FFSD-13-D-09.00-01-N 数据手册
REVISION AU
NOTES:
1. HIDDEN LINES ARE USED TO SHOW POLARIZATION
WHEN USING -N OPTION.
2. C REPRESENTS A CRITICAL DIMENSION.
3. FFSD CABLE ASSEMBLIES ARE LEAD FREE.
4. ALL ASSEMBLIES TO BE 100% ELECTRICALLY TESTED
FOR SHORTS AND OPENS.
C 5. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 630V.
6. STRAIN RELIEF TO WITHSTAND 5LB[22N] STRAIGHT PULL.
No OF POSITIONS
7. NOTE DELETED.
-02 THRU -25
8. WHEN CUTTING CABLE TO LENGTH, CONDUCTORS SHOULD NOT EXTEND
(PER ROW)
PAST THE CABLE INSULATION, EXTENDING LESS THAN 25% OF CABLE
END ASSEMBLY
THICKNESS ON CONSECUTIVE AND LESS THAN 50% OF CABLE THICKNESS
ON NON-CONSECUTIVE STRANDS IS CONSIDERED A PROCESS INDICATOR.
-S: SINGLE END
9. REFERENCE FFSD-XX-XX-X-N-XXX FOR CONNECTOR ASSEMBLY
-D: DOUBLE END
DIMENSIONS AND ITS REQUIREMENTS.
C 10. COLORED WIRE MUST MATCH FIRST POSITION INDICATOR
ASSEMBLY LENGTH
ON THE FIRST CONNECTOR FOR ALL OPTIONS WITH THE
(INCLUDES ADDED OPTION LENGTHS)
EXCEPTION OF -RW.
ALL OPTIONS THAT USE -D"XX": 4.00 [101.6] MINIMUM
11. FOR LENGTHS LESS THAN 12.5", TOLERANCE SHALL BE +/-.125,
ALL OTHER OPTIONS: 1.00 [25.4] MINIMUM
ALL OTHER LENGTHS SHALL BE +/-1%.
FFSD-XX-X-XX.XX-01-X-X-XXX
DO NOT
SCALE FROM
THIS PRINT
OPTION
-RW: REVERSE WIRING
(NOT AVAILABLE WITH -RN1 OR -RN2)
-D"XX": DAISY CHAIN (MINIMUM 2.00[50.8],
1.00[25.4] INCREMENTS)
-R: REVERSED (-D"XX" OPTIONAL)
(NOT AVAILABLE WITH -M OR -O)
-RN1: REVERSE POLARIZATION NOTCH
(NOT AVAILABLE WITH -RW OR -RN2)
-RN2: REVERSE POLARIZATION NOTCH
(NOT AVAILABLE WITH -RW OR -RN1)
-M: MIDDLE REVERSE (REQUIRES -D"XX")
(NOT AVAILABLE WITH -R OR -O)
-O: OUTSIDE REVERSE (REQUIRES -D"XX")
(NOT AVAILABLE WITH -R OR -M)
-SR: STRAIN RELIEF
(NOT AVAILABLE WITH -O, -M,
-R, OR -D"XX")
(SOLD AS ASSEMBLIES ONLY)
LEAD STYLE
PLATING OPTIONS
- LEAVE BLANK FOR STANDARD,
USE C-67-L: 10µ" GOLD IN CONTACT AREA
TIN IN IDC AREA
-S: USE C-67-S: 30µ" GOLD IN CONTACT AREA
TIN IN IDC AREA
-F: USE C-67-F: 3µ" GOLD IN CONTACT AREA
TIN IN IDC AREA
C
XX.XX[XX.X x 25.4]±1%
(SEE NOTE 8 & 11)
STANDARD POLARIZATION NOTCH
-N: POLARIZATION NOTCH
(NOT AVAILABLE IN -02 THRU -04)
(LEAVE BLANK FOR -02, -03, -04)
.075 1.91
REF
.120 3.05
REF
C
(No OF POS x .050[1.27])
+ .165[4.19]
.006 0.15 MAX
+.006
(SEE NOTE 8 & 11)
FLUSH TO .010 0.25 MAX
CABLE OVERHANG
(SEE NOTE 8)
2
RED WIRE TO SIDE
OF FIRST POS INDICATOR
-N OPTION
+0.15
C .200 - .003 5.08 - 0.08
-N OPTION
1
.040 1.02
REF
FIG 2
(FFSD-10-S-XX.XX-01-X-N SHOWN)
(SAME AS FIG 1, DIFFERENT AS SHOWN)
NOTCH DENOTES
FIRST POSITION
FIG 1
(FFSD-10-D-XX.XX-01-X-N SHOWN)
RED WIRE TO OPPOSITE
SIDE OF FIRST POS INDICATOR
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
TOLERANCES ARE:
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
DECIMALS
ANGLES
.XX: .01[0.3]
2
.XXX: .005[0.13]
.XXXX: .0020[0.051]
MATERIAL:
FIG 11
(FFSD-10-X-XX.XX-01-X-N-RW SHOWN)
F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW
PROPRIETARY NOTE
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
PROPRIETARY INFORMATION AND ALL DESIGN,
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 2:1
INSULATORS: PBT UL94V-0, COLOR: BLACK
CONTACT: BeCu
WIRE: 30 AWG, 7/38, TINNED, STRANDED WITH
GRAY PVC INSULATOR
PLATING: .000010 GOLD OVER .000050 NICKEL
REMAINDER: .000200 REF TIN OVER .000050 NICKEL
DESCRIPTION:
.050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY
DWG. NO.
