100R7-76B
100R7-76B
    PARLEXUSALLC
    CABLE FLAT FLEX 7POS 1MM 3"
100R7-76B 数据手册
PROPRIETARY INFORMATION NOTICE This document and the designs, specifications, and engineering information disclosed herein are the property of Parlex USA LLC and are not to be disseminated or reproduced without expressed written consent. This document is loaned in confidence and then only for consideration of the matter disclosed hereon. In accepting loan of this document, the recipient agrees to keep it and the matter disclosed hereon in confidence and not to use or permit their use in any way detrimental to Parlex USA LLC Standard ZIF Cable - Same side exposure Cable Length Exposed Conductor X X X R X X - X X X X X X - Stiffener Margin Standard Part Numbering Configuration Pitch 15 Characters maximum Cable Width Span Conductor Width Space ( 1 space between orientation and method ) Orientation of cable ends ( See Sheet 2 ) Cable length in MM ( Up to 4 spaces, No decimal points ) # of Conductors ( 1 - 99 ) See below note Marking - See Note Mating Thickness - ( Dash ) ( For cables with less than 10 Conductors use only 1 number Ex. 100R8-1252B - ) Notes: Cable Width = ( # of conductors +1)*( Pitch ) Span = ( # of conductors -1 )*( Pitch ) Mating Thickness = .012" ( .305mm ) Insulation = .002" Polyester with .0015" Flame Retardent Adhesive Conductors = Copper Tin Plated Temperature rating = -55°C to 105°C Dielectric Strength = 2500 Volts/Mil UL Flame Rating = VW-1 Insulation Resistance = 10 Megaohm min. Marking - Minimum marking to be " PARLEX and Date Code". On cables where spacing does not allow parts will not be marked. Pitch Margin .0197" (.500mm) .0246" (.625mm) .025" (.635mm) .0315" (.800mm) .0394" (1.00mm) .0492" (1.25mm) .050" (1.27mm) .100" (2.54mm) .014" (.356mm) .017" (.422mm) .020" (.495mm) .023" (.572mm) .026" (.660mm) .033" (.845mm) .034" (.864mm) .069" (1.753mm) Exposed Conductor .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .170" (4.318mm) .170" (4.318mm) .240" (6.096mm) Stiffener Length .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .294" (7.5mm) .294" (7.5mm) .394" (10mm) Copper Thickness .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) Copper Width .011" (.280mm) .016" (.406mm) .011" (.280mm) .019" (.483mm) .026" (.660mm) .0315" (.800mm) .0315" (.800mm) .062" (1.575mm) UL Style # 20890 20890 20890 20566 20566 20566 & 2643 20566 & 2643 2643 0-3" 3"-6" 6"-12" 12"-18" 18"-24" 24"-36" Over 36" Exposed Conductor Length Stiffener Length Pitch Span Margin Cable Width Current Rating .50 AMPS .50 AMPS .50 AMPS .80 AMPS 1.5 AMPS 2.0 AMPS 2.0 AMPS 3.0 AMPS A Johnson Electric Company Parlex Standard ZIF Style Cables Part Numbering Configurations and General Specifications SIZE FSCM B SCALE Cables in piece form BN BO Exposed Conductor Pitch KK Bulk roll with no exposed conductors and no stiffeners Cable Width ZIF with Stiffeners both ends Opposite sides KS Bulk roll with no exposed conductors and no stiffeners with stripe marked over first conductor ZIF with Stiffener one end and Blunt cut one end Bulk roll with exposed conductors and no stiffeners N ZIF with no Stiffeners KR Mating Thickness Bulk roll with exposed conductors and stiffeners on opposite sides Pitch KBN .0197" (.500mm) .0246" (.625mm) .025" (.635mm) .0315" (.800mm) .0394" (1.00mm) .0492" (1.25mm) .050" (1.27mm) .100" (2.54mm) Bulk roll with exposed conductors and stiffeners every other window ZIF with no Stiffener one end and Lasered one end KNO ZIF with no Stiffener one end and Blunt cut one end KRN Bulk roll with exposed conductors and no stiffeners opposite sides Exposed Margin Conductor .014" (.356mm) .140" (3.556mm) .017" (.422mm) .140" (3.556mm) .020" (.495mm) .140" (3.556mm) .023" (.572mm) .140" (3.556mm) .026" (.660mm) .140" (3.556mm) .033" (.845mm) .170" (4.318mm) .034" (.864mm) .170" (4.318mm) .069" (1.753mm) .240" (6.096mm) Stiffener Length .