Type: RG-316 (131-1403-001) Part Number 415-0003-MM150 415-0003-006 Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-316 415-0003-MM500 Part Number Standard Cable Lengthc Metric Cable Length Cable Type 19.7" 500 mm RG-316 24” 610 mm RG-316 29.53" 750 mm RG-316 6” 152 mm RG-316 415-0003-024 9.84" 250 mm RG-316 415-0003-MM750 415-0003-012 12” 305 mm RG-316 415-0003-036 36" 914 mm RG-316 415-0003-018 18” 457 mm RG-316 415-0003-M1.0 39.4" 1000 mm RG-316 415-0003-MM250 SMB Straight Plug to SMB Right Angle Plug Connector by Cable Type: RG-178 (131-3402-001, 131-1402-101) RG-316 (131-1403-001, 131-1403-101) RG-316 DS (131-1404-001, 131-1404-101) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0007-006 6" 152 mm RG-178 415-0002-024 24" 610 mm RG-316 415-0007-012 12" 305 mm RG-178 415-0002-030 30" 762 mm RG-316 415-0007-018 18" 457 mm RG-178 415-0002-036 36" 914 mm RG-316 415-0007-024 24" 610 mm RG-178 415-0005-006 6" 152 mm RG-316 DS 415-0007-030 30" 762 mm RG-178 415-0005-012 12" 305 mm RG-316 DS 415-0007-036 36" 914 mm RG-178 415-0005-018 18" 457 mm RG-316 DS 415-0002-006 6" 152 mm RG-316 415-0005-024 24" 610 mm RG-316 DS 415-0002-012 12" 305 mm RG-316 415-0005-030 30" 762 mm RG-316 DS 415-0002-018 18" 457 mm RG-316 415-0005-036 36" 914 mm RG-316 DS SMB Right Angle Plug to SMB Right Angle Plug Connector by Cable Type: RG-178 (131-1402-101) RG-316 (131-1403-101) RG-316 DS (131-1404-101) Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-178 415-0004-012 12" 305 mm RG-316 6" 152 mm RG-178 415-0004-018 18" 457 mm RG-316 9.84" 250 mm RG-178 415-0004-MM500 19.7" 500 mm RG-316 415-0001-012 12" 305 mm RG-178 415-0004-024 415-0001-018 18" 457 mm RG-178 415-0004-MM750 19.7" 500 mm RG-178 24" 610 mm RG-178 29.53" 750 mm 415-0001-030 30" 415-0001-036 36" 415-0001-M1.0 415-0004-MM150 Part Number 415-0001-MM150 415-0001-006 415-0001-MM250 415-0001-MM500 415-0001-024 415-0001-MM750 415-0004-006 415-0004-MM250 10 24" 610 mm RG-316 29.53" 750 mm RG-316 415-0004-030 30" 762 mm RG-316 415-0004-036 36" 914 mm RG-316 RG-178 415-0004-M1.0 39.4" 1000 mm RG-316 762 mm RG-178 415-0006-006 6" 152 mm RG-316 DS 914 mm RG-178 415-0006-012 12" 305 mm RG-316 DS 39.4" 1000 mm RG-178 415-0006018 18" 457 mm RG-316 DS 5.9" 150 mm RG-316 415-0006-024 24" 610 mm RG-316 DS 6" 152 mm RG-316 415-0006-030 30" 762 mm RG-316 DS 9.84" 250 mm RG-316 415-0006-036 36" 914 mm RG-316 DS Metric assemblies available, highlighted in blue SMB Mini-75 Ohm Straight Plug to SMB Mini-75 Ohm Straight Plug Connector by Cable Type: RG-179 (131-8403-011) RG-179 DS (131-8404-011) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0008-006 6” 152 mm RG-179 415-0010-006 6” 152 mm RG-179 DS 415-0008-012 12” 305 mm RG-179 415-0010-012 12” 305 mm RG-179 DS 415-0008-018 18” 457 mm RG-179 415-0010-018 18” 457 mm RG-179 DS 415-0008-024 24” 610 mm RG-179 415-0010-024 24” 610 mm RG-179 DS 415-0008-030 30" 762 mm RG-179 415-0010-030 30" 762 mm