BY:
T NEWTON
02/15/2008 SHEET 1 OF 5
REVISION AU
FIRST CONNECTOR,
SECOND CONNECTOR,
03
01
02
(FFSD-10-S-XX.XX-01-X-N-RN1 SHOWN)
(SAME AS FIG 2, DIFFERENT AS SHOWN)
SECOND CONNECTOR,
FIRST CONNECTOR,
(FFSD-10-D-XX.XX-01-X-N-RN2 SHOWN)
(FFSD-10-D-XX.XX-01-X-N-RN1 SHOWN)
FIG 3
(FFSD-10-X-XX.XX-01-X-N-RNX SHOWN)
(REVERSE NOTCH NOT AVAILABLE WITH -RW OR ANY
DAISY CHAIN OPTIONS)
-RN1 = REVERSE NOTCH ON 1ST CONNECTOR ONLY
(NOT AVAILABLE WITH -R OPTION)
-RN2 = REVERSE NOTCH ON 2ND CONNECTOR ONLY
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
SHEET SCALE: 2:1
DESCRIPTION:
DWG. NO.
BY:
T NEWTON
02/15/2008 SHEET 2 OF 5
REVISION AU
WITH -RW OPTION ONLY:
RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR
XX.XX[XX.X x 25.4] .13[3.2]
(MIN 2")
(MIN 2")
MIDDLE CONNECTOR REVERSED WHEN DAISY CHAINED
OUTSIDE CONNECTOR REVERSED WHEN DAISY CHAINED
FIG 4
(FFSD-10-D-XX.XX-01-X-N-DXX-O SHOWN)
(2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS)
FIG 5
(FFSD-10-D-XX.XX-01-X-N-DXX-M SHOWN)
(MIN 2")
(MIN 2")
FIG 7
(FFSD-10-D-XX.XX-01-X-N-DXX SHOWN)
PROPRIETARY NOTE
BOTH CONNECTORS REVERSED WHEN DAISY CHAINED
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
FIG 6
(FFSD-10-D-XX.XX-01-X-N-DXX-R SHOWN)
(NOT AVAILABLE WITH -RN1 OR -RN2 OPTION)
SHEET SCALE: 2:1
DESCRIPTION:
DWG. NO.
BY:
T NEWTON
02/15/2008 SHEET 3 OF 5
REVISION AU
(No OF POS x .050[1.27]) C
+ .315[8.00] REF
XX.XX[XX.X x 25.4] + .4375[11.113]±.125[3.18]
IN-PROCESS 1
(2-15 POS -SR ONLY FOR DOUBLE END)
4
.039 0.99
.335±.010 8.51±0.25
3
C
(XX.XX[XX.XX x 25.4] ± .13[3.2])
C
(XX.XX[XX.XX x 25.4] .13[3.2]
FIG 9
IN-PROCESS 2
STRAIN RELIEF OPTION (POS 2-15 ONLY)
(FFSD-10-D-XX.XX-01-X-N-SR SHOWN)
XX.XX[XX.XX x 25.4] +.4375[11.113] .125[3.18]
IN-PROCESS 1
(16-25 POS -SR ONLY FOR DOUBLE END)
C
XX.XX[XX.XX x 25.4]
.13[3.2]
IN-PROCESS 2
+0.05
.0228+-.002
.000 0.58 0.00
DETAIL 'A'
SCALE 8 : 1
6
IN-PROCESS 3
PROPRIETARY NOTE
'A'
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
5
FIG 10
STRAIN RELIEF OPTION (POS 16-25 ONLY)
(FFSD-25-D-XX.XX-01-X-N-SR SHOWN)
(SAME AS FIG 9, DIFFERENT AS SHOWN)
SCALE 1 : 1
SHEET SCALE: 2:1
DESCRIPTION:
DWG. NO.
BY:
T NEWTON
02/15/2008 SHEET 4 OF 5
REVISION AU
(XX.XX[XX.XX x 25.4] ± .125[3.18])
IN-PROCESS 1
IN-PROCESS 1
(FFSD-XX-S-XX.XX-01-X-N-RW ONLY)
(16-25 POS -SR ONLY FOR SINGLE END)
XX.XX[XX.XX x 25.4]
.125[3.18]
C
IN-PROCESS 1
IN-PROCESS 2
(2-15 POS -SR ONLY FOR SINGLE END)
IN-PROCESS 3
C
PROPRIETARY NOTE
IN-PROCESS 2
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
SHEET SCALE: 2.5:1
DESCRIPTION:
DWG. NO.
BY:
T NEWTON 02/15/2008
SHEET 5 OF 5