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .294" (7.5mm) .294" (7.5mm) .394" (10mm) Copper Thickness .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) Copper Width .011" (.280mm) .016" (.406mm) .011" (.280mm) .019" (.483mm) .026" (.660mm) .0315" (.800mm) .0315" (.800mm) .062" (1.575mm) UL Style # 20890 20890 20890 20566 20566 20566 & 2643 20566 & 2643 2643 Current Rating .50 AMPS .50 AMPS .50 AMPS .80 AMPS 1.5 AMPS 2.0 AMPS 2.0 AMPS 3.0 AMPS Standard Tolerances ±.075" (1.905mm) ±.100" (2.54mm) ±.125" (3.175mm) ±.150" (3.810mm) ±.200" (5.08mm) ±.250" (6.35mm) ±1% OF LENGTH ±.030" (.76MM) ±.050" (1.27MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) UL Style # Notes 20890 = .008" Min spacing between conductors, Voltage rating = 90 Volts 0.280"±0.030" Lasered Area 20566 = .010" Min spacing between conductors, Voltage rating = 90 Volts Lasered cable both ends 2643 = .016" Min spacing between conductors, Voltage rating = 300 Volts SIZE Cable Blunt cut both ends 0-3" 3"-6" 6"-12" 12"-18" 18"-24" 24"-36" Over 36" Exposed Conductor Length Stiffener Length Pitch Span Margin Cable Width Bulk roll with exposed conductors and stiffeners every other window opposite sides 0.112" Ref. Bussbar Cable Length Dimension Bulk roll with exposed conductors with stiffeners and double bare area 0.112" Ref. Bussbar 0.280"±0.030" Lasered Area Marking - See Note Notes: Cable Width = ( # of conductors +1)*( Pitch ) Span = ( # of conductors -1 )*( Pitch ) Mating Thickness = .012" ( .305mm ) Insulation = .002" Polyester with .0015" Flame Retardent Adhesive Conductors = Copper Tin Plated Temperature rating = -55°C to 105°C Dielectric Strength = 2500 Volts/Mil UL Flame Rating = VW-1 Insulation Resistance = 10 Megaohm min. Marking - Minimum marking to be " PARLEX and Date Code". On cables where spacing does not allow parts will not be marked. Double Exposed Area KL Span Conductor Width 0.280"±0.030" Lasered Area Cable Length - Stiffener Margin ZIF with no Stiffeners Opposite sides Rev. SHEET 3 OF 4 ZIF with Stiffener on one end only 0.112" Ref. Bussbar PS-3705 18377 NA Cable Length Bulk roll with exposed conductors and stiffeners TT FSCM B Cables in bulk form KN L SIZE SCALE Standard ZIF Cable - Reverse side exposure BT NT 2643 = .016" Min spacing between conductors, Voltage rating = 300 Volts Cable end orientations KW NL 20566 = .010" Min spacing between conductors, Voltage rating = 90 Volts SHEET 1 OF 4 NA ZIF with Stiffeners one end and Lasered one end NO 20890 = .008" Min spacing between conductors, Voltage rating = 90 Volts - ZIF with Stiffeners on both ends Cable Length BL PS-3705 ±.050" (1.27mm) ±.060" (1.524mm) ±.070" (1.778mm) ±.110" (2.794mm) ±.120" (3.048mm) ±.150" (3.810mm) ±1% OF LENGTH ±.030" (.76MM) ±.050" (1.27MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) UL Style # Notes Rev. Cable Length B 18377 Standard Tolerances Dimension Cable Length Method - = Standard Cable Pitch 050 = 0.50MM ( 0.0197" ) 062 = 0.625MM ( 0.0246" ) 100 = 1.00MM ( 0.0394" ) 125 = 1.25MM ( 0.0492" ) 127 = 1.27MM ( 0.050" ) 254 = 2.54MM ( 0.100" ) R = RoHS Compliant FSCM B SCALE 18377 NA PS-3705 Rev. - SHEET 2 OF 4 SIZE FSCM B SCALE 18377 