RG-179 DS 415-0008-036 36” 914 mm RG-179 415-0010-036 36” 914 mm RG-179 DS SMB Mini-75 Ohm Right Angle Plug to SMB Mini-75 Ohm Right Angle Plug Connector by Cable Type: RG-179 (131-8403-111) RG-179 DS (131-8404-111) Belden 735A (131-8445-101) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0009-006 6” 152 mm RG-179 415-0011-024 24” 610 mm RG-179 DS 415-0009-012 12” 305 mm RG-179 415-0011-030 30" 762 mm RG-179 DS 415-0009-018 18” 457 mm RG-179 415-0011-036 36” 914 mm RG-179 DS 415-0009-024 24” 610 mm RG-179 415-0013-006 6” 152 mm Belden 735A 415-0009-030 30" 762 mm RG-179 415-0013-012 12” 305 mm Belden 735A 415-0009-036 36” 914 mm RG-179 415-0013-018 18” 457 mm Belden 735A 415-0011-006 6” 152 mm RG-179 DS 415-0013-024 24” 610 mm Belden 735A 415-0011-012 12” 305 mm RG-179 DS 415-0013-030 30" 762 mm Belden 735A 415-0011-018 18” 457 mm RG-179 DS 415-0013-036 36” 914 mm Belden 735A N Straight Plug to N Straight Plug Connector by Cable Type: RG-58 (CPN-1) RG-142 (CPN-142T) RG-8 (CPN-8) RG-213 (CPN-8) Part Number Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 415-0058-012 12” 305 mm RG-58 415-0062-012 12” 305 mm RG-8 415-0058-024 24” 610 mm RG-58 415-0062-024 24” 610 mm RG-8 415-0058-036 36” 914 mm RG-58 415-0062-036 36” 914 mm RG-8 415-0058-048 48” 1219 mm RG-58 415-0062-048 48” 1219 mm RG-8 415-0058-060 60” 1524 mm RG-58 415-0062-060 60” 1524 mm RG-8 415-0060-012 12” 305 mm RG-142 415-0063-012 12” 305 mm RG-213 415-0060-024 24” 610 mm RG-142 415-0063-024 24” 610 mm RG-213 415-0060-036 36” 914 mm RG-142 415-0063-036 36” 914 mm RG-213 415-0060-048 48” 1219 mm RG-142 415-0063-048 48” 1219 mm RG-213 415-0060-060 60” 1524 mm RG-142 415-0063-060 60” 1524 mm RG-213 Metric assemblies available, highlighted in blue 11 BNC Straight Plug to BNC Straight Plug with Boot Connector by Cable Type: RG-58 (CPMC-88-1) RG-58 PLENUM (CPMC-88-10) RG-59 (CPMC-88-2) Belden 8218 (CPMC-88-18) Part Number 415-0054-MM250 415-0054-012 415-0054-MM500 415-0054-024 415-0054-MM750 Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 9.84" 250 mm RG-58 415-0055-048 48” 1219 mm RG-59 PLENUM 12" 305 mm RG-58 415-0055-060 60" 1524 mm RG-59 PLENUM 19.7" 500 mm RG-58 415-0057-012 12" 305 mm RG-59 24" 610 mm RG-58 415-0057-024 24" 610 mm RG-59 29.53" 750 mm RG-58 415-0057-036 36" 914 mm RG-59 415-0054-036 36" 914 mm RG-58 415-0057-048 48” 1219 mm RG-59 415-0054-M1.0 39.4" 1000 mm RG-58 415-0057-060 60" 1524 mm RG-59 415-0054-048 48” 1219 mm RG-58 With Heatshrink 415-0054-M1.5 59.1" 1500 mm RG-58 415-0056-012 12" 305 mm Belden 8218 415-0054-060 60" 1524 mm RG-58 415-0056-024 24" 610 mm Belden 8218 415-0055-012 12" 305 mm RG-59 PLENUM 415-0056-036 36" 914 mm Belden 8218 415-0055-024 24" 610 mm RG-59 PLENUM 415-0056-048 48” 1219 mm Belden 8218 415-0055-036 36" 914 mm RG-59 PLENUM 415-0056-060 60" 1524 mm Belden 8218 75 Ohm BNC Straight Plug to 75 Ohm BNC Straight Plug with Boot or Heatshrink Connector by Cable Type: RG-59 (CPMC-68-2) Belden 734A (CPMC-68-35) Belden 8218 (CPMC-68-18) Belden 8281 (CPMC-68-3) Commscope 735 (CPMC-68-33) Belden 735A (CPMC-68-33) Belden 1694A (CPMC-68-45) Standard Cable Lengthc Metric Cable Length Cable Type Standard Cable Lengthc Metric Cable Length Cable Type 415-0048-012 12" 305 mm RG-59 415-0048-024 24" 610 mm RG-59 415-0047-012 12" 305 mm Belden 8218 415-0047-024 24" 610 mm Belden 8218 415-0048-036 36" 914 mm RG-59 415-0047-036 36" 914 mm Belden 8218 415-0048-048 48” 415-0048-060 60" 1219 mm RG-59 415-0047-048 48” 1219 mm Belden 8218 1524 mm RG-59 415-0047-060 60" 1524 mm Belden 8218 415-0052-012 415-0052-024 12" 305 mm Belden 734A 415-0049-012 12" 305 mm Belden 8281 24" 610 mm Belden 734A 415-0049-024 24" 610 mm Belden 8281 415-0052-036 36" 914 mm Belden 734A 415-0049-036 36" 914 mm Belden 8281 415-0052-048 48” 1219 mm Belden 734A 415-0049-048 48” 1219 mm Belden 8281 415-0052-060 60" 1524 mm Belden 734A 415-0049-060 60" 1524 mm Belden 8281 415-0050-012 12" 305 mm Commscope 735 415-0050-024 24" 610 mm Commscope 735 415-0050-036 36" 914 mm Commscope 735 415-0050-048 48” 1219 mm Commscope 735 415-0050-060 60" 1524 mm Commscope 735 415-0051-012 12" 305 mm Belden 735A 415-0051-024 24" 610 mm Belden 735A 415-0051-036 36" 914 mm Belden 735A 415-0051-048 48” 1219 mm Belden 735A 415-0051-060 60" 1524 mm Belden 735A 415-0053-012 12" 305 mm Belden 1694A 415-0053-024 24" 610 mm Belden 1694A 415-0053-036 36" 914 mm Belden 1694A 415-0053-048 48” 1219 mm Belden 1694A 415-0053-060 60" 1524 mm Belden 1694A Part Number with Boot 12 Metric assemblies available, highlighted in blue Part Number with Heatshrink SMA Straight Plug to BNC Straight Plug Connector by Cable Type: RG-316 (142-0403-011, CPM-88-19) RG-58 (142-0407-011, CPMC-88-1) RG-142 (142-0408-011, CPMC-88-13) Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 5.9" 150 mm RG-316 415-0037-012 12" 305 mm RG-58 6" 152 mm RG-316 415-0037-MM500 19.7" 500 mm RG-58 9.84" 250 mm RG-316 415-0037-024 24" 610 mm RG-58 415-0028-012 12" 305 mm RG-316 415-0037-MM750 29.53" 750 mm RG-58 415-0028-018 18" 457 mm RG-316 415-0037-036 36" 914 mm RG-58 19.7" 500 mm RG-316 415-0037-M1.0 39.4" 1000 mm RG-58 24" 610 mm RG-316 415-0037-048 48” 1219 mm RG-58 29.53" 750 mm RG-316 415-0037-M1.5 59.1" 1500 mm RG-58 Part Number 415-0028-MM150 415-0028-006 415-0028-MM250 415-0028-MM500 415-0028-024 415-0028-MM750 415-0028-036 36" 914 mm RG-316 415-0037-060 60" 1524 mm RG-58 415-0028-M1.0 39.4" 1000 mm RG-316 415-0037-M2.0 78.7" 2000 mm RG-58 415-0028-048 48” 1219 mm RG-316 415-0042-012 12" 305 mm RG-142 415-0028-M1.5 59.1" 1500 mm RG-316 415-0042-024 24" 610 mm RG-142 415-0028-M2.0 78.7" 2000 mm RG-316 415-0042-036 36" 914 mm RG-142 415-0037-MM250 9.84" 250 mm RG-58 415-0042-048 48” 1219 mm RG-142 415-0042-060 60" 1524 mm RG-142 SMA Straight Plug to N Straight Plug Connector by Cable Type: RG-58 (142-0407-011, CPN-1) RG-142 (142-0408-011, CPN-142T) Part