N024-01K-BL
N024-01K-BL
    TRIPPLITE
    N024-01K-BL
N024-01K-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Solid Core Plenum-Rated (UTP) PVC Bulk Ethernet Cable - Blue, 1000 ft. (304.8 m) MODEL NUMBER: N024-01K-BL Highlights ● Ideal for all horizontal wiring applications ● Rated for 350 MHz/1 Gbps communications ● High-quality 24 AWG 4-pair solid copper wire ● Plenum-rated PVC jacket ● Meets IEEE 802.3ab and ANSI/EIA/TIA 568 standards Package Includes ● Premium cabling designed for Cat5/5e premise (in-wall) applications in air ducts and drop ceilings, such as connecting an Ethernet wall jack to a router, patch panel or switch. Features Perfect Solution for Cat5/5e Premise Applications in Air Ducts and Drop Ceilings ● Designed for fast transmission and excellent signal quality throughout your LAN ● Delivers speeds up to 350 MHz/1 Gbps ● Ideal for all horizontal wiring applications, including 10/100/1000 Base-T Ethernet, 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type 3 applications Premium Construction for Superior Performance ● Made from 24 AWG copper wire ● 4-pair solid UTP ● Plenum-rated PVC jacket ● Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e, draft 11) Specifications OVERVIEW UPC Code 037332192158 Technology Cat5/5e PHYSICAL Cable Jacket Color Blue 1/3 N024-01K-BL Cat5e 350 MHz Bulk Solid-Core Plenum-Rated PVC Cable, Blue, 1000 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating CMP Cable Shielding UTP Cable Outer Diameter (OD) 5.1 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 24 AWG Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 13.10 x 10.40 x 13.60 Shipping Dimensions (hwd / cm) 33.27 x 26.42 x 34.54 Shipping Weight (lbs.) 21.40 Shipping Weight (kg) 9.71 ENVIRONMENTAL Operating Temperature Range -4 to 167 °F (-20 to 75 °C) Storage Temperature Range 32 to 140 F (0 to 60 C) COMMUNICATIONS Bandwidth per TIA Standard 100 MHz Maximum Bandwidth as Tested 350 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE Crossover Wiring No Connector Type Bare Wire Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Compliance RoHS; IEEE 802.3ab 1000Base-T; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N024-01K-BL 价格&库存
很抱歉,暂时无法提供与“N024-01K-BL”相匹配的价格&库存,您可以联系我们找货