NA PS-3705 Rev. - SHEET 4 OF 4 PROPRIETARY INFORMATION NOTICE This document and the designs, specifications, and engineering information disclosed herein are the property of Parlex USA LLC and are not to be disseminated or reproduced without expressed written consent. This document is loaned in confidence and then only for consideration of the matter disclosed hereon. In accepting loan of this document, the recipient agrees to keep it and the matter disclosed hereon in confidence and not to use or permit their use in any way detrimental to Parlex USA LLC Standard ZIF Cable - Same side exposure Cable Length Exposed Conductor X X X R X X - X X X X X X - Stiffener Margin Standard Part Numbering Configuration Pitch 15 Characters maximum Cable Width Span Conductor Width Space ( 1 space between orientation and method ) Orientation of cable ends ( See Sheet 2 ) Cable length in MM ( Up to 4 spaces, No decimal points ) # of Conductors ( 1 - 99 ) See below note Marking - See Note Mating Thickness - ( Dash ) ( For cables with less than 10 Conductors use only 1 number Ex. 100R8-1252B - ) Notes: Cable Width = ( # of conductors +1)*( Pitch ) Span = ( # of conductors -1 )*( Pitch ) Mating Thickness = .012" ( .305mm ) Insulation = .002" Polyester with .0015" Flame Retardent Adhesive Conductors = Copper Tin Plated Temperature rating = -55°C to 105°C Dielectric Strength = 2500 Volts/Mil UL Flame Rating = VW-1 Insulation Resistance = 10 Megaohm min. Marking - Minimum marking to be " PARLEX and Date Code". On cables where spacing does not allow parts will not be marked. Pitch Margin .0197" (.500mm) .0246" (.625mm) .025" (.635mm) .0315" (.800mm) .0394" (1.00mm) .0492" (1.25mm) .050" (1.27mm) .100" (2.54mm) .014" (.356mm) .017" (.422mm) .020" (.495mm) .023" (.572mm) .026" (.660mm) .033" (.845mm) .034" (.864mm) .069" (1.753mm) Exposed Conductor .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .170" (4.318mm) .170" (4.318mm) .240" (6.096mm) Stiffener Length .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .294" (7.5mm) .294" (7.5mm) .394" (10mm) Copper Thickness .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) Copper Width .011" (.280mm) .016" (.406mm) .011" (.280mm) .019" (.483mm) .026" (.660mm) .0315" (.800mm) .0315" (.800mm) .062" (1.575mm) UL Style # 20890 20890 20890 20566 20566 20566 & 2643 20566 & 2643 2643 0-3" 3"-6" 6"-12" 12"-18" 18"-24" 24"-36" Over 36" Exposed Conductor Length Stiffener Length Pitch Span Margin Cable Width Current Rating .50 AMPS .50 AMPS .50 AMPS .80 AMPS 1.5 AMPS 2.0 AMPS 2.0 AMPS 3.0 AMPS A Johnson Electric Company Parlex Standard ZIF Style Cables Part Numbering Configurations and General Specifications SIZE FSCM B SCALE Cables in piece form BN BO Exposed Conductor Pitch KK Bulk roll with no exposed conductors and no stiffeners Cable Width ZIF with Stiffeners both ends Opposite sides KS Bulk roll with no exposed conductors and no stiffeners with stripe marked over first conductor ZIF with Stiffener one end and Blunt cut one end Bulk roll with exposed conductors and no stiffeners N ZIF with no Stiffeners KR Mating Thickness Bulk roll with exposed conductors and stiffeners on opposite sides Pitch KBN .0197" (.500mm) .0246" (.625mm) .025" (.635mm) .0315" (.800mm) .0394" (1.00mm) .0492" (1.25mm) .050" (1.27mm) .100" (2.54mm) Bulk roll with exposed conductors and stiffeners every other window ZIF with no Stiffener one end and Lasered one end KNO ZIF with no Stiffener one end and Blunt cut one end KRN Bulk roll with exposed conductors and no stiffeners opposite sides Exposed Margin Conductor .014" (.356mm) .140" (3.556mm) .017" (.422mm) .140" (3.556mm) .020" (.495mm) .140" (3.556mm) .023" (.572mm) .140" (3.556mm) .026" (.660mm) .140" (3.556mm) .033" (.845mm) .170" (4.318mm) .034" (.864mm) .170" (4.318mm) .069" (1.753mm) .240" (6.096mm) Stiffener Length .