Number 415-0059-MM250 415-0059-012 415-0059-MM500 415-0059-024 415-0059-MM750 Standard Cable Lengthc Metric Cable Length Cable Type Part Number Standard Cable Lengthc Metric Cable Length Cable Type 9.84" 250 mm RG-58 415-0059-048 48” 1219 mm RG-58 12" 305 mm RG-58 415-0059-M1.5 59.1" 1500 mm RG-58 19.7" 500 mm RG-58 415-0061-060 60" 1524 mm RG-58 24" 610 mm RG-58 415-0061-012 12" 305 mm RG-142 29.53" 750 mm RG-58 415-0061-024 24" 610 mm RG-142 415-0059-036 36" 914 mm RG-58 415-0061-036 36" 914 mm RG-142 415-0059-M1.0 39.4" 1000 mm RG-58 415-0061-048 48” 1219 mm RG-142 415-0061-060 60" 1524 mm RG-142 Metric assemblies available, highlighted in blue 13 Innovative Interconnect Solutions Across the Globe In operation since 1917, Cinch supplies high quality, high performance connectors and cables globally to the Aerospace, Military/Defense, Commercial Transportation, Oil & Gas, High End Computer, and other Cinch Connectivity Solutions North America Office T +1 507.833.8822 ccsorders@us.cinch.com Cinch Connectivity Solutions Ltd European Office T +44 (0) 1245 342060 CinchConnectivity@eu.cinch.com markets. We provide custom solutions with our creative, hands on engineering and end to end approach. Our diverse product offerings include: connectors, enclosures and cable assemblies utilizing multiple contact technologies including copper and fiber optics. Our product engineering and development activities employ cutting edge technologies for design and modeling, and our various technologies and expertise enable us to deliver custom solutions and products for our strategic partnerships. We also serve a broad range of commercial markets, largely through our highly efficient distribution network. Cinch Connectivity Solutions Asia Pacific Office T +86 21 5442 7668 ccs.asia.sales@as.cinch.com We aim to exceed our customer’s expectations, and to continually provide innovative solutions to the rapidly changing needs of the markets, and customers, we serve. For more information, visit cinch.com © 2016 Cinch Connectivity Solutions CCS Johnson RF Cable Assembly Guide v03_03.17
415-0033-MM150
以下是对您要求的特定部分的中文分析:
1. 物料型号:文档中列出了多种电缆组件的型号,例如MMCX Straight Plug到MMCX Straight Plug的型号为415-0066-006、415-0066-012等,每种型号都有对应的标准电缆长度和度量电缆长度。
2. 器件简介:文档开头提到Cinch Connectivity Solutions自1917年以来一直在运营,提供高质量的连接器和电缆,服务于多个市场领域。
3. 引脚分配:文档中没有明确提到引脚分配,但详细列出了不同连接器类型和电缆类型的电气额定值。
4. 参数特性:详细列出了不同电缆组件的电气特性,包括连接器阻抗、工作频率、介质耐电压和工作电压。
5. 功能详解:文档提供了电缆组件的功能详解,包括电缆长度公差、定制解决方案、部件编号索引等。
6. 应用信息:Cinch Connectivity Solutions的电缆组件广泛应用于航空航天、军事/国防、商业运输、石油和天然气、高端计算机等市场。
415-0033-MM150 价格&库存
很抱歉,暂时无法提供与“415-0033-MM150”相匹配的价格&库存,您可以联系我们找货
415-0033-MM150
  • 1+196.967141+25.53069
  • 10+167.3970510+21.69785
  • 25+156.9130725+20.33893
  • 50+149.4251950+19.36835
  • 100+142.29649100+18.44434
  • 250+133.39581250+17.29064
  • 500+127.03745500+16.46648
415-0033-MM150
  • 15+66.82697
  • 25+61.84548
  • 50+57.22672
  • 100+54.68761
库存:125