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .294" (7.5mm) .294" (7.5mm) .394" (10mm) Copper Thickness .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) Copper Width .011" (.280mm) .016" (.406mm) .011" (.280mm) .019" (.483mm) .026" (.660mm) .0315" (.800mm) .0315" (.800mm) .062" (1.575mm) UL Style # 20890 20890 20890 20566 20566 20566 & 2643 20566 & 2643 2643 Current Rating .50 AMPS .50 AMPS .50 AMPS .80 AMPS 1.5 AMPS 2.0 AMPS 2.0 AMPS 3.0 AMPS Standard Tolerances ±.075" (1.905mm) ±.100" (2.54mm) ±.125" (3.175mm) ±.150" (3.810mm) ±.200" (5.08mm) ±.250" (6.35mm) ±1% OF LENGTH ±.030" (.76MM) ±.050" (1.27MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) UL Style # Notes 20890 = .008" Min spacing between conductors, Voltage rating = 90 Volts 0.280"±0.030" Lasered Area 20566 = .010" Min spacing between conductors, Voltage rating = 90 Volts Lasered cable both ends 2643 = .016" Min spacing between conductors, Voltage rating = 300 Volts SIZE Cable Blunt cut both ends 0-3" 3"-6" 6"-12" 12"-18" 18"-24" 24"-36" Over 36" Exposed Conductor Length Stiffener Length Pitch Span Margin Cable Width Bulk roll with exposed conductors and stiffeners every other window opposite sides 0.112" Ref. Bussbar Cable Length Dimension Bulk roll with exposed conductors with stiffeners and double bare area 0.112" Ref. Bussbar 0.280"±0.030" Lasered Area Marking - See Note Notes: Cable Width = ( # of conductors +1)*( Pitch ) Span = ( # of conductors -1 )*( Pitch ) Mating Thickness = .012" ( .305mm ) Insulation = .002" Polyester with .0015" Flame Retardent Adhesive Conductors = Copper Tin Plated Temperature rating = -55°C to 105°C Dielectric Strength = 2500 Volts/Mil UL Flame Rating = VW-1 Insulation Resistance = 10 Megaohm min. Marking - Minimum marking to be " PARLEX and Date Code". On cables where spacing does not allow parts will not be marked. Double Exposed Area KL Span Conductor Width 0.280"±0.030" Lasered Area Cable Length - Stiffener Margin ZIF with no Stiffeners Opposite sides Rev. SHEET 3 OF 4 ZIF with Stiffener on one end only 0.112" Ref. Bussbar PS-3705 18377 NA Cable Length Bulk roll with exposed conductors and stiffeners TT FSCM B Cables in bulk form KN L SIZE SCALE Standard ZIF Cable - Reverse side exposure BT NT 2643 = .016" Min spacing between conductors, Voltage rating = 300 Volts Cable end orientations KW NL 20566 = .010" Min spacing between conductors, Voltage rating = 90 Volts SHEET 1 OF 4 NA ZIF with Stiffeners one end and Lasered one end NO 20890 = .008" Min spacing between conductors, Voltage rating = 90 Volts - ZIF with Stiffeners on both ends Cable Length BL PS-3705 ±.050" (1.27mm) ±.060" (1.524mm) ±.070" (1.778mm) ±.110" (2.794mm) ±.120" (3.048mm) ±.150" (3.810mm) ±1% OF LENGTH ±.030" (.76MM) ±.050" (1.27MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) UL Style # Notes Rev. Cable Length B 18377 Standard Tolerances Dimension Cable Length Method - = Standard Cable Pitch 050 = 0.50MM ( 0.0197" ) 062 = 0.625MM ( 0.0246" ) 100 = 1.00MM ( 0.0394" ) 125 = 1.25MM ( 0.0492" ) 127 = 1.27MM ( 0.050" ) 254 = 2.54MM ( 0.100" ) R = RoHS Compliant FSCM B SCALE 18377 NA PS-3705 Rev. - SHEET 2 OF 4 SIZE FSCM B SCALE 18377 NA PS-3705 Rev. - SHEET 4 OF 4 PROPRIETARY INFORMATION NOTICE This document and the designs, specifications, and engineering information disclosed herein are the property of Parlex USA LLC and are not to be disseminated or reproduced without expressed written consent. This document is loaned in confidence and then only for consideration of the matter disclosed hereon. In accepting loan of this document, the recipient agrees to keep it and the matter disclosed hereon in confidence and not to use or permit their use in any way detrimental to Parlex USA LLC Standard ZIF Cable - Same side exposure Cable Length Exposed Conductor X X X R X X - X X X X X X - Stiffener Margin Standard Part Numbering Configuration Pitch 15 Characters maximum Cable Width Span Conductor Width Space ( 1 space between orientation and method ) Orientation of cable ends ( See Sheet 2 ) Cable length in MM ( Up to 4 spaces, No decimal points ) # of Conductors ( 1 - 99 ) See below note Marking - See Note Mating Thickness - ( Dash ) ( For cables with less than 10 Conductors use only 1 number Ex. 100R8-1252B - ) Notes: Cable Width = ( # of conductors +1)*( Pitch ) Span = ( # of conductors -1 )*( Pitch ) Mating Thickness = .012" ( .305mm ) Insulation = .002" Polyester with .0015" Flame Retardent Adhesive Conductors = Copper Tin Plated Temperature rating = -55°C to 105°C Dielectric Strength = 2500 Volts/Mil UL Flame Rating = VW-1 Insulation Resistance = 10 Megaohm min. Marking - Minimum marking to be " PARLEX and Date Code". On cables where spacing does not allow parts will not be marked. Pitch Margin .0197" (.500mm) .0246" (.625mm) .025" (.635mm) .0315" (.800mm) .0394" (1.00mm) .0492" (1.25mm) .050" (1.27mm) .100" (2.54mm) .014" (.356mm) .017" (.422mm) .020" (.495mm) .023" (.572mm) .026" (.660mm) .033" (.845mm) .034" (.864mm) .069" (1.753mm) Exposed Conductor .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .170" (4.318mm) .170" (4.318mm) .240" (6.096mm) Stiffener Length .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .294" (7.5mm) .294" (7.5mm) .394" (10mm) Copper Thickness .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) Copper Width .011" (.280mm) .016" (.406mm) .011" (.280mm) .019" (.483mm) .026" (.660mm) .0315" (.800mm) .0315" (.800mm) .062" (1.575mm) UL Style # 20890 20890 20890 20566 20566 20566 & 2643 20566 & 2643 2643 0-3" 3"-6" 6"-12" 12"-18" 18"-24" 24"-36" Over 36" Exposed Conductor Length Stiffener Length Pitch Span Margin Cable Width Current Rating .50 AMPS .50 AMPS .50 AMPS .80 AMPS 1.5 AMPS 2.0 AMPS 2.0 AMPS 3.0 AMPS A Johnson Electric Company Parlex Standard ZIF Style Cables Part Numbering Configurations and General Specifications SIZE FSCM B SCALE Cables in piece form BN BO Exposed Conductor Pitch KK Bulk roll with no exposed conductors and no stiffeners Cable Width ZIF with Stiffeners both ends Opposite sides KS Bulk roll with no exposed conductors and no stiffeners with stripe marked over first conductor ZIF with Stiffener one end and Blunt cut one end Bulk roll with exposed conductors and no stiffeners N ZIF with no Stiffeners KR Mating Thickness Bulk roll with exposed conductors and stiffeners on opposite sides Pitch KBN .0197" (.500mm) .0246" (.625mm) .025" (.635mm) .0315" (.800mm) .0394" (1.00mm) .0492" (1.25mm) .050" (1.27mm) .100" (2.54mm) Bulk roll with exposed conductors and stiffeners every other window ZIF with no Stiffener one end and Lasered one end KNO ZIF with no Stiffener one end and Blunt cut one end KRN Bulk roll with exposed conductors and no stiffeners opposite sides Exposed Margin Conductor .014" (.356mm) .140" (3.556mm) .017" (.422mm) .140" (3.556mm) .020" (.495mm) .140" (3.556mm) .023" (.572mm) .140" (3.556mm) .026" (.660mm) .140" (3.556mm) .033" (.845mm) .170" (4.318mm) .034" (.864mm) .170" (4.318mm) .069" (1.753mm) .240" (6.096mm) Stiffener Length .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .294" (7.5mm) .294" (7.5mm) .394" (10mm) Copper Thickness .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) Copper Width .011" (.280mm) .016" (.406mm) .011" (.280mm) .019" (.483mm) .026" (.660mm) .0315" (.800mm) .0315" (.800mm) .062" (1.575mm) UL Style # 20890 20890 20890 20566 20566 20566 & 2643 20566 & 2643 2643 Current Rating .50 AMPS .50 AMPS .50 AMPS .80 AMPS 1.5 AMPS 2.0 AMPS 2.0 AMPS 3.0 AMPS Standard Tolerances ±.075" (1.905mm) ±.100" (2.54mm) ±.125" (3.175mm) ±.150" (3.810mm) ±.200" (5.08mm) ±.250" (6.35mm) ±1% OF LENGTH ±.030" (.76MM) ±.050" (1.27MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) UL Style # Notes 20890 = .008" Min spacing between conductors, Voltage rating = 90 Volts 0.280"±0.030" Lasered Area 20566 = .010" Min spacing between conductors, Voltage rating = 90 Volts Lasered cable both ends 2643 = .016" Min spacing between conductors, Voltage rating = 300 Volts SIZE Cable Blunt cut both ends 0-3" 3"-6" 6"-12" 12"-18" 18"-24" 24"-36" Over 36" Exposed Conductor Length Stiffener Length Pitch Span Margin Cable Width Bulk roll with exposed conductors and stiffeners every other window opposite sides 0.112" Ref. Bussbar Cable Length Dimension Bulk roll with exposed conductors with stiffeners and double bare area 0.112" Ref. Bussbar 0.280"±0.030" Lasered Area Marking - See Note Notes: Cable Width = ( # of conductors +1)*( Pitch ) Span = ( # of conductors -1 )*( Pitch ) Mating Thickness = .012" ( .305mm ) Insulation = .002" Polyester with .0015" Flame Retardent Adhesive Conductors = Copper Tin Plated Temperature rating = -55°C to 105°C Dielectric Strength = 2500 Volts/Mil UL Flame Rating = VW-1 Insulation Resistance = 10 Megaohm min. Marking - Minimum marking to be " PARLEX and Date Code". On cables where spacing does not allow parts will not be marked. Double Exposed Area KL Span Conductor Width 0.280"±0.030" Lasered Area Cable Length - Stiffener Margin ZIF with no Stiffeners Opposite sides Rev. SHEET 3 OF 4 ZIF with Stiffener on one end only 0.112" Ref. Bussbar PS-3705 18377 NA Cable Length Bulk roll with exposed conductors and stiffeners TT FSCM B Cables in bulk form KN L SIZE SCALE Standard ZIF Cable - Reverse side exposure BT NT 2643 = .016" Min spacing between conductors, Voltage rating = 300 Volts Cable end orientations KW NL 20566 = .010" Min spacing between conductors, Voltage rating = 90 Volts SHEET 1 OF 4 NA ZIF with Stiffeners one end and Lasered one end NO 20890 = .008" Min spacing between conductors, Voltage rating = 90 Volts - ZIF with Stiffeners on both ends Cable Length BL PS-3705 ±.050" (1.27mm) ±.060" (1.524mm) ±.070" (1.778mm) ±.110" (2.794mm) ±.120" (3.048mm) ±.150" (3.810mm) ±1% OF LENGTH ±.030" (.76MM) ±.050" (1.27MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) UL Style # Notes Rev. Cable Length B 18377 Standard Tolerances Dimension Cable Length Method - = Standard Cable Pitch 050 = 0.50MM ( 0.0197" ) 062 = 0.625MM ( 0.0246" ) 100 = 1.00MM ( 0.0394" ) 125 = 1.25MM ( 0.0492" ) 127 = 1.27MM ( 0.050" ) 254 = 2.54MM ( 0.100" ) R = RoHS Compliant FSCM B SCALE 18377 NA PS-3705 Rev. - SHEET 2 OF 4 SIZE FSCM B SCALE 18377 NA PS-3705 Rev. - SHEET 4 OF 4 PROPRIETARY INFORMATION NOTICE This document and the designs, specifications, and engineering information disclosed herein are the property of Parlex USA LLC and are not to be disseminated or reproduced without expressed written consent. This document is loaned in confidence and then only for consideration of the matter disclosed hereon. In accepting loan of this document, the recipient agrees to keep it and the matter disclosed hereon in confidence and not to use or permit their use in any way detrimental to Parlex USA LLC Standard ZIF Cable - Same side exposure Cable Length Exposed Conductor X X X R X X - X X X X X X - Stiffener Margin Standard Part Numbering Configuration Pitch 15 Characters maximum Cable Width Span Conductor Width Space ( 1 space between orientation and method ) Orientation of cable ends ( See Sheet 2 ) Cable length in MM ( Up to 4 spaces, No decimal points ) # of Conductors ( 1 - 99 ) See below note Marking - See Note Mating Thickness - ( Dash ) ( For cables with less than 10 Conductors use only 1 number Ex. 100R8-1252B - ) Notes: Cable Width = ( # of conductors +1)*( Pitch ) Span = ( # of conductors -1 )*( Pitch ) Mating Thickness = .012" ( .305mm ) Insulation = .002" Polyester with .0015" Flame Retardent Adhesive Conductors = Copper Tin Plated Temperature rating = -55°C to 105°C Dielectric Strength = 2500 Volts/Mil UL Flame Rating = VW-1 Insulation Resistance = 10 Megaohm min. Marking - Minimum marking to be " PARLEX and Date Code". On cables where spacing does not allow parts will not be marked. Pitch Margin .0197" (.500mm) .0246" (.625mm) .025" (.635mm) .0315" (.800mm) .0394" (1.00mm) .0492" (1.25mm) .050" (1.27mm) .100" (2.54mm) .014" (.356mm) .017" (.422mm) .020" (.495mm) .023" (.572mm) .026" (.660mm) .033" (.845mm) .034" (.864mm) .069" (1.753mm) Exposed Conductor .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .140" (3.556mm) .170" (4.318mm) .170" (4.318mm) .240" (6.096mm) Stiffener Length .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .294" (7.5mm) .294" (7.5mm) .394" (10mm) Copper Thickness .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) Copper Width .011" (.280mm) .016" (.406mm) .011" (.280mm) .019" (.483mm) .026" (.660mm) .0315" (.800mm) .0315" (.800mm) .062" (1.575mm) UL Style # 20890 20890 20890 20566 20566 20566 & 2643 20566 & 2643 2643 0-3" 3"-6" 6"-12" 12"-18" 18"-24" 24"-36" Over 36" Exposed Conductor Length Stiffener Length Pitch Span Margin Cable Width Current Rating .50 AMPS .50 AMPS .50 AMPS .80 AMPS 1.5 AMPS 2.0 AMPS 2.0 AMPS 3.0 AMPS A Johnson Electric Company Parlex Standard ZIF Style Cables Part Numbering Configurations and General Specifications SIZE FSCM B SCALE Cables in piece form BN BO Exposed Conductor Pitch KK Bulk roll with no exposed conductors and no stiffeners Cable Width ZIF with Stiffeners both ends Opposite sides KS Bulk roll with no exposed conductors and no stiffeners with stripe marked over first conductor ZIF with Stiffener one end and Blunt cut one end Bulk roll with exposed conductors and no stiffeners N ZIF with no Stiffeners KR Mating Thickness Bulk roll with exposed conductors and stiffeners on opposite sides Pitch KBN .0197" (.500mm) .0246" (.625mm) .025" (.635mm) .0315" (.800mm) .0394" (1.00mm) .0492" (1.25mm) .050" (1.27mm) .100" (2.54mm) Bulk roll with exposed conductors and stiffeners every other window ZIF with no Stiffener one end and Lasered one end KNO ZIF with no Stiffener one end and Blunt cut one end KRN Bulk roll with exposed conductors and no stiffeners opposite sides Exposed Margin Conductor .014" (.356mm) .140" (3.556mm) .017" (.422mm) .140" (3.556mm) .020" (.495mm) .140" (3.556mm) .023" (.572mm) .140" (3.556mm) .026" (.660mm) .140" (3.556mm) .033" (.845mm) .170" (4.318mm) .034" (.864mm) .170" (4.318mm) .069" (1.753mm) .240" (6.096mm) Stiffener Length .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .237" (6mm) .294" (7.5mm) .294" (7.5mm) .394" (10mm) Copper Thickness .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) .003" (.076mm) Copper Width .011" (.280mm) .016" (.406mm) .011" (.280mm) .019" (.483mm) .026" (.660mm) .0315" (.800mm) .0315" (.800mm) .062" (1.575mm) UL Style # 20890 20890 20890 20566 20566 20566 & 2643 20566 & 2643 2643 Current Rating .50 AMPS .50 AMPS .50 AMPS .80 AMPS 1.5 AMPS 2.0 AMPS 2.0 AMPS 3.0 AMPS Standard Tolerances ±.075" (1.905mm) ±.100" (2.54mm) ±.125" (3.175mm) ±.150" (3.810mm) ±.200" (5.08mm) ±.250" (6.35mm) ±1% OF LENGTH ±.030" (.76MM) ±.050" (1.27MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) UL Style # Notes 20890 = .008" Min spacing between conductors, Voltage rating = 90 Volts 0.280"±0.030" Lasered Area 20566 = .010" Min spacing between conductors, Voltage rating = 90 Volts Lasered cable both ends 2643 = .016" Min spacing between conductors, Voltage rating = 300 Volts SIZE Cable Blunt cut both ends 0-3" 3"-6" 6"-12" 12"-18" 18"-24" 24"-36" Over 36" Exposed Conductor Length Stiffener Length Pitch Span Margin Cable Width Bulk roll with exposed conductors and stiffeners every other window opposite sides 0.112" Ref. Bussbar Cable Length Dimension Bulk roll with exposed conductors with stiffeners and double bare area 0.112" Ref. Bussbar 0.280"±0.030" Lasered Area Marking - See Note Notes: Cable Width = ( # of conductors +1)*( Pitch ) Span = ( # of conductors -1 )*( Pitch ) Mating Thickness = .012" ( .305mm ) Insulation = .002" Polyester with .0015" Flame Retardent Adhesive Conductors = Copper Tin Plated Temperature rating = -55°C to 105°C Dielectric Strength = 2500 Volts/Mil UL Flame Rating = VW-1 Insulation Resistance = 10 Megaohm min. Marking - Minimum marking to be " PARLEX and Date Code". On cables where spacing does not allow parts will not be marked. Double Exposed Area KL Span Conductor Width 0.280"±0.030" Lasered Area Cable Length - Stiffener Margin ZIF with no Stiffeners Opposite sides Rev. SHEET 3 OF 4 ZIF with Stiffener on one end only 0.112" Ref. Bussbar PS-3705 18377 NA Cable Length Bulk roll with exposed conductors and stiffeners TT FSCM B Cables in bulk form KN L SIZE SCALE Standard ZIF Cable - Reverse side exposure BT NT 2643 = .016" Min spacing between conductors, Voltage rating = 300 Volts Cable end orientations KW NL 20566 = .010" Min spacing between conductors, Voltage rating = 90 Volts SHEET 1 OF 4 NA ZIF with Stiffeners one end and Lasered one end NO 20890 = .008" Min spacing between conductors, Voltage rating = 90 Volts - ZIF with Stiffeners on both ends Cable Length BL PS-3705 ±.050" (1.27mm) ±.060" (1.524mm) ±.070" (1.778mm) ±.110" (2.794mm) ±.120" (3.048mm) ±.150" (3.810mm) ±1% OF LENGTH ±.030" (.76MM) ±.050" (1.27MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) ±.005" (.127MM) UL Style # Notes Rev. Cable Length B 18377 Standard Tolerances Dimension Cable Length Method - = Standard Cable Pitch 050 = 0.50MM ( 0.0197" ) 062 = 0.625MM ( 0.0246" ) 100 = 1.00MM ( 0.0394" ) 125 = 1.25MM ( 0.0492" ) 127 = 1.27MM ( 0.050" ) 254 = 2.54MM ( 0.100" ) R = RoHS Compliant FSCM B SCALE 18377 NA PS-3705 Rev. - SHEET 2 OF 4 SIZE FSCM B SCALE 18377 NA PS-3705 Rev. - SHEET 4 OF 4
100R7-76B 价格&库存
很抱歉,暂时无法提供与“100R7-76B”相匹配的价格&库存,您可以联系我们找货
